Save image frame with bounding box in C application
I am working with deepstream image meta-test example. I understood the process of saving a full-frame image. But How can I add the detected object to that frame? Please help me to add a bounding box and save a full-frame image.
Environment:
GPU Type: RTX 3070Ti
Nvidia Driver Version: 535.146.02
CUDA Version: 12.2
Operating System + Version: Ubuntu 22.04
@yuweiw @Amycao @yingliu @pshin @fanzh
Please add the probe function to the src pad of the osd.
  osd_src_pad = gst_element_get_static_pad (nvosd, "src");
  if (!osd_src_pad )
    g_print ("Unable to get src pad\n");
  else
    gst_pad_add_probe (osd_src_pad , GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, (gpointer) obj_ctx_handle, NULL);
  gst_object_unref (osd_src_pad );
Please set the frameData.saveImg to True.
Thank you for replying @yuweiw
I added whichever you mentioned. But there are no bounding boxes in full-frame images. I am attaching the c file. Please go through it.
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  GstBuffer *buf = (GstBuffer *) info->data;
  guint num_rects = 0;
  NvDsObjectMeta *obj_meta = NULL;
  guint vehicle_count = 0;
  guint person_count = 0;
  NvDsMetaList *l_frame = NULL;
  NvDsMetaList *l_obj = NULL;
  NvDsDisplayMeta *display_meta = NULL;
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
  NvOSD_RectParams *rect_params = display_meta->rect_params;
  for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
    int offset = 0;
    /* To verify  encoded metadata of cropped frames, we iterate through the
    * user metadata of each frame and if a metadata of the type
    * 'NVDS_CROP_IMAGE_META' is found then we write that to a file as
    * implemented below.
    char fileFrameNameString[FILE_NAME_SIZE];
     const char *osd_string = "OSD";
    /* For Demonstration Purposes we are writing metadata to jpeg images of
      * the first 10 frames only.
      * The files generated have an 'OSD' prefix. */
    if (frame_number < 11) {
      NvDsUserMetaList *usrMetaList = frame_meta->frame_user_meta_list;
      FILE *file;
      int stream_num = 0;
      while (usrMetaList != NULL) {
        NvDsUserMeta *usrMetaData = (NvDsUserMeta *) usrMetaList->data;
        if (usrMetaData->base_meta.meta_type == NVDS_CROP_IMAGE_META) {
          // snprintf (fileFrameNameString, FILE_NAME_SIZE, "%s_frame_%d_%d.jpg",
          //     osd_string, frame_number, stream_num++);
          snprintf (fileFrameNameString, FILE_NAME_SIZE, "new/%s_frame_%d_%d.jpg",osd_string, frame_number, stream_num++);
          NvDsObjEncOutParams *enc_jpeg_image = (NvDsObjEncOutParams *) usrMetaData->user_meta_data;
          /* Write to File */
          file = fopen (fileFrameNameString, "wb");
          fwrite (enc_jpeg_image->outBuffer, sizeof (uint8_t),enc_jpeg_image->outLen, file);
          fclose (file);
        usrMetaList = usrMetaList->next;
    for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
      obj_meta = (NvDsObjectMeta *) (l_obj->data);
      if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
        vehicle_count++;
        num_rects++;
      if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
        person_count++;
        num_rects++;
      /* To verify  encoded metadata of cropped objects, we iterate through the
       * user metadata of each object and if a metadata of the type
      char fileObjNameString[FILE_NAME_SIZE];
       * vehicles or persons for the first 100 frames only.
       * The files generated have a 'OSD' prefix. */
      if (frame_number < 100 && (obj_meta->class_id == PGIE_CLASS_ID_PERSON
              || obj_meta->class_id == PGIE_CLASS_ID_VEHICLE)) {
        NvDsUserMetaList *usrMetaList = obj_meta->obj_user_meta_list;
        FILE *file;
            snprintf (fileObjNameString, FILE_NAME_SIZE, "new/%s_%d_%d_%d_%s.jpg", osd_string, frame_number, frame_meta->batch_id, num_rects,
                obj_meta->obj_label);
            /* Write to File */
            file = fopen (fileObjNameString, "wb");
            fclose (file);
            usrMetaList = NULL;
          } else {
    display_meta = nvds_acquire_display_meta_from_pool (batch_meta);
    NvOSD_TextParams *txt_params = &display_meta->text_params[0];
    txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
    offset =
        snprintf (txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ",
        person_count);
    offset =
        snprintf (txt_params->display_text + offset, MAX_DISPLAY_LEN,
        "Vehicle = %d ", vehicle_count);
    /* Now set the offsets where the string should appear */
    txt_params->x_offset = 10;
    txt_params->y_offset = 12;
    /* Font , font-color and font-size */
    txt_params->font_params.font_name = "Serif";
    txt_params->font_params.font_size = 10;
    txt_params->font_params.font_color.red = 1.0;
    txt_params->font_params.font_color.green = 1.0;
    txt_params->font_params.font_color.blue = 1.0;
    txt_params->font_params.font_color.alpha = 1.0;
    /* Text background color */
    txt_params->set_bg_clr = 1;
    txt_params->text_bg_clr.red = 0.0;
    txt_params->text_bg_clr.green = 0.0;
    txt_params->text_bg_clr.blue = 0.0;
    txt_params->text_bg_clr.alpha = 1.0;
    nvds_add_display_meta_to_frame (frame_meta, display_meta);
  g_print ("Frame Number = %d Number of objects = %d "
      "Vehicle Count = %d Person Count = %d\n",
      frame_number, num_rects, vehicle_count, person_count);
  frame_number++;
  return GST_PAD_PROBE_OK;
pgie_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer ctx)
  GstMapInfo inmap = GST_MAP_INFO_INIT;
  if (!gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
    GST_ERROR ("input buffer mapinfo failed");
    return GST_PAD_PROBE_DROP;
  NvBufSurface *ip_surf = (NvBufSurface *) inmap.data;
  gst_buffer_unmap (buf, &inmap);
  const gchar *calc_enc_str = g_getenv ("CALCULATE_ENCODE_TIME");
  gboolean calc_enc = !g_strcmp0 (calc_enc_str, "yes");
    /* For demonstration purposes, we will encode the first 10 frames. */
    if(frame_count <= 10) {
      NvDsObjEncUsrArgs frameData = { 0 };
      /* Preset */
      frameData.isFrame = 1;
      /* To be set by user */
      frameData.saveImg = TRUE;
      frameData.attachUsrMeta = attach_user_meta;
      /* Set if Image scaling Required */
      frameData.scaleImg = FALSE;
      frameData.scaledWidth = 0;
      frameData.scaledHeight = 0;
      /* Quality */
      frameData.quality = 80;
      /* Set to calculate time taken to encode JPG image. */
      if (calc_enc) {
        frameData.calcEncodeTime = 1;
      /* Main Function Call */
      nvds_obj_enc_process (ctx, &frameData, ip_surf, NULL, frame_meta);
        vehicle_count++;
        num_rects++;
        person_count++;
        num_rects++;
      /* Conditions that user needs to set to encode the detected objects of
       * interest. Here, by default all the detected objects are encoded.
       * For demonstration, we will encode the first object in the frame. */
      if ((obj_meta->class_id == PGIE_CLASS_ID_PERSON
          && num_rects == 1) {
        NvDsObjEncUsrArgs objData = { 0 };
        objData.saveImg = save_img;
        objData.attachUsrMeta = attach_user_meta;
        objData.scaleImg = FALSE;
        objData.scaledWidth = 0;
        objData.scaledHeight = 0;
        /* Preset */
        objData.objNum = num_rects;
        /* Quality */
        objData.quality = 80;
        if (calc_enc) {
          objData.calcEncodeTime = 1;
        /*Main Function Call */
        nvds_obj_enc_process (ctx, &objData, ip_surf, obj_meta, frame_meta);
  nvds_obj_enc_finish (ctx);
  frame_count++;
**In main Function:**
  if (!osd_src_pad )
  else
    gst_pad_add_probe (osd_src_pad , GST_PAD_PROBE_TYPE_BUFFER, osd_sink_pad_buffer_probe, (gpointer) obj_ctx_handle, NULL);
    if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER, osd_sink_pad_buffer_probe, (gpointer) obj_ctx_handle, NULL);
  gst_object_unref (osd_sink_pad);
  if (!pgie_src_pad)
  else
    gst_pad_add_probe (pgie_src_pad, GST_PAD_PROBE_TYPE_BUFFER, pgie_src_pad_buffer_probe, (gpointer) obj_ctx_handle, NULL);
  gst_object_unref (pgie_src_pad);
You use the nvds_obj_enc_process API in the probe of pgie, but bbox is drawn in nvdsosd plugin. So you need to move the code to the probe function after the nvdsosd plugin.
Hello @yuweiw
I just tried
  if (!osd_src_pad )
  else
    gst_pad_add_probe (osd_src_pad , GST_PAD_PROBE_TYPE_BUFFER, pgie_src_pad_buffer_probe, (gpointer) obj_ctx_handle, NULL);
The cropped images are saved along with bounding boxes. However, the full-frame image is saved only once with all detected objects with bounding boxes.(frame-0)
I have not changed anything in pgie_src_pad_buffer_probe.
Should I change anything, please share any references so that they help new beginners like me can understand.
Thank You.
OK, you can refer the source code I attached, based on deepstream-image-meta-test.
And we suggest you refer to the Guide to learn some basic knowledge about Gstreamer and DeepStream.
deepstream_image_meta_test.c (16.7 KB)
Thank you for your time @yuweiw. Sorry for the late reply.
The frames are saved with bounding boxes.
Will learn the basics of Deepstream.
Thank You
