In my GUI, Collect Ftrace events
is not appeared. (attach my view)
Is there any documenation to view Collect Ftrace events
Reference
https://docs.nvidia.com/nsight-systems/UserGuide/index.html#linux-x86-64
Reference
I am surprised that the Ftrace options are not showing. @liuyis can you take a look at that?
Meanwhile, you can use the CLI to collect the ftrace data and then open in the GUI.
Hi @sakaia, could you manually login the target system using the same user (i.e. root
), and share the results of cat /sys/kernel/debug/tracing/available_events
Thank you for your suggestion.
I am currently using docker container.
I add -v /sys/kernel/debug:/sys/kernel/debug
to docker run and works fine.
