Improvement Suggestions for Isaac Lab Installation Documentation
Improvements are needed for the Isaac Lab documentation. Two installation methods are provided at the link below:
https://isaac-sim.github.io/IsaacLab/source/setup/installation/index.html
1. pip install method
The installation method suggested is not sufficient on its own. The following process must be completed first:
pip install isaacsim==4.0.0.0 --extra-index-url https://pypi.nvidia.com
Even after successfully completing this process, using it for development proves difficult.
The link below includes information about installation through the Omniverse Launcher, which is not necessary for development:
https://isaac-sim.github.io/IsaacLab/source/setup/developer.html
However, the use is hindered as autocomplete or IntelliSense support for related libraries is lacking.
Performing setup_python_env properly is impossible without the _isaac_sim symbolic link. While someone who has read Isaac Sim installed from binaries thoroughly would understand, those who have only seen the pip installation guide might find it difficult. The documentation needs clearer explanations.
2. using binaries install method
It is hard to discern the intent behind the Omniverse Launcher URL provided:
As demonstrated by the following post, there is confusion about what needs to be downloaded, necessitating improvements:
Furthermore, even after launching, installing version 4.0 is challenging as it is not the default and is hidden:
This oversight may have been mine, but clearer information regarding the need for Isaac Sim 4.0 when using the Isaac Lab would be appreciated. Since the previous versions were labeled as 2023.1.1, etc., I did not realize a different version was necessary.
I totally agree with you that the documentation is confused.
I went over the instructions from both isaac lab and isaac sim. I successfully installed both isaac lab and sim through pip install method. I did not run the setup_python_env in the vscode, but I could run the examples from isaac lab folders. I am not sure if it is necessary to run this command if we are using pip install method to install isaac sim.
If we used pip install method, do we still need to install the isaac sim in the omniuniverse-launch? If not, we probably do not have _isaac_sim.
I also noticed that from omni.isaac.lab.app import AppLauncher is not defined, but the code can be executed. Probably I still made some mistakes during the installation.
Hi there. I agree at this point I am confused.
I had installed Isaac Sim 4.1.0 from the launcher on Windows.
Now I wish to install Isaac Lab.
But, exactly where do I start???
I have ROS2 Humble installed as well. I have successfully started up Isaac Sim 4.1.0 and the ROS2 bridge was enabled. Then I shut that down.
So, I cloned Isaac Lab into my ROS2 workspace (C:\isaac_ws\src)?
Created the Isaac Sim Symbolic Link.
Then tried to run isaaclab.bat --install:
C:\isaac_ws\src\IsaacLab>isaaclab.bat --install
[INFO] Installing extensions inside the Isaac Lab repository…
“C:\isaac_ws\src\IsaacLab\source\extensions\omni.isaac.lab”
module: “C:\isaac_ws\src\IsaacLab\source\extensions\omni.isaac.lab”
C:\isaac_ws\src\IsaacLab_isaac_sim\kit\python\kit.exe: No module named pip
There was an error running python.
“C:\isaac_ws\src\IsaacLab\source\extensions\omni.isaac.lab_assets”
module: “C:\isaac_ws\src\IsaacLab\source\extensions\omni.isaac.lab_assets”
“C:\isaac_ws\src\IsaacLab\source\extensions\omni.isaac.lab_tasks”
module: “C:\isaac_ws\src\IsaacLab\source\extensions\omni.isaac.lab_tasks”
[INFO] Installing extra requirements such as learning frameworks…
[INFO] Installing all rl-frameworks.
[INFO] Setting up vscode settings…
Then tried to verify installation:
C:\isaac_ws\src\IsaacLab>isaaclab.bat -p source\standalone\tutorials\00_sim\create_empty.py
[INFO] Using python from: C:\isaac_ws\src\IsaacLab\_isaac_sim\python.bat
File “C:\isaac_ws\src\IsaacLab\source\standalone\tutorials\00_sim\create_empty.py”, line 20, in
ModuleNotFoundError: No module named ‘omni.isaac.lab’
So, that was a no go.
I am not sure how to proceed.
Any ideas? Any help would be appreciated, thanks in advance.
Jay
