The fisrt Des960 with 4 Ser 933 with VC support.
The second Des960 with 4 Ser933 with VC support
I used all the xavier csi port (A-H) as 4 four lanes.
My dts file as below:
Should below vc-id are 0 and 1?
Could you check the trace log for the failed case.
port@6 {
status = "okay";
reg = <6>;
ar231_vi_in2: endpoint {
status = "okay";
vc-id = <2>;
port-index = <5>; //use CSI G and H as 4 lanes for 960 port 1
bus-width = <4>;
remote-endpoint = <&ar231_csi_out2>;
port@7 {
status = "okay";
reg = <7>;
ar231_vi_in3: endpoint {
status = "okay";
vc-id = <3>;
bus-width = <4>;
remote-endpoint = <&ar231_csi_out3>;
