How to setup linter (in VScode) for PIP installed isaacsim?
I used to configure my new projects following the .vscode provided in the downloaded files, specifically by specifying the module paths in the settings.json file, like this:
    "python.analysis.extraPaths": [
        "exts/isaacsim.app.about",
        "exts/isaacsim.app.selector",
        "exts/isaacsim.app.setup",
Now, I am trying to migrate to the pip-installed IsaacSim 4.5.0. I found that running pip install isaacsim seems to overwrite the manually imported settings, causing an issue where VScode cannot analyze the APIs under the isaacsim namespace. I would like to know if other configuration methods exist to resolve this issue."
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Starting with version 4.5 I have this problem even when using the workstation installation and simply open the isaacsim directory.
While the old (but deprecated) imports still work fine!
Do not use pip to install (and don’t use environments ever installed via pip) and specify the paths in `settings.json’ work for my VSCode, but I haven’t found a pip-compatible method.
Which file is being overwritten during pip install isaacsim? I did not notice any changes in the .vscode/settings.json file.
Could you please share the detailed steps you followed to set up the linter and reproduce the issue? This will help us better understand and resolve the problem.
Here are the details:
I created a new environment using conda to install Isaac Sim. After running pip install isaacsim, I found the isaacsim folder in "$CONDA_PREFIX"/python3.10/site-packages/. When VSCode analyzes the packages, I noticed that it treats the paths under this folder as importable objects.
$ ls "$CONDA_PREFIX"/lib/python3.10/site-packages/isaacsim
apps  exts  extscache  extsDeprecated  extsPhysics  extsUser  __init__.py  LICENSE.txt  __pycache__  VERSION
You can see that this ls result exactly matches the imports I showed in the previous image.
To configure VSCode, I referred to older versions and wrote a settings.json file, i.e., adding all paths under "$CONDA_PREFIX"/lib/python3.10/site-packages/isaacsim/exts to "python.analysis.extraPaths" (I use absolute paths here).
However, this doesn’t fully work—paths starting with isaacsim are ignored. They cannot overwrite the default imports from"$CONDA_PREFIX"/lib/python3.10/site-packages/isaacsim, while paths that don’t start with isaacsim such as omni.isaac.repl are properly recognized in VSCode.
@DiscreteWaveletTransform have you tried the workstation installation?
I have more or less the same problem there, only that underisaacsim I only find the contents of the __init__.py file.
I assume some renaming could fix this problem, but I am not sure if that’s the best idea.
@johannes.pitz Using the workstation installation in a clean environment which never installed isaacsim via pip works for me:
My settings.json includes "python.analysis.autoImportCompletions": true,
and the list of "python.analysis.extraPaths". I copied the default list in the workstation folder and replaced the keys with corresponding absolute paths.
However, of course, there will still be an unfindable SimulationApp.
Hm, interesting. For me it is the other way around.
(Note: I don’t install isaacsim at all, I just use the isaacsim/python.sh that comes with the isaacsim download.)
I have a similar problem when using Docker image built from Isaac Lab’s Dockerfile (base image: nvcr.io/nvidia/isaac-sim, version: 4.5.0). VS Code finds only isaacsim in /isaac-sim/python_packages/isaacsim/__init__.py and not any other isaacsim modules (isaacsim.core.prims, isaacsim.core.utils.types, etc.).
I’m using the same boilerplate paths for settings.json (with proper absolute path). Interestingly, those paths work for pxr, omni, carb, etc. modules, only isaacsim.* seems to not work.
Did someone manage to fix this issue?
Hi, I ended up renaming the /isaac-sim/python_packages/isaacsim directory.
I tried to work around that with "python.analysis.excludePaths" settings but wasn’t successful.
It’s fine though, you don’t need to import it anyways (just do from isaacsim.simulation_app import SimulationApp).
Please let me know if you find a less intrusive fix.
There is a tool that might be helpful:
manager_isaacsim_link
@siky47 Cool, let me try it out.
This tool works like a charm for me (IsaacLab on Windows with IsaacSim installed via pip).
