Your ar0231 node in your device tree should reflect the physical layout of the hardware. If it is on the i2c mux at address 0x70 then you probably do want it at i2c0. Keep in mind that the i2c mux driver will create a virtual bus.
To see the i2c busses:
sudo i2cdetect -l
When you know the correct bus number then you can list the devices on that bus with
sudo i2cdetct -y -r $I2C_BUS
You’ll see a table that lists addresses. If a device was detected at the address the address number is listed. If a device is detected that is already claimed by a device driver then UU will appear in place of the address.
If your ar0231 driver is communicating with the image sensor them dmesg | grep ar0231 will probably list the device name you are looking for. Depending on your ar0231 driver you may need to enable dynamic debug for it.
