Hi:
I want to enable all the USB ports of TX2.Jetpack version is 4.6.
Below are the USB pins I used:
Step1:ODMDATA
Linux_for_Tegra/p2771-0000.conf.common
Step 2:pinctrl@3520000
Linux_for_Tegra/source/public/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi
pinctrl@3520000 {
vbus-0-supply = <&vdd_usb0_5v>;
vbus-1-supply = <&vdd_usb1_5v>;
vbus-2-supply = <&battery_reg>;//vbus-2-supply = <&vdd_usb2_5v>;
vbus-3-supply = <&battery_reg>;
vddio-hsic-supply = <&battery_reg>;
avdd_usb-supply = <&spmic_sd3>;
vclamp_usb-supply = <&spmic_sd2>;
avdd_pll_erefeut-supply = <&spmic_sd2>;
step 3:
Linux_for_Tegra/source/public/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-plugin-manager/tegra186-quill-p3310-1000-a00-plugin-manager.dtsi
I delete “fragment-500-pcie-config”,“fragment-500-xusb-config” and “fragment-500-e3325-pcie”.
step 4:
Linux_for_Tegra/source/public/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
pcie-controller@10003000 {
status="okay";
pci@1,0 {
//nvidia,num-lanes = <4>;
nvidia,num-lanes = <2>;
nvidia,disable-clock-request;
status="okay";
pci@2,0 {
//nvidia,num-lanes = <0>;
nvidia,num-lanes = <1>;
status="okay";
pci@3,0 {
status="disabled";
xhci@3530000 {
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-2}>;
phy-names = "usb2-0","usb2-1","usb2-2","usb3-0","usb3-1","usb3-2";
nvidia,boost_cpu_freq = <1200>;
xusb_padctl@3520000 {
ports {
usb3-2 {
nvidia,usb2-companion = <2>;
status = "okay";
usb3-1 {
nvidia,usb2-companion = <0>;
status = "okay";
usb3-0 {
nvidia,usb2-companion = <1>;
status = "okay";
After you finish updating the dtb.The result is:
Why is my device mounted on USB 2.0? How should I change it?
