My custom carrier board has USB ports 0 and 2 as USB 2.0 and USB port 1 as USB 3.0. i have not used the INA3221 power monitoring chip but i am able to use USB port 1 as USB 2.0 but unable use the other two ports.
I have tried the Power Tree Changes suggested in the PLATFORM ADAPTATION AND BRING-UP GUIDE but wasn’t successful.
I am using L4T 28.1.
Hi, which config (referring to table of USB 3.0, PCIe & SATA Lane Mapping Configurations in OEM DG) did you chose in the board design?
I have chosen config #5 but i am still yet to configure the source files for that and flash my device.
I wanted to enable USB ports first as it seemed easier.
So here is my plan
1.Enable USB ports
2.Enable UART and GPIO using PINMUX template
3.Configure SB 3.0, PCIe & SATA Lane Mapping.
4.Enable Audio Codec support.
