I’ve got Code running on my Windows 11 machine. I can paste in sample code from the tutorials and most of them work so I know that Code sees the Python engine installation and can execute properly Python scripts properly. However, one of the examples tries to import matplotlib. When I run i get a "ModuleNotFoundError: No module named ‘matplotlib’ error. The next line says “Executing: Python 1…(11) ” How do I get the matplotlib installed?
BTW, if I open a Command window and type in Python, the Python interpreter powers up. If I type into the >> prompt “import matplotlib” the Python interpreter outside of Omniverse runs and find the library. The problem is calling the matplotlib from inside of Code.
Thanks in advance for any help
