Hello @ahaidu, I have succesfully found the error. The bin/vulkan
info command showed the warning that :
WARNING: [Loader Message] Code 0 : Layer VK_LAYER_MESA_device_select uses API version 1.2 which is older than the application specified API version of 1.3. May cause issues.
This means I somehow need higher API version for Vulkan layer loading. I found on their webpage that the maximum possible API currently is “1.2”. ( Vulkan-Loader/LoaderLayerInterface.md at v1.3.212 · KhronosGroup/Vulkan-Loader · GitHub)
And then I realised that it maybe occuring as I am using Isaac Sim 2022.2.1. Thus I ran the terminal for the version 2022.2.0 and everything has worked out just fine. I think Isaac Sim 2022.2.1 needs Vulkan Layer Loader to be of version 1.3.
I get a bunch of warnings but I think I can ignore these:
Loading Stage /Isaac/Environments/Simple_Warehouse/full_warehouse.usd
2023-03-24 13:07:44 [9,501ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Materials/MaterialInstanceDynamic_1220.mdl?watch=00007fe4e44b6540(61,8): C181 unused variable 'Local15'
2023-03-24 13:07:44 [9,502ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Materials/MaterialInstanceDynamic_1220.mdl?watch=00007fe4e44b6540(61,8): C181 unused variable 'Local15'
2023-03-24 13:07:44 [9,502ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/Materials/MaterialInstanceDynamic_1220.mdl?watch=00007fe4e44b6540(61,8): C181 unused variable 'Local15'
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedPallet/SM_PaletteA_01. To enable SDF collisions, sdfResolution should be > 0.
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_0/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_1/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_2/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_3/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_4/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_5/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_6/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
2023-03-24 13:07:51 [16,919ms] [Warning] [omni.physx.plugin] PhysicsUSD: Parse collision - triangle mesh collision (approximation None/MeshSimplifixation) without SDF cannot be a part of a dynamic body, falling back to convexHull approximation: /MyScope/SimulatedCardbox_7/SM_CardBoxD_04. To enable SDF collisions, sdfResolution should be > 0.
Simulation stopped after 95 steps
2023-03-24 13:07:53 [18,398ms] [Warning] [carb.flatcache.plugin] UsdRelationship /Replicator/SDGPipeline/OgnGroup_06.inputs:prims has multiple targets, which is not supported
Outputting data to /home/user/.local/share/ov/pkg/isaac_sim-2022.2.0/_output_headless
2023-03-24 13:07:54 [19,095ms] [Warning] [carb.flatcache.plugin] PathToAttributesMap (0x1b878c10) contains attributes with duplicate name "camera" with different types but same per-element size. Data may become corrupted during request to move elements between buckets!
Module omni.replicator.core.ogn.python._impl.nodes.OgnSemanticSegmentation load on device 'cuda:0' took 1.07 ms
2023-03-24 13:08:00 [25,696ms] [Warning] [carb] Plugin interface for a client: omni.hydratexture.plugin was already released.
[25.702s] Simulation App Shutting Down
Thank you so much for the help!
