Hello.
I made a Jetson tx2 custom board.
I installed the OS on a custom board and checked each port after booting.
(L4T r32.3.1)
Ethernet and HDMI on the custom board are working fine .
USB have problem.
The custom board has one usb 2.0 micro-b and two usb 3.0 type-a.
I can install ubuntu os using usb2.0 micro-b.
But usb 2.0 micro-b and two usb 3.0 type-a cannot be used in host mode.
How do I edit dts and dtsi files?
The USB pin used are as follows.
usb 3.0 Type-A port
- USB_SSO_RX (F44, F43)
- USB_SSO_TX (C44, C43)
- USB1_D (A38, A39)
- USB1_EN_OC (A18)
- USB_SS1_RX (G42, G43)
- USB_SS1_TX (D42, D43)
- USB2_D (B42, B43)
- USB2_EN_OC (A19)
usb 2.0 micro-b port
- USB0_D (B40, B39)
- USB0_EN_OC (A17)
- USB0_OTG_ID (A36)
- USB0_VBUS_DEF (B37)
This is the kernel log captured at boot time.
And I tried following the methods in the link below, but the problem was not resolved.
https://elinux.org/Jetson/TX2_USB
