My Jetson AGX Orin SPE firmware has been updated, but it seems that SPE can only be updated via command line in the L4T directory? Is there a command that can update directly within the Jetson system? Since my devices are already in mass production and deployed, updating them one by one on a computer is very time-consuming. It would be great if there was a way to update the system directly using an OTA-like method.
You can take a look at Software Packages and the Update Mechanism — NVIDIA Jetson Linux Developer Guide
SPE FW is also part of bootloader, and OTA may help.
br
ChenJian
Is the bootloader located in the QSPI flash? Can I simply update the SPE by composing the new QSPI flash firmware?
Also, if I only have the new SPE firmware but not the complete bootloader firmware, can I still update it?
- for components in QSPI flash, you can take a look at the xml file after a successful flash, or check the corresponding EMMC_CFG. yes, most BL components are stored in QSPI flash.
- For single partition update, you can take a look at Update and Redundancy — NVIDIA Jetson Linux Developer Guide
- For development purpose and if RCM flash is available, flash -k may be a better choice.
br
ChenJian
