Saving Full Image Frame (Uncropped) with Bounding Box
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version DS 5.1
• JetPack Version (valid for Jetson only) 4.5.1
Hi, I would like to know how can I save the full image frame (uncropped) with bounding box shown as a jpeg image. I’ve seen the deepstream_image_meta_test source code and am currently using the codes but it only saves the raw images without the bounding box.
Can you make one object meta data with the dimension of the full frame to save the full frame?
hi kesong,
yes, my current codes modifies the object meta to save the full frame, the code is as below
static GstPadProbeReturn
pgie_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer ctx)
  GstBuffer *buf = (GstBuffer *) info->data;
  GstMapInfo inmap = GST_MAP_INFO_INIT;
  if (!gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
    GST_ERROR ("input buffer mapinfo failed");
    return GST_FLOW_ERROR;
  NvBufSurface *ip_surf = (NvBufSurface *) inmap.data;
  gst_buffer_unmap (buf, &inmap);
  NvDsObjectMeta *obj_meta = NULL;
  NvDsMetaList *l_frame = NULL;
  NvDsMetaList *l_obj = NULL;
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
  for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next)
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
    guint num_rects = 0;
    for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next)
      obj_meta = (NvDsObjectMeta *) (l_obj->data);
      if (obj_meta->class_id == 0) {
        num_rects++;
      /* Conditions that user needs to set to encode the detected objects of
       * interest. Here, by default all the detected objects are encoded.
       * For demonstration, we will encode the first object in the frame */
      if ( frame_meta->source_id == 0 && obj_meta->class_id == 0 && num_rects == 1 )
        NvDsObjEncUsrArgs userData = { 0 };
        /* To be set by user */
        userData.saveImg = TRUE;
        userData.attachUsrMeta = TRUE;
        /* Set if Image scaling Required */
        userData.scaleImg = FALSE;
        userData.scaledWidth = 0;
        userData.scaledHeight = 0;
        /* Preset */
        userData.objNum = num_rects;
        obj_meta->rect_params.width = frame_meta->source_frame_width ;
        obj_meta->rect_params.height = frame_meta->source_frame_height ;
        obj_meta->rect_params.top = 0.0f ;
        obj_meta->rect_params.left = 0.0f ;
        nvds_obj_enc_process (ctx, &userData, ip_surf, obj_meta, frame_meta);
  nvds_obj_enc_finish (ctx);
  return GST_PAD_PROBE_OK;
both images saved in this function and in the osd_sink_pad_buffer_probe() function saves the full frame but without bounding boxes. would like to know how can I save the images with the bounding boxes.
BBox will draw onto video in nvdsosd. Please put the probe after nvdsosd.
This is the function I referenced from the deepstream_image_meta_test source code
/* osd_sink_pad_buffer_probe will extract metadata received on OSD sink pad
 * and update params for drawing rectangle, object information. We also iterate
 * through the user meta of type "NVDS_CROP_IMAGE_META" to find image crop meta
 * and demonstrate how to access it.*/
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  guint vehicle_count = 0;
  guint person_count = 0;
  NvDsDisplayMeta *display_meta = NULL;
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
      l_frame = l_frame->next) {
    int offset = 0;
    for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
      if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
        vehicle_count++;
        num_rects++;
      if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
        person_count++;
        num_rects++;
      /* To verify  encoded metadata of cropped objects, we iterate through the
       * user metadata of each object and if a metadata of the type
       * 'NVDS_CROP_IMAGE_META' is found then we write that to a file as
       * implemented below.
      char fileNameString[FILE_NAME_SIZE];
      const char *osd_string = "OSD";
      int obj_res_width = (int) obj_meta->rect_params.width;
      int obj_res_height = (int) obj_meta->rect_params.height;
      if(prop.integrated) {
        obj_res_width = GST_ROUND_DOWN_2(obj_res_width);
        obj_res_height = GST_ROUND_DOWN_2(obj_res_height);
      snprintf (fileNameString, FILE_NAME_SIZE, "%s_%d_%d_%d_%s_%dx%d.jpg",
          osd_string, frame_number, frame_meta->source_id, num_rects,
          obj_meta->obj_label, obj_res_width, obj_res_height);
      /* For Demonstration Purposes we are writing metadata to jpeg images of
       * only vehicles for the first 100 frames only.
       * The files generated have a 'OSD' prefix. */
      if (frame_number < 100 && obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
        NvDsUserMetaList *usrMetaList = obj_meta->obj_user_meta_list;
        FILE *file;
        while (usrMetaList != NULL) {
          NvDsUserMeta *usrMetaData = (NvDsUserMeta *) usrMetaList->data;
          if (usrMetaData->base_meta.meta_type == NVDS_CROP_IMAGE_META) {
            NvDsObjEncOutParams *enc_jpeg_image =
                (NvDsObjEncOutParams *) usrMetaData->user_meta_data;
            /* Write to File */
            file = fopen (fileNameString, "wb");
            fwrite (enc_jpeg_image->outBuffer, sizeof (uint8_t),
                enc_jpeg_image->outLen, file);
            fclose (file);
            usrMetaList = NULL;
          } else {
            usrMetaList = usrMetaList->next;
Follow by the following code to add the probe
  NVGSTDS_BIN_ADD_GHOST_PAD (instance_bin->bin, last_elem, "sink");
  if (config->osd_config.enable) {
    NVGSTDS_ELEM_ADD_PROBE (instance_bin->all_bbox_buffer_probe_id,
        instance_bin->osd_bin.nvosd, "sink",
        osd_sink_pad_buffer_probe, GST_PAD_PROBE_TYPE_BUFFER, instance_bin);
  } else {
        instance_bin->sink_bin.bin, "sink",
However, I’m still getting the raw images. Able to advise the proper way of doing?
sink pad of nvdsosd is the input buffer of nvdsosd. Please put probe function after that.
