how to set tx2 usb3.0 port worked at device mode? we want use this port to make gadget function
my tx2 is with R28.2
Please refer to [url]https://devtalk.nvidia.com/default/topic/1014096/jetson-tx2/how-to-set-tx2-otg-usb-as-device-mode-/post/5205500/#5205500[/url]
hi DaneLLL:
thank for you reply
i have already change the code with both dts and dtsi and i rebuild dtb update to tx2 done
but it also can’t work,when i run echo 0x1 > /sys/class/extcon/extcon0/state
dmesg show me that the 3550000.xudc device mode on
i think my 3.0 host controller is 3530000 xhci host controller
[ 145.836236] tegra-xotg xotg: update_vbus_state: VBUS detected
[ 145.998830] tegra-usb-cd usb_cd: notification status (0x0, 0x10)
[ 146.004920] tegra-usb-cd usb_cd: connected to CDP
[ 146.009740] tegra-usb-cd usb_cd: set current 0ma
[ 146.014461] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 146.023180] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 146.028782] tegra-xudc-new 3550000.xudc: device mode on
root@tegra-ubuntu:/home/nvidia# echo 0x1 > /sys/class/extcon/extcon0/state
I just wanted to clarify…is this a custom board? If it is the development carrier board, then the USB3 full-sized connector is not wired for device mode and cannot do this. The micro-USB on the dev carrier is wired for OTG, but only for USB2.
