What is the reason for the following error when loading the network card? Have any friends met it? I would be very grateful if you could tell me how to solve it
root@smart03:/mnt# ./mlnxofedinstall --add-kernel-support --force
Note: This program will create MLNX_OFED_LINUX TGZ for ubuntu22.04 under /tmp/MLNX_OFED_LINUX-5.6-2.0.9.0-5.15.0-43-generic directory.
See log file /tmp/MLNX_OFED_LINUX-5.6-2.0.9.0-5.15.0-43-generic/mlnx_iso.863116_logs/mlnx_ofed_iso.863116.log
Checking if all needed packages are installed…
Building MLNX_OFED_LINUX DEBS . Please wait…
Creating metadata-rpms for 5.15.0-43-generic …
WARNING: If you are going to configure this package as a repository, then please note
WARNING: that it is not signed, therefore, you need to set ‘trusted=yes’ in the sources.list file.
WARNING: Example: deb [trusted=yes] file:/ ./
Created /tmp/MLNX_OFED_LINUX-5.6-2.0.9.0-5.15.0-43-generic/MLNX_OFED_LINUX-5.6-2.0.9.0-ubuntu22.04-ext.tgz
Removing old packages…
Uninstalling the previous version of MLNX_OFED_LINUX
Installing /tmp/MLNX_OFED_LINUX-5.6-2.0.9.0-5.15.0-43-generic/MLNX_OFED_LINUX-5.6-2.0.9.0-ubuntu22.04-ext
/tmp/MLNX_OFED_LINUX-5.6-2.0.9.0-5.15.0-43-generic/MLNX_OFED_LINUX-5.6-2.0.9.0-ubuntu22.04-ext/mlnxofedinstall --force --without-dkms --force
Logs dir: /tmp/MLNX_OFED_LINUX.1143378.logs
General log file: /tmp/MLNX_OFED_LINUX.1143378.logs/general.log
Below is the list of MLNX_OFED_LINUX packages that you have chosen
(some may have been added by the installer due to package dependencies):
ofed-scripts
mlnx-tools
mlnx-ofed-kernel-utils
mlnx-ofed-kernel-modules
iser-modules
isert-modules
srp-modules
rdma-core
libibverbs1
ibverbs-utils
ibverbs-providers
libibverbs-dev
libibverbs1-dbg
libibumad3
libibumad-dev
ibacm
librdmacm1
rdmacm-utils
librdmacm-dev
mstflint
ibdump
libibmad5
libibmad-dev
libopensm
opensm
opensm-doc
libopensm-devel
libibnetdisc5
infiniband-diags
mft
kernel-mft-modules
perftest
ibutils2
dump-pr
ibsim
ibsim-doc
ucx
sharp
hcoll
openmpi
mpitests
knem-modules
libdapl2
dapl2-utils
libdapl-dev
dpcp
srptools
mlnx-ethtool
mlnx-iproute2
rshim
This program will install the MLNX_OFED_LINUX package on your machine.
Note that all other Mellanox, OEM, OFED, RDMA or Distribution IB packages will be removed.
Those packages are removed due to conflicts with MLNX_OFED_LINUX, do not reinstall them.
Checking SW Requirements…
Installing new packages
Installing ofed-scripts-5.6…
Installing mlnx-tools-5.2.0…
Installing mlnx-ofed-kernel-utils-5.6…
Installing mlnx-ofed-kernel-modules-5.6…
Installing iser-modules-5.6…
Installing isert-modules-5.6…
Installing srp-modules-5.6…
Installing rdma-core-56mlnx40…
Installing libibverbs1-56mlnx40…
Installing ibverbs-utils-56mlnx40…
Installing ibverbs-providers-56mlnx40…
Installing libibverbs-dev-56mlnx40…
Installing libibverbs1-dbg-56mlnx40…
Installing libibumad3-56mlnx40…
Installing libibumad-dev-56mlnx40…
Installing ibacm-56mlnx40…
Installing librdmacm1-56mlnx40…
Installing rdmacm-utils-56mlnx40…
Installing librdmacm-dev-56mlnx40…
Installing mstflint-4.16.1…
Installing ibdump-6.0.0…
Installing libibmad5-56mlnx40…
Installing libibmad-dev-56mlnx40…
Installing libopensm-5.11.0.MLNX20220418.fd3d650…
Installing opensm-5.11.0.MLNX20220418.fd3d650…
Installing opensm-doc-5.11.0.MLNX20220418.fd3d650…
Installing libopensm-devel-5.11.0.MLNX20220418.fd3d650…
Installing libibnetdisc5-56mlnx40…
Installing infiniband-diags-56mlnx40…
Installing mft-4.20.0…
Installing kernel-mft-modules-4.20.0…
Installing perftest-4.5…
Installing ibutils2-2.1.1…
Installing dump-pr-1.0…
Installing ibsim-0.10…
Installing ibsim-doc-0.10…
Installing ucx-1.13.0…
Installing sharp-2.7.0.MLNX20220426.703f9a40…
Installing hcoll-4.7.3208…
Installing openmpi-4.1.4rc1…
Installing mpitests-3.2.20…
Installing knem-modules-1.1.4.90mlnx1…
Installing libdapl2-2.1.10.1.mlnx…
Installing dapl2-utils-2.1.10.1.mlnx…
Installing libdapl-dev-2.1.10.1.mlnx…
Installing dpcp-1.1.25…
Installing srptools-56mlnx40…
Installing mlnx-ethtool-5.15…
Installing mlnx-iproute2-5.16.0…
Installing rshim-2.0.6…
Selecting previously unselected package mlnx-fw-updater.
(Reading database … 233208 files and directories currently installed.)
Preparing to unpack …/mlnx-fw-updater_5.6-2.0.9.0_amd64.deb …
Unpacking mlnx-fw-updater (5.6-2.0.9.0) …
Setting up mlnx-fw-updater (5.6-2.0.9.0) …
Added 'RUN_FW_UPDATER_ONBOOT=no to /etc/infiniband/openib.conf
Initializing…
Attempting to perform Firmware update…
Querying Mellanox devices firmware …
write offset: Operation not permitted
FATAL - crspace read (0xf0014) failed: Operation not permitted
Device #1:
Device Type: N/A
Part Number: –
Description:
PSID:
PCI Device Name: 01:00.0
Port1 MAC: N/A
Port1 GUID: N/A
Port2 MAC: N/A
Port2 GUID: N/A
Versions: Current Available
FW –
Status: Failed to open device
-E- Failed to query 01:00.0 device, error : Operation not permitted. MFE_GENERAL_ERROR
Log File: /tmp/WmiyWRSdiB
Real log file: /tmp/MLNX_OFED_LINUX.1143378.logs/fw_update.log
Installation passed successfully
To load the new driver, run:
/etc/init.d/openibd restart
root@smart03:/dev/mst# lspci |grep Mellanox
01:00.0 Ethernet controller: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller (rev ff)
01:00.1 Ethernet controller: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller (rev ff)
01:00.2 DMA controller: Mellanox Technologies MT42822 BlueField-2 SoC Management Interface (rev ff)
