How to install jax==0.5.3 on Jetson Thor device
I try to build jax0.5.3 on jetson thor device, but the code did not recognize the sm_110
Please find below the building script:
when i use this script to compile jax 0.5.3, the error come out:
ERROR: /root/.cache/bazel/_bazel_root/cfd1b2cc6fe180f3eb424db6004de364/external/xla/third_party/gpus/cuda/hermetic/cuda_json_init_repository.bzl:50:13: An error occurred during the fetch of repository ‘cuda_redist_json’:
File “/root/.cache/bazel/_bazel_root/cfd1b2cc6fe180f3eb424db6004de364/external/xla/third_party/gpus/cuda/hermetic/cuda_json_init_repository.bzl”, line 50, column 13, in _cuda_redist_json_impl
fail(
Error in fail: The supported CUDA versions are [“11.8”, “12.1.1”, “12.2.0”, “12.3.1”, “12.3.2”, “12.4.0”, “12.4.1”, “12.5.0”, “12.5.1”, “12.6.0”, “12.6.1”, “12.6.2”, “12.6.3”, “12.8.0”]. Please provide a supported version in HERMETIC_CUDA_VERSION environment variable or add JSON URL for CUDA version=13.1.1.
ERROR: Error computing the main repository mapping: no such package ‘@@cuda_redist_json//’: The supported CUDA versions are [“11.8”, “12.1.1”, “12.2.0”, “12.3.1”, “12.3.2”, “12.4.0”, “12.4.1”, “12.5.0”, “12.5.1”, “12.6.0”, “12.6.1”, “12.6.2”, “12.6.3”, “12.8.0”]. Please provide a supported version in HERMETIC_CUDA_VERSION environment variable or add JSON URL for CUDA version=13.1.1.
Computing main repo mapping:
File “/opt/jax/build/build.py”, line 700, in
asyncio.run(main())
File “/usr/lib/python3.12/asyncio/runners.py”, line 194, in run
return runner.run(main)
File “/usr/lib/python3.12/asyncio/runners.py”, line 118, in run
return self._loop.run_until_complete(task)
File “/usr/lib/python3.12/asyncio/base_events.py”, line 687, in run_until_complete
return future.result()
File “/opt/jax/build/build.py”, line 693, in main
raise RuntimeError(f"Command failed with return code {result.return_code}")
RuntimeError: Command failed with return code 1
it seems the jax0.5.3 do not support cuda13.x
You might be able to run the script with this set in environment prior to running script.
export JAX_SKIP_CUDA_CONSTRAINTS_CHECK=1
But with significant potential functionality issues in that JAX-0.5.3 seems to want cuda-12* and its supporting libraries.
For JAX on Thor and Cuda-13* you could install with
NVIDIA GPU: 	pip install -U "jax[cuda13]"
i create a new conda env, use pip install -U “jax[cuda13]”, then run my jax test py,facing this error
(jax_test_py312) user@user:~$ python pi0/check_jax.py
JAX version: 0.9.1
W0313 10:15:53.265163 659646 cuda_executor.cc:1818] Memory clock rate or bus width is 0
W0313 10:15:53.265191 659646 cuda_executor.cc:1820] Using hardcoded values for Thor
W0313 10:15:53.278200 659583 cuda_executor.cc:1818] Memory clock rate or bus width is 0
W0313 10:15:53.278216 659583 cuda_executor.cc:1820] Using hardcoded values for Thor
Devices: [CudaDevice(id=0)]
Warming up (XLA compile)…
F0313 10:15:54.070059 659663 stream_executor_util.cc:519] Could not load RepeatBufferKernel: INTERNAL: CUDA Runtime error: [0] Failed call to cudaGetFuncBySymbol: cudaErrorNoKernelImageForDevice: no kernel image is available for execution on the device
*** Check failure stack trace: ***
@ 0xfffd03b4a968 absl::lts_20250814::log_internal::LogMessage::SendToLog()
@ 0xfffd03b4a8e4 absl::lts_20250814::log_internal::LogMessage::Flush()
@ 0xfffd029ac11c xla::gpu::InitializeTypedBuffer<>()
@ 0xfffd029a7fb8 xla::primitive_util::FloatingPointTypeSwitch<>()
@ 0xfffd029a71e8 xla::gpu::InitializeBuffer()
@ 0xfffcfbbbba28 stream_executor::RedzoneAllocator::CreateBuffer()
@ 0xfffcfbbbaa34 xla::gpu::RedzoneBuffers::CreateInputs()
@ 0xfffcfbbba744 xla::gpu::RedzoneBuffers::FromProgramShape()
@ 0xfffcfb988da0 xla::gpu::GpuProfiler::CreateInputBuffers()
@ 0xfffcfb97fea0 xla::Autotuner::ProfileAll()
@ 0xfffcfb9834d8 xla::Autotuner::TuneBestConfig()::$_0::operator()()
@ 0xfffcfb984290 tsl::internal::FutureBase<>::AndThen<>()::{lambda()#1}::operator()()
@ 0xfffcfb984498 tsl::AsyncValue::EnqueueWaiter<>()::Node::RunWaiterAndDeleteWaiterNode()
@ 0xfffcfb9885d0 tsl::internal::PromiseBase<>::emplace<>()
@ 0xfffcfb987f64 tsl::internal::JoinFutures<>::Update<>()
@ 0xfffcfb987dc0 tsl::JoinFutures<>()::{lambda()#1}::operator()()
@ 0xfffcfb987ca0 tsl::internal::FutureBase<>::AndThen<>()::{lambda()#1}::operator()()
@ 0xfffcfb9887b8 tsl::AsyncValue::EnqueueWaiter<>()::Node::RunWaiterAndDeleteWaiterNode()
@ 0xfffcfb984ddc tsl::internal::PromiseBase<>::emplace<>()
@ 0xfffcfb984c10 absl::lts_20250814::internal_any_invocable::RemoteInvoker<>()
@ 0xfffd039cd8c0 std::_Function_handler<>::_M_invoke()
@ 0xfffd039cc3a0 Eigen::ThreadPoolTempl<>::WorkerLoop()
@ 0xfffd039cc23c std::__invoke_impl<>()
@ 0xfffd039bbe24 tsl::(anonymous namespace)::PThread::ThreadFn()
@ 0xffffb8fc595c (unknown)
Aborted (core dumped)
Try installing these too.
pip install jaxlib jax-cuda13-plugin opt-einsum
Then run jax’s install test
python3 -c 'import jax; print(f"JAX version: {jax.__version__}"); print(f"CUDA devices: {jax.devices()}");'
If that works then try your check_jax.py
i did this ,but it does not work
root@5f8d964fc522:/workspace# python3 -c ‘import jax; print(f"JAX version: {jax.version}“); print(f"CUDA devices: {jax.devices()}”);’
JAX version: 0.9.1
W0316 03:17:13.948120 49624 cuda_executor.cc:1818] Memory clock rate or bus width is 0
W0316 03:17:13.948166 49624 cuda_executor.cc:1820] Using hardcoded values for Thor
W0316 03:17:13.960939 49572 cuda_executor.cc:1818] Memory clock rate or bus width is 0
W0316 03:17:13.960969 49572 cuda_executor.cc:1820] Using hardcoded values for Thor
CUDA devices: [CudaDevice(id=0)]
Based on the below config info, we build jax 0.10.0 for Thor.
Does the version work for your use case?
