How to save the complete frame with bounding boxes?
**• Hardware Platform (Jetson / GPU)**jetson nx
• DeepStream Version6.0
• TensorRT Version
**• Issue Type( questions, new requirements, bugs)**question
I can run deepstream-image-meta-test example.
But the screenshot is an image of each target.The existing effects are as follows:
4
I want to save image with bounding boxes. How should I modify the program?The desired effect is shown in the figure:
Below function will encode the obj. Seems you can make one obj for the whole frame and send to encoder.
    nvds_obj_enc_process (ctx, &userData, ip_surf, obj_meta, frame_meta);
**We used this function in deepstream-image-meta-test example,and the effect of the screenshot is:
test12
test16
And this function is encapsulated, we can’t refer to it and modify it, can you help me give a function for frame encoding. Thank you so much.**
Here is the doc of the API.
https://docs.nvidia.com/metropolis/deepstream/sdk-api/group__ee__object__encoder.html#ga83f212f9db247092c2b51b6f239f7482
I want to cut the big picture, not just the target. So you mean let us refer to this source code to modify it?
Yes. you get the object as you send obj_meta to the encoder. Please change the obj_meta to the meta data which contain one bigger BBox which cover the whole picture.
