Hi Jerry,
We need to use #define TEGRA194_AON_GPIO_PORT_BB 1 only. After making the pin num as 8. and configured as an input and tried to read the status of i/o it is working. But still as a output I am not able to toggle the i/o. I am using oscilloscope to probe the signals to check the i/o toggle.
[0124.506] I> is_gpio_valid: bank = 1, bank_Max = 5
[0125.007] I> grl_gpio_validation: Pin Read Value = 0 — Pin-16 connected to GND
[0125.007] I> is_gpio_valid: bank = 1, bank_Max = 5
[0125.507] I> grl_gpio_validation: Pin Read Value = 1 — Pin-16 connected to 3.3V
And I confirmed the respective GPIO is a part of A-ON not from MAIN GPIO Controller
gpiochip1: GPIOs 248-287, parent: platform/c2f0000.gpio, tegra-gpio-aon:
gpio-253 ( |pex-refclk-sel-low ) out lo
gpio-256 ( |sysfs ) out hi
gpio-284 ( |power-key ) in hi
And as per Wayne comment from the link “GPIO numbering - mapping to sysfs GPIO for JETSON XAVIER - #4 by WayneWWW” Need to refer tegra194-gpio.h for xavier and tegra186-gpio.h for TX2.
Correct me If I am wrong.
After changing the pin num to 8 and as input. I am able to get the status of the i/o. But as a output. I am not able to control. And the HW is working fine. I verified from user space application.
Thanks,
Prasanna
