How to resolve error that timed out while polling for tx timestamp on ptp operation?
Dear Nvidia,
I use Jetson Orin and I want to synchronize the clocks of a slave sensor and the Nvidia Jetson Orin as master via linuxptp.
linuxptp link : GitHub - richardcochran/linuxptp at v3.1.x
the sensor and the Orin are connected directory via ethernet.
the configuration file that use for ptp is attached.
As like as the log file attached, I enter the command “sudo ptp4l -i eth1 -f gPTP.cfg -2 -m”
And I can see the log about send syhnc failed.
Could you please help let me know how to resolve this error?
“ptp4l[154.779]: timed out while polling for tx timestamp
ptp4l[154.780]: increasing tx_timestamp_timeout may correct this issue, but it is likely caused by a driver bug
ptp4l[154.780]: port 1: send sync failed
ptp4l[154.780]: port 1: MASTER to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
ptp4l[170.869]: port 1: FAULTY to MASTER on INIT_COMPLETE”
tsync_master_3.1.1_240424_log.zip (6.8 KB)
Best regards,
We don’t have much experience on this use case, may other developers help to provide suggestions.
