How to maximize bitrate with RJ45 between the two Jetson AGX Orin Devkits
This is related to the following contents:
https://forums.developer.nvidia.com/t/how-to-maximize-bitrate-on-the-jetson-orin/229135
When you connect two Jetson AGX Orin Devkits directly, set MTU size to 9000, then you can achieve 9.8Gbps.
I have a question about the result above.
Q1: Could you please tell me about the concrete steps when you meet 9.8Gbps with two Jetson AGX Orin Devkits directly?
Q2: How about the JetPack version?
Q3: How about Power Mode?
Q4: Did you use “jetson_clocks”?
thanks
Please refer to this setup and give it a try:
The maximum speed of the 10G network port of the ORIN-32GB module can only reach 6.5G using iperf3 - #4 by DaneLLL
We try it on Jetpack 5.1.1 with the commands being executed:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
It should be same result on 5.1.2.
