NO.
That’s because you boot from the recovery partition, and that’s expected.
Please change back to either the default extlinux or kernel partition and capture the log again.
[0000.063] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.068] I> t234-A01-0-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.079] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0x0, rst_level: 0x0
[0000.090] I> Task: SE error check
[0000.094] I> Task: Bootchain select WAR set
[0000.098] I> Task: Enable SLCG
[0000.101] I> Task: CRC check
[0000.103] I> Task: Initialize MB2 params
[0000.108] I> MB2-params @ 0x40060000
[0000.111] I> Task: Crypto init
[0000.114] I> Task: Perform MB1 KAT tests
[0000.118] I> Task: NVRNG health check
[0000.121] I> NVRNG: Health check success
[0000.125] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.131] I> Task: Enabling and initialization of Bandwidth limiter
[0000.137] I> No request to configure MBWT settings for any PC!
[0000.143] I> Task: Secure debug controls
[0000.147] I> Task: strap war set
[0000.150] I> Task: Initialize SOC Therm
[0000.154] I> Task: Program NV master stream id
[0000.158] I> Task: Verify boot mode
[0000.164] I> Task: Alias fuses
[0000.167] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.174] I> Task: Print SKU type
[0000.177] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.182] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.186] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.191] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.195] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.204] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.212] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.217] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.221] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.229] I> FUSE_SKU_INFO_0 = 0xd3
[0000.232] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.236] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.240] I> SKU: Prod
[0000.242] I> Task: Boost clocks
[0000.245] I> Initializing PLLC2 for AXI_CBB.
[0000.249] I> AXI_CBB : src = 35, divisor = 0
[0000.254] I> Task: Voltage monitor
[0000.257] I> VMON: Vmon re-calibration and fine tuning done
[0000.262] I> Task: UPHY init
[0000.267] I> HSIO UPHY init done
[0000.270] W> Skipping GBE UPHY config
[0000.274] I> Task: Boot device init
[0000.277] I> Boot_device: QSPI_FLASH instance: 0
[0000.282] I> Qspi clock source : pllc_out0
[0000.286] I> QSPI Flash: Macronix 64MB
[0000.289] I> QSPI-0l initialized successfully
[0000.294] I> Task: TSC init
[0000.296] I> Task: Load membct
[0000.299] I> RAM_CODE 0x4000401
[0000.302] I> Loading MEMBCT
[0000.305] I> Slot: 1
[0000.307] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.313] I> Binary name: MEM-BCT-0
[0000.316] I> Size of crypto header is 8192
[0000.320] I> Size of crypto header is 8192
[0000.324] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.330] I> BCH of MEM-BCT-0 read from storage
[0000.334] I> BCH address is : 0x40050000
[0000.338] I> MEM-BCT-0 header integrity check is success
[0000.344] I> Binary magic in BCH component 0 is MEM0
[0000.348] I> component binary type is 0
[0000.352] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.359] I> MEM-BCT-0 binary is read from storage
[0000.364] I> MEM-BCT-0 binary integrity check is success
[0000.369] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.376] I> RAM_CODE 0x4000401
[0000.381] I> RAM_CODE 0x4000401
[0000.385] I> Task: Load Page retirement list
[0000.389] I> Task: SDRAM params override
[0000.393] I> Task: Save mem-bct info
[0000.396] I> Task: Carveout allocate
[0000.399] I> RCM blob carveout will not be allocated
[0000.404] I> Update CCPLEX IST carveout from MB1-BCT
[0000.409] I> ECC region[0]: Start:0x0, End:0x0
[0000.413] I> ECC region[1]: Start:0x0, End:0x0
[0000.418] I> ECC region[2]: Start:0x0, End:0x0
[0000.422] I> ECC region[3]: Start:0x0, End:0x0
[0000.426] I> ECC region[4]: Start:0x0, End:0x0
[0000.430] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.436] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.441] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.446] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.450] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.461] I> allocated(CO:43) base:0x47c000000 size:0x4000000 align: 0x200000
[0000.468] I> allocated(CO:39) base:0x479e00000 size:0x2200000 align: 0x10000
[0000.475] I> allocated(CO:20) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.482] I> allocated(CO:24) base:0x474000000 size:0x2000000 align: 0x2000000
[0000.489] I> allocated(CO:28) base:0x472000000 size:0x2000000 align: 0x2000000
[0000.496] I> allocated(CO:22) base:0x478000000 size:0x1000000 align: 0x1000000
[0000.503] I> allocated(CO:35) base:0x479000000 size:0xe00000 align: 0x10000
[0000.510] I> allocated(CO:02) base:0x471800000 size:0x800000 align: 0x800000
[0000.517] I> allocated(CO:03) base:0x471000000 size:0x800000 align: 0x800000
[0000.524] I> allocated(CO:06) base:0x470800000 size:0x800000 align: 0x800000
[0000.531] I> allocated(CO:56) base:0x470000000 size:0x800000 align: 0x200000
[0000.538] I> allocated(CO:07) base:0x46fc00000 size:0x400000 align: 0x400000
[0000.545] I> allocated(CO:33) base:0x46f800000 size:0x400000 align: 0x200000
[0000.552] I> allocated(CO:23) base:0x46f600000 size:0x200000 align: 0x200000
[0000.559] I> allocated(CO:01) base:0x46f500000 size:0x100000 align: 0x100000
[0000.566] I> allocated(CO:04) base:0x46f400000 size:0x100000 align: 0x100000
[0000.573] I> allocated(CO:05) base:0x46f300000 size:0x100000 align: 0x100000
[0000.580] I> allocated(CO:08) base:0x46f200000 size:0x100000 align: 0x100000
[0000.587] I> allocated(CO:09) base:0x46f100000 size:0x100000 align: 0x100000
[0000.594] I> allocated(CO:15) base:0x46f000000 size:0x100000 align: 0x100000
[0000.601] I> allocated(CO:17) base:0x46ef00000 size:0x100000 align: 0x100000
[0000.608] I> allocated(CO:27) base:0x46ee00000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:42) base:0x46ed00000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:54) base:0x46ec80000 size:0x80000 align: 0x80000
[0000.628] I> allocated(CO:34) base:0x46ec70000 size:0x10000 align: 0x10000
[0000.635] I> allocated(CO:72) base:0x46ea70000 size:0x200000 align: 0x10000
[0000.642] I> allocated(CO:47) base:0x46e600000 size:0x400000 align: 0x200000
[0000.649] I> allocated(CO:48) base:0x46ea50000 size:0x20000 align: 0x10000
[0000.655] I> allocated(CO:69) base:0x46ea30000 size:0x20000 align: 0x10000
[0000.662] I> allocated(CO:49) base:0x46ea20000 size:0x10000 align: 0x10000
[0000.669] I> allocated(CO:50) base:0x46ea10000 size:0x10000 align: 0x10000
[0000.676] I> NSDRAM base: 0x80000000, end: 0x46ea70000, size: 0x3eea70000
[0000.682] I> Task: Thermal check
[0000.686] I> max_chip_limit = 105
[0000.689] I> min_chip_limit = -28
[0000.692] I> max temp read = 45
[0000.695] I> min temp read = 44
[0000.698] I> Task: Update FSI SCR with thermal fuse data
[0000.703] I> Task: Enable WDT 5th expiry
[0000.707] I> Task: I2C register
[0000.710] I> Task: Set I2C bus freq
[0000.713] I> Task: Reset FSI
[0000.716] I> Task: Pinmux init
[0000.719] I> skipped mmio_addr = 0x9240008
[0000.723] I> skipped mmio_addr = 0x9240000
[0000.727] I> skipped mmio_addr = 0x9240010
[0000.731] I> skipped mmio_addr = 0x9240018
[0000.735] I> skipped mmio_addr = 0x9240020
[0000.739] I> skipped mmio_addr = 0x9240030
[0000.743] I> skipped mmio_addr = 0x9240028
[0000.747] I> skipped mmio_addr = 0x9240038
[0000.750] I> skipped mmio_addr = 0x9240040
[0000.754] I> skipped mmio_addr = 0x9240048
[0000.758] I> skipped mmio_addr = 0x9241000
[0000.762] I> skipped mmio_addr = 0x9241008
[0000.766] I> skipped mmio_addr = 0x9241010
[0000.770] I> skipped mmio_addr = 0x9241018
[0000.774] I> skipped mmio_addr = 0x9241020
[0000.778] I> skipped mmio_addr = 0x9241028
[0000.782] I> skipped mmio_addr = 0x9241030
[0000.786] I> skipped mmio_addr = 0x9241038
[0000.790] I> skipped mmio_addr = 0x9241040
[0000.794] I> skipped mmio_addr = 0x9242000
[0000.798] I> skipped mmio_addr = 0x9242008
[0000.802] I> Task: Prod config init
[0000.805] I> Task: Pad voltage init
[0000.808] I> Task: Prod init
[0000.811] I> Task: Program rst req config reg
[0000.815] I> Task: Common rail init
[0000.819] I> DONE: Thermal config
[0000.823] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.831] I> DONE: SOC rail config
[0000.835] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.841] I> DONE: MEMIO rail config
[0000.845] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.851] I> DONE: GPU rail info
[0000.854] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.860] I> DONE: CV rail info
[0000.863] I> Task: Mem clock src
[0000.866] I> Task: Misc. board config
[0000.870] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.876] I> Task: SDRAM init
[0000.878] I> MemoryType: 4 MemBctRevision: 1
[0000.885] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.892] I> MSS CAR: Init PLLM
[0000.895] I> MSS CAR: Init PLLHUB
[0000.900] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.912] I> SDRAM initialized!
[0000.915] I> SDRAM Size in Total 0x400000000
[0000.919] I> Task: Dram Ecc scrub
[0000.922] I> Task: DRAM alias check
[0000.938] I> Task: Program NSDRAM carveout
[0000.942] I> NSDRAM carveout encryption is enabled
[0000.947] I> Program NSDRAM carveout
[0000.951] I> Task: Register checker
[0000.956] I> Task: Enable clock-mon
[0000.961] I> FMON: Fmon re-programming done
[0000.965] I> Task: Mapper init
[0000.969] I> Task: SC7 Context Init
[0000.973] I> Task: CCPLEX IST init
[0000.977] I> Task: CPU WP0
[0000.980] I> Loading MCE
[0000.983] I> Slot: 1
[0000.985] I> Binary[8] block-85760 (partition size: 0x80000)
[0000.992] I> Binary name: MCE
[0000.995] I> Size of crypto header is 8192
[0000.999] I> Size of crypto header is 8192
[0001.004] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.012] I> BCH of MCE read from storage
[0001.016] I> BCH address is : 0x4003e000
[0001.021] I> MCE header integrity check is success
[0001.026] I> Binary magic in BCH component 0 is MTSM
[0001.031] I> component binary type is 8
[0001.036] I> Size of crypto header is 8192
[0001.040] I> strt_pg_num(85776) num_of_pgs(357) read_buf(0x40000000)
[0001.050] I> MCE binary is read from storage
[0001.055] I> MCE binary integrity check is success
[0001.060] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.068] I> Size of crypto header is 8192
[0001.083] I> Size of crypto header is 8192
[0001.088] I> Sending WP0 mailbox command to PSC
[0001.097] I> Task: XUSB Powergate
[0001.101] I> Skipping powergate XUSB.
[0001.105] I> Task: MB1 fixed firewalls
[0001.121] W> Firewall readback mismatch
[0001.132] I> Task: Load bpmp-fw
[0001.135] I> Slot: 1
[0001.138] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.144] I> Binary name: BPMP_FW
[0001.148] I> Size of crypto header is 8192
[0001.152] I> Size of crypto header is 8192
[0001.157] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.165] I> BCH of BPMP_FW read from storage
[0001.169] I> BCH address is : 0x807fe000
[0001.175] I> BPMP_FW header integrity check is success
[0001.180] I> Binary magic in BCH component 0 is BPMF
[0001.186] I> component binary type is 15
[0001.190] I> Size of crypto header is 8192
[0001.194] I> strt_pg_num(72976) num_of_pgs(2037) read_buf(0x80000000)
[0001.213] I> BPMP_FW binary is read from storage
[0001.220] I> BPMP_FW binary integrity check is success
[0001.226] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfea00)
[0001.234] I> Slot: 1
[0001.236] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.243] I> Binary name: BPMP_FW_DTB
[0001.247] I> Size of crypto header is 8192
[0001.251] I> Size of crypto header is 8192
[0001.256] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.264] I> BCH of BPMP_FW_DTB read from storage
[0001.269] I> BCH address is : 0x807fc000
[0001.274] I> BPMP_FW_DTB header integrity check is success
[0001.280] I> Binary magic in BCH component 0 is BPMD
[0001.285] I> component binary type is 16
[0001.289] I> Size of crypto header is 8192
[0001.294] I> strt_pg_num(76048) num_of_pgs(490) read_buf(0x807bebf0)
[0001.304] I> BPMP_FW_DTB binary is read from storage
[0001.311] I> BPMP_FW_DTB binary integrity check is success
[0001.316] I> Binary BPMP_FW_DTB loaded successfully at 0x807bebf0 (0x3d280)
[0001.325] I> Task: Load psc-fw
[0001.329] I> Slot: 1
[0001.331] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.338] I> Binary name: PSC_FW
[0001.341] I> Size of crypto header is 8192
[0001.346] I> Size of crypto header is 8192
[0001.350] I> strt_pg_num(84224) num_of_pgs(16) read_b�f(0x80ffe000)
[0001.358] I> BCH of PSC_FW read from storage
[0001.363] I> BCH address is : 0x80ffe000
[0001.368] I> PSC_FW header integrity check is success
[0001.374] I> Binary magic in BCH component 0 is PFWP
[0001.532] I> Task: Load tsec-fw
[0001.535] I> TSEC-FW load support not enabled
[0001.540] I> Task: GPIO interrupt map
[0001.544] I> Task: SC7 context save
[0001.548] I> Slot: 1
[0001.550] I> Binary[27] block-0 (partition size: 0x100000)
[0001.556] I> Binary name: BR_BCT
[0001.560] I> Size of crypto header is 8192
[0001.564] I> Size of crypto header is 8192
[0001.569] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.576] I> BR_BCT binary is read from storage
[0001.581] I> BR_BCT binary integrity check is success
[0001.587] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.594] I> Slot: 1
[0001.597] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.603] I> Binary name: SC7-FW
[0001.607] I> Size of crypto header is 8192
[0001.611] I> Size of crypto header is 8192
[0001.616] I> Size of crypto header is 8192
[0001.620] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.628] I> BCH of SC7-FW read from storage
[0001.633] I> BCH address is : 0xa0002000
[0001.638] I> SC7-FW header integrity check is success
[0001.643] I> Binary magic in BCH component 0 is WB0B
[0001.649] I> component binary type is 13
[0001.653] I> Size of crypto header is 8192
[0001.657] I> strt_pg_num(86800) num_of_pgs(345) read_buf(0xa0004000)
[0001.667] I> SC7-FW binary is read from storage
[0001.673] I> SC7-FW binary integrity check is success
[0001.678] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b0e0)
[0001.686] I> Slot: 1
[0001.688] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.695] I> Binary name: PSC_RF
[0001.698] I> Size of crypto header is 8192
[0001.703] I> Size of crypto header is 8192
[0001.708] I> Size of crypto header is 8192
[0001.712] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002f0e0)
[0001.720] I> BCH of PSC_RF read from storage
[0001.725] I> BCH address is : 0xa002f0e0
[0001.730] I> PSC_RF header integrity check is success
[0001.735] I> Binary magic in BCH component 0 is PSCR
[0001.741] I> component binary type is 22
[0001.745] I> Size of crypto header is 8192
[0001.749] I> strt_pg_num(87184) num_of_pgs(223) read_buf(0xa00310e0)
[0001.758] I> PSC_RF binary is read from storage
[0001.764] I> PSC_RF binary integrity check is success
[0001.769] I> Binary PSC_RF loaded successfully at 0xa00310e0 (0x1bdd0)
[0001.793] I> Task: Save WP0 payload to SC7 ctx
[0001.797] I> Task: Load MB2rf binary to SC7 ctx
[0001.802] I> Slot: 1
[0001.804] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.811] I> Binary name: MB2_RF
[0001.815] I> Size of crypto header is 8192
[0001.819] I> Size of crypto header is 8192
[0001.824] I> Size of crypto header is 8192
[0001.828] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d6a88)
[0001.836] I> BCH of MB2_RF read from storage
[0001.841] I> BCH address is : 0xa00d6a88
[0001.846] I> MB2_RF header integrity check is success
[0001.851] I> Binary magic in BCH component 0 is MB2R
[0001.857] I> component binary type is 14
[0001.861] I> Size of crypto header is 8192
[0001.865] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d8a88)
[0001.875] I> MB2_RF binary is read from storage
[0001.880] I> MB2_RF binary integrity check is success
[0001.886] I> Binary MB2_RF loaded successfully at 0xa00d8a88 (0x1bf80)
[0001.893] I> Task: Save fuse alias data to SC7 ctx
[0001.899] I> Task: Save PMIC data to SC7 ctx
[0001.903] I> Task: Save Pinmux data to SC7 ctx
[0001.908] I> Task: Save Pad Voltage data to SC7 ctx
[0001.913] I> Task: Save controller prod data to SC7 ctx
[0001.919] I> Task: Save prod cfg data to SC7 ctx
[0001.924] I> Task: Save I2C bus freq data to SC7 ctx
[0001.929] I> Task: Save SOCTherm data to SC7 ctx
[0001.934] I> Task: Save FMON data to SC7 ctx
[0001.938] I> Task: Save VMON data to SC7 ctx
[0001.943] I> Task: Save TZDRAM data to SC7 ctx
[0001.948] I> Task: Save GPIO int data to SC7 ctx
[0001.953] I> Task: Save clock data to SC7 ctx
[0001.957] I> Task: Save debug data to SC7 ctx
[0001.962] I> Task: Save MBWT data to SC7 ctx
[0001.971] I> SC7 context save done
[0001.975] I> Task: Load MB2/Applet/FSKP
[0001.979] I> Loading MB2
[0001.982] I> Slot: 1
[0001.984] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.991] I> Binary name: MB2
[0001.994] I> Size of crypto header is 8192
[0001.998] I> Size of crypto header is 8192
[0002.003] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0002.011] I> BCH of MB2 read from storage
[0002.015] I> BCH address is : 0x8007e000
[0002.021] I> MB2 header integrity check is success
[0002.026] I> Binary magic in BCH component 0 is MB2B
[0002.031] I> component binary type is 6
[0002.035] I> Size of crypto header is 8192
[0002.040] I> strt_pg_num(71440) num_of_pgs(841) read_buf(0x80000000)
[0002.052] I> MB2 binary is read from storage
[0002.058] I> MB2 binary integrity check is success
[0002.063] I> Binary MB2 loaded successfully at 0x80000000 (0x691f0)
[0002.071] I> Task: Map CCPLEX SHARED carveout
[0002.076] I> Task: Prepare MB2 params
[0002.081] I> BR-BCT Boot Chain Fields
[0002.085] I> u32_non_gpio_select_boot_chain : 1
[0002.090] I> u32_num_boot_chains : 2
[0002.095] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.100] I> Task: Dram ecc test
[0002.104] I> Task: Misc NV security settings
[0002.108] I> NVDEC sticky bits programming done
[0002.113] I> Successfully powergated NVDEC
[0002.118] I> Task: Disable/Reload WDT
[0002.122] I> Task: Program misc carveouts
[0002.126] I> Program IPC carveouts
[0002.134] I> SLCG Global override status := 0x0
[0002.139] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-4d0906e6)
I> Emulation:
I> Entry timestamp: 0x00211daf
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x470000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002034)
I> Task: Enable hot-plug capability (0x50028064)
I> Task: PSC mailbox init (0x500178b0)
I> Task: Crypto init (0x5000675c)
I> Task: Enable GP-SE clock (0x50002198)
I> Task: DICE Identity init (0x5001af00)
I> DICE is not enabled.
I> Task: Measured Boot init (0x5001b674)
I> Task: OEM SC7 context save init (0x5001a600)
I> Task: I2C register (0x50001ff8)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001fe0)
I> Task: Program CBB PCIE AMAP regions (0x5001ac14)
I> Task: Boot device init (0x50001f28)
I> Task: Partition Manager Init (0x50001f24)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001e198)
I> Task: Load AUXP FWs (0x50027c04)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APM FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register xUSB FW load task�I> Task: Revoke PKC fuse (0x50001d44)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001a790)
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE (0x50018474)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50024d68)
I> OEM firewalls configured
I> Task: Powergate APE (0x500185e8)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x500251bc)
I> Task: Unhalt AUXPs (0x50027e6c)
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
����vic initialized
����tsc initialized
����aon lic initialized
����spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
����spe: init
����scheduler initialized
����aon hsp initialized
����tag initialized
����tcu initialized
����bpmp ipc initialized
����spe: late init
����cpu_nic clock initialized
����apb clock initialized
����pm initialized
����bpmp hsp initialized
����top1 hsp initialized
����ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x50017930)
I> Sending opcode 0x4d420802 to psc
��INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x478002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
��I> Received ACK from psc
I> Tas��INFO: MONITOR: user task addr:0x478022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
bpmp: socket 0
bpmp: base binary md5 is 925eece486b7c46d91aa449178b5d322
bpmp: combined binary md5 is 029a50a8fb4897d35f94a799f82169a9
bpmp: firmware tag is 029a50a8fb4897d35f94-925eece486b
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
��k: Start secure NOR provision (0x5001aa2c)
I> Tas��initialized avfs_clk_platform
initialized powergate
��k: Load FSI keyblob (0x5��initialized dvs
��001��initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized mce_dbell
��7d54)
I> Task: Unhalt AUXPs (0x50027e74)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50018e1c)
I> Task: Load TOS (0x50019580)
I> Partition name: B_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-87��[ 2.564729] Camera-FW on t234-rce-safe started
��808��TCU early console enabled.
��initialized emc
initialized emc_mrq
�� (partition ��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
��size: 0x380000), name: B_cp��initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��u-bootloader
��initialized clk_cal_late
initialized noc_late
initialized cvc
initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not ��[ 2.724081] Camera-FW on t234-rce-safe ready SHA1=8676d22a (crt 21.625 ms, total boot 182.036 ms)
��matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized clk_mach_post
Z�Z�ZX�Z�Y��pg�post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: iniete
��DCE: FW Boot Done
��I> Partition name: B_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-94976 (partition size: 0x400000), name: B_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0x3eea70000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x46e600000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x47fdee000
I> Relocating OP-TEE dtb from: 0x47fefec50 to 0x47c000020, size: 0x2106
I> [0] START: 0x80000000, SIZE: 0x3eea70000
I> [1] START: 0x472000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: B_eks
I> Size of partition: 262144
I> Binary@ device:3/0 block-107264 (partition size: 0x40000), name: B_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x470000200
I> EKB detected (length: 0x410) @ VA:0x470000200
I> Task: Prepare TOS params (0x500194f8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x47c000020
I> Task: OEM SC7 context save (0x5001a88c)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50027f00)
I> Task: Program display sticky bits (0x50027e7c)
I> Task: Storage device deinit (0x500020a0)
I> Task: SMMU external bypass disable (0x50017894)
I> Task: SMMU init (0x500177b0)
I> Task: Program GICv3 registers (0x50027fa0)
I> Task: Audit firewall settings (0x50024fbc)
I> Task: Bootchain failure check (0x500025e8)
I> Current Boot-Chain Slot: 1
I> BR-BCT Boot-Chain is 1, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
��NOTICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0x47c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:55 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
L4T boot options
0: primary kernel
1: Custom Header Config: <HDR40 User Custom [2023-05-21-010242]>
Press 0-1 to boot selection within 3.0 seconds.
Press any other key to boot default (Option: 0)
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 13
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x466eb2698 SMBIOS=0xffff0000 SMBIOS 3.0=0x447590000 MEMATTR=0x44844a018 ESRT=0x44848bc98 RNG=0x44883f198 MEMRESERVE=0x448453f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x000000044848bc98 to 0x000000044848bcd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000045a800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000473ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000446bdffff]
[ 0.000000] node 0: [mem 0x0000000446be0000-0x0000000446e9afff]
[ 0.000000] node 0: [mem 0x0000000446e9b000-0x00000004474dffff]
[ 0.000000] node 0: [mem 0x00000004474e0000-0x000000044759ffff]
[ 0.000000] node 0: [mem 0x00000004475a0000-0x00000004482fffff]
[ 0.000000] node 0: [mem 0x0000000448300000-0x000000044839ffff]
[ 0.000000] node 0: [mem 0x00000004483a0000-0x00000004483affff]
[ 0.000000] node 0: [mem 0x00000004483b0000-0x00000004483bffff]
[ 0.000000] node 0: [mem 0x00000004483c0000-0x00000004483effff]
[ 0.000000] node 0: [mem 0x00000004483f0000-0x000000044841ffff]
[ 0.000000] node 0: [mem 0x0000000448420000-0x000000044845ffff]
[ 0.000000] node 0: [mem 0x0000000448460000-0x000000044847ffff]
[ 0.000000] node 0: [mem 0x0000000448480000-0x000000044851ffff]
[ 0.000000] node 0: [mem 0x0000000448520000-0x000000044852ffff]
[ 0.000000] node 0: [mem 0x0000000448530000-0x000000044858ffff]
[ 0.000000] node 0: [mem 0x0000000448590000-0x000000044876ffff]
[ 0.000000] node 0: [mem 0x0000000448770000-0x000000044882ffff]
[ 0.000000] node 0: [mem 0x0000000448830000-0x00000004488dffff]
[ 0.000000] node 0: [mem 0x00000004488e0000-0x000000044892ffff]
[ 0.000000] node 0: [mem 0x0000000448930000-0x0000000448b5ffff]
[ 0.000000] node 0: [mem 0x0000000448b60000-0x0000000448beffff]
[ 0.000000] node 0: [mem 0x0000000448bf0000-0x0000000448c3ffff]
[ 0.000000] node 0: [mem 0x0000000448c40000-0x0000000448c6ffff]
[ 0.000000] node 0: [mem 0x0000000448c70000-0x0000000448d0ffff]
[ 0.000000] node 0: [mem 0x0000000448d10000-0x0000000448d5ffff]
[ 0.000000] node 0: [mem 0x0000000448d60000-0x0000000448dfffff]
[ 0.000000] node 0: [mem 0x0000000448e00000-0x00000004492dffff]
[ 0.000000] node 0: [mem 0x00000004492e0000-0x00000004494bffff]
[ 0.000000] node 0: [mem 0x00000004494c0000-0x000000046ab2ffff]
[ 0.000000] node 0: [mem 0x000000046ab30000-0x000000046ab7ffff]
[ 0.000000] node 0: [mem 0x000000046ab80000-0x000000046ea0ffff]
[ 0.000000] node 0: [mem 0x000000046ea10000-0x000000046ea1ffff]
[ 0.000000] node 0: [mem 0x0000000472000000-0x0000000473ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000473ffffff]
[ 0.000000] On node 0, zone Normal: 480 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4066592
[ 0.000000] Kernel command line: root=PARTUUID=0fbb0d07-56c4-4081-9210-fd4e452f2556 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 15619596K/16525440K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 643700K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000644] Console: colour dummy device 80x25
[ 0.000690] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000699] pid_max: default: 32768 minimum: 301
[ 0.000806] LSM: Security Framework initializing
[ 0.000833] Yama: becoming mindful.
[ 0.000854] SELinux: Initializing.
[ 0.000943] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000971] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.002194] rcu: Hierarchical SRCU implementation.
[ 0.002300] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002839] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3768-0000-a0.dts
[ 0.002844] DTB Build time: Mar 19 2023 08:08:40
[ 0.004097] Tegra Revision: A01 SKU: 0xd3 CPU Process: 0 SoC Process: 0
[ 0.004269] Remapping and enabling EFI services.
[ 0.004773] smp: Bringing up secondary CPUs ...
[ 0.033498] Detected PIPT I-cache on CPU1
[ 0.033540] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033572] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062247] Detected PIPT I-cache on CPU2
[ 0.062258] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062275] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.090892] Detected PIPT I-cache on CPU3
[ 0.090901] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.090914] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.121591] Detected PIPT I-cache on CPU4
[ 0.121613] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.121639] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.150320] Detected PIPT I-cache on CPU5
[ 0.150329] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.150343] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.178980] Detected PIPT I-cache on CPU6
[ 0.178990] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.179004] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.207636] Detected PIPT I-cache on CPU7
[ 0.207646] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.207660] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.207716] smp: Brought up 1 node, 8 CPUs
[ 0.207731] SMP: Total of 8 processors activated.
[ 0.207734] CPU features: detected: Privileged Access Never
[ 0.207736] CPU features: detected: LSE atomic instructions
[ 0.207737] CPU features: detected: User Access Override
[ 0.207739] CPU features: detected: 32-bit EL0 Support
[ 0.207741] CPU features: detected: Common not Private translations
[ 0.207743] CPU features: detected: RAS Extension Support
[ 0.207744] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.207746] CPU features: detected: CRC32 instructions
[ 0.207747] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.240536] CPU: All CPU(s) started at EL2
[ 0.242550] devtmpfs: initialized
[ 0.259353] Registered cp15_barrier emulation handler
[ 0.259362] Registered setend emulation handler
[ 0.259368] KASLR enabled
[ 0.259510] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.259522] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.261231] pinctrl core: initialized pinctrl subsystem
[ 0.261726] SMBIOS 3.0.0 present.
[ 0.261733] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 0.262069] NET: Registered protocol family 16
[ 0.262694] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.262805] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.262904] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.262934] audit: initializing netlink subsys (disabled)
[ 0.263034] audit: type=2000 audit(0.260:1): state=initialized audit_enabled=0 res=1
[ 0.263238] thermal_sys: Registered thermal governor 'step_wise'
[ 0.263239] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.263241] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.264084] cpuidle: using governor menu
[ 0.264183] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.264272] ASID allocator initialised with 32768 entries
[ 0.264373] Serial: AMBA PL011 UART driver
[ 0.266305] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.266329] Tegra reboot handler registered.
[ 0.284922] mc: mapped MMIO address: 0xffff800010b10000 -> 0x2c10000
[ 0.284931] mc: mapped MMIO address: 0xffff800010b30000 -> 0x2c20000
[ 0.284937] mc: mapped MMIO address: 0xffff800010b50000 -> 0x2c30000
[ 0.284943] mc: mapped MMIO address: 0xffff800010b70000 -> 0x2c40000
[ 0.284948] mc: mapped MMIO address: 0xffff800010b90000 -> 0x2c50000
[ 0.284953] mc: mapped MMIO address: 0xffff800010bb0000 -> 0x2b80000
[ 0.284959] mc: mapped MMIO address: 0xffff800010bd0000 -> 0x2b90000
[ 0.284964] mc: mapped MMIO address: 0xffff800010bf0000 -> 0x2ba0000
[ 0.284972] mc: mapped MMIO address: 0xffff800010c10000 -> 0x2bb0000
[ 0.284977] mc: mapped MMIO address: 0xffff800010c30000 -> 0x1700000
[ 0.284983] mc: mapped MMIO address: 0xffff800010c50000 -> 0x1710000
[ 0.284988] mc: mapped MMIO address: 0xffff800010c70000 -> 0x1720000
[ 0.284993] mc: mapped MMIO address: 0xffff800010c90000 -> 0x1730000
[ 0.284998] mc: mapped MMIO address: 0xffff800010cb0000 -> 0x1740000
[ 0.285008] mc: mapped MMIO address: 0xffff800010cd0000 -> 0x1750000
[ 0.285013] mc: mapped MMIO address: 0xffff800010cf0000 -> 0x1760000
[ 0.285018] mc: mapped MMIO address: 0xffff800010d10000 -> 0x1770000
[ 0.285026] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.285073] mc-err: mcerr ops are set to t23x
[ 0.285798] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 1.455128] printk: console [ttyAMA0] enabled
[ 1.463648] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.470354] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.477052] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.483749] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.492615] ACPI: Interpreter disabled.
[ 1.496860] ddr-vddq: supplied by vdd-5v
[ 1.500948] ddr-vdd2: supplied by vdd-5v
[ 1.504962] vdd-AO-1v2: supplied by vdd-5v
[ 1.509154] vdd-3v3: supplied by vdd-5v
[ 1.513353] vdd-rtc: supplied by vdd-AO-1v2
[ 1.517697] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 1.522554] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 1.527505] vdd-1v8: supplied by vdd-3v3-sys
[ 1.531881] vdd-3v3-AO: supplied by vdd-5v-sys
[ 1.536448] vdd-av10-hub: supplied by vdd-5v-sys
[ 1.541174] vdd-vbus-a: supplied by vdd-5v-sys
[ 1.545737] vdd-vbus-b: supplied by vdd-5v-sys
[ 1.550303] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 1.555149] iommu: Default domain type: Translated
[ 1.560107] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.566462] SCSI subsystem initialized
[ 1.570286] usbcore: registered new interface driver usbfs
[ 1.575778] usbcore: registered new interface driver hub
[ 1.581094] usbcore: registered new device driver usb
[ 1.586429] mc: Linux media interface: v0.10
[ 1.590703] videodev: Linux video capture interface: v2.00
[ 1.596318] pps_core: LinuxPPS API ver. 1 registered
[ 1.601279] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.610412] PTP clock support registered
[ 1.614596] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.621780] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.629458] Registered efivars operations
[ 1.633996] FPGA manager framework
[ 1.637442] Advanced Linux Sound Architecture Driver Initialized.
[ 1.643802] Bluetooth: Core ver 2.22
[ 1.647383] NET: Registered protocol family 31
[ 1.651824] Bluetooth: HCI device and connection manager initialized
[ 1.658179] Bluetooth: HCI socket layer initialized
[ 1.663055] Bluetooth: L2CAP socket layer initialized
[ 1.668107] Bluetooth: SCO socket layer initialized
[ 1.673597] camchar: rtcpu character device driver loaded
[ 1.679306] clocksource: Switched to clocksource arch_sys_counter
[ 1.842888] VFS: Disk quotas dquot_6.6.0
[ 1.846850] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.854019] pnp: PnP ACPI: disabled
[ 1.859498] la/ptsa driver initialized.
[ 1.863398] NET: Registered protocol family 2
[ 1.867958] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.877771] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 1.886418] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.894621] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.902533] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.909231] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 1.916050] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 1.923379] NET: Registered protocol family 1
[ 1.928014] RPC: Registered named UNIX socket transport module.
[ 1.933940] RPC: Registered udp transport module.
[ 1.938639] RPC: Registered tcp transport module.
[ 1.943339] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.949782] PCI: CLS 0 bytes, default 64
[ 1.953815] Trying to unpack rootfs image as initramfs...
[ 2.089767] Freeing initrd memory: 9552K
[ 2.095575] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.103468] kvm [1]: IPA Size Limit: 48 bits
[ 2.107790] kvm [1]: GICv3: no GICV resource entry
[ 2.112578] kvm [1]: disabling GICv2 emulation
[ 2.117035] kvm [1]: GIC system register CPU interface enabled
[ 2.122935] kvm [1]: vgic interrupt IRQ9
[ 2.126974] kvm [1]: VHE mode initialized successfully
[ 2.132782] Initialise system trusted keyrings
[ 2.137328] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 2.146157] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.152326] NFS: Registering the id_resolver key type
[ 2.157403] Key type id_resolver registered
[ 2.161584] Key type id_legacy registered
[ 2.165626] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.172331] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.179735] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.195711] NET: Registered protocol family 38
[ 2.200156] Key type asymmetric registered
[ 2.204250] Asymmetric key parser 'x509' registered
[ 2.209143] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.216596] io scheduler mq-deadline registered
[ 2.221128] io scheduler kyber registered
[ 2.229056] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.234654] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.240238] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.246593] efifb: probing for efifb
[ 2.250199] efifb: framebuffer at 0x479e00000, using 8192k, total 8192k
[ 2.256811] efifb: mode is 1280x1024x32, linelength=8192, pages=1
[ 2.262901] efifb: scrolling: redraw
[ 2.266471] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 2.274063] Console: switching to colour frame buffer device 160x64
[ 2.282095] fb0: EFI VGA frame buffer device
[ 2.288007] tegra_dc_assign_hw_data: no matching compatible node
[ 2.294011] tegradccommon module_init failed
[ 2.298297] tegradc module_init failed
[ 2.302297] EINJ: ACPI disabled.
[ 2.306983] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.313863] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.319173] tegra-pmc: ### PMC reset level: L0
[ 2.323613] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.329831] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.968537] printk: console [ttyTCU0] enabled
[ 3.973516] arm-smmu 12000000.iommu: probing hardware configuration...
[ 3.980214] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.985035] arm-smmu 12000000.iommu: stage 1 translation
[ 3.990578] arm-smmu 12000000.iommu: stage 2 translation
[ 3.996116] arm-smmu 12000000.iommu: nested translation
[ 4.001560] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.008963] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.018080] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.024766] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.031449] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.038986] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.045679] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.050500] arm-smmu 10000000.iommu: stage 1 translation
[ 4.056034] arm-smmu 10000000.iommu: stage 2 translation
[ 4.061575] arm-smmu 10000000.iommu: nested translation
[ 4.067019] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.074419] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.083444] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.090134] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.096820] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.103956] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.110562] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.115295] arm-smmu 8000000.iommu: stage 1 translation
[ 4.120738] arm-smmu 8000000.iommu: stage 2 translation
[ 4.126181] arm-smmu 8000000.iommu: nested translation
[ 4.131536] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.138850] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.147813] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.154422] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.161022] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.168298] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.177928] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.183930] tegra_profiler: auth: init
[ 4.188104] nvsciipc: loaded module
[ 4.193256] tun: Universal TUN/TAP device driver, 1.6
[ 4.198864] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.206271] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.211751] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.216833] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.222916] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.228448] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.234312] PPP generic driver version 2.4.2
[ 4.238736] PPP BSD Compression module registered
[ 4.243562] PPP Deflate Compression module registered
[ 4.248742] PPP MPPE Compression module registered
[ 4.253675] usbcore: registered new interface driver r8152
[ 4.259308] usbcore: registered new interface driver asix
[ 4.264854] usbcore: registered new interface driver ax88179_178a
[ 4.271113] usbcore: registered new interface driver cdc_ether
[ 4.277105] usbcore: registered new interface driver net1080
[ 4.282917] usbcore: registered new interface driver cdc_subset
[ 4.288994] usbcore: registered new interface driver zaurus
[ 4.294717] usbcore: registered new interface driver cdc_ncm
[ 4.300541] usbcore: registered new interface driver aqc111
[ 4.306360] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.312711] ohci-pci: OHCI PCI platform driver
[ 4.317276] ohci-platform: OHCI generic platform driver
[ 4.322917] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.329281] usbcore: registered new interface driver uas
[ 4.334755] usbcore: registered new interface driver usb-storage
[ 4.341079] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.347198] mousedev: PS/2 mouse device common for all mice
[ 4.352935] usbcore: registered new interface driver xpad
[ 4.360299] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.365749] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:32 UTC (32)
[ 4.373969] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.380364] i2c /dev entries driver
[ 4.384061] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.389862] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.395582] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.401259] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.406920] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.412593] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.418268] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.423935] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.432954] device-mapper: uevent: version 1.0.3
[ 4.437779] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.447498] sdhci: Secure Digital Host Controller Interface driver
[ 4.453833] sdhci: Copyright(c) Pierre Ossman
[ 4.458289] Synopsys Designware Multimedia Card Interface Driver
[ 4.464511] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.470758] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.478114] tegra-bpmp bpmp: firmware: 029a50a8fb4897d35f94-925eece486b
[ 4.486463] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.492159] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.503423] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.509350] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[ 5.626463] hid: raw HID events driver (C) Jiri Kosina
[ 5.632282] usbcore: registered new interface driver usbhid
[ 5.638021] usbhid: USB HID core driver
[ 5.642395] tegra-dce d800000.dce: Adding to iommu group 3
[ 5.650023] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.658766] tegra234-aon c000000.aon: Adding to iommu group 4
[ 5.665384] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.674349] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 5.674923] c000000.aon:hsp: probed
[ 5.686802] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.687492] tegra234-aon c000000.aon: init done
[ 5.698404] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.698959] tegra23x-psc e860000.psc: Adding to iommu group 5
[ 5.707357] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 5.707359] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 5.707360] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 5.707369] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 5.713621] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 5.721716] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 5.730471] tegra23x-psc e860000.psc: init done
[ 5.737992] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 5.737993] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 5.738002] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 5.746936] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 6
[ 5.753467] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 5.762946] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.816785] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.825972] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.837678] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 5.849149] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 5.860978] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 5.873546] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 5.886368] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 5.898442] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (112)
[ 5.905249] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.913609] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 5.927249] t19x_cache tegra-cache: probed
[ 5.931665] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 5.94����3611] optee: pr��I��obing for conduit met��/��hod.
��TC: Reserved shared memory is disabled
��[ 5.948207] optee: revision 3.21 (d8269f24)
[ 6.006997] optee: dynamic shared memory is enabled
[ 6.016437] optee: initialized driver
[ 6.033092] nvpmodel: initialized successfully
[ 6.037763] tegra_hv: get_hvd: not initialized yet
[ 6.042706] user_ivc_mempool: hypervisor not present
[ 6.048615] usbcore: registered new interface driver snd-usb-audio
[ 6.055830] u32 classifier
[ 6.058615] input device check on
[ 6.062386] Actions configured
[ 6.066044] Initializing XFRM netlink socket
[ 6.070962] NET: Registered protocol family 10
[ 6.076932] Segment Routing with IPv6
[ 6.080748] NET: Registered protocol family 17
[ 6.085340] NET: Registered protocol family 15
[ 6.089954] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.104088] Bluetooth: RFCOMM socket layer initialized
[ 6.109382] Bluetooth: RFCOMM ver 1.11
[ 6.113241] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.119334] Bluetooth: HIDP socket layer initialized
[ 6.124651] 9pnet: Installing 9P2000 support
[ 6.129098] Key type dns_resolver registered
[ 6.134203] registered taskstats version 1
[ 6.138428] Loading compiled-in X.509 certificates
[ 6.154101] Loaded X.509 cert 'Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9'
[ 6.165117] tegra194-pcie 14100000.pcie: Adding to iommu group 7
[ 6.178440] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.185796] tegra194-pcie 14160000.pcie: Adding to iommu group 8
[ 6.198374] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.205514] tegra194-pcie 141e0000.pcie: Adding to iommu group 9
[ 6.217654] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.224572] tegra194-pcie 140a0000.pcie: Adding to iommu group 10
[ 6.237184] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 6.271013] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 11
[ 6.282218] host1x 13e40000.host1x: Adding to iommu group 12
[ 6.313205] host1x 13e40000.host1x: initialized
[ 6.318409] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[ 6.326535] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.338658] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[ 6.346690] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.358659] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[ 6.366694] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.378671] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[ 6.386689] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.398675] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[ 6.406719] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.418722] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[ 6.426754] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.438764] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[ 6.446778] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.458798] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[ 6.466809] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.478808] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[ 6.486837] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.498813] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[ 6.506852] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.518867] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[ 6.526904] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.538912] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[ 6.546985] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.558999] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[ 6.567013] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.579010] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[ 6.587028] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.599032] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[ 6.607042] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.619048] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[ 6.627062] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.639111] falcon 15340000.vic: Adding to iommu group 29
[ 6.649575] falcon 15340000.vic: initialized
[ 6.654342] falcon 15380000.nvjpg: Adding to iommu group 30
[ 6.662792] falcon 15380000.nvjpg: initialized
[ 6.667530] falcon 15540000.nvjpg1: Adding to iommu group 31
[ 6.676071] falcon 15540000.nvjpg1: initialized
[ 6.680878] falcon 154c0000.nvenc: Adding to iommu group 32
[ 6.691054] falcon 154c0000.nvenc: initialized
[ 6.695775] falcon 15a50000.ofa: Adding to iommu group 33
[ 6.703468] falcon 15a50000.ofa: initialized
[ 6.708023] nvdec 15480000.nvdec: Adding to iommu group 34
[ 6.719031] nvdec 15480000.nvdec: initialized
[ 6.723643] tsec 15500000.tsec: Adding to iommu group 35
[ 6.733782] tsec 15500000.tsec: initialized
[ 6.740714] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.758687] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.773651] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.780399] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.788173] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.795486] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.802461] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.808995] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.815471] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.823723] tegra194-isp5 14800000.isp: Adding to iommu group 36
[ 6.833234] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.842626] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.849099] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.858316] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.867705] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[ 6.875845] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[ 6.883824] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.893619] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.900437] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.910064] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.916852] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.926793] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.933632] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 39
[ 6.942341] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 6.953719] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 40
[ 6.962407] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 6.973775] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 41
[ 6.982421] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 6.993771] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 42
[ 7.002412] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.013772] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 43
[ 7.022420] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.033794] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 44
[ 7.042438] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.053798] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 45
[ 7.062448] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.073820] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 46
[ 7.082452] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.093817] pva 16000000.pva0: Adding to iommu group 47
[ 7.103983] pva 16000000.pva0: initialized
[ 7.116577] nvdla 15880000.nvdla0: Adding to iommu group 48
[ 7.126806] nvdla 15880000.nvdla0: initialized
[ 7.133127] nvdla 158c0000.nvdla1: Adding to iommu group 49
[ 7.143197] nvdla 158c0000.nvdla1: initialized
[ 7.149471] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.156449] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.163971] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.170594] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.177339] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.183995] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 7.193450] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.199957] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 7.209269] serial-tegra 3140000.serial: Adding to iommu group 2
[ 7.215749] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 7.242519] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.252288] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.257854] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.266501] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.276117] tegra-xusb 3610000.xhci: irq 229, io mem 0x03610000
[ 7.282597] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.291102] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.298529] usb usb1: Product: xHCI Host Controller
[ 7.303533] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.309798] usb usb1: SerialNumber: 3610000.xhci
[ 7.315721] hub 1-0:1.0: USB hub found
[ 7.319615] hub 1-0:1.0: 4 ports detected
[ 7.324088] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.329644] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.337431] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.344951] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.353452] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.360889] usb usb2: Product: xHCI Host Controller
[ 7.365896] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.372155] usb usb2: SerialNumber: 3610000.xhci
[ 7.377426] hub 2-0:1.0: USB hub found
[ 7.381297] hub 2-0:1.0: 4 ports detected
[ 7.408725] i2c i2c-2: Added multiplexed i2c bus 9
[ 7.414348] i2c i2c-2: Added multiplexed i2c bus 10
[ 7.419368] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 7.426374] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.448998] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1988000 KHz, changing to: 1984000 KHz
[ 7.461557] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1987000 KHz, changing to: 1984000 KHz
[ 7.473230] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.480305] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.487641] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.494814] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.503499] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.512189] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 7.587461] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 7.627528] tegra194-pcie 14100000.pcie: Link up
[ 7.634472] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 7.641272] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 7.646906] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 7.656733] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 7.667556] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 7.675477] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 7.681808] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 7.691485] pci 0001:01:00.0: [8086:2526] type 00 class 0x028000
[ 7.697844] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 7.705886] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[ 7.716080] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 7.723510] pci 0001:01:00.0: BAR 0: assigned [mem 0x20a8000000-0x20a8003fff 64bit]
[ 7.731483] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 7.736853] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 7.744214] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 7.746811] usb 1-2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice=90.23
[ 7.752961] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 7.761317] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.770245] pcieport 0001:00:00.0: Adding to iommu group 7
[ 7.777329] usb 1-2: Product: USB2.0 Hub
[ 7.777330] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 7.778577] hub 1-2:1.0: USB hub found
[ 7.783200] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 7.788529] hub 1-2:1.0: 4 ports detected
[ 7.794062] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 7.814195] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 7.821646] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 7.828827] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 7.837510] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 7.846191] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 7.891225] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[ 7.925469] usb 2-1: New USB device found, idVendor=2109, idProduct=0817, bcdDevice=90.23
[ 7.933890] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.941238] usb 2-1: Product: USB3.0 Hub
[ 7.946434] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 7.954331] hub 2-1:1.0: USB hub found
[ 7.958521] hub 2-1:1.0: 4 ports detected
[ 7.963456] tegra194-pcie 14160000.pcie: Link up
[ 7.969229] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 7.976052] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 7.981692] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 7.991811] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.002638] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.010553] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.016859] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.026322] pci 0004:01:00.0: [2646:5017] type 00 class 0x010802
[ 8.032665] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.044717] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.051495] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 8.052155] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.067008] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.072388] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.079742] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.088474] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.097402] pcieport 0004:00:00.0: Adding to iommu group 8
[ 8.103237] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 8.109411] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 8.115447] nvme 0004:01:00.0: Adding to iommu group 8
[ 8.121167] nvme nvme0: pci function 0004:01:00.0
[ 8.126235] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.126793] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 8.139388] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 8.146569] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 8.154690] nvme nvme0: allocated 64 MiB host memory buffer.
[ 8.155252] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 8.169742] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 8.183816] nvme nvme0: 8/0/0 default/read/poll queues
[ 8.197640] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 8.211288] usb 1-3: New USB device found, idVendor=8087, idProduct=0025, bcdDevice= 0.02
[ 8.219716] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.519302] usb 1-2.1: new full-speed USB device number 4 using tegra-xusb
[ 8.683840] usb 1-2.1: New USB device found, idVendor=4037, idProduct=2804, bcdDevice= 1.10
[ 8.692434] usb 1-2.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 8.699955] usb 1-2.1: Product: 2.4G Composite Devic
[ 8.711405] input: 2.4G Composite Devic as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:4037:2804.0001/input/input0
[ 8.763686] usb 2-1.3: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[ 8.783886] hid-generic 0003:4037:2804.0001: input,hidraw0: USB HID v1.10 Keyboard [2.4G Composite Devic] on usb-3610000.xhci-2.1/input0
[ 8.800742] input: 2.4G Composite Devic Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:4037:2804.0002/input/input1
[ 8.813729] usb 2-1.3: New USB device found, idVendor=2109, idProduct=0817, bcdDevice= 2.14
[ 8.822301] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.829846] input: 2.4G Composite Devic Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:4037:2804.0002/input/input2
[ 8.843532] usb 2-1.3: Product: USB3.0 Hub
[ 8.848893] usb 2-1.3: Manufacturer: VIA Labs, Inc.
[ 8.857358] hub 2-1.3:1.0: USB hub found
[ 8.861770] hub 2-1.3:1.0: 4 ports detected
[ 8.911539] input: 2.4G Composite Devic System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:4037:2804.0002/input/input3
[ 8.925630] hid-generic 0003:4037:2804.0002: input,hidraw1: USB HID v1.10 Mouse [2.4G Composite Devic] on usb-3610000.xhci-2.1/input1
[ 8.947817] usb 2-1.4: new SuperSpeed Gen 1 USB device number 4 using tegra-xusb
[ 8.982425] usb 2-1.4: New USB device found, idVendor=8086, idProduct=0b07, bcdDevice=50.e0
[ 8.991012] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.998526] usb 2-1.4: Product: Intel(R) RealSense(TM) Depth Camera 435
[ 9.005419] usb 2-1.4: Manufacturer: Intel(R) RealSense(TM) Depth Camera 435
[ 9.012767] usb 2-1.4: SerialNumber: 822213023066
[ 9.107300] usb 1-2.2: new high-speed USB device number 5 using tegra-xusb
[ 9.266552] usb 1-2.2: config 1 interface 0 altsetting 0 bulk endpoint 0x81 has invalid maxpacket 64
[ 9.275942] usb 1-2.2: config 1 interface 0 altsetting 0 bulk endpoint 0x1 has invalid maxpacket 64
[ 9.284831] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 9.288591] usb 1-2.2: New USB device found, idVendor=03e7, idProduct=2150, bcdDevice= 0.01
[ 9.291404] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 9.299905] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.306716] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 9.314228] usb 1-2.2: Product: Movidius MA2X5X
[ 9.314229] usb 1-2.2: Manufacturer: Movidius Ltd.
[ 9.319864] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 9.324512] usb 1-2.2: SerialNumber: 03e72150
[ 9.343999] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.354819] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 9.362738] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 9.369057] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 9.382041] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 9.387430] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.396385] pcieport 0007:00:00.0: Adding to iommu group 9
[ 9.402257] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 9.408455] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 9.414404] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 9.420507] pci 0007:00:00.0: Removing from iommu group 9
[ 9.426062] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 9.433605] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 9.440398] vdd-3v3-sd: supplied by vdd-3v3
[ 9.446602] tegra194-isp5 14800000.isp: initialized
[ 9.455657] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.459306] usb 1-2.3: new high-speed USB device number 6 using tegra-xusb
[ 9.462119] (NULL device *): fops function table already registered
[ 9.477534] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.484656] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 9.491508] irq: IRQ302: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.609039] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 9.616223] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 9.624398] usb 1-2.3: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.14
[ 9.624916] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 9.633495] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.642172] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 9.649681] usb 1-2.3: Product: USB2.0 Hub
[ 9.663730] usb 1-2.3: Manufacturer: VIA Labs, Inc.
[ 9.670545] hub 1-2.3:1.0: USB hub found
[ 9.674590] random: crng init done
[ 9.678115] hub 1-2.3:1.0: 4 ports detected
[ 9.763455] tegra194-pcie 140a0000.pcie: Link up
[ 9.771695] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 9.778497] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 9.784131] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 9.794249] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.805073] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 9.812990] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.819296] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 9.828897] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 9.835213] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 9.841126] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 9.848222] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 9.856227] pci 0008:01:00.0: supports D1 D2
[ 9.860621] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 9.871517] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 9.878945] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 9.885664] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 9.893635] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 9.901600] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 9.908236] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 9.913608] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 9.920240] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 9.927599] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 9.936341] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 9.945267] pcieport 0008:00:00.0: Adding to iommu group 10
[ 9.951210] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 9.957400] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 9.964435] irq: IRQ304: trimming hierarchy from :pmc@c360000
[ 9.970415] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.978131] input: gpio-keys as /devices/platform/gpio-keys/input/input4
[ 9.985781] tegra-se-nvhost 15810000.se: Adding to iommu group 50
[ 9.992408] tegra-se-nvhost 15810000.se: initialized
[ 10.006308] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.012702] tegra-se-nvhost 15820000.se: Adding to iommu group 51
[ 10.019263] tegra-se-nvhost 15820000.se: initialized
[ 10.026712] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.033079] tegra-se-nvhost 15840000.se: Adding to iommu group 52
[ 10.039649] tegra-se-nvhost 15840000.se: initialized
[ 10.049420] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.056383] tegra_actmon d230000.actmon: in actmon_register()...
[ 10.062852] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.069486] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.077937] hvc_sysfs: hypervisor is not present
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��[ 10.123026] ALSA device list:
[ 10.126081] No soundcards found.
[ 10.130220] Freeing unused kernel memory: 3968K
[ 10.134925] Run /init as init process
[ 10.151385] Root device found: PARTUUID=0fbb0d07-56c4-4081-9210-fd4e452f2556
[ 10.407314] usb 1-2.3.1: new full-speed USB device number 7 using tegra-xusb
[ 10.428710] EXT4-fs (nvme0n1p1): 1 orphan inode deleted
[ 10.434091] EXT4-fs (nvme0n1p1): recovery complete
[ 10.440558] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.452974] Rootfs mounted over PARTUUID=0fbb0d07-56c4-4081-9210-fd4e452f2556
[ 10.467148] Switching from initrd to actual rootfs
[ 10.521925] systemd[1]: System time before build time, advancing clock.
[ 10.570785] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFU)
[ 10.594447] systemd[1]: Detected architecture arm64.
[ 10.606646] usb 1-2.3.1: New USB device found, idVendor=1209, idProduct=5741, bcdDevice= 2.00
[ 10.615411] usb 1-2.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 10.623106] usb 1-2.3.1: Product: mini-pix
[ 10.627316] usb 1-2.3.1: Manufacturer: ArduPilot
[ 10.632059] usb 1-2.3.1: SerialNumber: 3C0055000E51363135393734
[ 10.655483] systemd[1]: Set hostname to <nrover>.
[ 10.737685] systemd[1]: /etc/systemd/system/teamviewerd.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /run/teamviewerd.pid; please update .
[ 10.779308] usb 1-2.3.4: new full-speed USB device number 8 using tegra-xusb
[ 10.829501] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 10.842540] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 10.852296] systemd[1]: Created slice system-modprobe.slice.
[ 10.871751] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 10.891669] systemd[1]: Created slice User and Session Slice.
[ 10.911401] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.935570] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.938648] usb 1-2.3.4: New USB device found, idVendor=1546, idProduct=01a8, bcdDevice= 3.01
[ 10.954020] usb 1-2.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.954022] usb 1-2.3.4: Product: u-blox GNSS receiver
[ 10.966990] usb 1-2.3.4: Manufacturer: u-blox AG - www.u-blox.com
[ 10.987385] systemd[1]: Reached target User and Group Name Lookups.
[ 11.011337] systemd[1]: Reached target Slices.
[ 11.031324] systemd[1]: Reached target Mounting snaps.
[ 11.051575] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 11.076046] systemd[1]: Listening on Syslog Socket.
[ 11.099437] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 11.123380] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.147538] systemd[1]: Listening on Journal Audit Socket.
[ 11.167415] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.187442] systemd[1]: Listening on Journal Socket.
[ 11.207446] systemd[1]: Listening on udev Control Socket.
[ 11.227390] systemd[1]: Listening on udev Kernel Socket.
[ 11.248563] systemd[1]: Mounting Huge Pages File System...
[ 11.268486] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.288453] systemd[1]: Mounting RPC Pipe File System...
[ 11.308521] systemd[1]: Mounting Kernel Debug File System...
[ 11.328432] systemd[1]: Mounting Kernel Trace File System...
[ 11.348694] systemd[1]: Starting Journal Service...
[ 11.368673] systemd[1]: Starting Set the console keyboard layout...
[ 11.392824] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 11.416563] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 11.439367] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 11.448818] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 11.468322] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 11.488286] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 11.508313] systemd[1]: Starting Load Kernel Module ramoops...
[ 11.528424] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 11.552418] systemd[1]: Started Nameserver information manager.
[ 11.571540] systemd[1]: Reached target Network (Pre).
[ 11.591814] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 11.601185] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 11.612135] systemd[1]: Starting Load Kernel Modules...
[ 11.623911] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 11.631323] nvmap_page_pool_init: Total RAM pages: 3973815
[ 11.632633] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.636960] nvmap_page_pool_init: nvmap page pool size: 496726 pages (1940 MB)
[ 11.637316] nvmap_background_zero_thread: PP zeroing thread starting.
[ 11.640445] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 11.671075] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 11.671075]
[ 11.696728] systemd[1]: Starting udev Coldplug all Devices...
[ 11.717173] systemd[1]: Started Journal Service.
[ 12.030312] systemd-journald[271]: Received client request to flush runtime journal.
[ 12.667060] nvidia: loading out-of-tree module taints kernel.
[ 12.750744] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 12.770721] imx219 9-0010: board setup failed
[ 12.778858] iwlwifi 0001:01:00.0: WRT: Overriding region id 0
[ 12.780089] imx219: probe of 9-0010 failed with error -121
[ 12.787935] iwlwifi 0001:01:00.0: WRT: Overriding region id 1
[ 12.803111] iwlwifi 0001:01:00.0: WRT: Overriding region id 2
[ 12.809041] iwlwifi 0001:01:00.0: WRT: Overriding region id 3
[ 12.814964] iwlwifi 0001:01:00.0: WRT: Overriding region id 4
[ 12.820873] iwlwifi 0001:01:00.0: WRT: Overriding region id 6
[ 12.820875] iwlwifi 0001:01:00.0: WRT: Overriding region id 8
[ 12.820877] iwlwifi 0001:01:00.0: WRT: Overriding region id 9
[ 12.820878] iwlwifi 0001:01:00.0: WRT: Overriding region id 10
[ 12.820879] iwlwifi 0001:01:00.0: WRT: Overriding region id 11
[ 12.820881] iwlwifi 0001:01:00.0: WRT: Overriding region id 15
[ 12.820882] iwlwifi 0001:01:00.0: WRT: Overriding region id 16
[ 12.820884] iwlwifi 0001:01:00.0: WRT: Overriding region id 18
[ 12.820885] iwlwifi 0001:01:00.0: WRT: Overriding region id 19
[ 12.820887] iwlwifi 0001:01:00.0: WRT: Overriding region id 20
[ 12.820888] iwlwifi 0001:01:00.0: WRT: Overriding region id 21
[ 12.820890] iwlwifi 0001:01:00.0: WRT: Overriding region id 28
[ 12.856968] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 12.875080] fusb301 1-0025: failed to read device id, err : 0xffffff87
[ 12.881273] imx219 10-0010: board setup failed
[ 12.887076] fusb301 1-0025: fusb301 not support
[ 12.887093] fusb301: probe of 1-0025 failed with error -22
[ 12.893172] imx219: probe of 10-0010 failed with error -121
[ 13.184894] thermal thermal_zone9: failed to read out thermal zone (-61)
[ 15.159454] using random self ethernet address
[ 15.164043] using random host ethernet address
[ 15.400687] using random self ethernet address
[ 15.407696] using random host ethernet address
[ 16.186492] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[ 16.192059] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[ 18.269898] Bridge firewalling registered
[ 19.131951] CPU:0, Error: dce-fabric@0xde00000, irq=28
[ 19.137245] **************************************
[ 19.142170] CPU:0, Error:dce-fabric, Errmon:2
[ 19.146648] Multiple type of errors reported
[ 19.151308] Error Code : FIREWALL_ERR
[ 19.155436] Error Code : TIMEOUT_ERR
[ 19.159466] Overflow : Multiple FIREWALL_ERR
[ 19.164217]
[ 19.165746] Error Code : TIMEOUT_ERR
[ 19.169772] MASTER_ID : DCE
[ 19.172990] Address : 0x1380c01c
[ 19.176666] Cache : 0x1 -- Bufferable
[ 19.180963] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 19.187769] Access_Type : Read
[ 19.191255] Access_ID : 0x0
[ 19.191256] Fabric : dce-fabric
[ 19.198066] Slave_Id : 0x37
[ 19.201290] Burst_length : 0x0
[ 19.204784] Burst_type : 0x1
[ 19.208102] Beat_size : 0x2
[ 19.211329] VQC : 0x0
[ 19.214111] GRPSEC : 0x3f
[ 19.217163] FALCONSEC : 0x0
[ 19.220386] Unable to handle kernel paging request at virtual address 0000000000081000
[ 19.228527] Mem abort info:
[ 19.231396] ESR = 0x96000004
[ 19.234535] EC = 0x25: DABT (current EL), IL = 32 bits
[ 19.239994] SET = 0, FnV = 0
[ 19.243128] EA = 0, S1PTW = 0
[ 19.246352] Data abort info:
[ 19.249311] ISV = 0, ISS = 0x00000004
[ 19.253257] CM = 0, WnR = 0
[ 19.256312] user pgtable: 4k pages, 48-bit VAs, pgdp=00000001381a4000
[ 19.262928] [0000000000081000] pgd=0000000000000000, p4d=0000000000000000
[ 19.269890] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 19.275626] Modules linked in: nvidia_modeset(O) fuse xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptai
[ 19.275703] tegra_bpmp_thermal snd_hda_tegra snd_hda_codec snd_hda_core nv_imx219 r8168 iwlwifi spi_tegra114 cfg80211 nvidia(O) loop ina3221 pwm_fan nvgpu nvmap ip_tables x_tables [last unloaded: mtd]
[ 19.384330] CPU: 0 PID: 2608 Comm: dbus Tainted: G O 5.10.120-tegra #1
[ 19.392349] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 19.403667] pstate: 40400089 (nZcv daIf +PAN -UAO -TCO BTYPE=--)
[ 19.409822] pc : __pi_strlen+0x10/0x84
[ 19.413669] lr : strstr+0x30/0x90
[ 19.417064] sp : ffff800010003cc0
[ 19.420453] x29: ffff800010003cc0 x28: ffff475f40f3d980
[ 19.425895] x27: ffffc10133852f70 x26: 0000000000081000
[ 19.431333] x25: 0000000000000370 x24: ffff800044aee228
[ 19.436768] x23: ffffc10133c6de90 x22: 0000000000000001
[ 19.442203] x21: ffffc10133c6dfc0 x20: 0000000000000007
[ 19.447647] x19: 0000000000081000 x18: 0000000000000010
[ 19.453097] x17: 0000000000000000 x16: ffffc10132545220
[ 19.458538] x15: ffff475f68464f30 x14: ffffffffffffffff
[ 19.463978] x13: ffff800090003917 x12: 0000000000000038
[ 19.469427] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 19.474871] x9 : 535e554b525e7224 x8 : 7f7f7f7f7f7f7f7f
[ 19.480313] x7 : 0000000000000000 x6 : 0000000000000080
[ 19.485753] x5 : 8000000000000000 x4 : 8080808080000000
[ 19.491189] x3 : 545f564c535f7325 x2 : 0042504132495841
[ 19.496636] x1 : 0000000000081000 x0 : 0000000000081000
[ 19.502081] Call trace:
[ 19.504580] __pi_strlen+0x10/0x84
[ 19.508064] print_err_notifier+0x610/0x734
[ 19.512344] tegra234_cbb_isr+0xd0/0x170
[ 19.516358] __handle_irq_event_percpu+0x68/0x2a0
[ 19.521169] handle_irq_event_percpu+0x40/0xa0
[ 19.525714] handle_irq_event+0x50/0xf0
[ 19.529639] handle_fasteoi_irq+0xc0/0x170
[ 19.533837] generic_handle_irq+0x40/0x60
[ 19.537948] __handle_domain_irq+0x70/0xd0
[ 19.542151] gic_handle_irq+0x68/0x134
[ 19.545995] el1_irq+0xd0/0x180
[ 19.549213] ptep_clear_flush+0xcc/0xd0
[ 19.553148] wp_page_copy+0x1d4/0xbe0
[ 19.556894] do_wp_page+0xa0/0x530
[ 19.560373] handle_mm_fault+0xa3c/0x1020
[ 19.564482] do_page_fault+0x118/0x400
[ 19.568318] do_mem_abort+0x54/0xb0
[ 19.571892] el0_da+0x38/0x50
[ 19.574938] el0_sync_handler+0x80/0xb0
[ 19.578869] el0_sync+0x16c/0x180
[ 19.582273] Code: b200c3eb 927cec01 f2400c07 54000261 (a8c10c22)
[ 19.588524] ---[ end trace 2092c12953d6e31c ]---
[ 19.597629] Kernel panic - not syncing: Oops: Fatal exception in interrupt
[ 19.604677] SMP: stopping secondary CPUs
[ 19.608694] Kernel Offset: 0x410122520000 from 0xffff800010000000
[ 19.614938] PHYS_OFFSET: 0xffffb8a1c0000000
[ 19.619228] CPU features: 0x08040006,4a80aa38
[ 19.623692] Memory Limit: none
[ 19.631141] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
and follow with
[0000.065] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.070] I> t234-A01-0-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.077] I> Entry timestamp: 0x00000000
[0000.081] I> last_boot_error: 0x0
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] I> rst_source: 0x13, rst_level: 0x0
[0000.092] I> Task: SE error check
[0000.095] I> Task: Bootchain select WAR set
[0000.099] I> Task: Enable SLCG
[0000.102] I> Task: CRC check
[0000.105] I> Task: Initialize MB2 params
[0000.109] I> MB2-params @ 0x40060000
[0000.113] I> Task: Crypto init
[0000.116] I> Task: Perform MB1 KAT tests
[0000.120] I> Task: NVRNG health check
[0000.123] I> NVRNG: Health check success
[0000.127] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.133] I> Task: Enabling and initialization of Bandwidth limiter
[0000.139] I> No request to configure MBWT settings for any PC!
[0000.145] I> Task: Secure debug controls
[0000.149] I> Task: strap war set
[0000.152] I> Task: Initialize SOC Therm
[0000.155] I> Task: Program NV master stream id
[0000.160] I> Task: Verify boot mode
[0000.165] I> Task: Alias fuses
[0000.169] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.176] I> Task: Print SKU type
[0000.179] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.184] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.189] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.193] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.197] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.206] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.215] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.219] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.223] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.227] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.231] I> FUSE_SKU_INFO_0 = 0xd3
[0000.235] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.239] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.242] I> SKU: Prod
[0000.245] I> Task: Boost clocks
[0000.248] I> Initializing PLLC2 for AXI_CBB.
[0000.252] I> AXI_CBB : src = 35, divisor = 0
[0000.256] I> Task: Voltage monitor
[0000.259] I> VMON: Vmon re-calibration and fine tuning done
[0000.265] I> Task: UPHY init
[0000.269] I> HSIO UPHY init done
[0000.273] W> Skipping GBE UPHY config
[0000.276] I> Task: Boot device init
[0000.279] I> Boot_device: QSPI_FLASH instance: 0
[0000.284] I> Qspi clock source : pllc_out0
[0000.288] I> QSPI Flash: Macronix 64MB
[0000.292] I> QSPI-0l initialized successfully
[0000.296] I> Task: TSC init
[0000.299] I> Task: Load membct
[0000.302] I> RAM_CODE 0x4000401
[0000.305] I> Loading MEMBCT
[0000.307] I> Slot: 1
[0000.309] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.315] I> Binary name: MEM-BCT-0
[0000.318] I> Size of crypto header is 8192
[0000.322] I> Size of crypto header is 8192
[0000.326] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.332] I> BCH of MEM-BCT-0 read from storage
[0000.337] I> BCH address is : 0x40050000
[0000.341] I> MEM-BCT-0 header integrity check is success
[0000.346] I> Binary magic in BCH component 0 is MEM0
[0000.351] I> component binary type is 0
[0000.354] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.361] I> MEM-BCT-0 binary is read from storage
[0000.366] I> MEM-BCT-0 binary integrity check is success
[0000.371] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.378] I> RAM_CODE 0x4000401
[0000.383] I> RAM_CODE 0x4000401
[0000.387] I> Task: Load Page retirement list
[0000.391] I> Task: SDRAM params override
[0000.395] I> Task: Save mem-bct info
[0000.398] I> Task: Carveout allocate
[0000.402] I> RCM blob carveout will not be allocated
[0000.407] I> Update CCPLEX IST carveout from MB1-BCT
[0000.411] I> ECC region[0]: Start:0x0, End:0x0
[0000.416] I> ECC region[1]: Start:0x0, End:0x0
[0000.420] I> ECC region[2]: Start:0x0, End:0x0
[0000.424] I> ECC region[3]: Start:0x0, End:0x0
[0000.429] I> ECC region[4]: Start:0x0, End:0x0
[0000.433] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.439] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.443] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.448] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.453] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.463] I> allocated(CO:43) base:0x47c000000 size:0x4000000 align: 0x200000
[0000.470] I> allocated(CO:39) base:0x479e00000 size:0x2200000 align: 0x10000
[0000.477] I> allocated(CO:20) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.485] I> allocated(CO:24) base:0x474000000 size:0x2000000 align: 0x2000000
[0000.492] I> allocated(CO:28) base:0x472000000 size:0x2000000 align: 0x2000000
[0000.499] I> allocated(CO:22) base:0x478000000 size:0x1000000 align: 0x1000000
[0000.506] I> allocated(CO:35) base:0x479000000 size:0xe00000 align: 0x10000
[0000.513] I> allocated(CO:02) base:0x471800000 size:0x800000 align: 0x800000
[0000.520] I> allocated(CO:03) base:0x471000000 size:0x800000 align: 0x800000
[0000.527] I> allocated(CO:06) base:0x470800000 size:0x800000 align: 0x800000
[0000.534] I> allocated(CO:56) base:0x470000000 size:0x800000 align: 0x200000
[0000.540] I> allocated(CO:07) base:0x46fc00000 size:0x400000 align: 0x400000
[0000.547] I> allocated(CO:33) base:0x46f800000 size:0x400000 align: 0x200000
[0000.554] I> allocated(CO:23) base:0x46f600000 size:0x200000 align: 0x200000
[0000.561] I> allocated(CO:01) base:0x46f500000 size:0x100000 align: 0x100000
[0000.568] I> allocated(CO:04) base:0x46f400000 size:0x100000 align: 0x100000
[0000.575] I> allocated(CO:05) base:0x46f300000 size:0x100000 align: 0x100000
[0000.582] I> allocated(CO:08) base:0x46f200000 size:0x100000 align: 0x100000
[0000.589] I> allocated(CO:09) base:0x46f100000 size:0x100000 align: 0x100000
[0000.596] I> allocated(CO:15) base:0x46f000000 size:0x100000 align: 0x100000
[0000.603] I> allocated(CO:17) base:0x46ef00000 size:0x100000 align: 0x100000
[0000.610] I> allocated(CO:27) base:0x46ee00000 size:0x100000 align: 0x100000
[0000.617] I> allocated(CO:42) base:0x46ed00000 size:0x100000 align: 0x100000
[0000.624] I> allocated(CO:54) base:0x46ec80000 size:0x80000 align: 0x80000
[0000.631] I> allocated(CO:34) base:0x46ec70000 size:0x10000 align: 0x10000
[0000.637] I> allocated(CO:72) base:0x46ea70000 size:0x200000 align: 0x10000
[0000.644] I> allocated(CO:47) base:0x46e600000 size:0x400000 align: 0x200000
[0000.651] I> allocated(CO:48) base:0x46ea50000 size:0x20000 align: 0x10000
[0000.658] I> allocated(CO:69) base:0x46ea30000 size:0x20000 align: 0x10000
[0000.665] I> allocated(CO:49) base:0x46ea20000 size:0x10000 align: 0x10000
[0000.671] I> allocated(CO:50) base:0x46ea10000 size:0x10000 align: 0x10000
[0000.678] I> NSDRAM base: 0x80000000, end: 0x46ea70000, size: 0x3eea70000
[0000.685] I> Task: Thermal check
[0000.688] I> max_chip_limit = 105
[0000.691] I> min_chip_limit = -28
[0000.694] I> max temp read = 47
[0000.697] I> min temp read = 45
[0000.700] I> Task: Update FSI SCR with thermal fuse data
[0000.705] I> Task: Enable WDT 5th expiry
[0000.709] I> Task: I2C register
[0000.712] I> Task: Set I2C bus freq
[0000.715] I> Task: Reset FSI
[0000.718] I> Task: Pinmux init
[0000.721] I> skipped mmio_addr = 0x9240008
[0000.725] I> skipped mmio_addr = 0x9240000
[0000.729] I> skipped mmio_addr = 0x9240010
[0000.733] I> skipped mmio_addr = 0x9240018
[0000.737] I> skipped mmio_addr = 0x9240020
[0000.741] I> skipped mmio_addr = 0x9240030
[0000.745] I> skipped mmio_addr = 0x9240028
[0000.749] I> skipped mmio_addr = 0x9240038
[0000.753] I> skipped mmio_addr = 0x9240040
[0000.757] I> skipped mmio_addr = 0x9240048
[0000.761] I> skipped mmio_addr = 0x9241000
[0000.765] I> skipped mmio_addr = 0x9241008
[0000.769] I> skipped mmio_addr = 0x9241010
[0000.773] I> skipped mmio_addr = 0x9241018
[0000.776] I> skipped mmio_addr = 0x9241020
[0000.780] I> skipped mmio_addr = 0x9241028
[0000.784] I> skipped mmio_addr = 0x9241030
[0000.788] I> skipped mmio_addr = 0x9241038
[0000.792] I> skipped mmio_addr = 0x9241040
[0000.796] I> skipped mmio_addr = 0x9242000
[0000.800] I> skipped mmio_addr = 0x9242008
[0000.804] I> Task: Prod config init
[0000.807] I> Task: Pad voltage init
[0000.811] I> Task: Prod init
[0000.813] I> Task: Program rst req config reg
[0000.818] I> Task: Common rail init
[0000.821] I> DONE: Thermal config
[0000.825] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.834] I> DONE: SOC rail config
[0000.837] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.844] I> DONE: MEMIO rail config
[0000.848] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.854] I> DONE: GPU rail info
[0000.857] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.863] I> DONE: CV rail info
[0000.866] I> Task: Mem clock src
[0000.869] I> Task: Misc. board config
[0000.873] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.878] I> Task: SDRAM init
[0000.881] I> MemoryType: 4 MemBctRevision: 1
[0000.888] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.895] I> MSS CAR: Init PLLM
[0000.898] I> MSS CAR: Init PLLHUB
[0000.903] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.915] I> SDRAM initialized!
[0000.918] I> SDRAM Size in Total 0x400000000
[0000.922] I> Task: Dram Ecc scrub
[0000.925] I> Task: DRAM alias check
[0000.941] I> Task: Program NSDRAM carveout
[0000.945] I> NSDRAM carveout encryption is enabled
[0000.950] I> Program NSDRAM carveout
[0000.954] I> Task: Register checker
[0000.959] I> Task: Enable clock-mon
[0000.964] I> FMON: Fmon re-programming done
[0000.968] I> Task: Mapper init
[0000.972] I> Task: SC7 Context Init
[0000.976] I> Task: CCPLEX IST init
[0000.980] I> Task: CPU WP0
[0000.983] I> Loading MCE
[0000.986] I> Slot: 1
[0000.988] I> Binary[8] block-85760 (partition size: 0x80000)
[0000.995] I> Binary name: MCE
[0000.998] I> Size of crypto header is 8192
[0001.002] I> Size of crypto header is 8192
[0001.007] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.015] I> BCH of MCE read from storage
[0001.019] I> BCH address is : 0x4003e000
[0001.024] I> MCE header integrity check is success
[0001.029] I> Binary magic in BCH component 0 is MTSM
[0001.035] I> component binary type is 8
[0001.039] I> Size of crypto header is 8192
[0001.043] I> strt_pg_num(85776) num_of_pgs(357) read_buf(0x40000000)
[0001.053] I> MCE binary is read from storage
[0001.058] I> MCE binary integrity check is success
[0001.063] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.071] I> Size of crypto header is 8192
[0001.086] I> Size of crypto header is 8192
[0001.091] I> Sending WP0 mailbox command to PSC
[0001.100] I> Task: XUSB Powergate
[0001.104] I> Skipping powergate XUSB.
[0001.108] I> Task: MB1 fixed firewalls
[0001.124] W> Firewall readback mismatch
[0001.135] I> Task: Load bpmp-fw
[0001.138] I> Slot: 1
[0001.141] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.147] I> Binary name: BPMP_FW
[0001.151] I> Size of crypto header is 8192
[0001.155] I> Size of crypto header is 8192
[0001.160] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.168] I> BCH of BPMP_FW read from storage
[0001.173] I> BCH address is : 0x807fe000
[0001.178] I> BPMP_FW header integrity check is success
[0001.183] I> Binary magic in BCH component 0 is BPMF
[0001.189] I> component binary type is 15
[0001.193] I> Size of crypto header is 8192
[0001.197] I> strt_pg_num(72976) num_of_pgs(2037) read_buf(0x80000000)
[0001.216] I> BPMP_FW binary is read from storage
[0001.223] I> BPMP_FW binary integrity check is success
[0001.229] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfea00)
[0001.237] I> Slot: 1
[0001.239] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.246] I> Binary name: BPMP_FW_DTB
[0001.250] I> Size of crypto header is 8192
[0001.254] I> Size of crypto header is 8192
[0001.259] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.267] I> BCH of BPMP_FW_DTB read from storage
[0001.272] I> BCH address is : 0x807fc000
[0001.277] I> BPMP_FW_DTB header integrity check is success
[0001.283] I> Binary magic in BCH component 0 is BPMD
[0001.288] I> component binary type is 16
[0001.292] I> Size of crypto header is 8192
[0001.297] I> strt_pg_num(76048) num_of_pgs(490) read_buf(0x807bebf0)
[0001.307] I> BPMP_FW_DTB binary is read from storage
[0001.314] I> BPMP_FW_DTB binary integrity check is success
[0001.319] I> Binary BPMP_FW_DTB loaded successfully at 0x807bebf0 (0x3d280)
[0001.328] I> Task: Load psc-fw
[0001.332] I> Slot: 1
[0001.334] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.341] I> Binary name: PSC_FW
[0001.344] I> Size of crypto header is 8192
[0001.349] I> Size of crypto header is 8192
[0001.353] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.361] I> BCH of PSC_FW read from storage
[0001.366] I> BCH address is : 0x80ffe000
[0001.371] I> PSC_FW header integrity check is success
[0001.377] I> Binary magic in BCH component 0 is PFWP
[0001.382] I> component binary type is 17
[0001.386] I> Size of crypto header is 8192
[0001.391] I> strt_pg_num(84240) num_of_pgs(717) read_buf(0x80fa4600)
[0001.402] I> PSC_FW binary is read from storage
[0001.408] I> PSC_FW binary integrity check is success
[0001.414] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.422] I> Task: Load nvdec-fw
[0001.426] I> Slot: 1
[0001.428] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.435] I> Binary name: NVDEC
[0001.438] I> Size of crypto header is 8192
[0001.443] I> Size of crypto header is 8192
[0001.447] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.455] I> BCH of NVDEC read from storage
[0001.460] I> BCH address is : 0x800fe000
[0001.465] I> NVDEC header integrity check is success
[0001.470] I> Binary magic in BCH component 0 is NDEC
[0001.475] I> component binary type is 7
[0001.480] I> Size of crypto header is 8192
[0001.484] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.495] I> NVDEC binary is read from storage
[0001.501] I> NVDEC binary integrity check is success
[0001.506] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.514] I> Size of crypto header is 8192
[0001.535] I> Task: Load tsec-fw
[0001.538] I> TSEC-FW load support not enabled
[0001.543] I> Task: GPIO interrupt map
[0001.547] I> Task: SC7 context save
[0001.551] I> Slot: 1
[0001.553] I> Binary[27] block-0 (partition size: 0x100000)
[0001.559] I> Binary name: BR_BCT
[0001.563] I> Size of crypto header is 8192
[0001.567] I> Size of crypto header is 8192
[0001.572] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.579] I> BR_BCT binary is read from storage
[0001.584] I> BR_BCT binary integrity check is success
[0001.590] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.597] I> Slot: 1
[0001.600] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.606] I> Binary name: SC7-FW
[0001.610] I> Size of crypto header is 8192
[0001.614] I> Size of crypto header is 8192
[0001.619] I> Size of crypto header is 8192
[0001.623] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.631] I> BCH of SC7-FW read from storage
[0001.636] I> BCH address is : 0xa0002000
[0001.641] I> SC7-FW header integrity check is success
[0001.646] I> Binary magic in BCH component 0 is WB0B
[0001.652] I> component binary type is 13
[0001.656] I> Size of crypto header is 8192
[0001.660] I> strt_pg_num(86800) num_of_pgs(345) read_buf(0xa0004000)
[0001.670] I> SC7-FW binary is read from storage
[0001.676] I> SC7-FW binary integrity check is success
[0001.681] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b0e0)
[0001.689] I> Slot: 1
[0001.691] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.698] I> Binary name: PSC_RF
[0001.701] I> Size of crypto header is 8192
[0001.706] I> Size of crypto header is 8192
[0001.711] I> Size of crypto header is 8192
[0001.715] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002f0e0)
[0001.723] I> BCH of PSC_RF read from storage
[0001.728] I> BCH address is : 0xa002f0e0
[0001.733] I> PSC_RF header integrity check is success
[0001.738] I> Binary magic in BCH component 0 is PSCR
[0001.744] I> component binary type is 22
[0001.748] I> Size of crypto header is 8192
[0001.752] I> strt_pg_num(87184) num_of_pgs(223) read_buf(0xa00310e0)
[0001.762] I> PSC_RF binary is read from storage
[0001.767] I> PSC_RF binary integrity check is success
[0001.772] I> Binary PSC_RF loaded successfully at 0xa00310e0 (0x1bdd0)
[0001.796] I> Task: Save WP0 payload to SC7 ctx
[0001.800] I> Task: Load MB2rf binary to SC7 ctx
[0001.805] I> Slot: 1
[0001.808] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.814] I> Binary name: MB2_RF
[0001.818] I> Size of crypto header is 8192
[0001.822] I> Size of crypto header is 8192
[0001.827] I> Size of crypto header is 8192
[0001.831] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d6a88)
[0001.839] I> BCH of MB2_RF read from storage
[0001.844] I> BCH address is : 0xa00d6a88
[0001.849] I> MB2_RF header integrity check is success
[0001.854] I> Binary magic in BCH component 0 is MB2R
[0001.860] I> component binary type is 14
[0001.864] I> Size of crypto header is 8192
[0001.868] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d8a88)
[0001.878] I> MB2_RF binary is read from storage
[0001.883] I> MB2_RF binary integrity check is success
[0001.889] I> Binary MB2_RF loaded successfully at 0xa00d8a88 (0x1bf80)
[0001.896] I> Task: Save fuse alias data to SC7 ctx
[0001.902] I> Task: Save PMIC data to SC7 ctx
[0001.906] I> Task: Save Pinmux data to SC7 ctx
[0001.911] I> Task: Save Pad Voltage data to SC7 ctx
[0001.916] I> Task: Save controller prod data to SC7 ctx
[0001.922] I> Task: Save prod cfg data to SC7 ctx
[0001.927] I> Task: Save I2C bus freq data to SC7 ctx
[0001.932] I> Task: Save SOCTherm data to SC7 ctx
[0001.937] I> Task: Save FMON data to SC7 ctx
[0001.941] I> Task: Save VMON data to SC7 ctx
[0001.946] I> Task: Save TZDRAM data to SC7 ctx
[0001.951] I> Task: Save GPIO int data to SC7 ctx
[0001.956] I> Task: Save clock data to SC7 ctx
[0001.960] I> Task: Save debug data to SC7 ctx
[0001.965] I> Task: Save MBWT data to SC7 ctx
[0001.974] I> SC7 context save done
[0001.978] I> Task: Load MB2/Applet/FSKP
[0001.982] I> Loading MB2
[0001.985] I> Slot: 1
[0001.987] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.994] I> Binary name: MB2
[0001.997] I> Size of crypto header is 8192
[0002.001] I> Size of crypto header is 8192
[0002.006] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0002.014] I> BCH of MB2 read from storage
[0002.018] I> BCH address is : 0x8007e000
[0002.024] I> MB2 header integrity check is success
[0002.029] I> Binary magic in BCH component 0 is MB2B
[0002.034] I> component binary type is 6
[0002.038] I> Size of crypto header is 8192
[0002.043] I> strt_pg_num(71440) num_of_pgs(841) read_buf(0x80000000)
[0002.055] I> MB2 binary is read from storage
[0002.061] I> MB2 binary integrity check is success
[0002.066] I> Binary MB2 loaded successfully at 0x80000000 (0x691f0)
[0002.074] I> Task: Map CCPLEX SHARED carveout
[0002.079] I> Task: Prepare MB2 params
[0002.084] I> BR-BCT Boot Chain Fields
[0002.088] I> u32_non_gpio_select_boot_chain : 1
[0002.093] I> u32_num_boot_chains : 2
[0002.098] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.103] I> Task: Dram ecc test
[0002.107] I> Task: Misc NV security settings
[0002.111] I> NVDEC sticky bits programming done
[0002.116] I> Successfully powergated NVDEC
[0002.121] I> Task: Disable/Reload WDT
[0002.125] I> Task: Program misc carveouts
[0002.129] I> Program IPC carveouts
[0002.137] I> SLCG Global override status := 0x0
[0002.142] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-4d0906e6)
I> Emulation:
I> Entry timestamp: 0x00212f37
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x470000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002034)
I> Task: Enable hot-plug capability (0x50028064)
I> Task: PSC mailbox init (0x500178b0)
I> Task: Crypto init (0x5000675c)
I> Task: Enable GP-SE clock (0x50002198)
I> Task: DICE Identity init (0x5001af00)
I> DICE is not enabled.
I> Task: Measured Boot init (0x5001b674)
I> Task: OEM SC7 context save init (0x5001a600)
I> Task: I2C register (0x50001ff8)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001fe0)
I> Task: Program CBB PCIE AMAP regions (0x5001ac14)
I> Task: Boot device init (0x50001f28)
I> Task: Partition Manager Init (0x50001f24)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001e198)
I> Task: Load AUXP FWs (0x50027c04)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: B_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
I> Partition name: B_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x46f200000
I> Partition name: B_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x46ef00000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x476000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9449600 bytes
I> dce: plain binary integrity check is success
I> Partition name: B_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x476000000
I> Partition name: B_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x46fc00000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x46f300000
I> Task: Carveout setup (0x500208f8)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50017784)
I> Task: Enable FSI VMON (0x50017280)
I> Task: Validate FSI Therm readings (0x50017364)
I> Task: Restore XUSB sec (0x50001ef8)
I> Task: Enable FSI SE clock (0x50017d0c)
I> Task: Initialize SBSA UART CAR (0x500020fc)
I> Task: Initialize CPUBL Params (0x50018cf8)
I> CPUBL-params @ 0x472000000
I> Task: Ratchet update (0x50029100)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50018ac4)
I> Task: Revoke PKC fuse (0x50001d44)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001a790)
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE (0x50018474)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50024d68)
I> OEM firewalls configured
I> Task: Powergate APE (0x500185e8)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x500251bc)
I> Task: Unhalt AUXPs (0x50027e6c)
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
����vic initialized
����tsc initialized
����aon lic initialized
����spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
����spe: init
����scheduler initialized
����aon hsp initialized
����tag initialized
����tcu initialized
����bpmp ipc initialized
����spe: late init
����cpu_nic clock initialized
����apb clock initialized
����pm initialized
����bpmp hsp initialized
����top1 hsp initialized
����ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x50017930)
I> Sending opcode 0x4d420802 to psc
��INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x478002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
��I> Received ACK from psc
I> Task: ��INFO: MONITOR: user task addr:0x478022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
bpmp: socket 0
bpmp: base binary md5 is 925eece486b7c46d91aa449178b5d322
bpmp: combined binary md5 is 029a50a8fb4897d35f94a799f82169a9
bpmp: firmware tag is 029a50a8fb4897d35f94-925eece486b
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
��Start secure NOR provision (0x5001aa2c)
I> Task: ��initialized avfs_clk_platform
initialized powergate
��Load FSI keyblob (0x5001��initialized dvs
��7d5��initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized mce_dbell
��4)
I> Task: Unhalt AUXPs (0x50027e74)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50018e1c)
I> Task: Load TOS (0x50019580)
I> Partition name: B_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-87808 (p��[ 2.567918] Camera-FW on t234-rce-safe started
TCU early console ena��initialized emc
initialized emc_mrq
��bled.
��artiti��
��on size: ��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
��0x380000), name: B_cpu-b��initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��ootloader
��initialized clk_cal_late
initialized noc_late
initialized cvc
initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
��[ 2.726700] Camer��enable can2_core
enable can2_host
enable pwm3
enable��a-FW on t234-rce-safe�� mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized clk_mach_post
initialized pg_post
initialized regulator_�� ready SHA1=8676d22a (crt 21.702 ms, total boot 181.542 ms)
��post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
��DCE: FW Boot Done
��I> Partition name: B_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-94976 (partition size: 0x400000), name: B_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0x3eea70000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x46e600000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x47fdee000
I> Relocating OP-TEE dtb from: 0x47fefec50 to 0x47c000020, size: 0x2106
I> [0] START: 0x80000000, SIZE: 0x3eea70000
I> [1] START: 0x472000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: B_eks
I> Binary@ device:3/0 block-107264 (partition size: 0x40000), name: B_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x470000200
I> EKB detected (length: 0x410) @ VA:0x470000200
I> Task: Prepare TOS params (0x500194f8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x47c000020
I> Task: OEM SC7 context save (0x5001a88c)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50027f00)
I> Task: Program display sticky bits (0x50027e7c)
I> Task: Storage device deinit (0x500020a0)
I> Task: SMMU external bypass disable (0x50017894)
I> Task: SMMU init (0x500177b0)
I> Task: Program GICv3 registers (0x50027fa0)
I> Task: Audit firewall settings (0x50024fbc)
I> Task: Bootchain failure check (0x500025e8)
I> Current Boot-Chain Slot: 1
I> BR-BCT Boot-Chain is 1, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
��NOTICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0x47c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:55 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
If the carrier board is using an HDMI port, then it is a known bug in 35.4.1,
and please refer to section Adaptation to the Carrier Board with HDMI for the Orin NX/Nano Modules
in the release note:
However, even without this bug, please note that Debian-based OTA for Orin NX is only supported when it’s used with an Orin Nano DevKit, and you should not try Debian-based OTA when using Xavier NX DevKit or any custom carrier boards.
This situation is so surrealist that I will leave the surrealist part for other day and probably other person and pass directly to How I fix the boot problem and recover my installation and data?
How I fix the boot problem and recover my installation and data.
Is that clear? But I don’t see you being cooperative with words like surrealist.
Since you are using an NVMe drive, it’s easy to backup data inside it.
