How to reflash bootloader only on Xavier AGX
Board: Xavier AGX
Reflashing the entire system takes more tha ten minutes.
How can I reflash bootloader only on Xavier AGX ?
I tried this (from the document [1]) but it ends with an error.
export BOARD="jetson-xavier"
sudo ./flash.sh -k EBT ${BOARD} mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 4.2
Welcome to Tegra Flash
version 1.0.0
[   5.4098 ] Sending bootloader and pre-requisite binaries
[   5.4107 ] tegrarcm_v2 --download blob blob.bin
[   5.4114 ] Applet version 01.00.0000
[   5.4289 ] Sending blob
[   5.4290 ] [................................................] 100%
[   6.2924 ]
[   6.2941 ] tegrarcm_v2 --boot recovery
[   6.2960 ] Applet version 01.00.0000
[   6.3025 ]
[   7.3051 ] tegrarcm_v2 --isapplet
[   7.8712 ]
[   7.8747 ] tegrarcm_v2 --ismb2
[   7.8797 ]
[   7.8827 ] tegradevflash_v2 --iscpubl
[   7.8841 ] Bootloader version 01.00.0000
[   7.9006 ] Bootloader version 01.00.0000
[   7.9016 ]
[   7.9016 ] Writing partition
[   7.9034 ] tegradevflash_v2 --write EBT 1_nvtboot_cpu_t194_sigheader.bin.encrypt
[   7.9049 ] Bootloader version 01.00.0000
[   7.9208 ] Writing partition EBT with 1_nvtboot_cpu_t194_sigheader.bin.encrypt
[   7.9218 ] 000000000d0d000d: o open partition %s.
[   7.9222 ]
[   7.9222 ]
Error: Return value 13
Command tegradevflash_v2 --write EBT 1_nvtboot_cpu_t194_sigheader.bin.encrypt
Failed to flash/read t186ref.
[1] Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
Parameters in flash.sh
“-r” means re-use the system.img so that it will take less time
“-k” needs to have a partition name as input to indicate which partition to flash.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fpart_config.html
If you want to flash cboot only, then the command should be
sudo ./flash.sh -r -k cpu-bootloader jetson-xavier mmcblk0p1.
Hi @WayneWWW,
thank you.
In this case I replace the file cboot_t194.bin
cp out/build-t194/lk.bin ../Linux_for_Tegra/bootloader/cboot_t194.bin
and call the programmer again
It works and allows me to run a fast development/test cycle.
