How to run resnet10 example jetson nano
resnet10 is our sample detector and most of config with primary-gie component use it.
For example,
$ deepstream-app -c source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
thank you. for example, How to remove the full screen mode?
You can update the size of sink component.
Ex.
[sink0]
width=1280
height=720
How to make sure the data stream is still processed without showing the screen?
Deepstream-app will print out profiling data periodically.
It the log keep outputting, the stream should work ideally.
