what is the recommended way? I cannot find any mounting holes on a dev kit. I’d need to mount a whole dev kit as is – with the base and the fan and everything.
I’m sorry but I haven’t found any useful info how to fix the dev kit. Could you may be more specific? Anything better than scotch tape is greatly appreciated.
One thing to notice is that the plastic base has screws for mounting the board to that. I have not tried this, but I’m thinking you could unscrew that plastic base and use standoff hardware.
Chitoku Yato at NVIDIA designed a 3D printed mount bracket for the NX form factor Jetsons for the iRobot iCreate 3. Here’s a link to the page: Compute Boards - Create® 3 Docs
Here’s a link to the STL file for the NX: https://iroboteducation.github.io/create3_docs/hw/data/models/Compute/NVIDIA_Jetson/Mount_Bracket/C3-JetsonXavierNX-Mount.stl
The bracket captures the edges of the dev kit and allows mounting points for your project.
