How to embed nveglglessink into an gtk window widget on wayland/weston env
We don’t have experience in this case. Is it possible to implement it in using jetson_multimedia_api? We have NvEglRenderer in
/usr/src/jetson_multimedia_api/samples/common/classes/NvEglRenderer.cpp
If you can customize it to run the case, it may be a solution to hook to appsink and use NvEglRenderer. There is a sample:
