how to install “visual studio code”?
I want develop c++11 on tx2.
Any IDE or text-editer is ok .
i choice “visual studio code”, but i can’t install it.
hwo to do?
or other good soft.
thank your times.
hwo to do?
or other good soft.
thank your times.
It looks like the pre-built packages for Linux provided by Microsoft are only for x86_64. For ARM architecture (aarch64), you would need to build it from source from their repo: [url]https://github.com/Microsoft/vscode[/url]
Alternatively, if you have trouble building VS Code from source, I personally use GEdit (“Text Editor” in Ubuntu Unity) with GEdit’s file browser panel on, and keep a Terminal window open for building with CMake and managing my repos with Git.
You might be interested in something like “geany” (not a complete substitute, but is sufficiently light weight combined with features and available on arm64):
sudo apt-get install geany
            For a more complete IDE with debugger support, you may also use QtCreator.
Installing it on Jetson is not straight forward however, check this post.
Thanks for sharing this. I’ve been trying to install vscode on my R28.2-DP.
I’ve had to install some extra packages:
apt-transport-https libxkbfile-dev libsecret-1-dev rpm
having already these packages
libx11-dev fakeroot
Also installed nodejs 8.11.2:
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
sudo apt-get install -y nodejs
and installed yarn
curl -sS https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update
sudo apt-get install yarn
but when I launch yarn in vscode directory, it fails:
nvidia@tegra-ubuntu:/media/nvidia/Data/VS_Code/vscode-master$ yarn
yarn install v1.7.0
$ node build/npm/preinstall.js
[1/4] Resolving packages...
[2/4] Fetching packages...
info vscode-fsevents@0.3.8: The platform "linux" is incompatible with this module.
info "vscode-fsevents@0.3.8" is an optional dependency and failed compatibility check. Excluding it from installation.
info windows-foreground-love@0.1.0: The platform "linux" is incompatible with this module.
info "windows-foreground-love@0.1.0" is an optional dependency and failed compatibility check. Excluding it from installation.
info windows-mutex@0.2.0: The platform "linux" is incompatible with this module.
info "windows-mutex@0.2.0" is an optional dependency and failed compatibility check. Excluding it from installation.
info windows-process-tree@0.2.2: The platform "linux" is incompatible with this module.
info "windows-process-tree@0.2.2" is an optional dependency and failed compatibility check. Excluding it from installation.
[3/4] Linking dependencies...
[4/4] Building fresh packages...
[9/13] ⠠ vscode-nsfw
[8/13] ⠠ spdlog
[11/13] ⠠ oniguruma
[12/13] ⠠ electron-mksnapshot
error /media/nvidia/Data/VS_Code/vscode-master/node_modules/electron-mksnapshot: Command failed.
Exit code: 1
Command: node ./download-mksnapshot.js
Arguments:
Directory: /media/nvidia/Data/VS_Code/vscode-master/node_modules/electron-mksnapshot
Output:
/media/nvidia/Data/VS_Code/vscode-master/node_modules/electron-mksnapshot/download-mksnapshot.js:16
  if (error != null) throw error
Error: Failed to find Electron v1.7.0 for linux-arm64 at https://github.com/electron/electron/releases/download/v1.7.0/mksnapshot-v1.7.0-linux-arm64.zip
    at Request.<anonymous> (/media/nvidia/Data/VS_Code/vscode-master/node_modules/nugget/index.js:169:61)
    at emitOne (events.js:116:13)
    at Request.emit (events.js:211:7)
    at Request.onRequestResponse (/media/nvidia/Data/VS_Code/vscode-master/node_modules/request/request.js:1068:10)
    at ClientRequest.emit (events.js:211:7)
    at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:543:21)
Any idea how to solve it ? Link https://github.com/electron/electron/releases/download/v1.7.0/mksnapshot-v1.7.0-linux-arm64.zip seems wrong.
Also tried:
npm install --save-dev electron-mksnapshot
> electron-mksnapshot@1.7.1 install /media/nvidia/Data/VS_Code/vscode-master/node_modules/electron-mksnapshot
    at Request.onRequestResponse (/media/nvidia/Data/VS_Code/vscode-master/node_modules/request/request.js:1062:10)
    at HTTPParser.parserOnHeadersComplete (_http_common.js:112:17)
    at TLSSocket.socketOnData (_http_client.js:440:20)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! electron-mksnapshot@1.7.1 install: `node ./download-mksnapshot.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the electron-mksnapshot@1.7.1 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /home/nvidia/.npm/_logs/2018-05-24T21_17_16_579Z-debug.log
For reference, attached is the log file.
2018-05-24T21_17_16_579Z-debug.log (285 KB)
Tried cloning ToT with
git clone --recursive https://github.com/Microsoft/vscode.git
instead of using zip file, not better.
And trying:
yarn run watch
yarn run v1.7.0
$ gulp watch --max_old_space_size=4096
[00:34:16] Node flags detected: --max_old_space_size=4096
[00:34:16] Respawned to PID: 31508
module.js:549
    throw err;
Error: Cannot find module 'gulp-watch'
    at Function.Module._resolveFilename (module.js:547:15)
    at Function.Module._load (module.js:474:25)
    at Module.require (module.js:596:17)
    at require (internal/module.js:11:18)
    at Object.<anonymous> (/media/nvidia/Data/VS_Code/vscode-master/vscode/build/lib/watch/index.js:33:68)
    at Module._compile (module.js:652:30)
    at Object.Module._extensions..js (module.js:663:10)
    at Module.load (module.js:565:32)
    at tryModuleLoad (module.js:505:12)
    at Function.Module._load (module.js:497:3)
error Command failed with exit code 1.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
            Ok, got it, but it has been a real pain…
The issue is that electron support for arm was a bit erratic in older versions.
Further than these Prerequisites :
cd <where_is_your_vscode_root>
gedit packages.json
Then you will change related lines into:
"electron-mksnapshot": "~2.0.0",
and
"gulp-atom-electron": "^1.17.0",
Then also edit file :
gedit test/smoke/package.json
and change related line into:
"electron": "^2.0.0",
Then you can run:
yarn --arch=arm64
npm rebuild --arch=arm64
The latter may fail, but this step may be required depending on node version mismatch. Although it fails, it should have rebuilt what was in wrong version.
Then, again:
yarn --arch=arm64
and
yarn --arch=arm64 run watch
Once it’s done and shows something like:
[01:41:16] Starting 'watch-client'...
[01:45:01] [monaco.d.ts] Starting monaco.d.ts generation
[01:45:10] [monaco.d.ts] Finished monaco.d.ts generation
[01:45:10] <b>Finished compilation with 0 errors</b> after 233562 ms
then in another shell edit:
gedit node_modules/gulp-atom-electron/src/download.js
go to function download and force version to 2.0.0:
function download(opts, cb) {
+	opts.version = '2.0.0';
	var repo = opts.repo || 'atom/electron';
This is a nasty way to do, but I have no more time for finding a clean way.
You should then be able to launch vscode with:
./scripts/code.sh
            Honey_Patouceu and linuxdev, thank you app is good.
i try build vscode on ubuntu 16.04 (on desktop x64, because i worry tx2 damage).
i am fail, I do not know what to do.
i give up.
i debug code on desktop ubuntu, than copy code to tx2.
becuse it is faster. (build code time and test Features time)
These instructions were for native building on TX2. For building on x64, you would probably just install nodejs and yarn, and then in vscode root, just run:
yarn
yarn run watch
and after compilation is finished run
./scripts/code.sh
in another shell.
If you’re trying to cross-compile vscode on x64 for arm64, maybe you can try to pass flag --target_arch=arm64 to yarn, but I haven’t tried it.
BTW, if someone else tried to build vscode natively on TX2, please share if it is working for you or not.
@Honey_Patouceul Thanks for your instruction. I built vscode on TX2 natively with below code. Has some modifications on your code. Comments:
1. add dependency libnss3.
2. remove parameter --arch=arm64.
3. command “yarn run watch” will finish successfully but not exit. Just manually stop it.
4. vscode will update ffmpeg and electron for the first time running.
5. vscode takes ~8 sec to load and show window.
6. totally takes extra ~2.2GB disk space. IMO it’s slow and huge as editor.
# dependencies
sudo apt install git libx11-dev libxkbfile-dev libsecret-1-dev fakeroot rpm libnss3 apt-transport-https
# node.js
wget https://deb.nodesource.com/setup_8.x
sudo bash setup_8.x
sudo apt install -y nodejs
nodejs -v
# yarn
wget https://dl.yarnpkg.com/debian/pubkey.gpg
sudo apt-key add pubkey.gpg
sudo apt update
sudo apt install yarn
yarn --version
# clone code and install all dependencies by yarn
git clone https://github.com/microsoft/vscode
cd vscode
gedit package.json
    "electron":"2.0.0",
yarn
# build
yarn run watch
# run
 ./scripts/code.sh
            @Honey_Patouceul
today i test agin.
Is work! i am successful! (on Tx2)
@zxrgb
this is work!
I really appreciate~
that works for me also! Great!
Did you also know how enable the extension for C++ on TX2 after  sucessfuly compile?
Is there also a way to compile the extensions?
thanks for you help
I haven’t used vscode much more and cannot tell, but if you’re ready for building/installing these you may find these here.
It may also be possible to get binaries online and updates, but I cannot tell how.
By the way guys, if anyone wants to use an extension in vscode after it’s installed, my understanding is that it requires the VSIX file (ctrl+shift+p and then type vsix, choose install extension from vsix) and prior to doing that, find that VSIX. I was looking for the one for vscode-python so I found in the github repo that specific extension file (under that link: [url]https://github.com/Microsoft/vscode-python/releases[/url]). Hope this can help someone!! :)
I’v tried to compile visual studio code on my TX2
current specs of the platform:
jetsontx2@jetsontx2-desktop
OS: Ubuntu 18.04 bionic
Kernel: aarch64 Linux 4.9.140-tegra
Packages: 2641
Shell: bash 4.4.19
Resolution: 5760x1080
WM: Mutter(Budgie)
WM Theme: Adwaita
CPU: ARMv8 rev 3 (v8l) @ 4x 2.0352GHz [37.0°C]
GPU: tegra_fb
RAM: 531MiB / 7860MiB
i have been folowing this script:
I’m stuck on Step 7 ( ~$ yarn) with the following message output:
jetsontx2@jetsontx2-desktop:~/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode$ yarn
yarn install v1.16.0
[1/4] Resolving packages…
[2/4] Fetching packages…
info vscode-fsevents@0.3.10: The platform “linux” is incompatible with this module.
info “vscode-fsevents@0.3.10” is an optional dependency and failed compatibility check. Excluding it from installation.
info fsevents@1.2.7: The platform “linux” is incompatible with this module.
info “fsevents@1.2.7” is an optional dependency and failed compatibility check. Excluding it from installation.
info fsevents@1.2.4: The platform “linux” is incompatible with this module.
info “fsevents@1.2.4” is an optional dependency and failed compatibility check. Excluding it from installation.
info vscode-windows-ca-certs@0.1.0: The platform “linux” is incompatible with this module.
info “vscode-windows-ca-certs@0.1.0” is an optional dependency and failed compatibility check. Excluding it from installation.
info vscode-windows-registry@1.0.1: The platform “linux” is incompatible with this module.
info “vscode-windows-registry@1.0.1” is an optional dependency and failed compatibility check. Excluding it from installation.
info windows-foreground-love@0.1.0: The platform “linux” is incompatible with this module.
info “windows-foreground-love@0.1.0” is an optional dependency and failed compatibility check. Excluding it from installation.
info windows-mutex@0.2.1: The platform “linux” is incompatible with this module.
info “windows-mutex@0.2.1” is an optional dependency and failed compatibility check. Excluding it from installation.
info windows-process-tree@0.2.3: The platform “linux” is incompatible with this module.
info “windows-process-tree@0.2.3” is an optional dependency and failed compatibility check. Excluding it from installation.
[3/4] Linking dependencies…
[4/4] Building fresh packages…
success Saved lockfile.
$ node build/npm/postinstall.js
Installing dependencies in ‘extensions’.
warning package.json: No license field
warning vscode-extensions@0.0.1: No license field
$ node ./postinstall
[##] 2/2removed ‘/home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/extensions/node_modules/typescript/lib/tsc.js’
removed ‘/home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/extensions/node_modules/typescript/lib/tsserverlibrary.d.ts’
removed ‘/home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/extensions/node_modules/typescript/lib/tsserverlibrary.js’
removed ‘/home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/extensions/node_modules/typescript/lib/typescriptServices.d.ts’
removed ‘/home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/extensions/node_modules/typescript/lib/typescriptServices.js’
Done in 0.58s.
Installing dependencies in ‘remote’.
warning vscode-reh@0.0.0: No license field
[1/7] ⡀ keytar
[2/7] ⡀ native-watchdog
[3/7] ⡀ node-pty
[4/7] ⡀ spdlog
error /home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/remote/node_modules/native-watchdog: Command failed.
Exit code: 1
Command: node-gyp rebuild
Arguments:
Directory: /home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/remote/node_modules/native-watchdog
Output:
gyp info it worked if it ends with ok
gyp info using node-gyp@3.8.0
gyp info using node@8.16.0 | linux | arm64
gyp http GET http://nodejs.org/dist/v10.11.0/node-v10.11.0-headers.tar.gz
gyp http 200 http://nodejs.org/dist/v10.11.0/node-v10.11.0-headers.tar.gz
gyp http GET http://nodejs.org/dist/v10.11.0/SHASUMS256.txt
gyp http 200 http://nodejs.org/dist/v10.11.0/SHASUMS256.txt
gyp info spawn /usr/bin/python2
gyp info spawn args [ ‘/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py’,
gyp info spawn args   ‘binding.gyp’,
gyp info spawn args   ‘-f’,
gyp info spawn args   ‘make’,
gyp info spawn args   ‘-I’,
gyp info spawn args   ‘/home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/remote/node_modules/native-watchdog/build/config.gypi’,
gyp info spawn args   ‘/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi’,
gyp info spawn args   ‘/home/jetsontx2/.node-gyp/10.11.0/include/node/common.gypi’,
gyp info spawn args   ‘-Dlibrary=shared_library’,
gyp info spawn args   ‘-Dvisibility=default’,
gyp info spawn args   ‘-Dnode_root_dir=/home/jetsontx2/.node-gyp/10.11.0’,
gyp info spawn args   ‘-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp’,
gyp info spawn args   ‘-Dnode_lib_file=/home/jetsontx2/.node-gyp/10.11.0/<(target_arch)/node.lib’,
gyp info spawn args   ‘-Dmodule_root_dir=/home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/remote/node_modules/native-watchdog’,
gyp info spawn args   ‘-Dnode_engine=v8’,
gyp info spawn args   ‘–depth=.’,
gyp info spawn args   ‘–no-parallel’,
gyp info spawn args   ‘–generator-output’,
gyp info spawn args   ‘build’,
gyp info spawn args   ‘-Goutput_dir=.’ ]
gyp: name ‘build_v8_with_gn’ is not defined while evaluating condition ‘build_v8_with_gn == “true”’ in binding.gyp while trying to load binding.gyp
gyp ERR! configure error
gyp ERR! stack Error: gyp failed with exit code: 1
gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
gyp ERR! stack     at emitTwo (events.js:126:13)
gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
gyp ERR! System Linux 4.9.140-tegra
gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
gyp ERR! cwd /home/jetsontx2/jetson_software/visual_studio_code_source/new_installation_13_06_2019/vscode/remote/node_modules/native-watchdog
info Visit yarn install | Yarn for documentation about this command.
I do not really know how to deal with it. Did someone stumbled upon the same issue and can point me in the right direction?
You may try this.
#Install Node.JS - version >= 10.15.1, < 11.0.0  can solve the problem
curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
To enable extensions, edit the product.json file and add the following:
“extensionsGallery”: {
“serviceUrl”: “https://marketplace.visualstudio.com/_apis/public/gallery”,
“cacheUrl”: “https://vscode.blob.core.windows.net/gallery/index”,
“itemUrl”: “https://marketplace.visualstudio.com/items”
