How to Power the Xavier AGX with 5V?
The product documentation of the Jetson Xavier states that it can be operated either via SYS_VIN_HV with 9V-20V or via SYS_VIN_MV with 5V.
I would like to use the Xavier with the 5V but I am not sure how? I have tried the type-C connection over the barrel jack but without success. Can anyone give me information about this?
You would need a “boost” converter to increase the voltage.
Ok so it is not possible to power the AGX via USB-C?
No. The voltage would be too low even if it were designed to do this (in which case it would need a boost converter on voltage).
