Do anyone know how to enable two USB3.0 port?
I am using customer carrier board,i want to enable two USB3.0 port.
F43, F44, C43, C44
A38, A39, A18 -
G39, G40, D39, D40
B37 A17 A36 B40 B39
after try https://elinux.org/Jetson/TX2_USB#USB-Lane_Mapping,
the first one[F43, F44, C43, C44 A38, A39, A18] work well,but the second one can not work.
I make some modification as following.
- modify the ODMDATA value in file “p2771-0000.conf.common”
process_board_version()
local kerndtbfab="-c03"; # default = C03
ODMDATA=0x6090000; # default = C0X
- comment out above three fragment in hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-plugin-manager/
tegra186-quill-p3310-1000-a00-plugin-manager.dtsi
fragment-500-pcie-config {
ids = ">=3310-1000-500";
override@0 {
target = <&tegra_pcie>;
_overlay_ {
pci@1,0 {
nvidia,num-lanes = <4>;
pci@2,0 {
nvidia,num-lanes = <0>;
pci@3,0 {
nvidia,num-lanes = <1>;
fragment-500-xusb-config {
override@0 {
target = <&{/xhci@3530000}>;
_overlay_ {
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(2)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(0)>;
phy-names = "utmi-0", "utmi-1", "utmi-2", "usb3-0";
override@1 {
target = <&tegra_xusb_padctl_pinmux_default>;
_overlay_ {
usb3-std-A-port2 {
nvidia,lanes = "usb3-0";
e3325-usb3-std-A-HS {
status = "okay";
fragment-500-e3325-pcie {
enable-override-on-all-matches;
odm-data = "enable-pcie-on-uphy-lane0";
override@0 {
_overlay_ {
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(2)>;
phy-names = "utmi-0", "utmi-1", "utmi-2";
override@1 {
_overlay_ {
usb3-std-A-port2 {
status = "disabled";
override@2 {
target = <&tegra_main_gpio>;
_overlay_ {
pcie0_lane2_mux {
status = "okay";
- modify the file hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi to change vbus-2-supply from vdd_usb2_5v to battery_reg
pinctrl@3520000 {
vbus-0-supply = <&vdd_usb0_5v>;
vbus-1-supply = <&vdd_usb1_5v>;
vbus-2-supply = <&battery_reg>;
vbus-3-supply = <&battery_reg>;
vddio-hsic-supply = <&battery_reg>;
avdd_usb-supply = <&spmic_sd3>;
vclamp_usb-supply = <&spmic_sd2>;
avdd_pll_erefeut-supply = <&spmic_sd2>;
- modify the file hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
gpio@2200000 {
sdmmc-wake-support-input {
status = "okay";
sdmmc-wake-support-output {
status = "okay";
pcie0_lane2_mux {
status = "okay"; //This is for switch from usb3.0 to x1 PCIe on M.2.
pcie-controller@10003000 {
pci@1,0 {
nvidia,num-lanes = <2>;
nvidia,disable-clock-request;
status = "okay";
pci@2,0 {
status = "okay";
pci@3,0 {
status = "okay";
xhci@3530000 {
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(2)>;
phy-names = "utmi-0", "utmi-1", "utmi-2", "usb3-1", "usb3-2";
pinctrl@3520000 {
pinmux {
usb3-std-A-port2 {
nvidia,lanes = "usb3-1";
nvidia,port-cap = <TEGRA_PADCTL_PORT_HOST_ONLY>;
status = "okay";
usb3-std-A-port3 {
nvidia,lanes = "usb3-2";
status = "okay";
status = "okay"; //This is usb2.0 port on M.2
Are there any wrong step, many thanks?
