Isaac Sim Version
☑ 5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
☑ Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: RTX 4090
- Driver Version: 550.120
Topic Description
Detailed Description
Firstly:
I am creating a
RTXlidarusingomni.kit.commands.execute,https://docs.isaacsim.omniverse.nvidia.com/latest/sensors/isaacsim_sensors_rtx_annotators.html
I’d like to know how to set the properties of an annotators in isaacsim5.0 after creating one, such as the
intensityandtimestampinIsaacExtractRTXSensorPointCloudNoAccumulator. I haven’t found any relevant examples.When using isaacsim4.5, I set these parameters when initializing annotators,
lidar_config = "Hesai_XT32_SD10" _, sensor = omni.kit.commands.execute( "IsaacSensorCreateRtxLidar", path="/lidar", parent="/World/h1/imu_link", config=lidar_config, translation=(0.2, 0, 0.2), orientation=Gf.Quatd(1,0,0,0), ) render_product = rep.create.render_product(sensor.GetPath(), [1, 1]) lidar = rep.AnnotatorRegistry.get_annotator("RtxSensorCpuIsaacCreateRTXLidarScanBuffer") lidar.initialize(outputTimestamp=True, transformPoints=False) lidar.attach(render_product)but I always get an error in version 5.0.
_, sensor = omni.kit.commands.execute( "IsaacSensorCreateRtxLidar", path="/sensor", parent="/World/h1/imu_link", config="Example_Rotary", translation=(0, 0, 1.0), orientation=Gf.Quatd(1.0, 0.0, 0.0, 0.0), # Gf.Quatd is w,i,j,k ) # RTX sensors are cameras and must be assigned to their own render product hydra_texture = rep.create.render_product(sensor.GetPath(), [1, 1], name="Isaac") lidar=rep.AnnotatorRegistry.get_annotator("IsaacExtractRTXSensorPointCloudNoAccumulator") lidar.initialize(outputTimestamp=True) lidar.attach(hydra_texture)Error is:
2025-08-15T02:49:18Z [38,865ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last): 2025-08-15T02:49:18Z [38,865ms] [Error] [omni.kit.app._impl] [py stderr]: File "/media/nav1/DATA4/isaacsim50_work/H1_sim50/entry50.py", line 85, in <module> 2025-08-15T02:49:18Z [38,865ms] [Error] [omni.kit.app._impl] [py stderr]: lidar.attach(hydra_texture) 2025-08-15T02:49:18Z [38,865ms] [Error] [omni.kit.app._impl] [py stderr]: File "/media/nav1/DATA4/isaacsim50_work/isaacsim/_build/linux-x86_64/release/extscache/omni.replicator.core-1.12.10+107.3.0.lx64.r.cp311/omni/replicator/core/scripts/annotators.py", line 607, in attach 2025-08-15T02:49:18Z [38,875ms] [Error] [omni.kit.app._impl] [py stderr]: activated_result = sdg_iface.activate_node_template( 2025-08-15T02:49:18Z [38,875ms] [Error] [omni.kit.app._impl] [py stderr]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ 2025-08-15T02:49:18Z [38,875ms] [Error] [omni.kit.app._impl] [py stderr]: File "/media/nav1/DATA4/isaacsim50_work/isaacsim/_build/linux-x86_64/release/extscache/omni.syntheticdata-0.6.13+b0a86421.lx64.r.cp311/omni/syntheticdata/scripts/SyntheticData.py", line 1608, in activate_node_template 2025-08-15T02:49:18Z [38,875ms] [Error] [omni.kit.app._impl] [py stderr]: self._set_node_attributes(node_path, attributes) 2025-08-15T02:49:18Z [38,875ms] [Error] [omni.kit.app._impl] [py stderr]: File "/media/nav1/DATA4/isaacsim50_work/isaacsim/_build/linux-x86_64/release/extscache/omni.syntheticdata-0.6.13+b0a86421.lx64.r.cp311/omni/syntheticdata/scripts/SyntheticData.py", line 1488, in _set_node_attributes 2025-08-15T02:49:18Z [38,876ms] [Error] [omni.kit.app._impl] [py stderr]: raise SyntheticDataException(f"invalid node attribute {nodePath}.{attrName}") 2025-08-15T02:49:18Z [38,876ms] [Error] [omni.kit.app._impl] [py stderr]: omni.syntheticdata.scripts.SyntheticData.SyntheticDataException: invalid node attribute /Render/PostProcess/SDGPipeline/Isaac_IsaacExtractRTXSensorPointCloudNoAccumulator.inputs:outputTimestamp
Secondly:
When I use
path="/sensor",
lidar = rep.AnnotatorRegistry.get_annotator("IsaacExtractRTXSensorPointCloudNoAccumulator")
lidar.initialize()
simulation_app.update()
while simulation_app.is_running():
my_world.step(render=True)
if my_world.is_stopped():
reset_needed = True
if my_world.is_playing():
print(lidar.get_data())
print("running...")
simulation_app.close()
to create an RTXLidar in IsaacSim 5.0, and then use the get_data() method to get the data, the data field in the result dictionary is all 0. What is the problem? I am using the Simple_Warehouse/warehouse.usd asset.
