How to uninstall cuda 12.4
i am trying to uninstall cuda 12.4 because I need cuda 12.1, as this version is supported by pytorch.
The documentation says uninstalling will work via
sudo /usr/local/cuda-12.4/bin/cuda-uninstaller
However, I have
ls /usr/local/cuda/bin
bin2c              crt       cuda-gdbserver  fatbinary  nsight_ee_plugins_manage.sh  nsys-ui              nvcc.profile  nvprof   ptxas
computeprof        cudafe++  cu++filt        ncu        nsight-sys                   nvcc                 nvdisasm      nvprune
compute-sanitizer  cuda-gdb  cuobjdump       ncu-ui     nsys                         __nvcc_device_query  nvlink        nvvp
and
s /usr/local/cuda-12/bin
ls /usr/local/cuda-12.4/bin
so, no uninstaller available.
BTW, is it normal to have cuda, cuda-12 and cuda 12.4 or did I wrongly install too many versions?
Thank you
If you installed cuda using the package manager, you’ll also have to use it to uninstall.
Deleting the directory where all the cuda configs are located seemed to work for me
sudo rm -r /usr/local/cuda-12.4/
sudo apt clean && sudo apt autoclean
