How to prevent Xorg process from using the GPU? on Ubuntu 20.04.3 LTS (with a RTX 3050 Ti)
I want to preserve as much of the GPU memory as possible for deep learning processes. How can I prevent video processes from utilizing GPU resources?
Many solutions for older versions suggest to edit/create:
/etc/X11/xorg.conf
with:
Section “Device”
Identifier “intel”
Driver “modesetting”
BusID “PCI:0:2:0”
EndSection
There is no such file on my laptop.
What I want is to remove the following line in $ nvidia-smi
0 N/A N/A 1123 G /usr/lib/xorg/Xorg 896MiB
| NVIDIA-SMI 495.46 Driver Version: 495.46 CUDA Version: 11.5 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| N/A 58C P3 10W / N/A | 1468MiB / 3913MiB | 4% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1123 G /usr/lib/xorg/Xorg 896MiB |
| 0 N/A N/A 1473 G /usr/bin/gnome-shell 110MiB |
| 0 N/A N/A 1909 G …AAAAAAAAA= --shared-files 187MiB |
| 0 N/A N/A 34218 G …AAAAAAAAA= --shared-files 268MiB |
Any updated solution?
nvidia-bug-report.log.gz (1.4 MB)
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Just uploaded the file. Thanks
Just run
sudo prime-select on-demand
and reboot. This will run everything on the intel igpu, only leaving a 4MB process on the nvidia left.
If you also want to get of that, additionally create the file you mentioned in your first post, you’ll then have to make sure the nvidia-persistenced daemon is started on boot.
Hey @generix , Well done! It was much simpler than I thought. Indeed, I have now my /usr/lib/xorg/Xorg process with only 4MB and nothing else. Exactly the kind of GPU optimization I was looking for.
Thanks a lot for your quick support.
