JiaZW
#1
dear,
cmd: v4l2-ctl -d /dev/video0 -w --verbose --set-fmt-video=width=1920,height=1080,pixelformat=BG12 --stream-mmap --stream-count=1 --set-ctrl bypass_mode=0 --stream-to=/tmp/stream.raw &
debug:
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
log as follow:
JiaZW
#2
.412104] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
[ 42.412792] tegra194-vi5 15c10000.vi: channel error, resetting the channel
ntries-in-buffer/entries-written: 430/430 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/1:1-823 [001] .... 40.523944: rtcpu_vinotify_event: tstamp:1398507042 tag:CHANSEL_NOMATCH channel:0x01 frame:21 vi_tstamp:1398030903 data:0x00000589
kworker/1:1-823 [001] .... 40.523951: rtcpu_vinotify_error: tstamp:1399030850 tag:CSIMUX_FRAME channel:0x00 frame:21 vi_tstamp:1399028151 data:0x00c00060
kworker/1:1-823 [001] .... 40.523953: rtcpu_vinotify_event: tstamp:1399049945 tag:CSIMUX_FRAME channel:0x00 frame:21 vi_tstamp:1399028151 data:0x00c00060
kworker/1:1-823 [001] .... 40.523984: rtcpu_vinotify_error: tstamp:1399118061 tag:CHANSEL_NOMATCH channel:0x01 frame:22 vi_tstamp:1399115316 data:0x00000589
kworker/1:1-823 [001] .... 40.523986: rtcpu_vinotify_event: tstamp:1399592138 tag:FS channel:0x00 frame:22 vi_tstamp:1399096245 data:0x00000010
kworker/1:1-823 [001] .... 40.523987: rtcpu_vinotify_event: tstamp:1399592298 tag:CHANSEL_NOMATCH channel:0x01 frame:22 vi_tstamp:1399115316 data:0x00000589
kworker/1:1-823 [001] .... 40.523991: rtos_queue_peek_from_isr_failed: tstamp:1399694726 queue:0x0bcc8ef0
kworker/1:1-823 [001] .... 40.579903: rtcpu_vinotify_error: tstamp:1400115272 tag:CSIMUX_FRAME channel:0x00 frame:22 vi_tstamp:1400112565 data:0x00c00060
kworker/1:1-823 [001] .... 40.579906: rtcpu_vinotify_event: tstamp:1400135014 tag:CSIMUX_FRAME channel:0x00 frame:22 vi_tstamp:1400112565 data:0x00c00060
kworker/1:1-823 [001] .... 40.579908: rtcpu_vinotify_error: tstamp:1400202431 tag:CHANSEL_NOMATCH channel:0x01 frame:23 vi_tstamp:1400199731 data:0x00000589
kworker/1:1-823 [001] .... 40.579909: rtcpu_vinotify_event: tstamp:1400677200 tag:FS channel:0x00 frame:23 vi_tstamp:1400180660 data:0x00000010
kworker/1:1-823 [001] .... 40.579910: rtcpu_vinotify_event: tstamp:1400677368 tag:CHANSEL_NOMATCH channel:0x01 frame:23 vi_tstamp:1400199731 data:0x00000589
kworker/1:1-823 [001] .... 40.579911: rtcpu_vinotify_error: tstamp:1401199682 tag:CSIMUX_FRAME channel:0x00 frame:23 vi_tstamp:1401196979 data:0x00c00060
kworker/1:1-823 [001] .... 40.579913: rtcpu_vinotify_event: tstamp:1401220075 tag:CSIMUX_FRAME channel:0x00 frame:23 vi_tstamp:1401196979 data:0x00c00060
kworker/1:1-823 [001] .... 40.579914: rtcpu_vinotify_error: tstamp:1401287772 tag:CHANSEL_NOMATCH channel:0x01 frame:24 vi_tstamp:1401285070 data:0x00000589
kworker/1:1-823 [001] .... 40.635987: rtcpu_vinotify_event: tstamp:1401762265 tag:FS channel:0x00 frame:24 vi_tstamp:1401265999 data:0x00000010
kworker/1:1-823 [001] .... 40.635993: rtcpu_vinotify_event: tstamp:1401762414 tag:CHANSEL_NOMATCH channel:0x01 frame:24 vi_tstamp:1401285070 data:0x00000589
kworker/1:1-823 [001] .... 40.635995: rtcpu_vinotify_error: tstamp:1402285005 tag:CSIMUX_FRAME channel:0x00 frame:24 vi_tstamp:1402282318 data:0x00c00060
kworker/1:1-823 [001] .... 40.635996: rtcpu_vinotify_event: tstamp:1402305132 tag:CSIMUX_FRAME channel:0x00 frame:24 vi_tstamp:1402282318 data:0x00c00060
kworker/1:1-823 [001] .... 40.635997: rtcpu_vinotify_error: tstamp:1402372164 tag:CHANSEL_NOMATCH channel:0x01 frame:25 vi_tstamp:1402369483 data:0x00000589
kworker/1:1-823 [001] .... 40.635999: rtcpu_vinotify_event: tstamp:1402847305 tag:FS channel:0x00 frame:25 vi_tstamp:1402350412 data:0x00000010
kworker/1:1-823 [001] .... 40.636039: rtcpu_vinotify_event: tstamp:1402847493 tag:CHANSEL_NOMATCH channel:0x01 frame:25 vi_tstamp:1402369483 data:0x00000589
kworker/1:1-823 [001] .... 40.691926: rtcpu_vinotify_error: tstamp:1403369419 tag:CSIMUX_FRAME channel:0x00 frame:25 vi_tstamp:1403366731 data:0x00c00060
kworker/1:1-823 [001] .... 40.691933: rtcpu_vinotify_event: tstamp:1403390172 tag:CSIMUX_FRAME channel:0x00 frame:25 vi_tstamp:1403366731 data:0x00c00060
kworker/1:1-823 [001] .... 40.691934: rtcpu_vinotify_error: tstamp:1403456745 tag:CHANSEL_NOMATCH channel:0x01 frame:26 vi_tstamp:1403453898 data:0x00000589
kworker/1:1-823 [001] .... 40.691936: rtcpu_vinotify_event: tstamp:1403457147 tag:FS channel:0x00 frame:26 vi_tstamp:1403434827 data:0x00000010
kworker/1:1-823 [001] .... 40.691937: rtcpu_vinotify_event: tstamp:1403457287 tag:CHANSEL_NOMATCH channel:0x01 frame:26 vi_tstamp:1403453898 data:0x00000589
kworker/1:1-823 [001] .... 40.691938: rtcpu_vinotify_error: tstamp:1404453829 tag:CSIMUX_FRAME channel:0x00 frame:26 vi_tstamp:1404451146 data:0x00c00060
kworker/1:1-823 [001] .... 40.691939: rtcpu_vinotify_event: tstamp:1404475416 tag:CSIMUX_FRAME channel:0x00 frame:26 vi_tstamp:1404451146 data:0x00c00060
kworker/1:1-823 [001] .... 40.691940: rtcpu_vinotify_error: tstamp:1404540993 tag:CHANSEL_NOMATCH channel:0x01 frame:27 vi_tstamp:1404538311 data:0x00000589
kworker/1:1-823 [001] .... 40.691976: rtos_queue_peek_from_isr_failed: tstamp:1404694707 queue:0x0bcc8ef0
kworker/1:1-823 [001] .... 40.691978: rtcpu_vinotify_event: tstamp:1405017628 tag:FS channel:0x00 frame:27 vi_tstamp:1404519240 data:0x00000010
kworker/1:1-823 [001] .... 40.691979: rtcpu_vinotify_event: tstamp:1405017794 tag:CHANSEL_NOMATCH channel:0x01 frame:27 vi_tstamp:1404538311 data:0x00000589
kworker/1:1-823 [001] .... 40.747930: rtcpu_vinotify_error: tstamp:1405607279 tag:CSIMUX_FRAME channel:0x00 frame:27 vi_tstamp:1405604579 data:0x000000a0
kworker/1:1-823 [001] .... 40.747935: rtcpu_vinotify_error: tstamp:1405626330 tag:CHANSEL_NOMATCH channel:0x01 frame:28 vi_tstamp:1405623649 data:0x00000589
JiaZW
#3
kworker/0:2-3171 [000] .... 31.494147: rtos_queue_send_from_isr_failed: tstamp:1116848066 queue:0x0bcc6558
kworker/0:2-3171 [000] .... 31.494148: rtos_queue_send_from_isr_failed: tstamp:1116848272 queue:0x0bcc7318
kworker/0:2-3171 [000] .... 31.494149: rtos_queue_send_from_isr_failed: tstamp:1116848479 queue:0x0bcc80d8
kworker/0:2-3171 [000] .... 31.494178: rtcpu_string: tstamp:1116856588 id:0x04010000 str:"vi5_hwinit: firmware CL2018061801 protocol versi"
kworker/0:2-3171 [000] .... 31.494181: rtcpu_string: tstamp:1116856777 id:0x04010000 str:"on 2.2
kworker/0:2-3171 [000] .... 31.494215: rtos_queue_send_from_isr_failed: tstamp:1116883577 queue:0x0bcc10a0
kworker/0:2-3171 [000] .... 31.494216: rtos_queue_send_from_isr_failed: tstamp:1116883830 queue:0x0bcc49d8
kworker/0:2-3171 [000] .... 31.494217: rtos_queue_send_from_isr_failed: tstamp:1116884043 queue:0x0bcc6558
kworker/0:2-3171 [000] .... 31.494219: rtos_queue_send_from_isr_failed: tstamp:1116884251 queue:0x0bcc7318
kworker/0:2-3171 [000] .... 31.494220: rtos_queue_send_from_isr_failed: tstamp:1116884459 queue:0x0bcc80d8
kworker/0:2-3171 [000] .... 31.494221: rtos_queue_send_from_isr_failed: tstamp:1117161738 queue:0x0bcc10a0
kworker/0:2-3171 [000] .... 31.494222: rtos_queue_send_from_isr_failed: tstamp:1117161890 queue:0x0bcc49d8
kworker/0:2-3171 [000] .... 31.494223: rtos_queue_send_from_isr_failed: tstamp:1117162047 queue:0x0bcc6558
kworker/0:2-3171 [000] .... 31.494224: rtos_queue_send_from_isr_failed: tstamp:1117162192 queue:0x0bcc7318
kworker/0:2-3171 [000] .... 31.494225: rtos_queue_send_from_isr_failed: tstamp:1117162336 queue:0x0bcc80d8
kworker/0:2-3171 [000] .... 31.494229: rtcpu_vinotify_event: tstamp:1117357200 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1380626624 data:0x10000000
kworker/0:2-3171 [000] .... 31.494230: rtcpu_vinotify_event: tstamp:1117357349 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1380630432 data:0x31000001
kworker/0:2-3171 [000] .... 31.494231: rtcpu_vinotify_event: tstamp:1117357519 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:1380631424 data:0x07020001
kworker/0:2-3171 [000] .... 31.494233: rtcpu_vinotify_event: tstamp:1117357662 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1380686336 data:0x10000000
kworker/0:2-3171 [000] .... 31.494234: rtcpu_vinotify_event: tstamp:1117357826 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1380690176 data:0x31000002
kworker/0:2-3171 [000] .... 31.662110: rtos_queue_peek_from_isr_failed: tstamp:1121839066 queue:0x0bcc8ef0
kworker/0:2-3171 [000] .... 31.830132: rtos_queue_peek_from_isr_failed: tstamp:1126839044 queue:0x0bcc8ef0
kworker/0:2-3171 [000] .... 31.886164: rtos_queue_send_from_isr_failed: tstamp:1128471755 queue:0x0bcc10a0
kworker/0:2-3171 [000] .... 31.886170: rtos_queue_send_from_isr_failed: tstamp:1128471907 queue:0x0bcc49d8
kworker/0:2-3171 [000] .... 31.886171: rtos_queue_send_from_isr_failed: tstamp:1128472056 queue:0x0bcc6558
kworker/0:2-3171 [000] .... 31.886172: rtos_queue_send_from_isr_failed: tstamp:1128472201 queue:0x0bcc7318
kworker/0:2-3171 [000] .... 31.886189: rtos_queue_send_from_isr_failed: tstamp:1128472347 queue:0x0bcc80d8
kworker/0:2-3171 [000] .... 31.886193: rtcpu_vinotify_event: tstamp:1128751248 tag:FS channel:0x00 frame:1 vi_tstamp:1128408874 data:0x00000010
kworker/0:2-3171 [000] .... 31.886194: rtcpu_vinotify_event: tstamp:1128751419 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:1128408877 data:0x00000000
kworker/0:2-3171 [000] .... 31.886196: rtcpu_vinotify_event: tstamp:1128751571 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:1128427913 data:0x00000001
kworker/0:2-3171 [000] .... 31.886197: rtcpu_vinotify_event: tstamp:1128751755 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:1749959072 data:0x08020001
kworker/0:2-3171 [000] .... 31.886198: rtcpu_vinotify_event: tstamp:1128751899 tag:CHANSEL_FAULT channel:0x23 frame:1 vi_tstamp:1128432269 data:0x00010200
kworker/0:2-3171 [000] .... 31.886199: rtcpu_vinotify_event: tstamp:1128752066 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:1750102112 data:0x01020001
kworker/0:2-3171 [000] .... 31.886202: rtcpu_vinotify_error: tstamp:1129428734 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:1129425162 data:0x00c00060
kworker/0:2-3171 [000] .... 31.886204: rtos_queue_send_from_isr_failed: tstamp:1129464853 queue:0x0bcc10a0
kworker/0:2-3171 [000] .... 31.886236: rtos_queue_send_from_isr_failed: tstamp:1129465007 queue:0x0bcc49d8
kworker/0:2-3171 [000] .... 31.886237: rtos_queue_send_from_isr_failed: tstamp:1129465158 queue:0x0bcc6558
kworker/0:2-3171 [000] .... 31.886238: rtos_queue_send_from_isr_failed: tstamp:1129465304 queue:0x0bcc7318
kworker/0:2-3171 [000] .... 31.886239: rtos_queue_send_from_isr_failed: tstamp:1129465450 queue:0x0bcc80d8
kworker/0:2-3171 [000] .... 31.886240: rtcpu_vinotify_event: tstamp:1129470942 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:1129425162 data:0x00c00060
kworker/0:2-3171 [000] .... 31.886241: rtcpu_vinotify_event: tstamp:1129471112 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:1129425162 data:0x01000000
kworker/0:2-3171 [000] .... 31.886243: rtcpu_vinotify_event: tstamp:1129471260 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:1781890272 data:0x01020001
kworker/0:2-3171 [000] .... 31.886244: rtcpu_vinotify_event: tstamp:1129471430 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:1129425165 data:0x00000000
kworker/0:2-3171 [000] .... 31.886245: rtcpu_vinotify_event: tstamp:1129471569 tag:FS channel:0x00 frame:2 vi_tstamp:1129468296 data:0x00000010
kworker/0:2-3171 [000] .... 31.886246: rtcpu_vinotify_event: tstamp:1129998630 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:1129468299 data:0x00000000
kworker/0:2-3171 [000] .... 31.886272: rtcpu_vinotify_event: tstamp:1129998776 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:1129487367 data:0x00000001
kworker/0:2-3171 [000] .... 31.886273: rtcpu_vinotify_event: tstamp:1129998965 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:1783861568 data:0x08020001
kworker/0:2-3171 [000] .... 31.886274: rtcpu_vinotify_event: tstamp:1129999106 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:1129487629 data:0x00000200
kworker/0:2-3171 [000] .... 31.886275: rtcpu_vinotify_event: tstamp:1129999289 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:1783873600 data:0x01020001
kworker/0:0-4 [000] .... 31.942097: rtcpu_vinotify_error: tstamp:1130488184 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:1130484616 data:0x00c00060
kworker/0:0-4 [000] .... 31.942102: rtcpu_vinotify_event: tstamp:1130541547 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:1130484616 data:0x00c00060
kworker/0:0-4 [000] .... 31.942103: rtcpu_vinotify_event: tstamp:1130541732 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:2 vi_tstamp:1130484616 data:0x01000000
kworker/0:0-4 [000] .... 31.942105: rtcpu_vinotify_event: tstamp:1130541876 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:1815792736 data:0x01020001
kworker/0:0-4 [000] .... 31.942106: rtcpu_vinotify_event: tstamp:1130542060 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:1130484618 data:0x00000000
kworker/0:0-4 [000] .... 31.942107: rtcpu_vinotify_error: tstamp:1130574483 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:1130571780 data:0x00000589
kworker/0:0-4 [000] .... 31.942144: rtcpu_vinotify_event: tstamp:1131083792 tag:FS channel:0x00 frame:3 vi_tstamp:1130552709 data:0x00000010
kworker/0:0-4 [000] .... 31.942146: rtcpu_vinotify_event: tstamp:1131083957 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:1130571780 data:0x00000589
kworker/0:0-4 [000] .... 31.942147: rtcpu_vinotify_error: tstamp:1131571781 tag:CSIMUX_FRAME channel:0x00 frame:3 vi_tstamp:1131569028 data:0x00c00060
kworker/0:0-4 [000] .... 31.942148: rtcpu_vinotify_event: tstamp:1131626663 tag:CSIMUX_FRAME channel:0x00 frame:3 vi_tstamp:1131569028 data:0x00c00060
kworker/0:0-4 [000] .... 31.942149: rtcpu_vinotify_error: tstamp:1131659827 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:1131657118 data:0x00000589
kworker/0:0-4 [000] .... 31.998118: rtos_queue_peek_from_isr_failed: tstamp:1131839071 queue:0x0bcc8ef0
kworker/0:0-4 [000] .... 31.998122: rtcpu_vinotify_event: tstamp:1132168857 tag:FS channel:0x00 frame:4 vi_tstamp:1131638048 data:0x00000010[ 34.470128] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 34.489161] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
kworker/0:0-4 [000] .... 31.998124: rtcpu_vinotify_event: tstamp:1132169004 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:1131657118 data:0x00000589
kworker/0:0-4 [000] .... 31.998126: rtcpu_vinotify_error: tstamp:1132725370 tag:CSIMUX_FRAME channel:0x00 frame:4 vi_tstamp:1132722463 data:0x000000a0
kworker/0:0-4 [000] .... 31.998128: rtcpu_vinotify_event: tstamp:1132725780 tag:CSIMUX_FRAME channel:0x00 frame:4 vi_tstamp:1132722463 data:0x000000a0
kworker/0:0-4 [000] .... 31.998129: rtcpu_vinotify_event: tstamp:1132725924 tag:FS channel:0x00 frame:5 vi_tstamp:1132722463 data:0x00000010
kworker/0:0-4 [000] .... 31.998130: rtcpu_vinotify_error: tstamp:1132744224 tag:CHANSEL_NOMATCH channel:0x01 frame:5 vi_tstamp:1132741534 data:0x00000589
kworker/0:0-4 [000] .... 31.998131: rtcpu_vinotify_event: tstamp:1133254233 tag:CHANSEL_NOMATCH channel:0x01 frame:5 vi_tstamp:1132741534 data:0x00000589
kworker/0:0-4 [000] .... 32.054112: rtcpu_vinotify_error: tstamp:1133741487 tag:CSIMUX_FRAME channel:0x00 frame:5 vi_tstamp:1133738782 data:0x00c00060
kworker/0:0-4 [000] .... 32.054116: rtcpu_vinotify_event: tstamp:1133796314 tag:CSIMUX_FRAME channel:0x00 frame:5 vi_tstamp:1133738782 data:0x00c00060
kworker/0:0-4 [000] .... 32.054119: rtcpu_vinotify_error: tstamp:1133828646 tag:CHANSEL_NOMATCH channel:0x01 frame:6 vi_tstamp:1133825947 data:0x00000589
kworker/0:0-4 [000] .... 32.054120: rtcpu_vinotify_event: tstamp:1134339297 tag:FS channel:0x00 frame:6 vi_tstamp:1133806876 data:0x00000010
kworker/0:0-4 [000] .... 32.054122: rtcpu_vinotify_event: tstamp:1134339438 tag:CHANSEL_NOMATCH channel:0x01 frame:6 vi_tstamp:1133825947 data:0x00000589
kworker/0:0-4 [000] .... 32.054123: rtcpu_vinotify_error: tstamp:1134825898 tag:CSIMUX_FRAME channel:0x00 frame:6 vi_tstamp:1134823196 data:0x00c00060
kworker/0:0-4 [000] .... 32.054124: rtcpu_vinotify_event: tstamp:1134881381 tag:CSIMUX_FRAME channel:0x00 frame:6 vi_tstamp:1134823196 data:0x00c00060
kworker/0:0-4 [000] .... 32.054125: rtcpu_vinotify_error: tstamp:1134913096 tag:CHANSEL_NOMATCH channel:0x01 frame:7 vi_tstamp:1134910362 data:0x00000589
kworker/0:0-4 [000] .... 32.110102: rtcpu_vinotify_event: tstamp:1135424363 tag:FS channel:0x00 frame:7 vi_tstamp:1134891290 data:0x00000010
Index : 0
kworker/0:0-4 [000] .... 32.110104: rtcpu_vinotify_event: tstamp:1135424535 tag:CHANSEL_NOMATCH channel:0x01 frame:7 vi_tstamp:1134910362 data:0x00000589
kworker/0:0-4 [000] .... 32.110105: rtcpu_vinotify_error: tstamp:1135910363 tag:CSIMUX_FRAME channel:0x00
JiaZW
#4
Can these logs locate some problems ???
Need help !!
thanks
Looks like the sensor output resolution not as expect. Have adjust the driver to report correct height.
kworker/0:2-3171 [000] … 31.886241: rtcpu_vinotify_event: tstamp:1129471112 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:1129425162 data:0x01000000
