How to run RTP Camera in deepstream on Nano
We are checking the issue. Since we do not have the IP cameras you have, please help run attached app and share the print:
bufferformat: NvBufferColorFormat_NV12
Please modify rtsp location in the code and execute the steps:
$ export MMAPI_INCLUDE=/usr/src/tegra_multimedia_api/include
$ export MMAPI_CLASS=/usr/src/tegra_multimedia_api/samples/common/classes
$ export USR_LIB=/usr/lib/aarch64-linux-gnu
$ g++ -Wall -std=c++11  decode.cpp -o decode $(pkg-config --cflags --libs gstreamer-app-1.0) -I$MMAPI_INCLUDE $USR_LIB/tegra/libnvbuf_utils.so $MMAPI_CLASS/NvEglRenderer.o $MMAPI_CLASS/NvElement.o $MMAPI_CLASS/NvElementProfiler.o $MMAPI_CLASS/NvLogging.o $USR_LIB/libEGL.so $USR_LIB/libGLESv2.so $USR_LIB/libX11.so
$ export DISPLAY=:1(or 0)
$ ./decode
decode.zip (1.47 KB)
