Crash on Launch with Driver 460.67 on Ubuntu 20.04
Crashpad
2021-06-17 00:21:09 [3,592ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(unsigned int, int, carb::cpp20::latch*), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2021-06-17 00:21:09 [3,596ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-06-17 00:21:09 [3,598ms] [Fatal] [carb.crashreporter-breakpad.plugin] libnvidia-glcore.so.460.67!vk_optimusGetDeviceProcAddr
2021-06-17 00:21:09 [3,600ms] [Fatal] [carb.crashreporter-breakpad.plugin] libnvidia-glcore.so.460.67!vk_optimusGetDeviceProcAddr
2021-06-17 00:21:09 [3,604ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.graphics-vulkan.plugin.so!_init
2021-06-17 00:21:09 [3,605ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!std::call_once<void (std::__future_base::_State_baseV2::*)(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*), std::__future_base::_State_baseV2*, std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*>(std::once_flag&, void (std::__future_base::_State_baseV2::*&&)(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*), std::__future_base::_State_baseV2*&&, std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*&&, bool*&&)::{lambda()#2}::_FUN()
2021-06-17 00:21:09 [3,606ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbGetPluginDeps
2021-06-17 00:21:09 [3,608ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!std::__future_base::_State_baseV2::_M_is_deferred_future() const
2021-06-17 00:21:09 [3,610ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)
2021-06-17 00:21:09 [3,612ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()
2021-06-17 00:21:09 [3,614ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-06-17 00:21:09 [3,616ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!carbOnPluginPostShutdown
2021-06-17 00:21:09 [3,616ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-06-17 00:21:09 [3,618ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-06-17 00:21:09 [3,619ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
(base) sam@spectrum:~/Downloads/1.2.176.1/x86_64$ nvidia-smi
Thu Jun 17 09:49:48 2021
| NVIDIA-SMI 460.67       Driver Version: 460.67       CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce RTX 208...  Off  | 00000000:2D:00.0  On |                  N/A |
| 27%   36C    P8    27W / 250W |    430MiB / 11016MiB |      2%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      1515      G   /usr/lib/xorg/Xorg                 59MiB |
|    0   N/A  N/A      2543      G   /usr/lib/xorg/Xorg                231MiB |
|    0   N/A  N/A      2682      G   /usr/bin/gnome-shell               48MiB |
|    0   N/A  N/A      3181      G   ...gAAAAAAAAA --shared-files       13MiB |
|    0   N/A  N/A      9148      G   ...AAAAAAAAA= --shared-files       62MiB |
Vulkan
(base) sam@spectrum:~/Downloads/1.2.176.1/x86_64$ bin/vulkaninfo
VULKANINFO
Vulkan Instance Version: 1.2.176
Instance Extensions: count = 18
	VK_EXT_acquire_xlib_display            : extension revision 1
	VK_EXT_debug_report                    : extension revision 9
	VK_EXT_debug_utils                     : extension revision 2
	VK_EXT_direct_mode_display             : extension revision 1
	VK_EXT_display_surface_counter         : extension revision 1
	VK_KHR_device_group_creation           : extension revision 1
	VK_KHR_display                         : extension revision 23
	VK_KHR_external_fence_capabilities     : extension revision 1
	VK_KHR_external_memory_capabilities    : extension revision 1
	VK_KHR_external_semaphore_capabilities : extension revision 1
	VK_KHR_get_display_properties2         : extension revision 1
	VK_KHR_get_physical_device_properties2 : extension revision 2
	VK_KHR_get_surface_capabilities2       : extension revision 1
	VK_KHR_surface                         : extension revision 25
	VK_KHR_surface_protected_capabilities  : extension revision 1
	VK_KHR_wayland_surface                 : extension revision 6
	VK_KHR_xcb_surface                     : extension revision 6
	VK_KHR_xlib_surface                    : extension revision 6
Layers: count = 10
VK_LAYER_KHRONOS_synchronization2 (Khronos Synchronization2 layer) Vulkan version 1.2.176, layer version 1:
	Layer Extensions: count = 0
	Devices: count = 1
		GPU id = 0 (GeForce RTX 2080 Ti)
		Layer-Device Extensions: count = 1
			VK_KHR_synchronization2 : extension revision 1
VK_LAYER_KHRONOS_validation (Khronos Validation Layer) Vulkan version 1.2.176, layer version 1:
	Layer Extensions: count = 3
		VK_EXT_debug_utils         : extension revision 1
		VK_EXT_validation_features : extension revision 2
	Devices: count = 1
		Layer-Device Extensions: count = 3
			VK_EXT_debug_marker     : extension revision 4
			VK_EXT_tooling_info     : extension revision 1
			VK_EXT_validation_cache : extension revision 1
VK_LAYER_LUNARG_api_dump (LunarG API dump layer) Vulkan version 1.2.176, layer version 2:
	Devices: count = 1
VK_LAYER_LUNARG_device_simulation (LunarG device simulation layer) Vulkan version 1.2.176, layer version 1:
	Devices: count = 1
VK_LAYER_LUNARG_gfxreconstruct (GFXReconstruct Capture Layer Version 0.9.7) Vulkan version 1.2.176, layer version 36871:
	Devices: count = 1
VK_LAYER_LUNARG_monitor (Execution Monitoring Layer) Vulkan version 1.2.176, layer version 1:
	Devices: count = 1
VK_LAYER_LUNARG_screenshot (LunarG image capture layer) Vulkan version 1.2.176, layer version 1:
	Devices: count = 1
VK_LAYER_MESA_device_select (Linux device selection layer) Vulkan version 1.1.73, layer version 1:
	Devices: count = 1
		Layer-Device Extensions: count = 0
VK_LAYER_NV_optimus (NVIDIA Optimus layer) Vulkan version 1.2.155, layer version 1:
	Devices: count = 1
VK_LAYER_NV_optimus (NVIDIA Optimus layer) Vulkan version 1.2.133, layer version 1:
	Devices: count = 1
Presentable Surfaces:
GPU id : 0 (GeForce RTX 2080 Ti):
	Surface types: count = 2
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
			format = FORMAT_B8G8R8A8_UNORM
			colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
		SurfaceFormat[1]:
			format = FORMAT_B8G8R8A8_SRGB
	Present Modes: count = 3
		PRESENT_MODE_FIFO_KHR
		PRESENT_MODE_FIFO_RELAXED_KHR
		PRESENT_MODE_IMMEDIATE_KHR
	VkSurfaceCapabilitiesKHR:
		minImageCount       = 2
		maxImageCount       = 8
		currentExtent:
			width  = 256
			height = 256
		minImageExtent:
			width  = 256
			height = 256
		maxImageExtent:
			width  = 256
			height = 256
		maxImageArrayLayers = 1
		supportedTransforms: count = 1
			SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		currentTransform    = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		supportedCompositeAlpha: count = 1
			COMPOSITE_ALPHA_OPAQUE_BIT_KHR
		supportedUsageFlags: count = 6
			IMAGE_USAGE_TRANSFER_SRC_BIT
			IMAGE_USAGE_TRANSFER_DST_BIT
			IMAGE_USAGE_SAMPLED_BIT
			IMAGE_USAGE_STORAGE_BIT
			IMAGE_USAGE_COLOR_ATTACHMENT_BIT
			IMAGE_USAGE_INPUT_ATTACHMENT_BIT
	VkSurfaceCapabilities2EXT:
		supportedSurfaceCounters: count = 0
			None
	VkSurfaceProtectedCapabilitiesKHR:
		supportsProtected = false
Device Groups:
Group 0:
	Properties:
		physicalDevices: count = 1
			GeForce RTX 2080 Ti (ID: 0)
		subsetAllocation = 0
	Present Capabilities:
		GeForce RTX 2080 Ti (ID: 0):
			Can present images from the following devices: count = 1
		Present modes: count = 1
			DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
	apiVersion     = 4202651 (1.2.155)
	driverVersion  = 1930477568 (0x7310c000)
	vendorID       = 0x10de
	deviceID       = 0x1e07
	deviceType     = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
	deviceName     = GeForce RTX 2080 Ti
VkPhysicalDeviceLimits:
	maxImageDimension1D                             = 32768
	maxImageDimension2D                             = 32768
	maxImageDimension3D                             = 16384
	maxImageDimensionCube                           = 32768
	maxImageArrayLayers                             = 2048
	maxTexelBufferElements                          = 134217728
	maxUniformBufferRange                           = 65536
	maxStorageBufferRange                           = 4294967295
	maxPushConstantsSize                            = 256
	maxMemoryAllocationCount                        = 4294967295
	maxSamplerAllocationCount                       = 4000
	bufferImageGranularity                          = 0x00000400
	sparseAddressSpaceSize                          = 0xffffffffff
	maxBoundDescriptorSets                          = 32
	maxPerStageDescriptorSamplers                   = 1048576
	maxPerStageDescriptorUniformBuffers             = 1048576
	maxPerStageDescriptorStorageBuffers             = 1048576
	maxPerStageDescriptorSampledImages              = 1048576
	maxPerStageDescriptorStorageImages              = 1048576
	maxPerStageDescriptorInputAttachments           = 1048576
	maxPerStageResources                            = 4294967295
	maxDescriptorSetSamplers                        = 1048576
	maxDescriptorSetUniformBuffers                  = 1048576
	maxDescriptorSetUniformBuffersDynamic           = 15
	maxDescriptorSetStorageBuffers                  = 1048576
	maxDescriptorSetStorageBuffersDynamic           = 16
	maxDescriptorSetSampledImages                   = 1048576
	maxDescriptorSetStorageImages                   = 1048576
	maxDescriptorSetInputAttachments                = 1048576
	maxVertexInputAttributes                        = 32
	maxVertexInputBindings                          = 32
	maxVertexInputAttributeOffset                   = 2047
	maxVertexInputBindingStride                     = 2048
	maxVertexOutputComponents                       = 128
	maxTessellationGenerationLevel                  = 64
	maxTessellationPatchSize                        = 32
	maxTessellationControlPerVertexInputComponents  = 128
	maxTessellationControlPerVertexOutputComponents = 128
	maxTessellationControlPerPatchOutputComponents  = 120
	maxTessellationControlTotalOutputComponents     = 4216
	maxTessellationEvaluationInputComponents        = 128
	maxTessellationEvaluationOutputComponents       = 128
	maxGeometryShaderInvocations                    = 32
	maxGeometryInputComponents                      = 128
	maxGeometryOutputComponents                     = 128
	maxGeometryOutputVertices                       = 1024
	maxGeometryTotalOutputComponents                = 1024
	maxFragmentInputComponents                      = 128
	maxFragmentOutputAttachments                    = 8
	maxFragmentDualSrcAttachments                   = 1
	maxFragmentCombinedOutputResources              = 16
	maxComputeSharedMemorySize                      = 49152
	maxComputeWorkGroupCount: count = 3
		2147483647
		65535
		65535
	maxComputeWorkGroupInvocations                  = 1024
	maxComputeWorkGroupSize: count = 3
		1024
		1024
		64
	subPixelPrecisionBits                           = 8
	subTexelPrecisionBits                           = 8
	mipmapPrecisionBits                             = 8
	maxDrawIndexedIndexValue                        = 4294967295
	maxDrawIndirectCount                            = 4294967295
	maxSamplerLodBias                               = 15
	maxSamplerAnisotropy                            = 16
	maxViewports                                    = 16
	maxViewportDimensions: count = 2
		32768
		32768
	viewportBoundsRange: count = 2
		-65536
		65536
	viewportSubPixelBits                            = 8
	minMemoryMapAlignment                           = 64
	minTexelBufferOffsetAlignment                   = 0x00000010
	minUniformBufferOffsetAlignment                 = 0x00000040
	minStorageBufferOffsetAlignment                 = 0x00000010
	minTexelOffset                                  = -8
	maxTexelOffset                                  = 7
	minTexelGatherOffset                            = -32
	maxTexelGatherOffset                            = 31
	minInterpolationOffset                          = -0.5
	maxInterpolationOffset                          = 0.4375
	subPixelInterpolationOffsetBits                 = 4
	maxFramebufferWidth                             = 32768
	maxFramebufferHeight                            = 32768
	maxFramebufferLayers                            = 2048
	framebufferColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferStencilSampleCounts: count = 5
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	framebufferNoAttachmentsSampleCounts: count = 5
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	maxColorAttachments                             = 8
	sampledImageColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageIntegerSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageStencilSampleCounts: count = 5
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	storageImageSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleMaskWords                              = 1
	timestampComputeAndGraphics                     = true
	timestampPeriod                                 = 1
	maxClipDistances                                = 8
	maxCullDistances                                = 8
	maxCombinedClipAndCullDistances                 = 8
	discreteQueuePriorities                         = 2
	pointSizeRange: count = 2
		1
		2047.94
	lineWidthRange: count = 2
		1
		64
	pointSizeGranularity                            = 0.0625
	lineWidthGranularity                            = 0.0625
	strictLines                                     = true
	standardSampleLocations                         = true
	optimalBufferCopyOffsetAlignment                = 0x00000001
	optimalBufferCopyRowPitchAlignment              = 0x00000001
	nonCoherentAtomSize                             = 0x00000040
VkPhysicalDeviceSparseProperties:
	residencyStandard2DBlockShape            = true
	residencyStandard2DMultisampleBlockShape = true
	residencyStandard3DBlockShape            = true
	residencyAlignedMipSize                  = false
	residencyNonResidentStrict               = true
VkPhysicalDeviceAccelerationStructurePropertiesKHR:
	maxGeometryCount                                           = 16777215
	maxInstanceCount                                           = 16777215
	maxPrimitiveCount                                          = 536870911
	maxPerStageDescriptorAccelerationStructures                = 1048576
	maxPerStageDescriptorUpdateAfterBindAccelerationStructures = 1048576
	maxDescriptorSetAccelerationStructures                     = 1048576
	maxDescriptorSetUpdateAfterBindAccelerationStructures      = 1048576
	minAccelerationStructureScratchOffsetAlignment             = 128
VkPhysicalDeviceBlendOperationAdvancedPropertiesEXT:
	advancedBlendMaxColorAttachments      = 8
	advancedBlendIndependentBlend         = false
	advancedBlendNonPremultipliedSrcColor = true
	advancedBlendNonPremultipliedDstColor = true
	advancedBlendCorrelatedOverlap        = true
	advancedBlendAllOperations            = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
	primitiveOverestimationSize                 = 0.00195312
	maxExtraPrimitiveOverestimationSize         = 0.75
	extraPrimitiveOverestimationSizeGranularity = 0.25
	primitiveUnderestimation                    = true
	conservativePointAndLineRasterization       = true
	degenerateTrianglesRasterized               = true
	degenerateLinesRasterized                   = true
	fullyCoveredFragmentShaderInputVariable     = true
	conservativeRasterizationPostDepthCoverage  = true
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
	maxCustomBorderColorSamplers = 4000
VkPhysicalDeviceDepthStencilResolveProperties:
	supportedDepthResolveModes: count = 4
		RESOLVE_MODE_SAMPLE_ZERO_BIT
		RESOLVE_MODE_AVERAGE_BIT
		RESOLVE_MODE_MIN_BIT
		RESOLVE_MODE_MAX_BIT
	supportedStencilResolveModes: count = 3
	independentResolveNone = true
	independentResolve     = true
VkPhysicalDeviceDescriptorIndexingProperties:
	maxUpdateAfterBindDescriptorsInAllPools              = 4294967295
	shaderUniformBufferArrayNonUniformIndexingNative     = true
	shaderSampledImageArrayNonUniformIndexingNative      = true
	shaderStorageBufferArrayNonUniformIndexingNative     = true
	shaderStorageImageArrayNonUniformIndexingNative      = true
	shaderInputAttachmentArrayNonUniformIndexingNative   = true
	robustBufferAccessUpdateAfterBind                    = true
	quadDivergentImplicitLod                             = true
	maxPerStageDescriptorUpdateAfterBindSamplers         = 1048576
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 1048576
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 1048576
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 1048576
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 1048576
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 1048576
	maxPerStageUpdateAfterBindResources                  = 4294967295
	maxDescriptorSetUpdateAfterBindSamplers              = 1048576
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 1048576
	maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 15
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 1048576
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 16
	maxDescriptorSetUpdateAfterBindSampledImages         = 1048576
	maxDescriptorSetUpdateAfterBindStorageImages         = 1048576
	maxDescriptorSetUpdateAfterBindInputAttachments      = 1048576
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
	maxDiscardRectangles = 8
VkPhysicalDeviceDriverProperties:
	driverID           = DRIVER_ID_NVIDIA_PROPRIETARY
	driverName         = NVIDIA
	driverInfo         = 460.67
	conformanceVersion = 1.2.4.0
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
	minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	shaderSignedZeroInfNanPreserveFloat16 = true
	shaderSignedZeroInfNanPreserveFloat32 = true
	shaderSignedZeroInfNanPreserveFloat64 = true
	shaderDenormPreserveFloat16           = true
	shaderDenormPreserveFloat32           = false
	shaderDenormPreserveFloat64           = false
	shaderDenormFlushToZeroFloat16        = false
	shaderDenormFlushToZeroFloat32        = false
	shaderDenormFlushToZeroFloat64        = false
	shaderRoundingModeRTEFloat16          = true
	shaderRoundingModeRTEFloat32          = true
	shaderRoundingModeRTEFloat64          = true
	shaderRoundingModeRTZFloat16          = false
	shaderRoundingModeRTZFloat32          = true
	shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceFragmentShadingRatePropertiesKHR:
	minFragmentShadingRateAttachmentTexelSize:
		width  = 16
		height = 16
	maxFragmentShadingRateAttachmentTexelSize:
		width  = 16
		height = 16
	maxFragmentShadingRateAttachmentTexelSizeAspectRatio = 1
	primitiveFragmentShadingRateWithMultipleViewports    = false
	layeredShadingRateAttachments                        = true
	fragmentShadingRateNonTrivialCombinerOps             = true
	maxFragmentSize:
		width  = 4
		height = 4
	maxFragmentSizeAspectRatio                           = 2
	maxFragmentShadingRateCoverageSamples                = 16
	maxFragmentShadingRateRasterizationSamples           = SAMPLE_COUNT_16_BIT
	fragmentShadingRateWithShaderDepthStencilWrites      = true
	fragmentShadingRateWithSampleMask                    = true
	fragmentShadingRateWithShaderSampleMask              = true
	fragmentShadingRateWithConservativeRasterization     = true
	fragmentShadingRateWithFragmentShaderInterlock       = true
	fragmentShadingRateWithCustomSampleLocations         = true
	fragmentShadingRateStrictMultiplyCombiner            = true
VkPhysicalDeviceIDProperties:
	deviceUUID      = 614af189-6ea8-cb25-53e5-e1ea2170029d
	driverUUID      = 96d8d3af-857f-3d5b-9d94-2ef8a25ff4c7
	deviceNodeMask  = 1
	deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
	maxInlineUniformBlockSize                               = 256
	maxPerStageDescriptorInlineUniformBlocks                = 32
	maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
	maxDescriptorSetInlineUniformBlocks                     = 32
	maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
	lineSubPixelPrecisionBits = 8
VkPhysicalDeviceMaintenance3Properties:
	maxPerSetDescriptors    = 4294967295
	maxMemoryAllocationSize = 0xffe00000
VkPhysicalDeviceMultiviewProperties:
	maxMultiviewViewCount     = 32
	maxMultiviewInstanceIndex = 134217727
VkPhysicalDevicePCIBusInfoPropertiesEXT:
	pciDomain   = 0
	pciBus      = 45
	pciDevice   = 0
	pciFunction = 0
VkPhysicalDevicePointClippingProperties:
	pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
	protectedNoFault = false
VkPhysicalDevicePushDescriptorPropertiesKHR:
	maxPushDescriptors = 32
VkPhysicalDeviceRayTracingPipelinePropertiesKHR:
	shaderGroupHandleSize              = 32
	maxRayRecursionDepth               = 31
	maxShaderGroupStride               = 4096
	shaderGroupBaseAlignment           = 64
	shaderGroupHandleCaptureReplaySize = 32
	maxRayDispatchInvocationCount      = 1073741824
	shaderGroupHandleAlignment         = 32
	maxRayHitAttributeSize             = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
	robustStorageBufferAccessSizeAlignment = 0x00000001
	robustUniformBufferAccessSizeAlignment = 0x00000010
VkPhysicalDeviceSampleLocationsPropertiesEXT:
	sampleLocationSampleCounts: count = 5
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	maxSampleLocationGridSize:
		width  = 1
		height = 1
	sampleLocationCoordinateRange: count = 2
		0
		0.9375
	sampleLocationSubPixelBits       = 4
	variableSampleLocations          = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
	filterMinmaxSingleComponentFormats = true
	filterMinmaxImageComponentMapping  = true
VkPhysicalDeviceSubgroupProperties:
	subgroupSize              = 32
	supportedStages: count = 16
		SHADER_STAGE_VERTEX_BIT
		SHADER_STAGE_TESSELLATION_CONTROL_BIT
		SHADER_STAGE_TESSELLATION_EVALUATION_BIT
		SHADER_STAGE_GEOMETRY_BIT
		SHADER_STAGE_FRAGMENT_BIT
		SHADER_STAGE_COMPUTE_BIT
		SHADER_STAGE_ALL_GRAPHICS
		SHADER_STAGE_ALL
		SHADER_STAGE_RAYGEN_BIT_KHR
		SHADER_STAGE_ANY_HIT_BIT_KHR
		SHADER_STAGE_CLOSEST_HIT_BIT_KHR
		SHADER_STAGE_MISS_BIT_KHR
		SHADER_STAGE_INTERSECTION_BIT_KHR
		SHADER_STAGE_CALLABLE_BIT_KHR
		SHADER_STAGE_TASK_BIT_NV
		SHADER_STAGE_MESH_BIT_NV
	supportedOperations: count = 9
		SUBGROUP_FEATURE_BASIC_BIT
		SUBGROUP_FEATURE_VOTE_BIT
		SUBGROUP_FEATURE_ARITHMETIC_BIT
		SUBGROUP_FEATURE_BALLOT_BIT
		SUBGROUP_FEATURE_SHUFFLE_BIT
		SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
		SUBGROUP_FEATURE_CLUSTERED_BIT
		SUBGROUP_FEATURE_QUAD_BIT
		SUBGROUP_FEATURE_PARTITIONED_BIT_NV
	quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
	minSubgroupSize              = 32
	maxSubgroupSize              = 32
	maxComputeWorkgroupSubgroups = 2097152
	requiredSubgroupSizeStages: count = 16
		SHADER_STAGE_ALL
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
	storageTexelBufferOffsetAlignmentBytes       = 0x00000010
	storageTexelBufferOffsetSingleTexelAlignment = true
	uniformTexelBufferOffsetAlignmentBytes       = 0x00000010
	uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
	maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
	maxTransformFeedbackStreams                = 4
	maxTransformFeedbackBuffers                = 4
	maxTransformFeedbackBufferSize             = 0xffffffffffffffff
	maxTransformFeedbackStreamDataSize         = 2048
	maxTransformFeedbackBufferDataSize         = 512
	maxTransformFeedbackBufferDataStride       = 2048
	transformFeedbackQueries                   = true
	transformFeedbackStreamsLinesTriangles     = false
	transformFeedbackRasterizationStreamSelect = true
	transformFeedbackDraw                      = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
	maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
	deviceNodeMask                    = 1
	subgroupSize                      = 32
	subgroupSupportedStages: count = 16
		SHADER_STAGE_ALL
	subgroupSupportedOperations: count = 9
	subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
	driverName                                           = NVIDIA
	driverInfo                                           = 460.67
	framebufferIntegerColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
Device Extensions: count = 128
	VK_EXT_4444_formats                       : extension revision 1
	VK_EXT_blend_operation_advanced           : extension revision 2
	VK_EXT_buffer_device_address              : extension revision 2
	VK_EXT_calibrated_timestamps              : extension revision 1
	VK_EXT_conditional_rendering              : extension revision 2
	VK_EXT_conservative_rasterization         : extension revision 1
	VK_EXT_custom_border_color                : extension revision 12
	VK_EXT_depth_clip_enable                  : extension revision 1
	VK_EXT_depth_range_unrestricted           : extension revision 1
	VK_EXT_descriptor_indexing                : extension revision 2
	VK_EXT_discard_rectangles                 : extension revision 1
	VK_EXT_display_control                    : extension revision 1
	VK_EXT_extended_dynamic_state             : extension revision 1
	VK_EXT_external_memory_host               : extension revision 1
	VK_EXT_fragment_shader_interlock          : extension revision 1
	VK_EXT_global_priority                    : extension revision 2
	VK_EXT_host_query_reset                   : extension revision 1
	VK_EXT_image_robustness                   : extension revision 1
	VK_EXT_index_type_uint8                   : extension revision 1
	VK_EXT_inline_uniform_block               : extension revision 1
	VK_EXT_line_rasterization                 : extension revision 1
	VK_EXT_memory_budget                      : extension revision 1
	VK_EXT_pci_bus_info                       : extension revision 2
	VK_EXT_pipeline_creation_cache_control    : extension revision 3
	VK_EXT_pipeline_creation_feedback         : extension revision 1
	VK_EXT_post_depth_coverage                : extension revision 1
	VK_EXT_private_data                       : extension revision 1
	VK_EXT_robustness2                        : extension revision 1
	VK_EXT_sample_locations                   : extension revision 1
	VK_EXT_sampler_filter_minmax              : extension revision 2
	VK_EXT_scalar_block_layout                : extension revision 1
	VK_EXT_separate_stencil_usage             : extension revision 1
	VK_EXT_shader_atomic_float                : extension revision 1
	VK_EXT_shader_demote_to_helper_invocation : extension revision 1
	VK_EXT_shader_image_atomic_int64          : extension revision 1
	VK_EXT_shader_subgroup_ballot             : extension revision 1
	VK_EXT_shader_subgroup_vote               : extension revision 1
	VK_EXT_shader_viewport_index_layer        : extension revision 1
	VK_EXT_subgroup_size_control              : extension revision 2
	VK_EXT_texel_buffer_alignment             : extension revision 1
	VK_EXT_transform_feedback                 : extension revision 1
	VK_EXT_vertex_attribute_divisor           : extension revision 3
	VK_EXT_ycbcr_image_arrays                 : extension revision 1
	VK_KHR_16bit_storage                      : extension revision 1
	VK_KHR_8bit_storage                       : extension revision 1
	VK_KHR_acceleration_structure             : extension revision 11
	VK_KHR_bind_memory2                       : extension revision 1
	VK_KHR_buffer_device_address              : extension revision 1
	VK_KHR_copy_commands2                     : extension revision 1
	VK_KHR_create_renderpass2                 : extension revision 1
	VK_KHR_dedicated_allocation               : extension revision 3
	VK_KHR_deferred_host_operations           : extension revision 3
	VK_KHR_depth_stencil_resolve              : extension revision 1
	VK_KHR_descriptor_update_template         : extension revision 1
	VK_KHR_device_group                       : extension revision 4
	VK_KHR_draw_indirect_count                : extension revision 1
	VK_KHR_driver_properties                  : extension revision 1
	VK_KHR_external_fence                     : extension revision 1
	VK_KHR_external_fence_fd                  : extension revision 1
	VK_KHR_external_memory                    : extension revision 1
	VK_KHR_external_memory_fd                 : extension revision 1
	VK_KHR_external_semaphore                 : extension revision 1
	VK_KHR_external_semaphore_fd              : extension revision 1
	VK_KHR_fragment_shading_rate              : extension revision 1
	VK_KHR_get_memory_requirements2           : extension revision 1
	VK_KHR_image_format_list                  : extension revision 1
	VK_KHR_imageless_framebuffer              : extension revision 1
	VK_KHR_maintenance1                       : extension revision 2
	VK_KHR_maintenance2                       : extension revision 1
	VK_KHR_maintenance3                       : extension revision 1
	VK_KHR_multiview                          : extension revision 1
	VK_KHR_pipeline_executable_properties     : extension revision 1
	VK_KHR_pipeline_library                   : extension revision 1
	VK_KHR_push_descriptor                    : extension revision 2
	VK_KHR_ray_query                          : extension revision 1
	VK_KHR_ray_tracing_pipeline               : extension revision 1
	VK_KHR_relaxed_block_layout               : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge       : extension revision 3
	VK_KHR_sampler_ycbcr_conversion           : extension revision 14
	VK_KHR_separate_depth_stencil_layouts     : extension revision 1
	VK_KHR_shader_atomic_int64                : extension revision 1
	VK_KHR_shader_clock                       : extension revision 1
	VK_KHR_shader_draw_parameters             : extension revision 1
	VK_KHR_shader_float16_int8                : extension revision 1
	VK_KHR_shader_float_controls              : extension revision 4
	VK_KHR_shader_non_semantic_info           : extension revision 1
	VK_KHR_shader_subgroup_extended_types     : extension revision 1
	VK_KHR_shader_terminate_invocation        : extension revision 1
	VK_KHR_spirv_1_4                          : extension revision 1
	VK_KHR_storage_buffer_storage_class       : extension revision 1
	VK_KHR_swapchain                          : extension revision 70
	VK_KHR_swapchain_mutable_format           : extension revision 1
	VK_KHR_timeline_semaphore                 : extension revision 2
	VK_KHR_uniform_buffer_standard_layout     : extension revision 1
	VK_KHR_variable_pointers                  : extension revision 1
	VK_KHR_vulkan_memory_model                : extension revision 3
	VK_NVX_binary_import                      : extension revision 1
	VK_NVX_image_view_handle                  : extension revision 2
	VK_NVX_multiview_per_view_attributes      : extension revision 1
	VK_NV_clip_space_w_scaling                : extension revision 1
	VK_NV_compute_shader_derivatives          : extension revision 1
	VK_NV_cooperative_matrix                  : extension revision 1
	VK_NV_corner_sampled_image                : extension revision 2
	VK_NV_coverage_reduction_mode             : extension revision 1
	VK_NV_cuda_kernel_launch                  : extension revision 2
	VK_NV_dedicated_allocation                : extension revision 1
	VK_NV_dedicated_allocation_image_aliasing : extension revision 1
	VK_NV_device_diagnostic_checkpoints       : extension revision 2
	VK_NV_device_diagnostics_config           : extension revision 1
	VK_NV_device_generated_commands           : extension revision 3
	VK_NV_fill_rectangle                      : extension revision 1
	VK_NV_fragment_coverage_to_color          : extension revision 1
	VK_NV_fragment_shader_barycentric         : extension revision 1
	VK_NV_fragment_shading_rate_enums         : extension revision 1
	VK_NV_framebuffer_mixed_samples           : extension revision 1
	VK_NV_geometry_shader_passthrough         : extension revision 1
	VK_NV_mesh_shader                         : extension revision 1
	VK_NV_ray_tracing                         : extension revision 3
	VK_NV_representative_fragment_test        : extension revision 2
	VK_NV_sample_mask_override_coverage       : extension revision 1
	VK_NV_scissor_exclusive                   : extension revision 1
	VK_NV_shader_image_footprint              : extension revision 2
	VK_NV_shader_sm_builtins                  : extension revision 1
	VK_NV_shader_subgroup_partitioned         : extension revision 1
	VK_NV_shading_rate_image                  : extension revision 3
	VK_NV_viewport_array2                     : extension revision 1
	VK_NV_viewport_swizzle                    : extension revision 1
VkQueueFamilyProperties:
	queueProperties[0]:
		minImageTransferGranularity = (1,1,1)
		queueCount                  = 16
		queueFlags                  = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		timestampValidBits          = 64
		present support             = true
	queueProperties[1]:
		queueCount                  = 2
		queueFlags                  = QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		present support             = false
	queueProperties[2]:
		queueCount                  = 8
		queueFlags                  = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 3
	memoryHeaps[0]:
		size   = 11811160064 (0x2c0000000) (11.00 GiB)
		budget = 11101143040 (0x295ae0000) (10.34 GiB)
		usage  = 0 (0x00000000) (0.00 B)
		flags: count = 1
			MEMORY_HEAP_DEVICE_LOCAL_BIT
	memoryHeaps[1]:
		size   = 50592328704 (0xbc789ac00) (47.12 GiB)
		budget = 50592328704 (0xbc789ac00) (47.12 GiB)
		flags: count = 0
			None
	memoryHeaps[2]:
		size   = 257949696 (0x0f600000) (246.00 MiB)
		budget = 249823232 (0x0ee40000) (238.25 MiB)
		usage  = 8126464 (0x007c0000) (7.75 MiB)
		flags: count = 1
memoryTypes: count = 11
	memoryTypes[0]:
		heapIndex     = 1
		propertyFlags = 0x0000: count = 0
			None
		usable for:
			IMAGE_TILING_OPTIMAL:
				None
			IMAGE_TILING_LINEAR:
				color images
				(non-sparse, non-transient)
	memoryTypes[1]:
		heapIndex     = 1
			None
		usable for:
				color images
				(non-sparse)
				None
	memoryTypes[2]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_D16_UNORM
				(non-sparse)
				None
	memoryTypes[3]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_X8_D24_UNORM_PACK32
				FORMAT_D24_UNORM_S8_UINT
				(non-sparse)
				None
	memoryTypes[4]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_D32_SFLOAT
				(non-sparse)
				None
	memoryTypes[5]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_D32_SFLOAT_S8_UINT
				(non-sparse)
				None
	memoryTypes[6]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_S8_UINT
				(non-sparse)
				None
	memoryTypes[7]:
		heapIndex     = 0
		propertyFlags = 0x0001: count = 1
			MEMORY_PROPERTY_DEVICE_LOCAL_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
	memoryTypes[8]:
		heapIndex     = 1
		propertyFlags = 0x0006: count = 2
			MEMORY_PROPERTY_HOST_VISIBLE_BIT
			MEMORY_PROPERTY_HOST_COHERENT_BIT
		usable for:
				None
				color images
	memoryTypes[9]:
		heapIndex     = 1
		propertyFlags = 0x000e: count = 3
			MEMORY_PROPERTY_HOST_CACHED_BIT
		usable for:
				None
				color images
	memoryTypes[10]:
		heapIndex     = 2
		propertyFlags = 0x0007: count = 3
		usable for:
				None
				None
VkPhysicalDeviceFeatures:
	robustBufferAccess                      = true
	fullDrawIndexUint32                     = true
	imageCubeArray                          = true
	independentBlend                        = true
	geometryShader                          = true
	tessellationShader                      = true
	sampleRateShading                       = true
	dualSrcBlend                            = true
	logicOp                                 = true
	multiDrawIndirect                       = true
	drawIndirectFirstInstance               = true
	depthClamp                              = true
	depthBiasClamp                          = true
	fillModeNonSolid                        = true
	depthBounds                             = true
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = true
	multiViewport                           = true
	samplerAnisotropy                       = true
	textureCompressionETC2                  = false
	textureCompressionASTC_LDR              = false
	textureCompressionBC                    = true
	occlusionQueryPrecise                   = true
	pipelineStatisticsQuery                 = true
	vertexPipelineStoresAndAtomics          = true
	fragmentStoresAndAtomics                = true
	shaderTessellationAndGeometryPointSize  = true
	shaderImageGatherExtended               = true
	shaderStorageImageExtendedFormats       = true
	shaderStorageImageMultisample           = true
	shaderStorageImageReadWithoutFormat     = true
	shaderStorageImageWriteWithoutFormat    = true
	shaderUniformBufferArrayDynamicIndexing = true
	shaderSampledImageArrayDynamicIndexing  = true
	shaderStorageBufferArrayDynamicIndexing = true
	shaderStorageImageArrayDynamicIndexing  = true
	shaderClipDistance                      = true
	shaderCullDistance                      = true
	shaderFloat64                           = true
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceResidency                 = true
	shaderResourceMinLod                    = true
	sparseBinding                           = true
	sparseResidencyBuffer                   = true
	sparseResidencyImage2D                  = true
	sparseResidencyImage3D                  = true
	sparseResidency2Samples                 = true
	sparseResidency4Samples                 = true
	sparseResidency8Samples                 = true
	sparseResidency16Samples                = true
	sparseResidencyAliased                  = true
	variableMultisampleRate                 = true
	inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeatures:
	storageBuffer16BitAccess           = true
	uniformAndStorageBuffer16BitAccess = true
	storagePushConstant16              = true
	storageInputOutput16               = false
VkPhysicalDevice4444FormatsFeaturesEXT:
	formatA4R4G4B4 = true
	formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
	storageBuffer8BitAccess           = true
	uniformAndStorageBuffer8BitAccess = true
	storagePushConstant8              = true
VkPhysicalDeviceAccelerationStructureFeaturesKHR:
	accelerationStructure                                 = true
	accelerationStructureCaptureReplay                    = true
	accelerationStructureIndirectBuild                    = false
	accelerationStructureHostCommands                     = false
	descriptorBindingAccelerationStructureUpdateAfterBind = true
VkPhysicalDeviceBlendOperationAdvancedFeaturesEXT:
	advancedBlendCoherentOperations = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
	bufferDeviceAddress              = true
	bufferDeviceAddressCaptureReplay = false
	bufferDeviceAddressMultiDevice   = true
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
	conditionalRendering          = true
	inheritedConditionalRendering = true
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
	customBorderColors             = true
	customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
	depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
	shaderInputAttachmentArrayDynamicIndexing          = true
	shaderUniformTexelBufferArrayDynamicIndexing       = true
	shaderStorageTexelBufferArrayDynamicIndexing       = true
	shaderUniformBufferArrayNonUniformIndexing         = true
	shaderSampledImageArrayNonUniformIndexing          = true
	shaderStorageBufferArrayNonUniformIndexing         = true
	shaderStorageImageArrayNonUniformIndexing          = true
	shaderInputAttachmentArrayNonUniformIndexing       = true
	shaderUniformTexelBufferArrayNonUniformIndexing    = true
	shaderStorageTexelBufferArrayNonUniformIndexing    = true
	descriptorBindingUniformBufferUpdateAfterBind      = true
	descriptorBindingSampledImageUpdateAfterBind       = true
	descriptorBindingStorageImageUpdateAfterBind       = true
	descriptorBindingStorageBufferUpdateAfterBind      = true
	descriptorBindingUniformTexelBufferUpdateAfterBind = true
	descriptorBindingStorageTexelBufferUpdateAfterBind = true
	descriptorBindingUpdateUnusedWhilePending          = true
	descriptorBindingPartiallyBound                    = true
	descriptorBindingVariableDescriptorCount           = true
	runtimeDescriptorArray                             = true
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
	extendedDynamicState = true
VkPhysicalDeviceFragmentShaderInterlockFeaturesEXT:
	fragmentShaderSampleInterlock      = true
	fragmentShaderPixelInterlock       = true
	fragmentShaderShadingRateInterlock = true
VkPhysicalDeviceFragmentShadingRateFeaturesKHR:
	pipelineFragmentShadingRate   = true
	primitiveFragmentShadingRate  = true
	attachmentFragmentShadingRate = true
VkPhysicalDeviceHostQueryResetFeatures:
	hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeaturesEXT:
	robustImageAccess = true
VkPhysicalDeviceImagelessFramebufferFeatures:
	imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
	indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
	inlineUniformBlock                                 = true
	descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
	rectangularLines         = true
	bresenhamLines           = true
	smoothLines              = true
	stippledRectangularLines = true
	stippledBresenhamLines   = true
	stippledSmoothLines      = true
VkPhysicalDeviceMultiviewFeatures:
	multiview                   = true
	multiviewGeometryShader     = true
	multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
	pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
	pipelineExecutableInfo = true
VkPhysicalDevicePrivateDataFeaturesEXT:
	privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
	protectedMemory = false
VkPhysicalDeviceRayQueryFeaturesKHR:
	rayQuery = true
VkPhysicalDeviceRayTracingPipelineFeaturesKHR:
	rayTracingPipeline                                    = true
	rayTracingPipelineShaderGroupHandleCaptureReplay      = false
	rayTracingPipelineShaderGroupHandleCaptureReplayMixed = false
	rayTracingPipelineTraceRaysIndirect                   = true
	rayTraversalPrimitiveCulling                          = true
VkPhysicalDeviceRobustness2FeaturesEXT:
	robustBufferAccess2 = true
	robustImageAccess2  = true
	nullDescriptor      = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
	samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
	scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
	separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
	shaderBufferFloat32Atomics   = true
	shaderBufferFloat32AtomicAdd = true
	shaderBufferFloat64Atomics   = true
	shaderBufferFloat64AtomicAdd = true
	shaderSharedFloat32Atomics   = true
	shaderSharedFloat32AtomicAdd = true
	shaderSharedFloat64Atomics   = true
	shaderSharedFloat64AtomicAdd = true
	shaderImageFloat32Atomics    = true
	shaderImageFloat32AtomicAdd  = true
	sparseImageFloat32Atomics    = true
	sparseImageFloat32AtomicAdd  = true
VkPhysicalDeviceShaderAtomicInt64Features:
	shaderBufferInt64Atomics = true
	shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
	shaderSubgroupClock = true
	shaderDeviceClock   = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
	shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
	shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
	shaderFloat16 = true
	shaderInt8    = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
	shaderImageInt64Atomics = true
	sparseImageInt64Atomics = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
	shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
	shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
	subgroupSizeControl  = true
	computeFullSubgroups = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
	texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
	timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
	transformFeedback = true
	geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
	uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
	variablePointersStorageBuffer = true
	variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
	vertexAttributeInstanceRateDivisor     = true
	vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
	multiview                          = true
VkPhysicalDeviceVulkan12Features:
	samplerMirrorClampToEdge                           = true
	drawIndirectCount                                  = true
	shaderInt8                                         = true
	descriptorIndexing                                 = true
	samplerFilterMinmax                                = true
	vulkanMemoryModel                                  = true
	vulkanMemoryModelDeviceScope                       = true
	vulkanMemoryModelAvailabilityVisibilityChains      = true
	shaderOutputViewportIndex                          = true
	shaderOutputLayer                                  = true
	subgroupBroadcastDynamicId                         = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
	ycbcrImageArrays = true
Launch before crash
(base) sam@spectrum:~/Downloads/1.2.176.1/x86_64$ /media/sam/data/datasets/omniverse/pkg/create-2021.1.1/_build/linux-x86_64/release/omni.create.launcher.sh
[Info] [carb] Logging to file: /home/sam/.nvidia-omniverse/logs/Kit/omni.create.launcher/100.3/kit_20210617_095105.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
[0.018s] Loading user config located at: '/media/sam/data/datasets/omniverse/data/Kit/omni.create.launcher/100.3/user.config.json'
[0.101s] [ext: omni.create.app.launcher-1.0.0] startup
[0.113s] [ext: omni.create.launcher-2021.1.0] startup
[0.114s] app started
[0.114s] [ext: omni.create.launcher-2021.1.0] shutdown
[0.114s] [ext: omni.create.app.launcher-1.0.0] shutdown
[Info] [carb] Logging to file: /home/sam/.nvidia-omniverse/logs/Kit/Create/2021.1/kit_20210617_095106.log
[0.015s] Loading user config located at: '/media/sam/data/datasets/omniverse/data/Kit/Create/2021.1/user.config.json'
(base) sam@spectrum:~/Downloads/1.2.176.1/x86_64$ [0.100s] [ext: omni.assets-0.0.0] startup
[0.101s] [ext: omni.kit.window.splash-0.0.0] startup
[0.138s] [ext: omni.kit.async_engine-0.0.0] startup
[0.149s] [ext: omni.kit.agent-0.1.0] startup
[0.151s] [ext: omni.kit.splash-0.1.0] startup
[0.161s] [ext: omni.kit.loop-default-0.1.0] startup
[0.161s] [ext: omni.kit.test-0.0.0] startup
[0.174s] [ext: omni.kit.pipapi-0.0.0] startup
[0.178s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.182s] [ext: omni.kit.commands-0.0.0] startup
[0.186s] [ext: carb.audio-0.1.0] startup
[0.206s] [ext: omni.timeline-0.0.0] startup
[0.209s] [ext: omni.services.facilities.base-1.0.0] startup
[0.212s] [ext: omni.usd-0.1.8] startup
[0.342s] [ext: omni.services.core-1.1.0] startup
[0.471s] [ext: omni.client-0.1.0] startup
[0.479s] [ext: omni.services.registry-1.0.0] startup
[0.632s] [ext: omni.services.transport.server.base-1.0.0] startup
[0.634s] [ext: omni.services.transport.server.http-1.0.0] startup
[0.725s] [ext: omni.stats-0.0.0] startup
[0.727s] [ext: omni.appwindow-0.1.0-rc1] startup
[0.744s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 460.67 | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | GeForce RTX 2080 Ti              | Yes    |     | 11510   MB | 10de      | 0          |
|     |                                  |        |     |            | 1e07      | 89f14a61.. |
| OS: Linux spectrum, Version: 5.8.0-48-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12009000 (1.20.9.0)
| Processor: AMD Ryzen 9 3950X 16-Core Processor             | Cores: Unknown | Logical: 32
| Total Memory (MB): 64331 | Free Memory: 51716
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[1.636s] [ext: omni.ui-2.1.2] startup
[1.648s] [ext: omni.kit.mainwindow-0.0.0] startup
[1.652s] [ext: omni.kit.uiapp-0.0.0] startup
[1.653s] [ext: omni.kit.tagging-0.1.0] startup
[1.708s] [ext: omni.kit.widget.path_field-2.0.0] startup
[1.712s] [ext: omni.kit.search_core-1.0.0] startup
[1.715s] [ext: omni.services.transport.client.base-1.0.0] startup
[1.718s] [ext: omni.kit.widget.browser_bar-2.0.0] startup
[1.721s] [ext: omni.kit.window.popup_dialog-1.0.0] startup
[1.725s] [ext: omni.kit.widget.filebrowser-2.0.4] startup
[1.731s] [ext: omni.services.client-0.2.0] startup
[1.746s] [ext: omni.kit.stage_templates-1.0.3] startup
[1.753s] [ext: omni.kit.window.filepicker-2.0.3] startup
[1.784s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[1.839s] [ext: omni.kit.window.file-1.0.1] startup
[1.889s] [ext: omni.kit.thumbnails.images-0.1.0] startup
[1.893s] [ext: omni.kit.material.library-1.0.3] startup
[1.901s] [ext: omni.debugdraw-0.0.0] startup
[1.904s] [ext: omni.usdphysics-1.1.0] startup
[1.906s] [ext: omni.kit.window.content_browser-2.0.3] startup
[1.932s] [ext: omni.kvdb-0.0.0] startup
[1.935s] [ext: omni.kit.context_menu-1.0.5] startup
[1.939s] [ext: omni.hydra.rtx-0.1.0] startup
[1.942s] [ext: omni.localcache-0.0.0] startup
[1.946s] [ext: omni.kit.widget.stage-2.3.3] startup
[1.961s] [ext: omni.renderer-rtx-0.0.0] startup
[1.961s] [ext: omni.kit.widget.graph-1.0.2] startup
[1.969s] [ext: omni.kit.window.viewport-0.0.0] startup
2021-06-17 00:21:08 [1,967ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] '/media/sam/data/datasets/omniverse/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
[2.739s] [ext: omni.convexdecomposition-1.1.0] startup
[2.743s] [ext: omni.kit.window.property-0.0.0] startup
[2.748s] [ext: omni.physx-1.1.0-5.1] startup
[2.812s] [ext: omni.kit.property.usd-3.4.2] startup
[2.863s] [ext: omni.physx.ui-1.1.0-5.1] startup
[2.870s] [ext: omni.kit.widget.layers-0.3.1] startup
[2.882s] [ext: omni.kit.window.extensions-1.0.2] startup
[2.889s] [ext: omni.kit.property.material-1.4.1] startup
[2.894s] [ext: omni.kit.window.toolbar-0.0.0] startup
[2.903s] [ext: omni.kit.window.script_editor-1.5.0] startup
[2.903s] [ext: omni.kit.property.physx-0.1.0] startup
[2.953s] [ext: omni.kit.property.layer-1.0.1] startup
[2.959s] [ext: omni.kit.asset_converter-1.0.1] startup
[2.971s] [ext: omni.physx.cct-1.1.0-5.1] startup
[2.979s] [ext: omni.physx.vehicle-1.1.0-5.1] startup
[2.991s] [ext: omni.kit.property.audio-1.0.3] startup
[3.001s] [ext: omni.kit.tool.asset_importer-2.0.0] startup
[3.012s] [ext: omni.physx.bundle-1.1.0-5.1] startup
[3.012s] [ext: omni.kit.usd_undo-0.0.0] startup
[3.017s] [ext: omni.kit.property.geometry-1.0.6] startup
[3.023s] [ext: omni.kit.property.transform-1.0.2] startup
[3.029s] [ext: omni.kit.property.light-1.0.2] startup
[3.035s] [ext: omni.kit.property.camera-1.0.2] startup
[3.040s] [ext: omni.kit.window.provide_feedback-0.1.0] startup
[3.046s] [ext: omni.kit.property.bundle-1.2.2] startup
[3.052s] [ext: omni.videoencoding-0.0.0] startup
[3.054s] [ext: omni.kit.renderer.capture-0.0.0] startup
[3.061s] [ext: omni.rtx.window.settings-0.6.0] startup
[3.068s] [ext: omni.kit.capture-0.3.2] startup
[3.075s] [ext: omni.rtx.settings.core-0.5.4] startup
[3.089s] [ext: omni.kit.menu.utils-1.0.1] startup
[3.096s] [ext: omni.kit.widget.imageview-1.0.0] startup
[3.102s] [ext: omni.kit.window.movie_maker-0.3.1] startup
[3.111s] [ext: omni.kit.menu.file-1.0.1] startup
[3.117s] [ext: omni.kit.window.imageviewer-1.0.3] startup
[3.125s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[3.134s] [ext: omni.kit.thumbnails.usd-0.3.0] startup
[3.145s] [ext: omni.kit.window.console-0.0.0] startup
[3.147s] [ext: omni.kit.property.tagging-1.0.1] startup
[3.156s] [ext: omni.kit.window.profiler-1.0.0] startup
[3.163s] [ext: omni.kit.tool.collect-2.0.0] startup
[3.178s] [ext: omni.kit.window.status_bar-0.0.0] startup
[3.179s] [ext: omni.kit.window.preferences-1.0.1] startup
[3.227s] [ext: omni.kit.window.about-0.2.1] startup
[3.234s] [ext: omni.kit.widget.stage_icons-1.0.0] startup
[3.241s] [ext: omni.kit.widget.live-0.0.0] startup
[3.243s] [ext: omni.kit.tool.asset_exporter-1.0.2] startup
[3.251s] [ext: omni.kit.search.service-0.1.0] startup
[3.261s] [ext: omni.kit.window.title-1.0.0] startup
[3.268s] [ext: omni.kit.window.stage-2.3.2] startup
[3.277s] [ext: omni.kit.selection-0.0.0] startup
[3.284s] [ext: omni.kit.filebrowser_column.tags-1.0.0] startup
[3.292s] [ext: omni.kit.window.usd_paths-1.0.3] startup
[3.300s] [ext: omni.kit.window.stats-0.0.0] startup
[3.308s] [ext: omni.create.app.setup-0.0.0] startup
[3.314s] [ext: omni.kit.quicklayout-1.0.0] startup
[3.321s] [ext: omni.create.next-2021.1.0] startup
[3.321s] app started
@saleskqr1v -
Sorry you are having issues with Create. Can try starting Create with this command
~/.local/share/ov/pkg/create-2021.1.1/omni.create.singlegpu.sh
Please inform me if it still crashes or if Create now starts without issues.
Same problem here. The provided command results in a segmentation fault.
[Info] [carb] Logging to file: /home/curtis/.nvidia-omniverse/logs/Kit/Create/2021.1/kit_20210712_105503.log
[0.020s] Loading user config located at: '/home/curtis/.local/share/ov/data/Kit/Create/2021.1/user.config.json'
[0.160s] [ext: omni.assets-0.0.0] startup
[0.163s] [ext: omni.kit.window.splash-0.0.0] startup
[0.190s] [ext: omni.kit.async_engine-0.0.0] startup
[0.200s] [ext: omni.kit.agent-0.1.0] startup
[0.201s] [ext: omni.kit.splash-0.1.0] startup
[0.208s] [ext: omni.kit.loop-default-0.1.0] startup
[0.209s] [ext: omni.kit.test-0.0.0] startup
[0.218s] [ext: omni.kit.pipapi-0.0.0] startup
[0.222s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.228s] [ext: omni.services.facilities.base-1.0.0] startup
[0.230s] [ext: omni.services.core-1.1.0] startup
[0.335s] [ext: omni.services.transport.server.base-1.0.0] startup
[0.337s] [ext: omni.services.transport.server.http-1.0.0] startup
[0.414s] [ext: omni.timeline-0.0.0] startup
[0.415s] [ext: omni.kit.commands-0.0.0] startup
[0.419s] [ext: carb.audio-0.1.0] startup
[0.420s] [ext: omni.usd-0.1.8] startup
[0.751s] [ext: omni.client-0.1.0] startup
[0.767s] [ext: omni.services.registry-1.0.0] startup
[0.907s] [ext: omni.stats-0.0.0] startup
[0.909s] [ext: omni.appwindow-0.1.0-rc1] startup
[0.916s] [ext: omni.ui-2.1.2] startup
[0.931s] [ext: omni.kit.tagging-0.1.0] startup
[0.981s] [ext: omni.kit.stage_templates-1.0.3] startup
[0.985s] [ext: omni.hydra.iray-0.1.0] startup
[0.989s] [ext: omni.ansel-0.0.0] startup
2021-07-12 16:55:04 [970ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.0.0] Failed to load plugins, folder doesn't exist: '/home/curtis/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.ansel/bin'.
2021-07-12 16:55:04 [970ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.0.0] '/home/curtis/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.ansel/bin/*.plugin' in '[[native.plugin]]' was not found.
[0.991s] [ext: omni.kit.search_core-1.0.0] startup
[0.994s] [ext: omni.renderer-rtx-0.0.0] startup
[0.996s] [ext: omni.hydra.rtx-0.1.0] startup
[0.999s] [ext: omni.kit.widget.path_field-2.0.0] startup
[1.003s] [ext: omni.kit.editor-full-0.0.0] startup
2021-07-12 16:55:04 [1,016ms] [Warning] [omni.ext.plugin] [ext: omni.kit.editor-full-0.0.0] '/home/curtis/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | GeForce RTX 3080                 | Yes    |     | 10486   MB | 10de      | 0          |
|     |                                  |        |     |            | 2206      | 95273615.. |
| OS: Linux RadLab-14, Version: 5.8.0-59-generic
| Processor: AMD Ryzen 9 5900 12-Core Processor              | Cores: Unknown | Logical: 24
| Total Memory (MB): 32100 | Free Memory: 26581
X Error of failed request:  GLXBadFBConfig
  Major opcode of failed request:  151 (GLX)
  Minor opcode of failed request:  34 ()
  Serial number of failed request:  227
  Current serial number in output stream:  225
2021-07-12 16:55:05 [2,155ms] [Warning] [carb.audio.context] 1 contexts were leaked
2021-07-12 16:55:05 [2,267ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-07-12 16:55:05 [2,268ms] [Fatal] [carb.crashreporter-breakpad.plugin] libxcb.so.1!xcb_poll_for_event
2021-07-12 16:55:05 [2,269ms] [Fatal] [carb.crashreporter-breakpad.plugin] libX11.so.6!_XFreeX11XCBStructure
I have the same problem but I have a different Driver Version and GeForce RTX 2080Ti. Here is the output when using the command:
2021-07-20 08:08:53 [881ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.0.0] Failed to load plugins, folder doesn't exist:/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.ansel/bin'.
2021-07-20 08:08:53 [881ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.0.0] '~/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.ansel/bin/*.plugin' in '[[native.plugin]]' was not found.
[0.893s] [ext: omni.kit.stage_templates-1.0.3] startup
[0.897s] [ext: omni.kit.widget.filebrowser-2.0.4] startup
[0.904s] [ext: omni.kit.editor-full-0.0.0] startup
2021-07-20 08:08:53 [942ms] [Warning] [omni.ext.plugin] [ext: omni.kit.editor-full-0.0.0] '~/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
2021-07-20 08:08:53 [1,186ms] [Warning] [carb.graphics-vulkan.plugin] Failed to initialize NGX. Optional DLSS feature will be disabled
| Driver Version: 460.73 | Graphics API: Vulkan
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 1e04      | 595b8d53.. |
| OS: Linux <hostname>, Version: 4.19.0-16-amd64
| XServer Vendor: The X.Org Foundation, XServer Version: 12004000 (1.20.4.0)
| Processor: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 64341 | Free Memory: 41679
| Total Page/Swap (MB): 8191 | Free Page/Swap: 8191
2021-07-20 08:08:54 [1,848ms] [Warning] [rtx.optixdenoising.plugin] optixInit() failed. Optix Error: OPTIX_ERROR_LIBRARY_NOT_FOUND.
Library not found
2021-07-20 08:08:54 [1,848ms] [Warning] [rtx.optixdenoising.plugin] Failed to initialize OptixDenoiserContext.
2021-07-20 08:08:54 [1,963ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(unsigned int, int, carb::cpp20::latch*), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2021-07-20 08:08:54 [1,972ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
zsh: segmentation fault  ~/.local/share/ov/pkg/create-2021.1.1/omni.create.singlegpu.sh
$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
$ readelf -a /usr/lib/x86_64-linux-gnu/libpthread.so
ELF Header:
  Magic:   7f 45 4c 46 02 01 01 03 00 00 00 00 00 00 00 00
  Class:                             ELF64
  Data:                              2's complement, little endian
  Version:                           1 (current)
  OS/ABI:                            UNIX - GNU
  ABI Version:                       0
  Type:                              DYN (Shared object file)
  Machine:                           Advanced Micro Devices X86-64
  Version:                           0x1
  Entry point address:               0x6c40
  Start of program headers:          64 (bytes into file)
  Start of section headers:          144728 (bytes into file)
  Flags:                             0x0
  Size of this header:               64 (bytes)
  Size of program headers:           56 (bytes)
  Number of program headers:         11
  Size of section headers:           64 (bytes)
  Number of section headers:         35
  Section header string table index: 34
Key to Flags:
  W (write), A (alloc), X (execute), M (merge), S (strings), I (info),
  L (link order), O (extra OS processing required), G (group), T (TLS),
  C (compressed), x (unknown), o (OS specific), E (exclude),
  l (large), p (processor specific)
There are no section groups in this file.
 Section to Segment mapping:
  Segment Sections...
   00
   01     .interp
   02     .note.gnu.build-id .note.ABI-tag .gnu.hash .dynsym .dynstr .gnu.version .gnu.version_d .gnu.version_r .rela.dyn .rela.plt
   03     .init .plt .plt.got .text .fini
   04     .rodata .interp .eh_frame_hdr .eh_frame .hash
   05     .init_array .fini_array .data.rel.ro .dynamic .got .got.plt .data .bss
   06     .dynamic
   07     .note.gnu.build-id .note.ABI-tag
   08     .eh_frame_hdr
   09
   10     .init_array .fini_array .data.rel.ro .dynamic .got
The decoding of unwind sections for machine type Advanced Micro Devices X86-64 is not currently supported.
Symbol table '.dynsym' contains 375 entries:
   Num:    Value          Size Type    Bind   Vis      Ndx Name
     0: 0000000000000000     0 NOTYPE  LOCAL  DEFAULT  UND
     1: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_siglongjmp@GLIBC_PRIVATE (13)
     2: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __tsearch@GLIBC_PRIVATE (13)
     3: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __clone@GLIBC_2.2.5 (14)
     4: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND free@GLIBC_2.2.5 (14)
     5: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __getrlimit@GLIBC_PRIVATE (13)
     6: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND abort@GLIBC_2.2.5 (14)
     7: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND unlink@GLIBC_2.2.5 (14)
     8: 0000000000000000     0 NOTYPE  WEAK   DEFAULT  UND _ITM_deregisterTMCloneTab
     9: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _exit@GLIBC_2.2.5 (14)
    10: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __sched_getscheduler@GLIBC_2.2.5 (14)
    11: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_dlclose@GLIBC_PRIVATE (13)
    12: 0000000000000000     0 TLS     GLOBAL DEFAULT  UND errno@GLIBC_PRIVATE (13)
    13: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_fatal@GLIBC_PRIVATE (13)
    14: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __statfs@GLIBC_2.2.5 (14)
    15: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __sched_get_priority_max@GLIBC_2.2.5 (14)
    16: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __mempcpy@GLIBC_2.2.5 (14)
    17: 0000000000000000     0 TLS     GLOBAL DEFAULT  UND __resp@GLIBC_PRIVATE (13)
    18: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND getpid@GLIBC_2.2.5 (14)
    19: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __sigtimedwait@GLIBC_PRIVATE (13)
    20: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __mmap@GLIBC_PRIVATE (13)
    21: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND fclose@GLIBC_2.2.5 (14)
    22: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND strlen@GLIBC_2.2.5 (14)
    23: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __getpid@GLIBC_2.2.5 (14)
    24: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __stack_chk_fail@GLIBC_2.4 (15)
    25: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_system@GLIBC_PRIVATE (13)
    26: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND getuid@GLIBC_2.2.5 (14)
    27: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND mmap@GLIBC_2.2.5 (14)
    28: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND strchr@GLIBC_2.2.5 (14)
    29: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __munmap@GLIBC_PRIVATE (13)
    30: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __gettimeofday@GLIBC_2.2.5 (14)
    31: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __assert_fail@GLIBC_2.2.5 (14)
    32: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND memset@GLIBC_2.2.5 (14)
    33: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_fork@GLIBC_PRIVATE (13)
    34: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _IO_enable_locks@GLIBC_PRIVATE (13)
    35: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __write_nocancel@GLIBC_PRIVATE (13)
    36: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __register_atfork@GLIBC_2.3.2 (16)
    37: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND sched_yield@GLIBC_2.2.5 (14)
    38: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _dl_deallocate_tls@GLIBC_PRIVATE (17)
    39: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __call_tls_dtors@GLIBC_PRIVATE (13)
    40: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __sched_getparam@GLIBC_2.2.5 (14)
    41: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _setjmp@GLIBC_2.2.5 (14)
    42: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND calloc@GLIBC_2.2.5 (14)
    43: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __getdelim@GLIBC_2.2.5 (14)
    44: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __getmntent_r@GLIBC_2.2.5 (14)
    45: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __fxstat64@GLIBC_2.2.5 (14)
    46: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  UND __libc_stack_end@GLIBC_2.2.5 (18)
    47: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND strcmp@GLIBC_2.2.5 (14)
    48: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_thread_freeres@GLIBC_PRIVATE (13)
    49: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __endmntent@GLIBC_2.2.5 (14)
    50: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND memcpy@GLIBC_2.14 (19)
    51: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __mprotect@GLIBC_PRIVATE (13)
    52: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  UND _rtld_global_ro@GLIBC_PRIVATE (17)
    53: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __clock_gettime@GLIBC_PRIVATE (13)
    54: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_fcntl64@GLIBC_PRIVATE (13)
    55: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND prctl@GLIBC_2.2.5 (14)
    56: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __nanosleep_nocancel@GLIBC_PRIVATE (13)
    57: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_current_sigrtmax_p@GLIBC_PRIVATE (13)
    58: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __tdelete@GLIBC_PRIVATE (13)
    59: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __sched_setscheduler@GLIBC_2.2.5 (14)
    60: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_dlopen_mode@GLIBC_PRIVATE (13)
    61: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __getpagesize@GLIBC_2.2.5 (14)
    62: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND malloc@GLIBC_2.2.5 (14)
    63: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __read_nocancel@GLIBC_PRIVATE (13)
    64: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _dl_make_stack_executable@GLIBC_PRIVATE (17)
    65: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_pthread_init@GLIBC_PRIVATE (13)
    66: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __ctype_init@GLIBC_PRIVATE (13)
    67: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND sscanf@GLIBC_2.2.5 (14)
    68: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND realloc@GLIBC_2.2.5 (14)
    69: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_dlsym@GLIBC_PRIVATE (13)
    70: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __tfind@GLIBC_PRIVATE (13)
    71: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND munmap@GLIBC_2.2.5 (14)
    72: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __open64_nocancel@GLIBC_PRIVATE (13)
    73: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_current_sigrtmin_p@GLIBC_PRIVATE (13)
    74: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_vfork@GLIBC_PRIVATE (13)
    75: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __madvise@GLIBC_PRIVATE (13)
    76: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __pause_nocancel@GLIBC_PRIVATE (13)
    77: 0000000000000000     0 TLS     GLOBAL DEFAULT  UND __h_errno@GLIBC_PRIVATE (13)
    78: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND fopen@GLIBC_2.2.5 (14)
    79: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __mktemp@GLIBC_PRIVATE (13)
    80: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __twalk@GLIBC_PRIVATE (13)
    81: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _dl_allocate_tls@GLIBC_PRIVATE (17)
    82: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __setmntent@GLIBC_2.2.5 (14)
    83: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __tunable_get_val@GLIBC_PRIVATE (17)
    84: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND sched_setparam@GLIBC_2.2.5 (14)
    85: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _dl_get_tls_static_info@GLIBC_PRIVATE (17)
    86: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND sprintf@GLIBC_2.2.5 (14)
    87: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND link@GLIBC_2.2.5 (14)
    88: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND exit@GLIBC_2.2.5 (14)
    89: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND getrlimit@GLIBC_2.2.5 (14)
    90: 0000000000000000     0 NOTYPE  WEAK   DEFAULT  UND _ITM_registerTMCloneTable
    91: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_alloca_cutoff@GLIBC_PRIVATE (13)
    92: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND _dl_allocate_tls_init@GLIBC_PRIVATE (17)
    93: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __close_nocancel@GLIBC_PRIVATE (13)
    94: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  UND _rtld_global@GLIBC_PRIVATE (17)
    95: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_allocate_rtsig_pri@GLIBC_PRIVATE (13)
    96: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __libc_longjmp@GLIBC_PRIVATE (13)
    97: 0000000000000000     0 FUNC    WEAK   DEFAULT  UND __cxa_finalize@GLIBC_2.2.5 (14)
    98: 0000000000000000     0 FUNC    GLOBAL DEFAULT  UND __sched_get_priority_min@GLIBC_2.2.5 (14)
    99: 000000000000c920     3 FUNC    GLOBAL DEFAULT   14 __pthread_mutexattr_destr@@GLIBC_2.2.5
   100: 0000000000011bb0   133 FUNC    WEAK   DEFAULT   14 nanosleep@@GLIBC_2.2.5
   101: 0000000000011620   149 FUNC    WEAK   DEFAULT   14 accept@@GLIBC_2.2.5
   102: 0000000000009a60   103 FUNC    GLOBAL DEFAULT   14 pthread_attr_getstacksize@@GLIBC_2.2.5
   103: 0000000000013f40    87 FUNC    GLOBAL DEFAULT   14 mtx_trylock@@GLIBC_2.28
   104: 000000000000cee0   975 FUNC    GLOBAL DEFAULT   14 __pthread_rwlock_wrlock@@GLIBC_2.2.5
   105: 000000000000fa60    38 FUNC    GLOBAL DEFAULT   14 pthread_getcpuclockid@@GLIBC_2.2.5
   106: 000000000000f390   238 FUNC    GLOBAL DEFAULT   14 __pthread_setspecific@@GLIBC_2.2.5
   107: 0000000000012960    12 FUNC    GLOBAL DEFAULT   14 __res_state@@GLIBC_2.2.5
   108: 0000000000012c00    36 FUNC    WEAK   DEFAULT   14 pthread_mutex_consistent_@@GLIBC_2.4
   109: 0000000000012380   153 FUNC    WEAK   DEFAULT   14 recvmsg@@GLIBC_2.2.5
   110: 0000000000009260    12 FUNC    WEAK   DEFAULT   14 pthread_join@@GLIBC_2.2.5
   111: 0000000000013ee0    87 FUNC    GLOBAL DEFAULT   14 mtx_timedlock@@GLIBC_2.28
   112: 0000000000010d00    89 FUNC    GLOBAL DEFAULT   14 __pthread_register_cancel@@GLIBC_2.3.3
   113: 000000000000ef40    62 FUNC    WEAK   DEFAULT   14 pthread_barrier_init@@GLIBC_2.2.5
   114: 0000000000010d60   116 FUNC    GLOBAL DEFAULT   14 __pthread_unregister_canc@@GLIBC_2.3.3
   115: 0000000000011d60   117 FUNC    WEAK   DEFAULT   14 pause@@GLIBC_2.2.5
   116: 0000000000010120  1233 FUNC    GLOBAL DEFAULT   14 sem_open@@GLIBC_2.2.5
   117: 00000000000126e0    49 FUNC    WEAK   DEFAULT   14 funlockfile@@GLIBC_2.2.5
   118: 0000000000014010    87 FUNC    GLOBAL DEFAULT   14 cnd_broadcast@@GLIBC_2.28
   119: 000000000000f220     3 FUNC    GLOBAL DEFAULT   14 pthread_barrierattr_destr@@GLIBC_2.2.5
   120: 0000000000009920     7 FUNC    GLOBAL DEFAULT   14 pthread_attr_setguardsize@@GLIBC_2.2.5
   121: 000000000000f260    86 FUNC    GLOBAL DEFAULT   14 __pthread_key_create@@GLIBC_2.2.5
   122: 00000000000119a0   185 FUNC    WEAK   DEFAULT   14 sendto@@GLIBC_2.2.5
   123: 000000000000d6d0   166 FUNC    GLOBAL DEFAULT   14 pthread_rwlock_tryrdlock@@GLIBC_2.2.5
   124: 00000000000113d0     5 FUNC    GLOBAL DEFAULT   14 __fork@GLIBC_2.2.5
   125: 000000000000c9f0     3 FUNC    GLOBAL DEFAULT   14 __pthread_rwlock_destroy@@GLIBC_2.2.5
   126: 00000000000139d0   450 FUNC    GLOBAL DEFAULT   14 pthread_setattr_default_n@@GLIBC_2.18
   127: 000000000000ef40    62 FUNC    GLOBAL DEFAULT   14 __pthread_barrier_init@@GLIBC_PRIVATE
   128: 0000000000012680    87 FUNC    GLOBAL DEFAULT   14 _IO_ftrylockfile@@GLIBC_2.2.5
   129: 0000000000012a50    13 FUNC    GLOBAL DEFAULT   14 pthread_setaffinity_np@GLIBC_2.3.3
   130: 0000000000012a10    55 FUNC    GLOBAL DEFAULT   14 pthread_setaffinity_np@@GLIBC_2.3.4
   131: 0000000000013da0     5 FUNC    GLOBAL DEFAULT   14 mtx_destroy@@GLIBC_2.28
   132: 000000000000f5d0   228 FUNC    GLOBAL DEFAULT   14 pthread_sigqueue@@GLIBC_2.11
   133: 000000000000ecd0   139 FUNC    GLOBAL DEFAULT   14 pthread_cond_timedwait@GLIBC_2.2.5
   134: 000000000000e100  1069 FUNC    GLOBAL DEFAULT   14 pthread_cond_timedwait@@GLIBC_2.3.2
   135: 0000000000009510   300 FUNC    GLOBAL DEFAULT   14 pthread_getschedparam@@GLIBC_2.2.5
   136: 0000000000009290    10 FUNC    WEAK   DEFAULT   14 pthread_timedjoin_np@@GLIBC_2.3.3
   137: 0000000000009e90   459 FUNC    WEAK   DEFAULT   14 pthread_mutex_init@@GLIBC_2.2.5
   138: 00000000000116c0   149 FUNC    WEAK   DEFAULT   14 connect@@GLIBC_2.2.5
   139: 000000000000da10     7 FUNC    GLOBAL DEFAULT   14 pthread_rwlockattr_getkin@@GLIBC_2.2.5
   140: 000000000000bfa0    10 FUNC    GLOBAL DEFAULT   14 __pthread_mutex_unlock@@GLIBC_2.2.5
   141: 0000000000013d00    12 FUNC    GLOBAL DEFAULT   14 thrd_exit@@GLIBC_2.28
   142: 000000000000f480   228 FUNC    GLOBAL DEFAULT   14 pthread_sigmask@@GLIBC_2.2.5
   143: 0000000000010e30    81 FUNC    GLOBAL DEFAULT   14 _pthread_cleanup_push_def@@GLIBC_2.2.5
   144: 000000000000ec30    19 FUNC    GLOBAL DEFAULT   14 pthread_cond_destroy@GLIBC_2.2.5
   145: 000000000000da70   153 FUNC    GLOBAL DEFAULT   14 pthread_cond_destroy@@GLIBC_2.3.2
   146: 0000000000013780   274 FUNC    GLOBAL DEFAULT   14 pthread_setname_np@@GLIBC_2.12
   147: 0000000000012c00    36 FUNC    GLOBAL DEFAULT   14 pthread_mutex_consistent@@GLIBC_2.12
   148: 000000000000fa50    12 FUNC    GLOBAL DEFAULT   14 pthread_atfork@GLIBC_2.2.5
   149: 000000000000f010   512 FUNC    WEAK   DEFAULT   14 pthread_barrier_wait@@GLIBC_2.2.5
   150: 0000000000012620    83 FUNC    WEAK   DEFAULT   14 flockfile@@GLIBC_2.2.5
   151: 000000000000c970    12 FUNC    WEAK   DEFAULT   14 pthread_mutexattr_getkind@@GLIBC_2.2.5
   152: 000000000000c980    34 FUNC    WEAK   DEFAULT   14 pthread_mutexattr_settype@@GLIBC_2.2.5
   153: 0000000000009a50    11 FUNC    GLOBAL DEFAULT   14 pthread_attr_setstackaddr@@GLIBC_2.2.5
   154: 0000000000014140    87 FUNC    GLOBAL DEFAULT   14 cnd_timedwait@@GLIBC_2.28
   155: 000000000000ef10    20 FUNC    GLOBAL DEFAULT   14 pthread_spin_trylock@@GLIBC_2.2.5
   156: 000000000000d2b0  1047 FUNC    GLOBAL DEFAULT   14 pthread_rwlock_timedwrloc@@GLIBC_2.2.5
   157: 0000000000013ca0    87 FUNC    GLOBAL DEFAULT   14 thrd_detach@@GLIBC_2.28
   158: 0000000000012940    17 FUNC    GLOBAL DEFAULT   14 __h_errno_location@@GLIBC_2.2.5
   159: 0000000000009770   257 FUNC    GLOBAL DEFAULT   14 pthread_setschedprio@@GLIBC_2.3.4
   160: 000000000000a6c0   660 FUNC    GLOBAL DEFAULT   14 __pthread_mutex_lock@@GLIBC_2.2.5
   161: 0000000000011500   153 FUNC    WEAK   DEFAULT   14 __read@@GLIBC_2.2.5
   162: 000000000000d7e0   475 FUNC    WEAK   DEFAULT   14 pthread_rwlock_unlock@@GLIBC_2.2.5
   163: 0000000000011460   153 FUNC    WEAK   DEFAULT   14 __write@@GLIBC_2.2.5
   164: 000000000000fe10     3 FUNC    GLOBAL DEFAULT   14 sem_destroy@@GLIBC_2.2.5
   165: 0000000000010cc0    36 FUNC    GLOBAL DEFAULT   14 __pthread_register_cancel@@GLIBC_2.3.3
   166: 00000000000129a0     1 FUNC    GLOBAL DEFAULT   14 pthread_kill_other_thread@GLIBC_2.2.5
   167: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.4
   168: 0000000000010e00    33 FUNC    GLOBAL DEFAULT   14 _pthread_cleanup_pop@@GLIBC_2.2.5
   169: 00000000000099b0    26 FUNC    GLOBAL DEFAULT   14 pthread_attr_setschedpoli@@GLIBC_2.2.5
   170: 000000000000f010   512 FUNC    GLOBAL DEFAULT   14 __pthread_barrier_wait@@GLIBC_PRIVATE
   171: 000000000000c9b0    58 FUNC    GLOBAL DEFAULT   14 __pthread_rwlock_init@@GLIBC_2.2.5
   172: 0000000000011de0   161 FUNC    WEAK   DEFAULT   14 pread64@@GLIBC_2.2.5
   173: 0000000000014260     5 FUNC    GLOBAL DEFAULT   14 tss_delete@@GLIBC_2.28
   174: 0000000000012f00    13 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_getprot@@GLIBC_2.4
   175: 000000000000f230     7 FUNC    GLOBAL DEFAULT   14 pthread_barrierattr_getps@@GLIBC_2.3.3
   176: 0000000000012b30   119 FUNC    GLOBAL DEFAULT   14 pthread_attr_setaffinity_@@GLIBC_2.3.4
   177: 0000000000012bb0    13 FUNC    GLOBAL DEFAULT   14 pthread_attr_setaffinity_@GLIBC_2.3.3
   178: 0000000000011ae0    36 FUNC    WEAK   DEFAULT   14 __lseek@@GLIBC_2.2.5
   179: 000000000000eef0    25 FUNC    GLOBAL DEFAULT   14 pthread_spin_lock@@GLIBC_2.2.5
   180: 00000000000115a0   125 FUNC    WEAK   DEFAULT   14 close@@GLIBC_2.2.5
   181: 0000000000012bd0    46 FUNC    WEAK   DEFAULT   14 pthread_mutexattr_setrobu@@GLIBC_2.4
   182: 000000000000eee0     3 FUNC    GLOBAL DEFAULT   14 pthread_spin_destroy@@GLIBC_2.2.5
   183: 00000000000113d0     5 FUNC    GLOBAL DEFAULT   14 fork@GLIBC_2.2.5
   184: 00000000000094f0    22 FUNC    GLOBAL DEFAULT   14 pthread_setconcurrency@@GLIBC_2.2.5
   185: 000000000000f300   131 FUNC    GLOBAL DEFAULT   14 __pthread_getspecific@@GLIBC_2.2.5
   186: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.2.5
   187: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.2.6
   188: 000000000000c9f0     3 FUNC    GLOBAL DEFAULT   14 pthread_rwlock_destroy@@GLIBC_2.2.5
   189: 000000000000d780    89 FUNC    GLOBAL DEFAULT   14 pthread_rwlock_trywrlock@@GLIBC_2.2.5
   190: 0000000000014000     5 FUNC    GLOBAL DEFAULT   14 call_once@@GLIBC_2.28
   191: 000000000000f570    92 FUNC    GLOBAL DEFAULT   14 pthread_kill@@GLIBC_2.2.5
   192: 0000000000011ae0    36 FUNC    WEAK   DEFAULT   14 lseek64@@GLIBC_2.2.5
   193: 0000000000011c40   286 FUNC    GLOBAL DEFAULT   14 __open64@@GLIBC_2.2.5
   194: 0000000000011fe0   157 FUNC    WEAK   DEFAULT   14 __wait@@GLIBC_2.2.5
   195: 0000000000010e90   148 FUNC    GLOBAL DEFAULT   14 _pthread_cleanup_pop_rest@@GLIBC_2.2.5
   196: 0000000000013d10   140 FUNC    GLOBAL DEFAULT   14 thrd_join@@GLIBC_2.28
   197: 0000000000009b40   843 FUNC    GLOBAL DEFAULT   14 pthread_getattr_np@@GLIBC_2.2.5
   198: 000000000000e530   839 FUNC    GLOBAL DEFAULT   14 pthread_cond_signal@@GLIBC_2.3.2
   199: 000000000000ed60   115 FUNC    GLOBAL DEFAULT   14 pthread_cond_signal@GLIBC_2.2.5
   200: 000000000000c910     9 FUNC    GLOBAL DEFAULT   14 __pthread_mutexattr_init@@GLIBC_2.2.5
   201: 0000000000012bc0    13 FUNC    WEAK   DEFAULT   14 pthread_mutexattr_getrobu@@GLIBC_2.4
   202: 0000000000011400    85 FUNC    WEAK   DEFAULT   14 __fcntl@GLIBC_2.2.5
   203: 0000000000013c30   103 FUNC    GLOBAL DEFAULT   14 thrd_create@@GLIBC_2.28
   204: 000000000000c920     3 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_destroy@@GLIBC_2.2.5
   205: 0000000000011e90   161 FUNC    WEAK   DEFAULT   14 __pwrite64@@GLIBC_2.2.5
   206: 0000000000013ba0   130 FUNC    GLOBAL DEFAULT   14 pthread_getattr_default_n@@GLIBC_2.18
   207: 0000000000012420   153 FUNC    WEAK   DEFAULT   14 sendmsg@@GLIBC_2.2.5
   208: 00000000000140e0    87 FUNC    GLOBAL DEFAULT   14 cnd_signal@@GLIBC_2.28
   209: 000000000000d9c0    10 FUNC    GLOBAL DEFAULT   14 pthread_rwlockattr_init@@GLIBC_2.2.5
   210: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.3.2
   211: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.3.3
   212: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.3.4
   213: 00000000000113f0     8 IFUNC   GLOBAL DEFAULT   14 __vfork@GLIBC_2.2.5
   214: 000000000000d9e0     8 FUNC    GLOBAL DEFAULT   14 pthread_rwlockattr_getpsh@@GLIBC_2.2.5
   215: 000000000000ee70     3 FUNC    GLOBAL DEFAULT   14 pthread_condattr_destroy@@GLIBC_2.2.5
   216: 00000000000099a0     8 FUNC    GLOBAL DEFAULT   14 pthread_attr_getschedpoli@@GLIBC_2.2.5
   217: 000000000000f390   238 FUNC    WEAK   DEFAULT   14 pthread_setspecific@@GLIBC_2.2.5
   218: 000000000000ec10    27 FUNC    GLOBAL DEFAULT   14 pthread_cond_init@GLIBC_2.2.5
   219: 000000000000da40    41 FUNC    GLOBAL DEFAULT   14 pthread_cond_init@@GLIBC_2.3.2
   220: 0000000000011500   153 FUNC    WEAK   DEFAULT   14 read@@GLIBC_2.2.5
   221: 00000000000126e0    49 FUNC    GLOBAL DEFAULT   14 _IO_funlockfile@@GLIBC_2.2.5
   222: 0000000000009940    94 FUNC    GLOBAL DEFAULT   14 pthread_attr_setschedpara@@GLIBC_2.2.5
   223: 0000000000009ad0    23 FUNC    GLOBAL DEFAULT   14 pthread_attr_setstacksize@@GLIBC_2.2.5
   224: 0000000000014070     5 FUNC    GLOBAL DEFAULT   14 cnd_destroy@@GLIBC_2.28
   225: 0000000000010620   229 FUNC    GLOBAL DEFAULT   14 sem_close@@GLIBC_2.2.5
   226: 00000000000110c0     9 FUNC    GLOBAL DEFAULT   14 longjmp@GLIBC_2.2.5
   227: 0000000000013fa0    87 FUNC    GLOBAL DEFAULT   14 mtx_unlock@@GLIBC_2.28
   228: 000000000000c930    10 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_getpsha@@GLIBC_2.2.5
   229: 0000000000012080   149 FUNC    WEAK   DEFAULT   14 waitpid@@GLIBC_2.2.5
   230: 000000000000cc50   650 FUNC    GLOBAL DEFAULT   14 pthread_rwlock_timedrdloc@@GLIBC_2.2.5
   231: 0000000000011a60   125 FUNC    GLOBAL DEFAULT   14 fsync@@GLIBC_2.2.5
   232: 0000000000011c40   286 FUNC    WEAK   DEFAULT   14 open64@@GLIBC_2.2.5
   233: 0000000000011060    69 FUNC    GLOBAL DEFAULT   14 __pthread_unwind@@GLIBC_PRIVATE
   234: 0000000000012980     5 FUNC    GLOBAL DEFAULT   14 __libc_current_sigrtmax@@GLIBC_2.2.5
   235: 0000000000011e90   161 FUNC    WEAK   DEFAULT   14 pwrite64@@GLIBC_2.2.5
   236: 0000000000010c40   116 FUNC    GLOBAL DEFAULT   14 sem_post@@GLIBC_2.2.5
   237: 000000000000f210     9 FUNC    GLOBAL DEFAULT   14 pthread_barrierattr_init@@GLIBC_2.2.5
   238: 0000000000012610     5 FUNC    GLOBAL DEFAULT   14 system@GLIBC_2.2.5
   239: 000000000000d7e0   475 FUNC    GLOBAL DEFAULT   14 __pthread_rwlock_unlock@@GLIBC_2.2.5
   240: 000000000000f2c0    54 FUNC    WEAK   DEFAULT   14 pthread_key_delete@@GLIBC_2.2.5
   241: 00000000000094e0     7 FUNC    GLOBAL DEFAULT   14 pthread_getconcurrency@@GLIBC_2.2.5
   242: 000000000000c980    34 FUNC    WEAK   DEFAULT   14 pthread_mutexattr_setkind@@GLIBC_2.2.5
   243: 0000000000013db0   196 FUNC    GLOBAL DEFAULT   14 mtx_init@@GLIBC_2.28
   244: 000000000000ee90    30 FUNC    GLOBAL DEFAULT   14 pthread_condattr_setpshar@@GLIBC_2.2.5
   245: 000000000000fa30    21 FUNC    WEAK   DEFAULT   14 pthread_once@@GLIBC_2.2.5
   246: 00000000000099e0    41 FUNC    GLOBAL DEFAULT   14 pthread_attr_setinheritsc@@GLIBC_2.2.5
   247: 0000000000012fc0   123 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_setprio@@GLIBC_2.4
   248: 00000000000135a0    30 FUNC    GLOBAL DEFAULT   14 pthread_mutex_getprioceil@@GLIBC_2.4
   249: 0000000000009640   292 FUNC    GLOBAL DEFAULT   14 pthread_setschedparam@@GLIBC_2.2.5
   250: 0000000000011820   185 FUNC    WEAK   DEFAULT   14 recvfrom@@GLIBC_2.2.5
   251: 00000000000098d0    11 FUNC    GLOBAL DEFAULT   14 pthread_attr_getdetachsta@@GLIBC_2.2.5
   252: 0000000000012f10    38 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_setprot@@GLIBC_2.4
   253: 0000000000011460   153 FUNC    WEAK   DEFAULT   14 write@@GLIBC_2.2.5
   254: 00000000000124c0   323 FUNC    GLOBAL DEFAULT   14 raise@@GLIBC_2.2.5
   255: 0000000000009270    30 FUNC    GLOBAL DEFAULT   14 pthread_tryjoin_np@@GLIBC_2.3.3
   256: 000000000000ca00   587 FUNC    WEAK   DEFAULT   14 pthread_rwlock_rdlock@@GLIBC_2.2.5
   257: 000000000000de10   752 FUNC    GLOBAL DEFAULT   14 pthread_cond_wait@@GLIBC_2.3.2
   258: 000000000000ec50   113 FUNC    GLOBAL DEFAULT   14 pthread_cond_wait@GLIBC_2.2.5
   259: 000000000000b070  2667 FUNC    WEAK   DEFAULT   14 pthread_mutex_timedlock@@GLIBC_2.2.5
   260: 0000000000011fe0   157 FUNC    WEAK   DEFAULT   14 wait@@GLIBC_2.2.5
   261: 0000000000006be0    25 FUNC    GLOBAL DEFAULT   14 __pthread_get_minstack@@GLIBC_PRIVATE
   262: 0000000000012c30    25 FUNC    GLOBAL DEFAULT   14 __pthread_cleanup_routine@@GLIBC_2.3.3
   263: 0000000000012680    87 FUNC    WEAK   DEFAULT   14 ftrylockfile@@GLIBC_2.2.5
   264: 000000000000f240    22 FUNC    GLOBAL DEFAULT   14 pthread_barrierattr_setps@@GLIBC_2.2.5
   265: 0000000000011de0   161 FUNC    WEAK   DEFAULT   14 pread@@GLIBC_2.2.5
   266: 000000000000a6c0   660 FUNC    WEAK   DEFAULT   14 pthread_mutex_lock@@GLIBC_2.2.5
   267: 0000000000011760   177 FUNC    WEAK   DEFAULT   14 recv@@GLIBC_2.2.5
   268: 0000000000011ae0    36 FUNC    WEAK   DEFAULT   14 lseek@@GLIBC_2.2.5
   269: 0000000000009930     7 FUNC    GLOBAL DEFAULT   14 pthread_attr_getschedpara@@GLIBC_2.2.5
   270: 00000000000099d0    13 FUNC    GLOBAL DEFAULT   14 pthread_attr_getinheritsc@@GLIBC_2.2.5
   271: 000000000000a060    29 FUNC    WEAK   DEFAULT   14 pthread_mutex_destroy@@GLIBC_2.2.5
   272: 000000000000c910     9 FUNC    WEAK   DEFAULT   14 pthread_mutexattr_init@@GLIBC_2.2.5
   273: 0000000000012620    83 FUNC    GLOBAL DEFAULT   14 _IO_flockfile@@GLIBC_2.2.5
   274: 0000000000010de0    30 FUNC    GLOBAL DEFAULT   14 _pthread_cleanup_push@@GLIBC_2.2.5
   275: 000000000000fd60    64 FUNC    GLOBAL DEFAULT   14 __shm_directory@@GLIBC_PRIVATE
   276: 0000000000012910    44 FUNC    GLOBAL DEFAULT   14 __sigaction@@GLIBC_2.2.5
   277: 000000000000fb30    78 FUNC    GLOBAL DEFAULT   14 __pthread_clock_settime@@GLIBC_PRIVATE
   278: 0000000000011c40   286 FUNC    GLOBAL DEFAULT   14 __open@@GLIBC_2.2.5
   279: 000000000000d6d0   166 FUNC    GLOBAL DEFAULT   14 __pthread_rwlock_tryrdloc@@GLIBC_2.2.5
   280: 0000000000014630    17 FUNC    GLOBAL DEFAULT   14 __errno_location@@GLIBC_2.2.5
   281: 00000000000118e0   177 FUNC    WEAK   DEFAULT   14 __send@@GLIBC_2.2.5
   282: 000000000000c9b0    58 FUNC    GLOBAL DEFAULT   14 pthread_rwlock_init@@GLIBC_2.2.5
   283: 000000000000bfa0    10 FUNC    WEAK   DEFAULT   14 pthread_mutex_unlock@@GLIBC_2.2.5
   284: 00000000000094d0     5 FUNC    GLOBAL DEFAULT   14 pthread_yield@@GLIBC_2.2.5
   285: 0000000000010710   303 FUNC    GLOBAL DEFAULT   14 sem_unlink@@GLIBC_2.2.5
   286: 000000000000ee80    10 FUNC    GLOBAL DEFAULT   14 pthread_condattr_getpshar@@GLIBC_2.2.5
   287: 0000000000012f40   120 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_getprio@@GLIBC_2.4
   288: 0000000000011400    85 FUNC    WEAK   DEFAULT   14 fcntl@GLIBC_2.2.5
   289: 000000000000ef30     9 FUNC    GLOBAL DEFAULT   14 pthread_spin_unlock@@GLIBC_2.2.5
   290: 00000000000094b0    10 FUNC    GLOBAL DEFAULT   14 pthread_self@GLIBC_2.2.5
   291: 000000000000fa90   149 FUNC    GLOBAL DEFAULT   14 __pthread_clock_gettime@@GLIBC_PRIVATE
   292: 000000000000fdd0    52 FUNC    GLOBAL DEFAULT   14 sem_init@@GLIBC_2.2.5
   293: 000000000000f300   131 FUNC    WEAK   DEFAULT   14 pthread_getspecific@@GLIBC_2.2.5
   294: 000000000000ee60     9 FUNC    GLOBAL DEFAULT   14 pthread_condattr_init@@GLIBC_2.2.5
   295: 000000000000d9f0    22 FUNC    GLOBAL DEFAULT   14 pthread_rwlockattr_setpsh@@GLIBC_2.2.5
   296: 0000000000009910    10 FUNC    GLOBAL DEFAULT   14 pthread_attr_getguardsize@@GLIBC_2.2.5
   297: 00000000000113e0     8 IFUNC   GLOBAL DEFAULT   14 vfork@GLIBC_2.2.5
   298: 0000000000011f40   149 FUNC    WEAK   DEFAULT   14 tcdrain@@GLIBC_2.2.5
   299: 0000000000014200    87 FUNC    GLOBAL DEFAULT   14 tss_create@@GLIBC_2.28
   300: 000000000000ef80   131 FUNC    GLOBAL DEFAULT   14 pthread_barrier_destroy@@GLIBC_2.2.5
   301: 00000000000094c0     9 FUNC    WEAK   DEFAULT   14 pthread_equal@@GLIBC_2.2.5
   302: 000000000000c940    41 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_setpsha@@GLIBC_2.2.5
   303: 0000000000012910    44 FUNC    WEAK   DEFAULT   14 sigaction@@GLIBC_2.2.5
   304: 000000000000eeb0    12 FUNC    GLOBAL DEFAULT   14 pthread_condattr_getclock@@GLIBC_2.3.3
   305: 000000000000a960  1800 FUNC    GLOBAL DEFAULT   14 __pthread_mutex_trylock@@GLIBC_2.2.5
   306: 000000000000c970    12 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_gettype@@GLIBC_2.2.5
   307: 000000000000eec0    24 FUNC    GLOBAL DEFAULT   14 pthread_condattr_setclock@@GLIBC_2.3.3
   308: 0000000000012990     5 FUNC    GLOBAL DEFAULT   14 __libc_allocate_rtsig@@GLIBC_2.2.5
   309: 0000000000014280    87 FUNC    GLOBAL DEFAULT   14 tss_set@@GLIBC_2.28
   310: 0000000000009200    91 FUNC    WEAK   DEFAULT   14 pthread_detach@@GLIBC_2.2.5
   311: 0000000000010bd0   108 FUNC    GLOBAL DEFAULT   14 sem_timedwait@@GLIBC_2.2.5
   312: 00000000000129b0    78 FUNC    GLOBAL DEFAULT   14 pthread_getaffinity_np@@GLIBC_2.3.4
   313: 0000000000012a00    13 FUNC    GLOBAL DEFAULT   14 pthread_getaffinity_np@GLIBC_2.3.3
   314: 0000000000012bc0    13 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_getrobu@@GLIBC_2.12
   315: 0000000000009e90   459 FUNC    GLOBAL DEFAULT   14 __pthread_mutex_init@@GLIBC_2.2.5
   316: 000000000000cee0   975 FUNC    WEAK   DEFAULT   14 pthread_rwlock_wrlock@@GLIBC_2.2.5
   317: 000000000000d9d0     3 FUNC    GLOBAL DEFAULT   14 pthread_rwlockattr_destro@@GLIBC_2.2.5
   318: 000000000000ca00   587 FUNC    GLOBAL DEFAULT   14 __pthread_rwlock_rdlock@@GLIBC_2.2.5
   319: 0000000000009a40    10 FUNC    GLOBAL DEFAULT   14 pthread_attr_getstackaddr@@GLIBC_2.2.5
   320: 0000000000011c40   286 FUNC    WEAK   DEFAULT   14 open@@GLIBC_2.2.5
   321: 000000000000f7b0   140 FUNC    GLOBAL DEFAULT   14 pthread_setcancelstate@@GLIBC_2.2.5
   322: 00000000000109d0    41 FUNC    GLOBAL DEFAULT   14 sem_wait@@GLIBC_2.2.5
   323: 0000000000014270     5 FUNC    GLOBAL DEFAULT   14 tss_get@@GLIBC_2.28
   324: 00000000000118e0   177 FUNC    WEAK   DEFAULT   14 send@@GLIBC_2.2.5
   325: 000000000000f840   153 FUNC    GLOBAL DEFAULT   14 pthread_setcanceltype@@GLIBC_2.2.5
   326: 000000000000c980    34 FUNC    GLOBAL DEFAULT   14 __pthread_mutexattr_setty@@GLIBC_2.2.5
   327: 000000000000a060    29 FUNC    GLOBAL DEFAULT   14 __pthread_mutex_destroy@@GLIBC_2.2.5
   328: 000000000000d780    89 FUNC    GLOBAL DEFAULT   14 __pthread_rwlock_trywrloc@@GLIBC_2.2.5
   329: 0000000000010a00    44 FUNC    GLOBAL DEFAULT   14 sem_trywait@@GLIBC_2.2.5
   330: 000000000000f770    55 FUNC    GLOBAL DEFAULT   14 pthread_testcancel@@GLIBC_2.2.5
   331: 0000000000010840     8 FUNC    GLOBAL DEFAULT   14 sem_getvalue@@GLIBC_2.2.5
   332: 00000000000135c0   442 FUNC    GLOBAL DEFAULT   14 pthread_mutex_setprioceil@@GLIBC_2.4
   333: 00000000000110b0    13 FUNC    GLOBAL DEFAULT   14 __pthread_unwind_next@@GLIBC_2.3.3
   334: 0000000000014080    87 FUNC    GLOBAL DEFAULT   14 cnd_init@@GLIBC_2.28
   335: 00000000000091d0    37 FUNC    WEAK   DEFAULT   14 pthread_exit@@GLIBC_2.2.5
   336: 0000000000012bd0    46 FUNC    GLOBAL DEFAULT   14 pthread_mutexattr_setrobu@@GLIBC_2.12
   337: 000000000000ef30     9 FUNC    GLOBAL DEFAULT   14 pthread_spin_init@@GLIBC_2.2.5
   338: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.11
   339: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.12
   340: 00000000000116c0   149 FUNC    WEAK   DEFAULT   14 __connect@@GLIBC_2.2.5
   341: 000000000000f6c0   166 FUNC    WEAK   DEFAULT   14 pthread_cancel@@GLIBC_2.2.5
   342: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.18
   343: 00000000000098e0    38 FUNC    GLOBAL DEFAULT   14 pthread_attr_setdetachsta@@GLIBC_2.2.5
   344: 00000000000138a0   304 FUNC    GLOBAL DEFAULT   14 pthread_getname_np@@GLIBC_2.12
   345: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_PRIVATE
   346: 0000000000011bb0   133 FUNC    GLOBAL DEFAULT   14 __nanosleep@@GLIBC_2.2.6
   347: 0000000000012270   125 FUNC    WEAK   DEFAULT   14 sigwait@@GLIBC_2.2.5
   348: 0000000000011b10   149 FUNC    GLOBAL DEFAULT   14 msync@@GLIBC_2.2.5
   349: 000000000000fa30    21 FUNC    GLOBAL DEFAULT   14 __pthread_once@@GLIBC_2.2.5
   350: 0000000000013e80    87 FUNC    GLOBAL DEFAULT   14 mtx_lock@@GLIBC_2.28
   351: 0000000000009af0    20 FUNC    GLOBAL DEFAULT   14 pthread_attr_getstack@@GLIBC_2.2.5
   352: 0000000000012a60   185 FUNC    GLOBAL DEFAULT   14 pthread_attr_getaffinity_@@GLIBC_2.3.4
   353: 0000000000012b20    13 FUNC    GLOBAL DEFAULT   14 pthread_attr_getaffinity_@GLIBC_2.3.3
   354: 0000000000009a10    14 FUNC    GLOBAL DEFAULT   14 pthread_attr_getscope@@GLIBC_2.2.5
   355: 000000000000f260    86 FUNC    WEAK   DEFAULT   14 pthread_key_create@@GLIBC_2.2.5
   356: 0000000000000000     0 OBJECT  GLOBAL DEFAULT  ABS GLIBC_2.28
   357: 0000000000008280  3908 FUNC    GLOBAL DEFAULT   14 pthread_create@@GLIBC_2.2.5
   358: 0000000000009b10    34 FUNC    GLOBAL DEFAULT   14 pthread_attr_setstack@@GLIBC_2.2.5
   359: 0000000000012970     5 FUNC    GLOBAL DEFAULT   14 __libc_current_sigrtmin@@GLIBC_2.2.5
   360: 0000000000009a20    31 FUNC    GLOBAL DEFAULT   14 pthread_attr_setscope@@GLIBC_2.2.5
   361: 0000000000011e90   161 FUNC    WEAK   DEFAULT   14 pwrite@@GLIBC_2.2.5
   362: 0000000000006c00    23 FUNC    GLOBAL DEFAULT   14 __libpthread_freeres@@GLIBC_PRIVATE
   363: 0000000000009880    42 FUNC    GLOBAL DEFAULT   14 pthread_attr_init@@GLIBC_2.2.5
   364: 00000000000098b0    20 FUNC    GLOBAL DEFAULT   14 pthread_attr_destroy@@GLIBC_2.2.5
   365: 0000000000011de0   161 FUNC    WEAK   DEFAULT   14 __pread64@@GLIBC_2.2.5
   366: 000000000000a960  1800 FUNC    WEAK   DEFAULT   14 pthread_mutex_trylock@@GLIBC_2.2.5
   367: 0000000000006860   881 FUNC    WEAK   DEFAULT   14 __pthread_initialize_mini@@GLIBC_PRIVATE
   368: 000000000000da20    22 FUNC    GLOBAL DEFAULT   14 pthread_rwlockattr_setkin@@GLIBC_2.2.5
   369: 00000000000141a0    87 FUNC    GLOBAL DEFAULT   14 cnd_wait@@GLIBC_2.28
   370: 00000000000110c0     9 FUNC    GLOBAL DEFAULT   14 siglongjmp@GLIBC_2.2.5
   371: 00000000000115a0   125 FUNC    GLOBAL DEFAULT   14 __close@@GLIBC_2.2.5
   372: 0000000000010cf0    14 FUNC    GLOBAL DEFAULT   14 __pthread_unregister_canc@@GLIBC_2.3.3
   373: 000000000000e880   903 FUNC    GLOBAL DEFAULT   14 pthread_cond_broadcast@@GLIBC_2.3.2
   374: 000000000000ede0   115 FUNC    GLOBAL DEFAULT   14 pthread_cond_broadcast@GLIBC_2.2.5
Version symbols section '.gnu.version' contains 375 entries:
 Addr: 0000000000004964  Offset: 0x004964  Link: 4 (.dynsym)
  000:   0 (*local*)       d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)
  004:   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)
  008:   0 (*local*)       e (GLIBC_2.2.5)   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)
  00c:   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)
  010:   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)
  014:   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)
  018:   f (GLIBC_2.4)     d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)
  01c:   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)
  020:   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)
  024:  10 (GLIBC_2.3.2)   e (GLIBC_2.2.5)  11 (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)
  028:   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)
  02c:   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)  12 (GLIBC_2.2.5)   e (GLIBC_2.2.5)
  030:   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)  13 (GLIBC_2.14)    d (GLIBC_PRIVATE)
  034:  11 (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)
  038:   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)
  03c:   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)
  040:  11 (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)
  044:   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)
  048:   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)
  04c:   d (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   d (GLIBC_PRIVATE)
  050:   d (GLIBC_PRIVATE)  11 (GLIBC_PRIVATE)   e (GLIBC_2.2.5)  11 (GLIBC_PRIVATE)
  054:   e (GLIBC_2.2.5)  11 (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)
  058:   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)   0 (*local*)       d (GLIBC_PRIVATE)
  05c:  11 (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)  11 (GLIBC_PRIVATE)   d (GLIBC_PRIVATE)
  060:   d (GLIBC_PRIVATE)   e (GLIBC_2.2.5)   e (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  064:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)
  068:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  06c:   7 (GLIBC_2.4)     2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)
  070:   5 (GLIBC_2.3.3)   2 (GLIBC_2.2.5)   5 (GLIBC_2.3.3)   2 (GLIBC_2.2.5)
  074:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    2 (GLIBC_2.2.5)
  078:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  07c:   2h(GLIBC_2.2.5)   2 (GLIBC_2.2.5)   a (GLIBC_2.18)    c (GLIBC_PRIVATE)
  080:   2 (GLIBC_2.2.5)   5h(GLIBC_2.3.3)   6 (GLIBC_2.3.4)   b (GLIBC_2.28)
  084:   8 (GLIBC_2.11)    2h(GLIBC_2.2.5)   4 (GLIBC_2.3.2)   2 (GLIBC_2.2.5)
  088:   5 (GLIBC_2.3.3)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  08c:   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  090:   2h(GLIBC_2.2.5)   4 (GLIBC_2.3.2)   9 (GLIBC_2.12)    9 (GLIBC_2.12)
  094:   2h(GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  098:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    2 (GLIBC_2.2.5)
  09c:   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    2 (GLIBC_2.2.5)   6 (GLIBC_2.3.4)
  0a0:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0a4:   2 (GLIBC_2.2.5)   5 (GLIBC_2.3.3)   2h(GLIBC_2.2.5)   7 (GLIBC_2.4)
  0a8:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   c (GLIBC_PRIVATE)   2 (GLIBC_2.2.5)
  0ac:   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    7 (GLIBC_2.4)     5 (GLIBC_2.3.3)
  0b0:   6 (GLIBC_2.3.4)   5h(GLIBC_2.3.3)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0b4:   2 (GLIBC_2.2.5)   7 (GLIBC_2.4)     2 (GLIBC_2.2.5)   2h(GLIBC_2.2.5)
  0b8:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   3 (GLIBC_2.2.6)
  0bc:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    2 (GLIBC_2.2.5)
  0c0:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0c4:   b (GLIBC_2.28)    2 (GLIBC_2.2.5)   4 (GLIBC_2.3.2)   2h(GLIBC_2.2.5)
  0c8:   2 (GLIBC_2.2.5)   7 (GLIBC_2.4)     2h(GLIBC_2.2.5)   b (GLIBC_2.28)
  0cc:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   a (GLIBC_2.18)    2 (GLIBC_2.2.5)
  0d0:   b (GLIBC_2.28)    2 (GLIBC_2.2.5)   4 (GLIBC_2.3.2)   5 (GLIBC_2.3.3)
  0d4:   6 (GLIBC_2.3.4)   2h(GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0d8:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2h(GLIBC_2.2.5)   4 (GLIBC_2.3.2)
  0dc:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0e0:   b (GLIBC_2.28)    2 (GLIBC_2.2.5)   2h(GLIBC_2.2.5)   b (GLIBC_2.28)
  0e4:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0e8:   2 (GLIBC_2.2.5)   c (GLIBC_PRIVATE)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0ec:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2h(GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0f0:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)
  0f4:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   7 (GLIBC_2.4)
  0f8:   7 (GLIBC_2.4)     2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  0fc:   7 (GLIBC_2.4)     2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   5 (GLIBC_2.3.3)
  100:   2 (GLIBC_2.2.5)   4 (GLIBC_2.3.2)   2h(GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  104:   2 (GLIBC_2.2.5)   c (GLIBC_PRIVATE)   5 (GLIBC_2.3.3)   2 (GLIBC_2.2.5)
  108:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  10c:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  110:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   c (GLIBC_PRIVATE)
  114:   2 (GLIBC_2.2.5)   c (GLIBC_PRIVATE)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  118:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  11c:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   7 (GLIBC_2.4)
  120:   2h(GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2h(GLIBC_2.2.5)   c (GLIBC_PRIVATE)
  124:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  128:   2 (GLIBC_2.2.5)   2h(GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)
  12c:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  130:   5 (GLIBC_2.3.3)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   5 (GLIBC_2.3.3)
  134:   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  138:   6 (GLIBC_2.3.4)   5h(GLIBC_2.3.3)   9 (GLIBC_2.12)    2 (GLIBC_2.2.5)
  13c:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  140:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)
  144:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  148:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  14c:   7 (GLIBC_2.4)     5 (GLIBC_2.3.3)   b (GLIBC_2.28)    2 (GLIBC_2.2.5)
  150:   9 (GLIBC_2.12)    2 (GLIBC_2.2.5)   8 (GLIBC_2.11)    9 (GLIBC_2.12)
  154:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   a (GLIBC_2.18)    2 (GLIBC_2.2.5)
  158:   9 (GLIBC_2.12)    c (GLIBC_PRIVATE)   3 (GLIBC_2.2.6)   2 (GLIBC_2.2.5)
  15c:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    2 (GLIBC_2.2.5)
  160:   6 (GLIBC_2.3.4)   5h(GLIBC_2.3.3)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  164:   b (GLIBC_2.28)    2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  168:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   c (GLIBC_PRIVATE)   2 (GLIBC_2.2.5)
  16c:   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   2 (GLIBC_2.2.5)   c (GLIBC_PRIVATE)
  170:   2 (GLIBC_2.2.5)   b (GLIBC_2.28)    2h(GLIBC_2.2.5)   2 (GLIBC_2.2.5)
  174:   5 (GLIBC_2.3.3)   4 (GLIBC_2.3.2)   2h(GLIBC_2.2.5)
Version definition section '.gnu.version_d' contains 12 entries:
  Addr: 0x0000000000004c58  Offset: 0x004c58  Link: 5 (.dynstr)
  000000: Rev: 1  Flags: BASE  Index: 1  Cnt: 1  Name: libpthread.so.0
  0x001c: Rev: 1  Flags: none  Index: 2  Cnt: 1  Name: GLIBC_2.2.5
  0x0038: Rev: 1  Flags: none  Index: 3  Cnt: 2  Name: GLIBC_2.2.6
  0x0054: Parent 1: GLIBC_2.2.5
  0x005c: Rev: 1  Flags: none  Index: 4  Cnt: 2  Name: GLIBC_2.3.2
  0x0078: Parent 1: GLIBC_2.2.6
  0x0080: Rev: 1  Flags: none  Index: 5  Cnt: 2  Name: GLIBC_2.3.3
  0x009c: Parent 1: GLIBC_2.3.2
  0x00a4: Rev: 1  Flags: none  Index: 6  Cnt: 2  Name: GLIBC_2.3.4
  0x00c0: Parent 1: GLIBC_2.3.3
  0x00c8: Rev: 1  Flags: none  Index: 7  Cnt: 2  Name: GLIBC_2.4
  0x00e4: Parent 1: GLIBC_2.3.4
  0x00ec: Rev: 1  Flags: none  Index: 8  Cnt: 2  Name: GLIBC_2.11
  0x0108: Parent 1: GLIBC_2.4
  0x0110: Rev: 1  Flags: none  Index: 9  Cnt: 2  Name: GLIBC_2.12
  0x012c: Parent 1: GLIBC_2.11
  0x0134: Rev: 1  Flags: none  Index: 10  Cnt: 2  Name: GLIBC_2.18
  0x0150: Parent 1: GLIBC_2.12
  0x0158: Rev: 1  Flags: none  Index: 11  Cnt: 2  Name: GLIBC_2.28
  0x0174: Parent 1: GLIBC_2.18
  0x017c: Rev: 1  Flags: none  Index: 12  Cnt: 2  Name: GLIBC_PRIVATE
  0x0198: Parent 1: GLIBC_2.28
Version needs section '.gnu.version_r' contains 2 entries:
 Addr: 0x0000000000004df8  Offset: 0x004df8  Link: 5 (.dynstr)
  000000: Version: 1  File: ld-linux-x86-64.so.2  Cnt: 2
  0x0010:   Name: GLIBC_2.2.5  Flags: none  Version: 18
  0x0020:   Name: GLIBC_PRIVATE  Flags: none  Version: 17
  0x0030: Version: 1  File: libc.so.6  Cnt: 5
  0x0040:   Name: GLIBC_2.14  Flags: none  Version: 19
  0x0050:   Name: GLIBC_2.3.2  Flags: none  Version: 16
  0x0060:   Name: GLIBC_2.4  Flags: none  Version: 15
  0x0070:   Name: GLIBC_2.2.5  Flags: none  Version: 14
  0x0080:   Name: GLIBC_PRIVATE  Flags: none  Version: 13
Displaying notes found in: .note.gnu.build-id
  Owner                 Data size	Description
  GNU                  0x00000014	NT_GNU_BUILD_ID (unique build ID bitstring)
    Build ID: e91114987a0147bd050addbd591eb8994b29f4b3
Displaying notes found in: .note.ABI-tag
  GNU                  0x00000010	NT_GNU_ABI_TAG (ABI version tag)
    OS: Linux, ABI: 3.2.0
Hi Everyone! I just wanted to let you know the the development team is looking into this issue. We have our QA department testing these issues now.
The 2021.1 crash should be fixed in the 102/103 branches. Please let me know if it is not!
Thanks for your patience!
Where can I find the 102/103 branches?
Yeah still seeing this with 2021.3.1
NVIDIA-smi
(base) sam@rotobot-ampere-dev:~/Desktop$ nvidia-smi
Thu Aug  5 13:16:26 2021
| NVIDIA-SMI 460.67       Driver Version: 460.67       CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce RTX 3090    Off  | 00000000:06:00.0 Off |                  N/A |
| 31%   41C    P8    24W / 350W |     11MiB / 24268MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  GeForce RTX 3090    Off  | 00000000:0A:00.0  On |                  N/A |
| 35%   44C    P8    34W / 350W |    417MiB / 24265MiB |     10%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A     50365      G   /usr/lib/xorg/Xorg                  4MiB |
|    0   N/A  N/A     50879      G   /usr/lib/xorg/Xorg                  4MiB |
|    1   N/A  N/A     50365      G   /usr/lib/xorg/Xorg                 65MiB |
|    1   N/A  N/A     50879      G   /usr/lib/xorg/Xorg                165MiB |
|    1   N/A  N/A     51092      G   /usr/bin/gnome-shell               56MiB |
|    1   N/A  N/A     54408      G   ...AAAAAAAA== --shared-files      110MiB |
vulkaninfo
(base) sam@rotobot-ampere-dev:~/Desktop$ vulkaninfo
VULKANINFO
Vulkan Instance Version: 1.2.182
Instance Extensions: count = 18
	VK_EXT_acquire_xlib_display            : extension revision 1
	VK_EXT_debug_report                    : extension revision 9
	VK_EXT_debug_utils                     : extension revision 2
	VK_EXT_direct_mode_display             : extension revision 1
	VK_EXT_display_surface_counter         : extension revision 1
	VK_KHR_device_group_creation           : extension revision 1
	VK_KHR_display                         : extension revision 23
	VK_KHR_external_fence_capabilities     : extension revision 1
	VK_KHR_external_memory_capabilities    : extension revision 1
	VK_KHR_external_semaphore_capabilities : extension revision 1
	VK_KHR_get_display_properties2         : extension revision 1
	VK_KHR_get_physical_device_properties2 : extension revision 2
	VK_KHR_get_surface_capabilities2       : extension revision 1
	VK_KHR_surface                         : extension revision 25
	VK_KHR_surface_protected_capabilities  : extension revision 1
	VK_KHR_wayland_surface                 : extension revision 6
	VK_KHR_xcb_surface                     : extension revision 6
	VK_KHR_xlib_surface                    : extension revision 6
Layers: count = 11
VK_LAYER_KHRONOS_synchronization2 (Khronos Synchronization2 layer) Vulkan version 1.2.182, layer version 1:
	Layer Extensions: count = 0
	Devices: count = 2
		GPU id = 0 (GeForce RTX 3090)
		Layer-Device Extensions: count = 1
			VK_KHR_synchronization2 : extension revision 1
		GPU id = 1 (GeForce RTX 3090)
VK_LAYER_KHRONOS_validation (Khronos Validation Layer) Vulkan version 1.2.182, layer version 1:
	Layer Extensions: count = 3
		VK_EXT_debug_utils         : extension revision 1
		VK_EXT_validation_features : extension revision 2
	Devices: count = 2
		Layer-Device Extensions: count = 3
			VK_EXT_debug_marker     : extension revision 4
			VK_EXT_tooling_info     : extension revision 1
			VK_EXT_validation_cache : extension revision 1
VK_LAYER_LUNARG_api_dump (LunarG API dump layer) Vulkan version 1.2.182, layer version 2:
	Devices: count = 2
VK_LAYER_LUNARG_device_simulation (LunarG device simulation layer) Vulkan version 1.2.182, layer version 1:
	Devices: count = 2
VK_LAYER_LUNARG_gfxreconstruct (GFXReconstruct Capture Layer Version 0.9.8) Vulkan version 1.2.182, layer version 36872:
	Devices: count = 2
VK_LAYER_LUNARG_monitor (Execution Monitoring Layer) Vulkan version 1.2.182, layer version 1:
	Devices: count = 2
VK_LAYER_LUNARG_screenshot (LunarG image capture layer) Vulkan version 1.2.182, layer version 1:
	Devices: count = 2
VK_LAYER_MESA_device_select (Linux device selection layer) Vulkan version 1.1.73, layer version 1:
	Devices: count = 2
		Layer-Device Extensions: count = 0
VK_LAYER_MESA_overlay (Mesa Overlay layer) Vulkan version 1.1.73, layer version 1:
	Devices: count = 2
VK_LAYER_NV_optimus (NVIDIA Optimus layer) Vulkan version 1.2.155, layer version 1:
	Devices: count = 2
	Devices: count = 2
Presentable Surfaces:
GPU id : 0 (GeForce RTX 3090):
	Surface types: count = 2
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
			format = FORMAT_B8G8R8A8_UNORM
			colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
		SurfaceFormat[1]:
			format = FORMAT_B8G8R8A8_SRGB
	Present Modes: count = 3
		PRESENT_MODE_FIFO_KHR
		PRESENT_MODE_FIFO_RELAXED_KHR
		PRESENT_MODE_IMMEDIATE_KHR
	VkSurfaceCapabilitiesKHR:
		minImageCount = 2
		maxImageCount = 8
		currentExtent:
			width = 256
			height = 256
		minImageExtent:
			width = 256
			height = 256
		maxImageExtent:
			width = 256
			height = 256
		maxImageArrayLayers = 1
		supportedTransforms: count = 1
			SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		supportedCompositeAlpha: count = 1
			COMPOSITE_ALPHA_OPAQUE_BIT_KHR
		supportedUsageFlags: count = 6
			IMAGE_USAGE_TRANSFER_SRC_BIT
			IMAGE_USAGE_TRANSFER_DST_BIT
			IMAGE_USAGE_SAMPLED_BIT
			IMAGE_USAGE_STORAGE_BIT
			IMAGE_USAGE_COLOR_ATTACHMENT_BIT
			IMAGE_USAGE_INPUT_ATTACHMENT_BIT
	VkSurfaceCapabilities2EXT:
		supportedSurfaceCounters:
			None
	VkSurfaceProtectedCapabilitiesKHR:
		supportsProtected = false
GPU id : 1 (GeForce RTX 3090):
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
		SurfaceFormat[1]:
		minImageCount = 2
		maxImageCount = 8
		currentExtent:
			width = 256
			height = 256
		minImageExtent:
			width = 256
			height = 256
		maxImageExtent:
			width = 256
			height = 256
			None
Device Groups:
Group 0:
	Properties:
		physicalDevices: count = 1
			GeForce RTX 3090 (ID: 0)
		subsetAllocation = 0
	Present Capabilities:
		GeForce RTX 3090 (ID: 0):
			Can present images from the following devices: count = 1
		Present modes: count = 1
			DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Group 1:
	Properties:
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
	apiVersion        = 4202651 (1.2.155)
	driverVersion     = 1930477568 (0x7310c000)
	vendorID          = 0x10de
	deviceID          = 0x2204
	deviceType        = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
	deviceName        = GeForce RTX 3090
	pipelineCacheUUID = c02886ec-16b9-e834-96d8-d3af857f3d5b
VkPhysicalDeviceLimits:
	maxImageDimension1D                             = 32768
	maxImageDimension2D                             = 32768
	maxImageDimension3D                             = 16384
	maxImageDimensionCube                           = 32768
	maxImageArrayLayers                             = 2048
	maxTexelBufferElements                          = 134217728
	maxUniformBufferRange                           = 65536
	maxStorageBufferRange                           = 4294967295
	maxPushConstantsSize                            = 256
	maxMemoryAllocationCount                        = 4294967295
	maxSamplerAllocationCount                       = 4000
	bufferImageGranularity                          = 0x00000400
	sparseAddressSpaceSize                          = 0xffffffffff
	maxBoundDescriptorSets                          = 32
	maxPerStageDescriptorSamplers                   = 1048576
	maxPerStageDescriptorUniformBuffers             = 1048576
	maxPerStageDescriptorStorageBuffers             = 1048576
	maxPerStageDescriptorSampledImages              = 1048576
	maxPerStageDescriptorStorageImages              = 1048576
	maxPerStageDescriptorInputAttachments           = 1048576
	maxPerStageResources                            = 4294967295
	maxDescriptorSetSamplers                        = 1048576
	maxDescriptorSetUniformBuffers                  = 1048576
	maxDescriptorSetUniformBuffersDynamic           = 15
	maxDescriptorSetStorageBuffers                  = 1048576
	maxDescriptorSetStorageBuffersDynamic           = 16
	maxDescriptorSetSampledImages                   = 1048576
	maxDescriptorSetStorageImages                   = 1048576
	maxDescriptorSetInputAttachments                = 1048576
	maxVertexInputAttributes                        = 32
	maxVertexInputBindings                          = 32
	maxVertexInputAttributeOffset                   = 2047
	maxVertexInputBindingStride                     = 2048
	maxVertexOutputComponents                       = 128
	maxTessellationGenerationLevel                  = 64
	maxTessellationPatchSize                        = 32
	maxTessellationControlPerVertexInputComponents  = 128
	maxTessellationControlPerVertexOutputComponents = 128
	maxTessellationControlPerPatchOutputComponents  = 120
	maxTessellationControlTotalOutputComponents     = 4216
	maxTessellationEvaluationInputComponents        = 128
	maxTessellationEvaluationOutputComponents       = 128
	maxGeometryShaderInvocations                    = 32
	maxGeometryInputComponents                      = 128
	maxGeometryOutputComponents                     = 128
	maxGeometryOutputVertices                       = 1024
	maxGeometryTotalOutputComponents                = 1024
	maxFragmentInputComponents                      = 128
	maxFragmentOutputAttachments                    = 8
	maxFragmentDualSrcAttachments                   = 1
	maxFragmentCombinedOutputResources              = 16
	maxComputeSharedMemorySize                      = 49152
	maxComputeWorkGroupCount: count = 3
		2147483647
		65535
		65535
	maxComputeWorkGroupInvocations                  = 1024
	maxComputeWorkGroupSize: count = 3
		1024
		1024
		64
	subPixelPrecisionBits                           = 8
	subTexelPrecisionBits                           = 8
	mipmapPrecisionBits                             = 8
	maxDrawIndexedIndexValue                        = 4294967295
	maxDrawIndirectCount                            = 4294967295
	maxSamplerLodBias                               = 15
	maxSamplerAnisotropy                            = 16
	maxViewports                                    = 16
	maxViewportDimensions: count = 2
		32768
		32768
	viewportBoundsRange: count = 2
		-65536
		65536
	viewportSubPixelBits                            = 8
	minMemoryMapAlignment                           = 64
	minTexelBufferOffsetAlignment                   = 0x00000010
	minUniformBufferOffsetAlignment                 = 0x00000040
	minStorageBufferOffsetAlignment                 = 0x00000010
	minTexelOffset                                  = -8
	maxTexelOffset                                  = 7
	minTexelGatherOffset                            = -32
	maxTexelGatherOffset                            = 31
	minInterpolationOffset                          = -0.5
	maxInterpolationOffset                          = 0.4375
	subPixelInterpolationOffsetBits                 = 4
	maxFramebufferWidth                             = 32768
	maxFramebufferHeight                            = 32768
	maxFramebufferLayers                            = 2048
	framebufferColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferStencilSampleCounts: count = 5
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	framebufferNoAttachmentsSampleCounts: count = 5
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	maxColorAttachments                             = 8
	sampledImageColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageIntegerSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageStencilSampleCounts: count = 5
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	storageImageSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleMaskWords                              = 1
	timestampComputeAndGraphics                     = true
	timestampPeriod                                 = 1
	maxClipDistances                                = 8
	maxCullDistances                                = 8
	maxCombinedClipAndCullDistances                 = 8
	discreteQueuePriorities                         = 2
	pointSizeRange: count = 2
		1
		2047.94
	lineWidthRange: count = 2
		1
		64
	pointSizeGranularity                            = 0.0625
	lineWidthGranularity                            = 0.0625
	strictLines                                     = true
	standardSampleLocations                         = true
	optimalBufferCopyOffsetAlignment                = 0x00000001
	optimalBufferCopyRowPitchAlignment              = 0x00000001
	nonCoherentAtomSize                             = 0x00000040
VkPhysicalDeviceSparseProperties:
	residencyStandard2DBlockShape            = true
	residencyStandard2DMultisampleBlockShape = true
	residencyStandard3DBlockShape            = true
	residencyAlignedMipSize                  = false
	residencyNonResidentStrict               = true
VkPhysicalDeviceAccelerationStructurePropertiesKHR:
	maxGeometryCount                                           = 16777215
	maxInstanceCount                                           = 16777215
	maxPrimitiveCount                                          = 536870911
	maxPerStageDescriptorAccelerationStructures                = 1048576
	maxPerStageDescriptorUpdateAfterBindAccelerationStructures = 1048576
	maxDescriptorSetAccelerationStructures                     = 1048576
	maxDescriptorSetUpdateAfterBindAccelerationStructures      = 1048576
	minAccelerationStructureScratchOffsetAlignment             = 128
VkPhysicalDeviceBlendOperationAdvancedPropertiesEXT:
	advancedBlendMaxColorAttachments      = 8
	advancedBlendIndependentBlend         = false
	advancedBlendNonPremultipliedSrcColor = true
	advancedBlendNonPremultipliedDstColor = true
	advancedBlendCorrelatedOverlap        = true
	advancedBlendAllOperations            = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
	primitiveOverestimationSize                 = 0.00195312
	maxExtraPrimitiveOverestimationSize         = 0.75
	extraPrimitiveOverestimationSizeGranularity = 0.25
	primitiveUnderestimation                    = true
	conservativePointAndLineRasterization       = true
	degenerateTrianglesRasterized               = true
	degenerateLinesRasterized                   = true
	fullyCoveredFragmentShaderInputVariable     = true
	conservativeRasterizationPostDepthCoverage  = true
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
	maxCustomBorderColorSamplers = 4000
VkPhysicalDeviceDepthStencilResolvePropertiesKHR:
	supportedDepthResolveModes: count = 4
		RESOLVE_MODE_SAMPLE_ZERO_BIT
		RESOLVE_MODE_AVERAGE_BIT
		RESOLVE_MODE_MIN_BIT
		RESOLVE_MODE_MAX_BIT
	supportedStencilResolveModes: count = 3
	independentResolveNone = true
	independentResolve     = true
VkPhysicalDeviceDescriptorIndexingPropertiesEXT:
	maxUpdateAfterBindDescriptorsInAllPools              = 4294967295
	shaderUniformBufferArrayNonUniformIndexingNative     = true
	shaderSampledImageArrayNonUniformIndexingNative      = true
	shaderStorageBufferArrayNonUniformIndexingNative     = true
	shaderStorageImageArrayNonUniformIndexingNative      = true
	shaderInputAttachmentArrayNonUniformIndexingNative   = true
	robustBufferAccessUpdateAfterBind                    = true
	quadDivergentImplicitLod                             = true
	maxPerStageDescriptorUpdateAfterBindSamplers         = 1048576
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 1048576
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 1048576
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 1048576
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 1048576
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 1048576
	maxPerStageUpdateAfterBindResources                  = 4294967295
	maxDescriptorSetUpdateAfterBindSamplers              = 1048576
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 1048576
	maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 15
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 1048576
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 16
	maxDescriptorSetUpdateAfterBindSampledImages         = 1048576
	maxDescriptorSetUpdateAfterBindStorageImages         = 1048576
	maxDescriptorSetUpdateAfterBindInputAttachments      = 1048576
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
	maxDiscardRectangles = 8
VkPhysicalDeviceDriverPropertiesKHR:
	driverID           = DRIVER_ID_NVIDIA_PROPRIETARY
	driverName         = NVIDIA
	driverInfo         = 460.67
	conformanceVersion = 1.2.4.0
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
	minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsPropertiesKHR:
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	shaderSignedZeroInfNanPreserveFloat16 = true
	shaderSignedZeroInfNanPreserveFloat32 = true
	shaderSignedZeroInfNanPreserveFloat64 = true
	shaderDenormPreserveFloat16           = true
	shaderDenormPreserveFloat32           = false
	shaderDenormPreserveFloat64           = false
	shaderDenormFlushToZeroFloat16        = false
	shaderDenormFlushToZeroFloat32        = false
	shaderDenormFlushToZeroFloat64        = false
	shaderRoundingModeRTEFloat16          = true
	shaderRoundingModeRTEFloat32          = true
	shaderRoundingModeRTEFloat64          = true
	shaderRoundingModeRTZFloat16          = false
	shaderRoundingModeRTZFloat32          = true
	shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceFragmentShadingRatePropertiesKHR:
	minFragmentShadingRateAttachmentTexelSize:
		width  = 16
		height = 16
	maxFragmentShadingRateAttachmentTexelSize:
		width  = 16
		height = 16
	maxFragmentShadingRateAttachmentTexelSizeAspectRatio = 1
	primitiveFragmentShadingRateWithMultipleViewports    = true
	layeredShadingRateAttachments                        = true
	fragmentShadingRateNonTrivialCombinerOps             = true
	maxFragmentSize:
		width  = 4
		height = 4
	maxFragmentSizeAspectRatio                           = 2
	maxFragmentShadingRateCoverageSamples                = 16
	maxFragmentShadingRateRasterizationSamples           = SAMPLE_COUNT_16_BIT
	fragmentShadingRateWithShaderDepthStencilWrites      = true
	fragmentShadingRateWithSampleMask                    = true
	fragmentShadingRateWithShaderSampleMask              = true
	fragmentShadingRateWithConservativeRasterization     = true
	fragmentShadingRateWithFragmentShaderInterlock       = true
	fragmentShadingRateWithCustomSampleLocations         = true
	fragmentShadingRateStrictMultiplyCombiner            = true
VkPhysicalDeviceIDPropertiesKHR:
	deviceUUID      = f6b69e65-5bc8-f1bb-dd15-10b2b7f1d4e6
	driverUUID      = 96d8d3af-857f-3d5b-9d94-2ef8a25ff4c7
	deviceNodeMask  = 1
	deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
	maxInlineUniformBlockSize                               = 256
	maxPerStageDescriptorInlineUniformBlocks                = 32
	maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
	maxDescriptorSetInlineUniformBlocks                     = 32
	maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
	lineSubPixelPrecisionBits = 8
VkPhysicalDeviceMaintenance3PropertiesKHR:
	maxPerSetDescriptors    = 4294967295
	maxMemoryAllocationSize = 0xffe00000
VkPhysicalDeviceMultiviewPropertiesKHR:
	maxMultiviewViewCount     = 32
	maxMultiviewInstanceIndex = 134217727
VkPhysicalDevicePCIBusInfoPropertiesEXT:
	pciDomain   = 0
	pciBus      = 6
	pciDevice   = 0
	pciFunction = 0
VkPhysicalDevicePointClippingPropertiesKHR:
	pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDevicePushDescriptorPropertiesKHR:
	maxPushDescriptors = 32
VkPhysicalDeviceRayTracingPipelinePropertiesKHR:
	shaderGroupHandleSize              = 32
	maxRayRecursionDepth               = 31
	maxShaderGroupStride               = 4096
	shaderGroupBaseAlignment           = 64
	shaderGroupHandleCaptureReplaySize = 32
	maxRayDispatchInvocationCount      = 1073741824
	shaderGroupHandleAlignment         = 32
	maxRayHitAttributeSize             = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
	robustStorageBufferAccessSizeAlignment = 0x00000001
	robustUniformBufferAccessSizeAlignment = 0x00000010
VkPhysicalDeviceSampleLocationsPropertiesEXT:
	sampleLocationSampleCounts: count = 5
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	maxSampleLocationGridSize:
		width  = 1
		height = 1
	sampleLocationCoordinateRange: count = 2
		0
		0.9375
	sampleLocationSubPixelBits       = 4
	variableSampleLocations          = true
VkPhysicalDeviceSamplerFilterMinmaxPropertiesEXT:
	filterMinmaxSingleComponentFormats = true
	filterMinmaxImageComponentMapping  = true
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
	minSubgroupSize              = 32
	maxSubgroupSize              = 32
	maxComputeWorkgroupSubgroups = 2097152
	requiredSubgroupSizeStages: count = 16
		SHADER_STAGE_VERTEX_BIT
		SHADER_STAGE_TESSELLATION_CONTROL_BIT
		SHADER_STAGE_TESSELLATION_EVALUATION_BIT
		SHADER_STAGE_GEOMETRY_BIT
		SHADER_STAGE_FRAGMENT_BIT
		SHADER_STAGE_COMPUTE_BIT
		SHADER_STAGE_ALL_GRAPHICS
		SHADER_STAGE_ALL
		SHADER_STAGE_RAYGEN_BIT_KHR
		SHADER_STAGE_ANY_HIT_BIT_KHR
		SHADER_STAGE_CLOSEST_HIT_BIT_KHR
		SHADER_STAGE_MISS_BIT_KHR
		SHADER_STAGE_INTERSECTION_BIT_KHR
		SHADER_STAGE_CALLABLE_BIT_KHR
		SHADER_STAGE_TASK_BIT_NV
		SHADER_STAGE_MESH_BIT_NV
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
	storageTexelBufferOffsetAlignmentBytes       = 0x00000010
	storageTexelBufferOffsetSingleTexelAlignment = true
	uniformTexelBufferOffsetAlignmentBytes       = 0x00000010
	uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphorePropertiesKHR:
	maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
	maxTransformFeedbackStreams                = 4
	maxTransformFeedbackBuffers                = 4
	maxTransformFeedbackBufferSize             = 0xffffffffffffffff
	maxTransformFeedbackStreamDataSize         = 2048
	maxTransformFeedbackBufferDataSize         = 512
	maxTransformFeedbackBufferDataStride       = 2048
	transformFeedbackQueries                   = true
	transformFeedbackStreamsLinesTriangles     = false
	transformFeedbackRasterizationStreamSelect = true
	transformFeedbackDraw                      = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
	maxVertexAttribDivisor = 4294967295
Device Extensions: count = 128
	VK_EXT_4444_formats                       : extension revision 1
	VK_EXT_blend_operation_advanced           : extension revision 2
	VK_EXT_buffer_device_address              : extension revision 2
	VK_EXT_calibrated_timestamps              : extension revision 1
	VK_EXT_conditional_rendering              : extension revision 2
	VK_EXT_conservative_rasterization         : extension revision 1
	VK_EXT_custom_border_color                : extension revision 12
	VK_EXT_depth_clip_enable                  : extension revision 1
	VK_EXT_depth_range_unrestricted           : extension revision 1
	VK_EXT_descriptor_indexing                : extension revision 2
	VK_EXT_discard_rectangles                 : extension revision 1
	VK_EXT_display_control                    : extension revision 1
	VK_EXT_extended_dynamic_state             : extension revision 1
	VK_EXT_external_memory_host               : extension revision 1
	VK_EXT_fragment_shader_interlock          : extension revision 1
	VK_EXT_global_priority                    : extension revision 2
	VK_EXT_host_query_reset                   : extension revision 1
	VK_EXT_image_robustness                   : extension revision 1
	VK_EXT_index_type_uint8                   : extension revision 1
	VK_EXT_inline_uniform_block               : extension revision 1
	VK_EXT_line_rasterization                 : extension revision 1
	VK_EXT_memory_budget                      : extension revision 1
	VK_EXT_pci_bus_info                       : extension revision 2
	VK_EXT_pipeline_creation_cache_control    : extension revision 3
	VK_EXT_pipeline_creation_feedback         : extension revision 1
	VK_EXT_post_depth_coverage                : extension revision 1
	VK_EXT_private_data                       : extension revision 1
	VK_EXT_robustness2                        : extension revision 1
	VK_EXT_sample_locations                   : extension revision 1
	VK_EXT_sampler_filter_minmax              : extension revision 2
	VK_EXT_scalar_block_layout                : extension revision 1
	VK_EXT_separate_stencil_usage             : extension revision 1
	VK_EXT_shader_atomic_float                : extension revision 1
	VK_EXT_shader_demote_to_helper_invocation : extension revision 1
	VK_EXT_shader_image_atomic_int64          : extension revision 1
	VK_EXT_shader_subgroup_ballot             : extension revision 1
	VK_EXT_shader_subgroup_vote               : extension revision 1
	VK_EXT_shader_viewport_index_layer        : extension revision 1
	VK_EXT_subgroup_size_control              : extension revision 2
	VK_EXT_texel_buffer_alignment             : extension revision 1
	VK_EXT_transform_feedback                 : extension revision 1
	VK_EXT_vertex_attribute_divisor           : extension revision 3
	VK_EXT_ycbcr_image_arrays                 : extension revision 1
	VK_KHR_16bit_storage                      : extension revision 1
	VK_KHR_8bit_storage                       : extension revision 1
	VK_KHR_acceleration_structure             : extension revision 11
	VK_KHR_bind_memory2                       : extension revision 1
	VK_KHR_buffer_device_address              : extension revision 1
	VK_KHR_copy_commands2                     : extension revision 1
	VK_KHR_create_renderpass2                 : extension revision 1
	VK_KHR_dedicated_allocation               : extension revision 3
	VK_KHR_deferred_host_operations           : extension revision 3
	VK_KHR_depth_stencil_resolve              : extension revision 1
	VK_KHR_descriptor_update_template         : extension revision 1
	VK_KHR_device_group                       : extension revision 4
	VK_KHR_draw_indirect_count                : extension revision 1
	VK_KHR_driver_properties                  : extension revision 1
	VK_KHR_external_fence                     : extension revision 1
	VK_KHR_external_fence_fd                  : extension revision 1
	VK_KHR_external_memory                    : extension revision 1
	VK_KHR_external_memory_fd                 : extension revision 1
	VK_KHR_external_semaphore                 : extension revision 1
	VK_KHR_external_semaphore_fd              : extension revision 1
	VK_KHR_fragment_shading_rate              : extension revision 1
	VK_KHR_get_memory_requirements2           : extension revision 1
	VK_KHR_image_format_list                  : extension revision 1
	VK_KHR_imageless_framebuffer              : extension revision 1
	VK_KHR_maintenance1                       : extension revision 2
	VK_KHR_maintenance2                       : extension revision 1
	VK_KHR_maintenance3                       : extension revision 1
	VK_KHR_multiview                          : extension revision 1
	VK_KHR_pipeline_executable_properties     : extension revision 1
	VK_KHR_pipeline_library                   : extension revision 1
	VK_KHR_push_descriptor                    : extension revision 2
	VK_KHR_ray_query                          : extension revision 1
	VK_KHR_ray_tracing_pipeline               : extension revision 1
	VK_KHR_relaxed_block_layout               : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge       : extension revision 3
	VK_KHR_sampler_ycbcr_conversion           : extension revision 14
	VK_KHR_separate_depth_stencil_layouts     : extension revision 1
	VK_KHR_shader_atomic_int64                : extension revision 1
	VK_KHR_shader_clock                       : extension revision 1
	VK_KHR_shader_draw_parameters             : extension revision 1
	VK_KHR_shader_float16_int8                : extension revision 1
	VK_KHR_shader_float_controls              : extension revision 4
	VK_KHR_shader_non_semantic_info           : extension revision 1
	VK_KHR_shader_subgroup_extended_types     : extension revision 1
	VK_KHR_shader_terminate_invocation        : extension revision 1
	VK_KHR_spirv_1_4                          : extension revision 1
	VK_KHR_storage_buffer_storage_class       : extension revision 1
	VK_KHR_swapchain                          : extension revision 70
	VK_KHR_swapchain_mutable_format           : extension revision 1
	VK_KHR_timeline_semaphore                 : extension revision 2
	VK_KHR_uniform_buffer_standard_layout     : extension revision 1
	VK_KHR_variable_pointers                  : extension revision 1
	VK_KHR_vulkan_memory_model                : extension revision 3
	VK_NVX_binary_import                      : extension revision 1
	VK_NVX_image_view_handle                  : extension revision 2
	VK_NVX_multiview_per_view_attributes      : extension revision 1
	VK_NV_clip_space_w_scaling                : extension revision 1
	VK_NV_compute_shader_derivatives          : extension revision 1
	VK_NV_cooperative_matrix                  : extension revision 1
	VK_NV_corner_sampled_image                : extension revision 2
	VK_NV_coverage_reduction_mode             : extension revision 1
	VK_NV_cuda_kernel_launch                  : extension revision 2
	VK_NV_dedicated_allocation                : extension revision 1
	VK_NV_dedicated_allocation_image_aliasing : extension revision 1
	VK_NV_device_diagnostic_checkpoints       : extension revision 2
	VK_NV_device_diagnostics_config           : extension revision 1
	VK_NV_device_generated_commands           : extension revision 3
	VK_NV_fill_rectangle                      : extension revision 1
	VK_NV_fragment_coverage_to_color          : extension revision 1
	VK_NV_fragment_shader_barycentric         : extension revision 1
	VK_NV_fragment_shading_rate_enums         : extension revision 1
	VK_NV_framebuffer_mixed_samples           : extension revision 1
	VK_NV_geometry_shader_passthrough         : extension revision 1
	VK_NV_mesh_shader                         : extension revision 1
	VK_NV_ray_tracing                         : extension revision 3
	VK_NV_representative_fragment_test        : extension revision 2
	VK_NV_sample_mask_override_coverage       : extension revision 1
	VK_NV_scissor_exclusive                   : extension revision 1
	VK_NV_shader_image_footprint              : extension revision 2
	VK_NV_shader_sm_builtins                  : extension revision 1
	VK_NV_shader_subgroup_partitioned         : extension revision 1
	VK_NV_shading_rate_image                  : extension revision 3
	VK_NV_viewport_array2                     : extension revision 1
	VK_NV_viewport_swizzle                    : extension revision 1
VkQueueFamilyProperties:
	queueProperties[0]:
		minImageTransferGranularity = (1,1,1)
		queueCount                  = 16
		queueFlags                  = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		timestampValidBits          = 64
		present support             = false
	queueProperties[1]:
		queueCount                  = 2
		queueFlags                  = QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
	queueProperties[2]:
		queueCount                  = 8
		queueFlags                  = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 3
	memoryHeaps[0]:
		size   = 25769803776 (0x600000000) (24.00 GiB)
		budget = 25435439104 (0x5ec120000) (23.69 GiB)
		usage  = 0 (0x00000000) (0.00 B)
		flags: count = 1
			MEMORY_HEAP_DEVICE_LOCAL_BIT
	memoryHeaps[1]:
		size   = 77332036608 (0x1201593c00) (72.02 GiB)
		budget = 77332036608 (0x1201593c00) (72.02 GiB)
		flags:
			None
	memoryHeaps[2]:
		size   = 257949696 (0x0f600000) (246.00 MiB)
		budget = 254410752 (0x0f2a0000) (242.62 MiB)
		usage  = 3538944 (0x00360000) (3.38 MiB)
		flags: count = 1
memoryTypes: count = 11
	memoryTypes[0]:
		heapIndex     = 1
		propertyFlags = 0x0000:
			None
		usable for:
			IMAGE_TILING_OPTIMAL:
				None
			IMAGE_TILING_LINEAR:
				color images
				(non-transient)
	memoryTypes[1]:
		heapIndex     = 1
			None
		usable for:
				color images
				None
	memoryTypes[2]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_D16_UNORM
				None
	memoryTypes[3]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_X8_D24_UNORM_PACK32
				FORMAT_D24_UNORM_S8_UINT
				None
	memoryTypes[4]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_D32_SFLOAT
				None
	memoryTypes[5]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_D32_SFLOAT_S8_UINT
				None
	memoryTypes[6]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_S8_UINT
				None
	memoryTypes[7]:
		heapIndex     = 0
		propertyFlags = 0x0001: count = 1
			MEMORY_PROPERTY_DEVICE_LOCAL_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
				(non-transient)
	memoryTypes[8]:
		heapIndex     = 1
		propertyFlags = 0x0006: count = 2
			MEMORY_PROPERTY_HOST_VISIBLE_BIT
			MEMORY_PROPERTY_HOST_COHERENT_BIT
		usable for:
				None
				color images
				(non-transient)
	memoryTypes[9]:
		heapIndex     = 1
		propertyFlags = 0x000e: count = 3
			MEMORY_PROPERTY_HOST_CACHED_BIT
		usable for:
				None
				color images
				(non-transient)
	memoryTypes[10]:
		heapIndex     = 2
		propertyFlags = 0x0007: count = 3
		usable for:
				None
				None
VkPhysicalDeviceFeatures:
	robustBufferAccess                      = true
	fullDrawIndexUint32                     = true
	imageCubeArray                          = true
	independentBlend                        = true
	geometryShader                          = true
	tessellationShader                      = true
	sampleRateShading                       = true
	dualSrcBlend                            = true
	logicOp                                 = true
	multiDrawIndirect                       = true
	drawIndirectFirstInstance               = true
	depthClamp                              = true
	depthBiasClamp                          = true
	fillModeNonSolid                        = true
	depthBounds                             = true
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = true
	multiViewport                           = true
	samplerAnisotropy                       = true
	textureCompressionETC2                  = false
	textureCompressionASTC_LDR              = false
	textureCompressionBC                    = true
	occlusionQueryPrecise                   = true
	pipelineStatisticsQuery                 = true
	vertexPipelineStoresAndAtomics          = true
	fragmentStoresAndAtomics                = true
	shaderTessellationAndGeometryPointSize  = true
	shaderImageGatherExtended               = true
	shaderStorageImageExtendedFormats       = true
	shaderStorageImageMultisample           = true
	shaderStorageImageReadWithoutFormat     = true
	shaderStorageImageWriteWithoutFormat    = true
	shaderUniformBufferArrayDynamicIndexing = true
	shaderSampledImageArrayDynamicIndexing  = true
	shaderStorageBufferArrayDynamicIndexing = true
	shaderStorageImageArrayDynamicIndexing  = true
	shaderClipDistance                      = true
	shaderCullDistance                      = true
	shaderFloat64                           = true
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceResidency                 = true
	shaderResourceMinLod                    = true
	sparseBinding                           = true
	sparseResidencyBuffer                   = true
	sparseResidencyImage2D                  = true
	sparseResidencyImage3D                  = true
	sparseResidency2Samples                 = true
	sparseResidency4Samples                 = true
	sparseResidency8Samples                 = true
	sparseResidency16Samples                = true
	sparseResidencyAliased                  = true
	variableMultisampleRate                 = true
	inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeaturesKHR:
	storageBuffer16BitAccess           = true
	uniformAndStorageBuffer16BitAccess = true
	storagePushConstant16              = true
	storageInputOutput16               = false
VkPhysicalDevice4444FormatsFeaturesEXT:
	formatA4R4G4B4 = true
	formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeaturesKHR:
	storageBuffer8BitAccess           = true
	uniformAndStorageBuffer8BitAccess = true
	storagePushConstant8              = true
VkPhysicalDeviceAccelerationStructureFeaturesKHR:
	accelerationStructure                                 = true
	accelerationStructureCaptureReplay                    = true
	accelerationStructureIndirectBuild                    = false
	accelerationStructureHostCommands                     = false
	descriptorBindingAccelerationStructureUpdateAfterBind = true
VkPhysicalDeviceBlendOperationAdvancedFeaturesEXT:
	advancedBlendCoherentOperations = true
VkPhysicalDeviceBufferDeviceAddressFeaturesKHR:
	bufferDeviceAddress              = true
	bufferDeviceAddressCaptureReplay = false
	bufferDeviceAddressMultiDevice   = true
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
	conditionalRendering          = true
	inheritedConditionalRendering = true
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
	customBorderColors             = true
	customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
	depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeaturesEXT:
	shaderInputAttachmentArrayDynamicIndexing          = true
	shaderUniformTexelBufferArrayDynamicIndexing       = true
	shaderStorageTexelBufferArrayDynamicIndexing       = true
	shaderUniformBufferArrayNonUniformIndexing         = true
	shaderSampledImageArrayNonUniformIndexing          = true
	shaderStorageBufferArrayNonUniformIndexing         = true
	shaderStorageImageArrayNonUniformIndexing          = true
	shaderInputAttachmentArrayNonUniformIndexing       = true
	shaderUniformTexelBufferArrayNonUniformIndexing    = true
	shaderStorageTexelBufferArrayNonUniformIndexing    = true
	descriptorBindingUniformBufferUpdateAfterBind      = true
	descriptorBindingSampledImageUpdateAfterBind       = true
	descriptorBindingStorageImageUpdateAfterBind       = true
	descriptorBindingStorageBufferUpdateAfterBind      = true
	descriptorBindingUniformTexelBufferUpdateAfterBind = true
	descriptorBindingStorageTexelBufferUpdateAfterBind = true
	descriptorBindingUpdateUnusedWhilePending          = true
	descriptorBindingPartiallyBound                    = true
	descriptorBindingVariableDescriptorCount           = true
	runtimeDescriptorArray                             = true
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
	extendedDynamicState = true
VkPhysicalDeviceFragmentShaderInterlockFeaturesEXT:
	fragmentShaderSampleInterlock      = true
	fragmentShaderPixelInterlock       = true
	fragmentShaderShadingRateInterlock = true
VkPhysicalDeviceFragmentShadingRateFeaturesKHR:
	pipelineFragmentShadingRate   = true
	primitiveFragmentShadingRate  = true
	attachmentFragmentShadingRate = true
VkPhysicalDeviceHostQueryResetFeaturesEXT:
	hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeaturesEXT:
	robustImageAccess = true
VkPhysicalDeviceImagelessFramebufferFeaturesKHR:
	imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
	indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
	inlineUniformBlock                                 = true
	descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
	rectangularLines         = true
	bresenhamLines           = true
	smoothLines              = true
	stippledRectangularLines = true
	stippledBresenhamLines   = true
	stippledSmoothLines      = true
VkPhysicalDeviceMultiviewFeaturesKHR:
	multiview                   = true
	multiviewGeometryShader     = true
	multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
	pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
	pipelineExecutableInfo = true
VkPhysicalDevicePrivateDataFeaturesEXT:
	privateData = true
VkPhysicalDeviceRayQueryFeaturesKHR:
	rayQuery = true
VkPhysicalDeviceRayTracingPipelineFeaturesKHR:
	rayTracingPipeline                                    = true
	rayTracingPipelineShaderGroupHandleCaptureReplay      = false
	rayTracingPipelineShaderGroupHandleCaptureReplayMixed = false
	rayTracingPipelineTraceRaysIndirect                   = true
	rayTraversalPrimitiveCulling                          = true
VkPhysicalDeviceRobustness2FeaturesEXT:
	robustBufferAccess2 = true
	robustImageAccess2  = true
	nullDescriptor      = true
VkPhysicalDeviceSamplerYcbcrConversionFeaturesKHR:
	samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeaturesEXT:
	scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeaturesKHR:
	separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
	shaderBufferFloat32Atomics   = true
	shaderBufferFloat32AtomicAdd = true
	shaderBufferFloat64Atomics   = true
	shaderBufferFloat64AtomicAdd = true
	shaderSharedFloat32Atomics   = true
	shaderSharedFloat32AtomicAdd = true
	shaderSharedFloat64Atomics   = true
	shaderSharedFloat64AtomicAdd = true
	shaderImageFloat32Atomics    = true
	shaderImageFloat32AtomicAdd  = true
	sparseImageFloat32Atomics    = true
	sparseImageFloat32AtomicAdd  = true
VkPhysicalDeviceShaderAtomicInt64FeaturesKHR:
	shaderBufferInt64Atomics = true
	shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
	shaderSubgroupClock = true
	shaderDeviceClock   = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
	shaderDemoteToHelperInvocation = true
VkPhysicalDeviceFloat16Int8FeaturesKHR:
	shaderFloat16 = true
	shaderInt8    = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
	shaderImageInt64Atomics = true
	sparseImageInt64Atomics = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeaturesKHR:
	shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
	shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
	subgroupSizeControl  = true
	computeFullSubgroups = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
	texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeaturesKHR:
	timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
	transformFeedback = true
	geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeaturesKHR:
	uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeaturesKHR:
	variablePointersStorageBuffer = true
	variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
	vertexAttributeInstanceRateDivisor     = true
	vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkanMemoryModelFeaturesKHR:
	vulkanMemoryModel                             = true
	vulkanMemoryModelDeviceScope                  = true
	vulkanMemoryModelAvailabilityVisibilityChains = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
	ycbcrImageArrays = true
GPU1:
	vendorID          = 0x10de
	deviceID          = 0x2204
		2147483647
		65535
		65535
		1024
		1024
		64
	maxViewports                                    = 16
		32768
		32768
		-65536
		65536
	minTexelOffset                                  = -8
	maxTexelOffset                                  = 7
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	timestampPeriod                                 = 1
		1
		2047.94
		1
		64
	strictLines                                     = true
	driverName         = NVIDIA
	driverInfo         = 460.67
		width  = 16
		height = 16
		width  = 16
		height = 16
	maxFragmentSize:
		width  = 4
		height = 4
	deviceUUID      = 3c6a2629-8def-c540-f517-f608559bc76b
	deviceNodeMask  = 1
	pciDomain   = 0
	pciBus      = 10
	pciDevice   = 0
	pciFunction = 0
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
		width  = 1
		height = 1
		0
		0.9375
		SHADER_STAGE_ALL
	queueProperties[0]:
		queueCount                  = 16
		present support             = true
	queueProperties[1]:
		queueCount                  = 2
	queueProperties[2]:
		queueCount                  = 8
	memoryHeaps[0]:
		budget = 24995299328 (0x5d1d60000) (23.28 GiB)
		flags: count = 1
	memoryHeaps[1]:
		flags:
			None
	memoryHeaps[2]:
		budget = 248119296 (0x0eca0000) (236.62 MiB)
		usage  = 9830400 (0x00960000) (9.38 MiB)
		flags: count = 1
	memoryTypes[0]:
		heapIndex     = 1
			None
		usable for:
				None
				color images
				(non-transient)
	memoryTypes[1]:
		heapIndex     = 1
			None
		usable for:
				color images
				None
	memoryTypes[2]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_D16_UNORM
				None
	memoryTypes[3]:
		heapIndex     = 1
			None
		usable for:
				None
	memoryTypes[4]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_D32_SFLOAT
				None
	memoryTypes[5]:
		heapIndex     = 1
			None
		usable for:
				None
	memoryTypes[6]:
		heapIndex     = 1
			None
		usable for:
				FORMAT_S8_UINT
				None
	memoryTypes[7]:
		heapIndex     = 0
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
				(non-transient)
	memoryTypes[8]:
		heapIndex     = 1
		usable for:
				None
				color images
				(non-transient)
	memoryTypes[9]:
		heapIndex     = 1
		usable for:
				None
				color images
				(non-transient)
	memoryTypes[10]:
		heapIndex     = 2
		usable for:
				None
				None
	dualSrcBlend                            = true
	logicOp                                 = true
	depthClamp                              = true
	depthBounds                             = true
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = true
	shaderInt64                             = true
	shaderInt16                             = true
	smoothLines              = true
	multiview                   = true
	privateData = true
	rayQuery = true
	shaderInt8    = true
(base) sam@rotobot-ampere-dev:~/Desktop$  cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.1 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.1 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
Same issue here on Ubuntu 21:
2021-10-13 05:30:49 [4,245ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-10-13 05:30:49 [4,250ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!gsignal
2021-10-13 05:30:49 [4,254ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!abort
2021-10-13 05:30:49 [4,256ms] [Fatal] [carb.crashreporter-breakpad.plugin] libffi.so.8!+0x2452
2021-10-13 05:30:49 [4,256ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ctypes.cpython-37m-x86_64-linux-gnu.so!PyInit__ctypes
2021-10-13 05:30:49 [4,260ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!free_keys_object
2021-10-13 05:30:49 [4,263ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!dict_dealloc
2021-10-13 05:30:49 [4,264ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ctypes.cpython-37m-x86_64-linux-gnu.so!_init
2021-10-13 05:30:49 [4,267ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!subtype_dealloc
2021-10-13 05:30:49 [4,270ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,273ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,277ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,280ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:49 [4,283ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-10-13 05:30:49 [4,287ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-10-13 05:30:49 [4,293ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-10-13 05:30:49 [4,298ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-10-13 05:30:49 [4,302ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-10-13 05:30:49 [4,305ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,310ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:49 [4,313ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:49 [4,317ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,321ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,324ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,328ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,331ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,334ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,337ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,340ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,343ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-10-13 05:30:49 [4,348ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-10-13 05:30:49 [4,353ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-10-13 05:30:49 [4,356ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-10-13 05:30:49 [4,360ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,363ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:49 [4,367ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-10-13 05:30:49 [4,371ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-10-13 05:30:49 [4,376ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-10-13 05:30:49 [4,380ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-10-13 05:30:49 [4,384ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-10-13 05:30:49 [4,387ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,390ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:49 [4,394ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:49 [4,396ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,399ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,402ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,406ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,411ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,415ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,419ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,422ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,426ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-10-13 05:30:49 [4,430ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-10-13 05:30:49 [4,434ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-10-13 05:30:49 [4,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-10-13 05:30:49 [4,441ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,445ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:49 [4,448ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-10-13 05:30:49 [4,451ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-10-13 05:30:49 [4,454ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-10-13 05:30:49 [4,457ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-10-13 05:30:49 [4,460ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-10-13 05:30:49 [4,465ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,471ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:49 [4,475ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:49 [4,478ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,482ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,486ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,490ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,494ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,498ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,501ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:49 [4,504ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:49 [4,507ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:50 [4,510ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:50 [4,513ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:50 [4,516ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:50 [4,520ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:50 [4,526ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:50 [4,530ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:50 [4,533ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-10-13 05:30:50 [4,537ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:50 [4,541ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:50 [4,545ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:50 [4,549ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:50 [4,553ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:50 [4,557ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:50 [4,560ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:50 [4,563ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:50 [4,566ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:50 [4,569ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:50 [4,573ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:50 [4,576ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-10-13 05:30:50 [4,581ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-10-13 05:30:50 [4,585ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-10-13 05:30:50 [4,588ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-10-13 05:30:50 [4,593ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-10-13 05:30:50 [4,596ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-10-13 05:30:50 [4,599ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-10-13 05:30:50 [4,603ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-10-13 05:30:50 [4,606ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-10-13 05:30:50 [4,609ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)
2021-10-13 05:30:50 [4,612ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-10-13 05:30:50 [4,615ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-10-13 05:30:50 [4,618ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-10-13 05:30:50 [4,621ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2021-10-13 05:30:50 [4,624ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (*)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, ...)
2021-10-13 05:30:50 [4,626ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-10-13 05:30:50 [4,627ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-10-13 05:30:50 [4,630ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-10-13 05:30:50 [4,630ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Wed Oct 13 07:33:36 2021
| NVIDIA-SMI 460.91.03    Driver Version: 460.91.03    CUDA Version: 11.2     |
|                               |                      |               MIG M. |
|   0  Quadro RTX 3000     Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   37C    P3     1W /  N/A |      6MiB /  5934MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      1332      G   /usr/lib/xorg/Xorg                  4MiB |
hello @vanthome -
Can you send the entire Create log? the snippet above is just the final unwind after a previous error condition.
Here is mine trying to run Create on Ubuntu 21 with driver 470-82:
kit_20211115_210652.log (257.5 KB)
2021-11-15 20:06:56 [3,989ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/plugins’ Filename: ‘carb.flatcache.plugin’
2021-11-15 20:06:56 [3,990ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/plugins’ Filename: ‘omni.gpucompute-cuda.plugin’
2021-11-15 20:06:56 [3,990ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/plugins’ Filename: ‘omni.gpucompute-d3dvk.plugin’
2021-11-15 20:06:56 [3,991ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/plugins’ Filename: ‘omni.realm.plugin’
2021-11-15 20:06:56 [3,993ms] [Info] [carb] Registered plugin: omni.hydra.scene_delegate.plugin (interfaces: [carb::fastcache::FastCache v0.4],[carb::fastcache::FastCacheHydra v0.2],[omni::hydra::IOmniHydra v2.0],[omni::hydra::ISceneDelegateFactory v0.1]) (impl: omni.hydra.scene_delegate.plugin)
2021-11-15 20:06:56 [3,995ms] [Info] [carb] Registered plugin: flatcache.plugin (interfaces: [carb::flatcache::FlatCache v0.2],[carb::flatcache::IChangeTrackerConfig v0.1],[carb::flatcache::IPath v0.1],[carb::flatcache::IPrimBucketList v0.1],[carb::flatcache::IStageAtTimeInterval v0.1],[carb::flatcache::IStageInProgress v0.1],[carb::flatcache::IStageWithHistory v0.1],[carb::flatcache::IStageWithHistoryDefaults v0.1],[carb::flatcache::IToken v0.1]) (impl: flatcache.plugin)
2021-11-15 20:06:56 [3,995ms] [Info] [carb] Registered plugin: omni.gpucompute-cuda.plugin (interfaces: [omni::gpucompute::GpuCompute v0.1]) (impl: omni.gpucompute-cuda.plugin)
2021-11-15 20:06:56 [3,995ms] [Info] [carb] Registered plugin: omni.gpucompute-d3dvk.plugin (interfaces: [omni::gpucompute::ComputeCompiler v0.1],[omni::gpucompute::GpuCompute v0.1]) (impl: omni.gpucompute-d3dvk.plugin)
2021-11-15 20:06:56 [4,006ms] [Info] [carb] Registered plugin: omni.realm.plugin (interfaces: [omni::realm::IRealm v0.1]) (impl: omni.realm.plugin)
2021-11-15 20:06:56 [4,006ms] [Info] [omni.ext.plugin] About to startup: [ext: carb.audio-0.1.0] (order: 0) Triggered by: omni.usd-1.4.5 (path: /home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/extscore/carb.audio)
2021-11-15 20:06:56 [4,006ms] [Info] [omni.kit.app.plugin] [4.039s] [ext: carb.audio-0.1.0] startup
2021-11-15 20:06:56 [4,006ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/plugins’ Filename: ‘carb.audio-forge.plugin’
2021-11-15 20:06:56 [4,029ms] [Info] [carb] Registered plugin: carb.audio-forge.plugin (interfaces: [carb::audio::IAudioCapture v1.0],[carb::audio::IAudioData v1.0],[carb::audio::IAudioDevice v1.0],[carb::audio::IAudioGroup v1.0],[carb::audio::IAudioPlayback v1.0],[carb::audio::IAudioUtils v1.0]) (impl: carb.audio-forge.plugin)
2021-11-15 20:06:56 [4,029ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.commands-0.0.0] (order: 0) Triggered by: omni.anim.skelJoint-102.2.1, omni.command.usd-1.0.1, omni.iray.settings.core-0.6.2, omni.kit.browser.asset-1.1.2, omni.kit.browser.sky-1.0.7, omni.kit.material.library-1.2.3, omni.kit.primitive.mesh-1.0.0, omni.kit.profiler.window-1.3.1, omni.kit.property.layer-1.1.2, omni.kit.property.skel-1.0.0, omni.kit.property.transform-1.0.2, omni.kit.property.usd-3.11.4, omni.kit.quicksearch.actions-0.8.7, omni.kit.quicksearch.deeptag-0.8.2, omni.kit.quicksearch.hdri-0.8.6, omni.kit.quicksearch.material-0.8.4, omni.kit.quicksearch.props-0.8.3, omni.kit.quicksearch.select-0.8.2, omni.kit.quicksearch.settings-0.8.2, omni.kit.selection-0.1.0, omni.kit.stage_column.variant-1.0.2, omni.kit.stage_templates-1.0.6, omni.kit.tests.bulk_usd_operations-1.0.0, omni.kit.widget.settings-1.0.0, omni.kit.window.extensions-1.0.2, omni.kit.window.material_graph-1.4.5, omni.kit.window.toolbar-1.2.1, omni.kit.window.usd_paths-1.0.3, omni.kit.window.viewport-0.0.0, omni.kit.xr-1.0.0, omni.kit.xr.profile.tabletar-1.0.0, omni.physx.commands-1.3.14-5.1, omni.physx.ui-1.3.14-5.1, omni.rtx.settings.core-0.5.4, omni.rtx.window.settings-0.6.0, omni.usd-1.4.5 (path: /home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/extscore/omni.kit.commands)
2021-11-15 20:06:56 [4,029ms] [Info] [omni.kit.app.plugin] [4.061s] [ext: omni.kit.commands-0.0.0] startup
2021-11-15 20:06:56 [4,036ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.usd-1.4.5] (order: 0) Triggered by: omni.anim.curve-102.1.4, omni.anim.skelJoint-102.2.1, omni.command.usd-1.0.1, omni.create.app.setup-0.2.0, omni.debugdraw-0.1.0, omni.kit.activity.model.cache_status-1.0.3, omni.kit.activity.model.file_status-1.0.2, omni.kit.activity.model.usd_status-1.0.2, omni.kit.asset_converter-1.1.42, omni.kit.browser.asset-1.1.2, omni.kit.browser.sky-1.0.7, omni.kit.capture-0.4.7, omni.kit.collaboration.viewport.camera-1.0.1, omni.kit.context_menu-1.3.2, omni.kit.hydra_texture-0.1.0, omni.kit.material.library-1.2.3, omni.kit.menu.create-1.0.1, omni.kit.menu.edit-1.0.3, omni.kit.menu.file-1.0.3, omni.kit.mesh.raycast-102.3.3, omni.kit.pointclouds-0.0.9, omni.kit.primitive.mesh-1.0.0, omni.kit.property.audio-1.0.5, omni.kit.property.bundle-1.2.4, omni.kit.property.camera-1.0.3, omni.kit.property.geometry-1.2.0, omni.kit.property.layer-1.1.2, omni.kit.property.light-1.0.4, omni.kit.property.material-1.7.2, omni.kit.property.physx-0.1.0, omni.kit.property.skel-1.0.0, omni.kit.property.transform-1.0.2, omni.kit.property.usd-3.11.4, omni.kit.quicksearch.commands-1.1.2, omni.kit.selection-0.1.0, omni.kit.stage_templates-1.0.6, omni.kit.tests.bulk_usd_operations-1.0.0, omni.kit.thumbnails.mdl-1.0.7, omni.kit.thumbnails.usd-0.5.0, omni.kit.tool.asset_exporter-1.0.8, omni.kit.tool.asset_importer-2.3.12, omni.kit.tool.collect-2.0.8, omni.kit.tool.paint-102.3.5, omni.kit.viewport_widgets_manager-1.0.3, omni.kit.widget.layers-1.5.12, omni.kit.widget.live-0.1.0, omni.kit.widget.material_preview-1.0.3, omni.kit.widget.settings-1.0.0, omni.kit.widget.stage-2.6.8, omni.kit.window.console-0.1.0, omni.kit.window.content_browser-2.4.10, omni.kit.window.file-1.3.5, omni.kit.window.material_graph-1.4.5, omni.kit.window.movie_maker-0.5.9, omni.kit.window.preferences-1.1.5, omni.kit.window.property-1.6.2, omni.kit.window.quicksearch-2.0.6, omni.kit.window.stage-2.3.4, omni.kit.window.status_bar-0.1.0, omni.kit.window.title-1.1.0, omni.kit.window.usd_paths-1.0.3, omni.kit.window.viewport-0.0.0, omni.kit.xr-1.0.0, omni.physx-1.3.14-5.1, omni.physx.commands-1.3.14-5.1, omni.physx.demos-1.3.14-5.1, omni.physx.ui-1.3.14-5.1, omni.rtx.settings.core-0.5.4, omni.rtx.window.settings-0.6.0, omni.usd.fileformat.e57-0.1.6 (path: /home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/extscore/omni.usd)
2021-11-15 20:06:56 [4,036ms] [Info] [omni.kit.app.plugin] [4.068s] [ext: omni.usd-1.4.5] startup
2021-11-15 20:06:56 [4,037ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/extscore/omni.usd/bin’ Filename: '.plugin’
2021-11-15 20:06:56 [4,038ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: ‘/home/bruno/.local/share/ov/pkg/deps/4a4ac5b063f92375d0d74eb0f2c3ac9b/plugins’ Filename: ‘omni.audiodeviceenum.plugin’
2021-11-15 20:06:56 [4,040ms] [Info] [carb] Registered plugin: omni.stageupdate.plugin (interfaces: [omni::kit::IStageUpdate v1.0]) (impl: omni.stageupdate.plugin)
2021-11-15 20:06:56 [4,040ms] [Info] [carb] Registered plugin: omni.audiodeviceenum.plugin (interfaces: [omni::audio::IAudioDeviceEnum v0.1]) (impl: omni.audiodeviceenum.plugin)
2021-11-15 20:06:56 [4,059ms] [Info] [carb] Initializing plugin: omni.stageupdate.plugin (interfaces: [omni::kit::IStageUpdate v1.0]) (impl: omni.stageupdate.plugin)
2021-11-15 20:06:56 [4,059ms] [Info] [carb] Initializing plugin: carb.audio-forge.plugin (interfaces: [carb::audio::IAudioCapture v1.0],[carb::audio::IAudioData v1.0],[carb::audio::IAudioDevice v1.0],[carb::audio::IAudioGroup v1.0],[carb::audio::IAudioPlayback v1.0],[carb::audio::IAudioUtils v1.0]) (impl: carb.audio-forge.plugin)
2021-11-15 20:06:56 [4,066ms] [Info] [carb.audio.audio] Forge audio backend = ‘PulseAudio’
2021-11-15 20:06:56 [4,291ms] [Info] [carb.audio.output] {speakers = 0x00000003, map = 0x7fff1abf5a70}
2021-11-15 20:06:56 [4,292ms] [Info] [omni.usd] initial audio volumes: (1.00, 1.00, 1.00)
2021-11-15 20:06:56 [4,297ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.asset_converter-1.1.42] (order: -100) Triggered by: omni.create-2021.3.7-rc.7, omni.kit.tool.asset_exporter-1.0.8, omni.kit.tool.asset_importer-2.3.12 (path: /home/bruno/.local/share/ov/pkg/deps/bf897eb238228a14b52d0e235dceb729/extscache/omni.kit.asset_converter-1.1.42+lx64.r.cp37)
2021-11-15 20:06:56 [4,297ms] [Info] [omni.kit.app.plugin] [4.329s] [ext: omni.kit.asset_converter-1.1.42] startup
2021-11-15 20:06:56 [4,479ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__sigaction
2021-11-15 20:06:56 [4,483ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!pthread_kill
2021-11-15 20:06:56 [4,487ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!raise
2021-11-15 20:06:56 [4,490ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!abort
2021-11-15 20:06:56 [4,493ms] [Fatal] [carb.crashreporter-breakpad.plugin] libffi.so.8!+0x2488
2021-11-15 20:06:56 [4,493ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ctypes.cpython-37m-x86_64-linux-gnu.so!PyInit__ctypes
2021-11-15 20:06:56 [4,497ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!free_keys_object
2021-11-15 20:06:56 [4,500ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!dict_dealloc
2021-11-15 20:06:56 [4,501ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ctypes.cpython-37m-x86_64-linux-gnu.so!_init
2021-11-15 20:06:56 [4,505ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!subtype_dealloc
2021-11-15 20:06:56 [4,508ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,512ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,516ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,519ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:56 [4,523ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-15 20:06:56 [4,527ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-15 20:06:56 [4,530ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-15 20:06:56 [4,534ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-15 20:06:56 [4,538ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-15 20:06:56 [4,541ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,545ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:56 [4,549ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:56 [4,552ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,556ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,560ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,564ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,567ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,571ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,574ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,578ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,582ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-15 20:06:56 [4,585ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-15 20:06:56 [4,589ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-15 20:06:56 [4,592ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-15 20:06:56 [4,596ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,599ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:56 [4,603ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-15 20:06:56 [4,607ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-15 20:06:56 [4,610ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-15 20:06:56 [4,614ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-15 20:06:56 [4,618ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-15 20:06:56 [4,621ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,625ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:56 [4,629ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:56 [4,633ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,637ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,641ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,644ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,648ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,652ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,656ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:56 [4,660ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:56 [4,663ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyFunction_FastCallDict
2021-11-15 20:06:56 [4,667ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-15 20:06:56 [4,671ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyObject_CallMethodIdObjArgs
2021-11-15 20:06:57 [4,675ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-15 20:06:57 [4,678ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin___import
2021-11-15 20:06:57 [4,682ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyCFunction_Call
2021-11-15 20:06:57 [4,686ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,690ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [4,694ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [4,698ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,702ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,705ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,710ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,713ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-15 20:06:57 [4,717ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-15 20:06:57 [4,721ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-15 20:06:57 [4,725ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-15 20:06:57 [4,729ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,732ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [4,736ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-15 20:06:57 [4,740ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-15 20:06:57 [4,744ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-15 20:06:57 [4,747ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-15 20:06:57 [4,751ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-15 20:06:57 [4,755ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,759ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [4,762ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [4,766ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,770ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,774ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,777ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,781ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,785ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,789ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,793ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,797ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-15 20:06:57 [4,800ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-15 20:06:57 [4,804ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-15 20:06:57 [4,808ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-15 20:06:57 [4,812ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,816ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [4,820ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-15 20:06:57 [4,823ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-15 20:06:57 [4,827ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-15 20:06:57 [4,830ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-15 20:06:57 [4,834ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-15 20:06:57 [4,838ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,842ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [4,846ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [4,850ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,854ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,858ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,861ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,865ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,869ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,873ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,876ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,880ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-15 20:06:57 [4,884ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-15 20:06:57 [4,887ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-15 20:06:57 [4,891ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-15 20:06:57 [4,895ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,898ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [4,902ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-15 20:06:57 [4,906ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-15 20:06:57 [4,909ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-15 20:06:57 [4,913ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-15 20:06:57 [4,917ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-15 20:06:57 [4,921ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,925ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [4,928ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [4,932ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,935ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,939ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,942ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,946ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,950ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,953ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,957ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [4,961ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-15 20:06:57 [4,964ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-15 20:06:57 [4,968ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-15 20:06:57 [4,972ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-15 20:06:57 [4,975ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [4,979ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [4,983ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-15 20:06:57 [4,986ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-15 20:06:57 [4,990ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-15 20:06:57 [4,994ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-15 20:06:57 [4,998ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-15 20:06:57 [5,001ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,005ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,009ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [5,013ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,016ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,020ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,024ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,028ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,031ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,035ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,039ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,042ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-15 20:06:57 [5,046ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-15 20:06:57 [5,050ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-15 20:06:57 [5,054ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-15 20:06:57 [5,057ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,061ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,064ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-15 20:06:57 [5,068ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-15 20:06:57 [5,071ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-15 20:06:57 [5,075ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-15 20:06:57 [5,079ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-15 20:06:57 [5,083ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,086ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,090ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [5,094ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,098ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,102ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,106ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,109ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,113ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,117ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,120ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,124ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,128ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,131ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [5,135ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,139ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,142ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [5,146ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,150ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-15 20:06:57 [5,153ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,157ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,161ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [5,165ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,168ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,171ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [5,175ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,179ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,182ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [5,187ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,190ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,194ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-15 20:06:57 [5,197ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-15 20:06:57 [5,201ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-15 20:06:57 [5,205ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-15 20:06:57 [5,209ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-15 20:06:57 [5,212ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-11-15 20:06:57 [5,216ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-11-15 20:06:57 [5,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocatorstd::string >::_M_realloc_insertstd::string&(__gnu_cxx::__normal_iterator<std::string
, std::vector<std::string, std::allocatorstd::string > >, std::string&)
2021-11-15 20:06:57 [5,223ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocatorstd::string >::_M_realloc_insertstd::string&(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocatorstd::string > >, std::string&)
2021-11-15 20:06:57 [5,226ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator const&, std::forward_iterator_tag)
2021-11-15 20:06:57 [5,229ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string)
2021-11-15 20:06:57 [5,232ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string
2021-11-15 20:06:57 [5,236ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string)
2021-11-15 20:06:57 [5,239ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocatorstd::string, std::__detail::_Identity, std::equal_tostd::string, std::hashstd::string, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocatorstd::string, std::__detail::_Identity, std::equal_tostd::string, std::hashstd::string, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2021-11-15 20:06:57 [5,243ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (
)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)
2021-11-15 20:06:57 [5,246ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-11-15 20:06:57 [5,246ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-11-15 20:06:57 [5,250ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_init_first
2021-11-15 20:06:57 [5,254ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-11-15 20:06:57 [5,254ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
hello @bruno.vetter -
I see you have the following GPUs:
| Driver Version: 470.82      | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | Intel(R) UHD Graphics (TGL GT1)  |        |     | 23890   MB | 8086      | 0          |
| 1   | NVIDIA GeForce RTX 3080 Laptop.. | Yes: 0 |     | 16384   MB | 10de      | 0          |
The Create app should pick the RTX 3080. Can you do the following to force this choice
get a terminal prompt at:
/home/YOURLOGIN/.local/share/ov/pkg/create-2021.3.7
Then execute this command to start Create (will use GPU NVIDIA GeForce RTX 3080 Laptop)
/omni.create.singlegpu.sh --/renderer/activeGpu=1
Please tell me the results. Would like to know if Create starts and is viable.
Thanks for the quick reply. It seems the gui starts up and then closes with the following log output:
bruno@bruno-Blade-17-Mid-2021-RZ09-0406:~/.local/share/ov/pkg/create-2021.3.7$ ./omni.create.singlegpu.sh --/renderer/activeGpu=1
[Info] [carb] Logging to file: /home/bruno/.nvidia-omniverse/logs/Kit/Create.Next/2021.3/kit_20211116_091032.log
[0.217s] [ext: omni.assets.plugins-0.0.0] startup
[0.219s] [ext: omni.kit.window.splash-0.0.0] startup
[0.244s] [ext: omni.kit.async_engine-0.0.0] startup
[0.251s] [ext: omni.kit.agent-0.1.0] startup
[0.252s] [ext: omni.kit.splash-0.2.1] startup
[0.258s] [ext: omni.kit.pipapi-0.0.0] startup
[0.262s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.268s] [ext: omni.usd.config-1.0.0] startup
[0.270s] [ext: omni.usd.libs-1.0.0] startup
[0.490s] [ext: omni.stats-0.0.0] startup
[0.492s] [ext: omni.gpu_foundation-0.0.0] startup
[0.504s] [ext: omni.kit.telemetry-0.1.0] startup
[0.512s] [ext: omni.usd.schema.semantics-0.0.0] startup
[Warning] [omni.telemetry.transmitter] Couldn't acquire tokens interface and initialize default tokens.
[0.519s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.523s] [ext: omni.hydra.iray-0.1.0] startup
[0.531s] [ext: omni.kit.loop-default-0.1.0] startup
[0.531s] [ext: omni.appwindow-1.0.0] startup
[0.541s] [ext: omni.client-0.1.0] startup
[0.547s] [ext: omni.kit.test-0.0.0] startup
[0.614s] [ext: omni.kit.renderer.core-0.0.0] startup
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 9a60      | ee98bced.. |
|     |                                  |        |     |            | 249c      | 1a6d9cb0.. |
| OS: Linux bruno-Blade-17-Mid-2021-RZ09-0406, Version: 5.13.0-21-generic
| Processor: 11th Gen Intel(R) Core(TM) i9-11900H @ 2.50GHz | Cores: Unknown | Logical: 16
| Total Memory (MB): 31854 | Free Memory: 28457
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2021-11-16 08:10:35 [2,820ms] [Warning] [gpu.foundation.plugin] Different GPUs have different availalbe VRAM. The texture streaming system will be limited to the lower VRAM number
[3.135s] [ext: omni.ui-2.5.3] startup
[3.149s] [ext: omni.kit.mainwindow-0.0.0] startup
[3.151s] [ext: omni.kit.uiapp-0.0.0] startup
[3.152s] [ext: omni.usd.schema.physics-1.0.0] startup
[3.161s] [ext: omni.usd.schema.anim-0.0.0] startup
[3.178s] [ext: omni.timeline-1.0.2] startup
[3.181s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[3.198s] [ext: carb.audio-0.1.0] startup
[3.221s] [ext: omni.kit.commands-0.0.0] startup
[3.227s] [ext: omni.usd-1.4.5] startup
[3.473s] [ext: omni.kit.asset_converter-1.1.42] startup
2021-11-16 08:10:36 [3,538ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__sigaction
2021-11-16 08:10:36 [3,540ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!pthread_kill
2021-11-16 08:10:36 [3,541ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!raise
2021-11-16 08:10:36 [3,543ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!abort
2021-11-16 08:10:36 [3,544ms] [Fatal] [carb.crashreporter-breakpad.plugin] libffi.so.8!+0x2488
2021-11-16 08:10:36 [3,544ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ctypes.cpython-37m-x86_64-linux-gnu.so!PyInit__ctypes
2021-11-16 08:10:36 [3,546ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!free_keys_object
2021-11-16 08:10:36 [3,548ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!dict_dealloc
2021-11-16 08:10:36 [3,548ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ctypes.cpython-37m-x86_64-linux-gnu.so!_init
2021-11-16 08:10:36 [3,550ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!subtype_dealloc
2021-11-16 08:10:36 [3,552ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,554ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,555ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,557ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,558ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-16 08:10:36 [3,560ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-16 08:10:36 [3,562ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-16 08:10:36 [3,563ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-16 08:10:36 [3,565ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-16 08:10:36 [3,566ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,568ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,569ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,571ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,573ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,574ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,576ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,578ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,579ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,581ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,582ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,584ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-16 08:10:36 [3,585ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-16 08:10:36 [3,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-16 08:10:36 [3,588ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-16 08:10:36 [3,590ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,592ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,593ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-16 08:10:36 [3,595ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-16 08:10:36 [3,597ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-16 08:10:36 [3,598ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-16 08:10:36 [3,600ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-16 08:10:36 [3,601ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,603ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,604ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,606ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,608ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,609ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,611ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,612ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,614ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,616ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,617ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,619ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-16 08:10:36 [3,621ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-16 08:10:36 [3,624ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-16 08:10:36 [3,626ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-16 08:10:36 [3,629ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin___import__
2021-11-16 08:10:36 [3,632ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyCFunction_Call
2021-11-16 08:10:36 [3,634ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,636ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,639ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,642ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,644ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,647ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,649ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,652ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-16 08:10:36 [3,654ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-16 08:10:36 [3,656ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-16 08:10:36 [3,659ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-16 08:10:36 [3,661ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,663ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,665ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-16 08:10:36 [3,666ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-16 08:10:36 [3,668ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-16 08:10:36 [3,670ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-16 08:10:36 [3,671ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-16 08:10:36 [3,673ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,675ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,676ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,678ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,679ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,681ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,682ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,684ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,686ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,687ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,689ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,690ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-16 08:10:36 [3,692ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-16 08:10:36 [3,694ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-16 08:10:36 [3,695ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-16 08:10:36 [3,697ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,699ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,700ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-16 08:10:36 [3,702ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-16 08:10:36 [3,704ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-16 08:10:36 [3,705ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-16 08:10:36 [3,707ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-16 08:10:36 [3,708ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,710ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,712ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,713ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,715ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,716ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,718ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,720ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,721ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,723ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,725ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,726ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-16 08:10:36 [3,728ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-16 08:10:36 [3,729ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-16 08:10:36 [3,732ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-16 08:10:36 [3,734ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,735ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,737ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-16 08:10:36 [3,739ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-16 08:10:36 [3,740ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-16 08:10:36 [3,742ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-16 08:10:36 [3,744ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-16 08:10:36 [3,746ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,747ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,749ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,750ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,752ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,754ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,755ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,757ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,759ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,760ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,762ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,764ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-16 08:10:36 [3,765ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-16 08:10:36 [3,767ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-16 08:10:36 [3,769ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-16 08:10:36 [3,770ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,772ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,773ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-16 08:10:36 [3,775ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-16 08:10:36 [3,777ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-16 08:10:36 [3,778ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-16 08:10:36 [3,780ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-16 08:10:36 [3,782ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,783ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,785ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,787ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,788ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,790ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,792ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,793ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,795ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,797ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,798ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,800ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2021-11-16 08:10:36 [3,802ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!object_vacall
2021-11-16 08:10:36 [3,803ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs
2021-11-16 08:10:36 [3,805ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject
2021-11-16 08:10:36 [3,807ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,808ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,810ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-16 08:10:36 [3,812ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-16 08:10:36 [3,813ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!builtin_exec
2021-11-16 08:10:36 [3,815ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict
2021-11-16 08:10:36 [3,817ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyCFunction_FastCallDict
2021-11-16 08:10:36 [3,818ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,820ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,822ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,823ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,825ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,827ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,828ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,830ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,832ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,833ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,835ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,837ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,839ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,840ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,842ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,843ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,845ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,847ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,848ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!function_code_fastcall
2021-11-16 08:10:36 [3,850ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,852ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,853ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,855ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,858ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,860ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,861ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,863ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,864ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,866ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,868ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallKeywords
2021-11-16 08:10:36 [3,869ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2021-11-16 08:10:36 [3,871ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalCodeWithName
2021-11-16 08:10:36 [3,872ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCodeEx
2021-11-16 08:10:36 [3,874ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyEval_EvalCode
2021-11-16 08:10:36 [3,875ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-11-16 08:10:36 [3,877ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-11-16 08:10:36 [3,878ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-11-16 08:10:36 [3,880ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-11-16 08:10:36 [3,881ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)
2021-11-16 08:10:36 [3,882ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-11-16 08:10:36 [3,884ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-11-16 08:10:36 [3,885ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-11-16 08:10:36 [3,887ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2021-11-16 08:10:36 [3,888ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (*)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, ...)
2021-11-16 08:10:36 [3,889ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-11-16 08:10:36 [3,889ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-11-16 08:10:36 [3,891ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_init_first
2021-11-16 08:10:36 [3,893ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-11-16 08:10:36 [3,893ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Aborted (core dumped)
Isaac Sim crashes with a similar output.
@bruno.vetter - Thanks you for doing that test. Can i ask for some system information?
type of server vendor/model
anything attached like a joystick, etc…
Sure. It’s a new Razer Blade 17 GeForce RTX 3080 2.5GHz 8-core Intel i9-11900H 32GB DDR4
Nothing attached except Bluetooth Mouse by Logitech.
I need a kernel > 5.11 to support the new hardware, so I am running Ubuntu 21.
Hi, I am also having the same problem. I have added the default Nucleus Server according to this link, and exported the user name and password for the server. Known Issues — Omniverse Robotics documentation
After clicking the launch button a black screen opens up and crashes. I have also tried with the /home/sumit/.local/share/ov/pkg/isaac_sim-2021.1.1/isaac-sim.sh -v command it also does not work. I am adding my launcher and kit log.
launcher.log (33.6 KB)
kit_20211119_172305.log (185.9 KB)
I have also tried with the doker installation on my local machine. Got this error…
[144.260s] [ext: omni.isaac.sim.base-2021.1.1] startup
2021-11-19 17:39:33 [144,247ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.isaac.sim-2021.1.1] (order: 0) Triggered by API/CLI/Config.
2021-11-19 17:39:33 [144,247ms] [Info] [omni.kit.app.plugin] [144.260s] [ext: omni.isaac.sim-2021.1.1] startup
2021-11-19 17:39:33 [144,248ms] [Info] [omni.kit.app.plugin] [144.260s] app started
2021-11-19 17:39:33 [144,536ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-11-19 17:39:33 [144,542ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long const&)
2021-11-19 17:39:33 [144,548ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2021-11-19 17:39:33 [144,555ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!std::__future_base::_State_baseV2::_M_is_deferred_future() const
2021-11-19 17:39:33 [144,563ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!void std::this_thread::sleep_for<long, std::ratio<1l, 1000000l> >(std::chrono::duration<long, std::ratio<1l, 1000000l> > const&)
2021-11-19 17:39:33 [144,570ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()
2021-11-19 17:39:33 [144,578ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-11-19 17:39:33 [144,583ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!carbOnPluginPostShutdown
2021-11-19 17:39:33 [144,583ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-11-19 17:39:33 [144,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-11-19 17:39:33 [144,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
hello @user25981 -
The problem you are experiencing is that your GPU (940MX) cannot be used with the Issac Sim product. This application needs a RTX type of card.
can you please check this, the simulator is starting now but there is nothing displaying.
https://forums.developer.nvidia.com/t/isacc-sim-starts-but-does-not-show-any-environment-or-robot-after-i-try-to-import/195801
