Last time I upgrade jetpack, I lost all the data because the instructions doesn’t work for NVME or I got a known bug which solution didn’t work, really I don’t know why I lost the data. Orin NX supports NVME, but still you are putting instructions only for flash memory (or sdcard maybe?), if the NVME have different commands, different instructions should be included in the guide, as I don’t know what of the two things made the data lost I cannot trust in follow the guide. Please , tell me what commands I need to use in the guide to update in NVME and update the guide to add the step by step for NVME installations. I cannot afford lose the data again.
This issue only happens when you update from 34.1 to 35.2.1, and if your L4T is already 35.2.1+, then it would not be affected.
But I’d suggest making sure your rootfs is using all the space available on the NVMe drive, so the update won’t be interrupted by some questions about enlarging the partition, which may cause the update to fail if you just abort it.
hi I specifically refer to the commands with /dev/mmcblk0 , I don’t think I have such address for that commands, or if something is written there, I don’t thing my nvme file system will find those new updated files there and will crash, I think is what made my lose of data, but obviously I have no clue of this kernel stuff , probably Im wrong, if you say me that /dev/mmcblk0 commands are ok with system flashed in nvme for me is fine I will , my file system takes all the nvme data available, wont ask expand anything.
My partitions are nvme0n1px where filesystem is nvme0n1p1 , nvme0n1p11 for EFI, no mmcblk0 anywhere
My Orin NX is not booting after update. It is not entering in BIOS config also, just booting logo with some test, but wont take action when push the keys it says, but I shouldn’t touch any keys, or config anything that just should boot. No errors where displayed in the update process.
Could enter in bios, it is recognizing my nvme and it is select to boot in it boot it is not booting just black screen and restarting itself after a few minutes in a boucle.
So you update to 5.1.2 and the device is not able to boot up now?
Do you have any serial console log to share?
Is it a DevKit (Xavier NX DevKit/Orin Nano DevKit) or a custom board?
exactly I was said and I asked
only boots in logo screen and I can enter in bios, my nvme that was working perfect with 4 moths of work on it, updated as the guide and you said, no errors.
just dont boot in default and stock waveshare kit carrier board.
nothing to share except the default logo screen, no console is openned, just logo , f1 and f11 options and something about a custom header in the screen center.
Are you sure there was no error during update?
Debian-based OTA is only intended for DevKits by NVIDIA, but not custom carrier boards by third-party vendors.
I mean something like this:
there is not such nvidia carrier board for orin nx. About what carrier are you talking about, waveshare carrier board the same than nvidia carrier board. Nothing the guide says of something doesn’t exists.
obviously no errors.
not possible console if doesn’t boot , only the boot screen.
waveshare carrier board is 1:1 nvidia carrier board
I dont have access to the serial terminals right now, as I don’t have Linux now, it is in a rover that I need dismount to access.
what about the micro usb and putty
Can you tell me what can be happening, and please don’t say me the carrier board, because for sure is not.
What about the recovery partition it is said in the bios, can I return to previous condition?
There is. Orin NX can be used with Xavier NX Developer Kit or Orin Nano Developer Kit.
If you don’t know what I’m talking about, just take a picture of the device you are using.
Micro USB is not going to give you access to serial console log; it’s only accessible via TTL-USB cable.
I don’t think you know more than us about the issue.
Can you be more specific?
I think we only have recovery kernel, which the device will enter after multiple failure of trying to boot up.
Just one thing for notice:
For any booting issues like “Why me device does not work?” or “It only boots into a black screen”, there is nothing we can help without booting log from serial console, or debugging without the log is just like telepathy.
what says there Nvidia development kit. OK
you can see me nvme is recognized
you can see the recovery partition I refer, can go back with any option there?
It doesn’t mater if the NVMe drive is being recognized or not; if the rootfs is corrupted, then it is not going to boot the device.
It is not going to give much help.
Again, we need booting log from serial console, not these blurry pictures.
Or there really is nothing we can do except re-flashing.
can I have a contact of your supervisor?
If it is the kernel image that gets corrupted, then switching to Kernel Partition in L4T Boot Mode may help.
Kernel image is by default loaded from a file in rootfs, but we also have a dedicated partition for storing kernel images.
If you just cannot give the log we need,
the situation won’t change no matter who is taking care of this issue…
[ 2.369201] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.375763] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.382764] arm-smmu 8000000.iommu: probing hardware configuration...
[ 2.388889] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.393611] arm-smmu 8000000.iommu: stage 1 translation
[ 2.399129] arm-smmu 8000000.iommu: stage 2 translation
[ 2.404551] arm-smmu 8000000.iommu: nested translation
[ 2.409714] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.416888] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.425586] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.430101] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.436664] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.443975] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.452624] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.456880] tegra_profiler: auth: init
[ 2.460942] nvsciipc: loaded module
[ 2.465873] tun: Universal TUN/TAP device driver, 1.6
[ 2.469815] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.476570] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.482127] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.486890] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.492768] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.498176] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.504007] PPP generic driver version 2.4.2
[ 2.508375] PPP BSD Compression module registered
[ 2.512970] PPP Deflate Compression module registered
[ 2.518224] PPP MPPE Compression module registered
[ 2.523222] usbcore: registered new interface driver r8152
[ 2.528548] usbcore: registered new interface driver asix
[ 2.533888] usbcore: registered new interface driver ax88179_178a
[ 2.540009] usbcore: registered new interface driver cdc_ether
[ 2.545961] usbcore: registered new interface driver net1080
[ 2.551557] usbcore: registered new interface driver cdc_subset
[ 2.557594] usbcore: registered new interface driver zaurus
[ 2.563293] usbcore: registered new interface driver cdc_ncm
[ 2.568970] usbcore: registered new interface driver aqc111
[ 2.574495] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.580699] ohci-pci: OHCI PCI platform driver
[ 2.584989] ohci-platform: OHCI generic platform driver
[ 2.590346] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.596343] usbcore: registered new interface driver uas
[ 2.601277] usbcore: registered new interface driver usb-storage
[ 2.607267] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.613011] mousedev: PS/2 mouse device common for all mice
[ 2.618436] usbcore: registered new interface driver xpad
[ 2.625748] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.629180] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:20 UTC (20)
[ 2.636974] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.643223] i2c /dev entries driver
[ 2.646779] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 2.652364] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 2.657750] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 2.663166] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 2.668500] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 2.674024] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 2.679434] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 2.684769] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 2.693584] device-mapper: uevent: version 1.0.3
[ 2.694805] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.704289] sdhci: Secure Digital Host Controller Interface driver
[ 2.709405] sdhci: Copyright(c) Pierre Ossman
[ 2.713686] Synopsys Designware Multimedia Card Interface Driver
[ 2.719800] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.725947] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.733265] tegra-bpmp bpmp: firmware: 029a50a8fb4897d35f94-925eece486b
[ 2.740838] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 2.744610] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 2.755651] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 2.755826] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[ 4.410990] hid: raw HID events driver (C) Jiri Kosina
[ 4.411599] usbcore: registered new interface driver usbhid
[ 4.411767] usbhid: USB HID core driver
[ 4.412262] tegra-dce d800000.dce: Adding to iommu group 3
[ 4.413632] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 4.414561] tegra234-aon c000000.aon: Adding to iommu group 4
[ 4.415796] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 4.416048] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 4.416180] c000000.aon:hsp: probed
[ 4.416373] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 4.416679] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 4.416912] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 4.416914] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 4.416928] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 4.417124] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 4.417356] tegra234-aon c000000.aon: init done
[ 4.417637] tegra23x-psc e860000.psc: Adding to iommu group 5
[ 4.433163] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 4.434935] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 4.441906] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 4.441907] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 4.441916] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 4.448323] tegra23x-psc e860000.psc: init done
[ 4.456356] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 4.465040] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 6
[ 4.490677] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.501343] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.506795] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.517754] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.528758] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.539794] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.55149����8] ��I/T��teg��C: ��ra-��Res��ivc��erv��-bu��ed ��s b��sh��c00��are��000��d m��.rt��emo��cpu��ry ��:iv��is ��c-b��di��us:��sab��ivc��led��cap��
��ff8����e@4��I/��: i��TC:��vcc�� Dy��apt��nam��ure��ic ��: v��sha��er=��re��0 g��d m��rp=��emo��1 R��ry ��X[5��is ��12x��ena��64]��bl��=0x��ed
��0-0����x18��I/��000��TC:�� TX�� No��[51��rma��2x6��l W��4]=��or��0x1��ld ��800��vir��0-0��tua��x20��liz��080��ati��
��on��[ �� su�� 4��ppo��.56��rt ��398��is��8] �� di��teg��sab��ra-��led��ivc��
��-bu����s b��I/��c00��TC:��000�� As��.rt��ync��cpu��hro��:iv��no��c-b��us ��us:��not��dia��ifi��g@5��cat��: d��ion��iag��s ��: v��are��er=�� di��0 g��sab��rp=��led��1 R��
��X[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.575952] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (112)
[ 4.582081] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.594750] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 4.603710] t19x_cache tegra-cache: probed
[ 4.605589] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 4.618820] optee: probing for conduit method.
[ 4.618950] optee: revision 3.21 (d8269f24)
[ 4.679217] optee: dynamic shared memory is enabled
[ 4.679589] optee: initialized driver
[ 4.695153] nvpmodel: initialized successfully
[ 4.695382] tegra_hv: get_hvd: not initialized yet
[ 4.695518] user_ivc_mempool: hypervisor not present
[ 4.696548] usbcore: registered new interface driver snd-usb-audio
[ 4.697888] u32 classifier
[ 4.697963] input device check on
[ 4.698053] Actions configured
[ 4.699803] Initializing XFRM netlink socket
[ 4.704535] NET: Registered protocol family 10
[ 4.710144] Segment Routing with IPv6
[ 4.712152] NET: Registered protocol family 17
[ 4.716492] NET: Registered protocol family 15
[ 4.720908] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.734837] Bluetooth: RFCOMM socket layer initialized
[ 4.739163] Bluetooth: RFCOMM ver 1.11
[ 4.743089] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.748941] Bluetooth: HIDP socket layer initialized
[ 4.755035] 9pnet: Installing 9P2000 support
[ 4.758361] Key type dns_resolver registered
[ 4.763734] registered taskstats version 1
[ 4.766806] Loading compiled-in X.509 certificates
[ 4.782079] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[ 4.782765] tegra194-pcie 14100000.pcie: Adding to iommu group 7
[ 4.794345] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 4.795561] tegra194-pcie 14160000.pcie: Adding to iommu group 8
[ 4.806204] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 4.807058] tegra194-pcie 141e0000.pcie: Adding to iommu group 9
[ 4.817999] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 4.818745] tegra194-pcie 140a0000.pcie: Adding to iommu group 10
[ 4.830085] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 4.856860] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 11
[ 4.861479] host1x 13e40000.host1x: Adding to iommu group 12
[ 4.883379] host1x 13e40000.host1x: initialized
[ 4.883997] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[ 4.884533] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 4.886235] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[ 4.886711] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 4.888359] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[ 4.891677] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 4.903257] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[ 4.909655] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 4.921000] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[ 4.927483] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 4.939016] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[ 4.939102] random: crng init done
[ 4.945544] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 4.960458] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[ 4.966963] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 4.978476] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[ 4.984995] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 4.996510] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[ 5.003024] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 5.014540] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[ 5.021076] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 5.032571] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[ 5.039054] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 5.050569] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[ 5.057103] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 5.068615] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[ 5.075089] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 5.086648] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[ 5.093125] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 5.104650] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[ 5.111158] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 5.122698] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[ 5.129218] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 5.140739] falcon 15340000.vic: Adding to iommu group 29
[ 5.150023] falcon 15340000.vic: initialized
[ 5.150502] falcon 15380000.nvjpg: Adding to iommu group 30
[ 5.158199] falcon 15380000.nvjpg: initialized
[ 5.159674] falcon 15540000.nvjpg1: Adding to iommu group 31
[ 5.169061] falcon 15540000.nvjpg1: initialized
[ 5.170039] falcon 154c0000.nvenc: Adding to iommu group 32
[ 5.180184] falcon 154c0000.nvenc: initialized
[ 5.180455] falcon 15a50000.ofa: Adding to iommu group 33
[ 5.188722] falcon 15a50000.ofa: initialized
[ 5.190143] nvdec 15480000.nvdec: Adding to iommu group 34
[ 5.201920] nvdec 15480000.nvdec: initialized
[ 5.202164] tsec 15500000.tsec: Adding to iommu group 35
[ 5.209919] tsec 15500000.tsec: initialized
[ 5.212990] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 5.226432] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 5.239477] gpio-397 (camera-control-output-low): hogged as output/low
[ 5.239692] gpio-486 (camera-control-output-low): hogged as output/low
[ 5.240933] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 5.243347] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 5.248864] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 5.256074] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 5.261931] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 5.269997] tegra194-isp5 14800000.isp: Adding to iommu group 36
[ 5.275008] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 5.280908] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 5.286806] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.295726] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.305081] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[ 5.313163] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[ 5.320028] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 5.329018] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 5.335021] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 5.344834] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 5.351020] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 5.360821] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 5.366790] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 39
[ 5.375142] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 5.386034] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 40
[ 5.394575] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 5.405284] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 41
[ 5.413642] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 5.424512] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 42
[ 5.432870] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 5.443592] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 43
[ 5.452168] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 5.462844] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 44
[ 5.471386] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 5.482109] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 45
[ 5.490681] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 5.501354] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 46
[ 5.509889] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 5.520605] pva 16000000.pva0: Adding to iommu group 47
[ 5.531191] pva 16000000.pva0: initialized
[ 5.540700] nvdla 15880000.nvdla0: Adding to iommu group 48
[ 5.546279] nvdla 15880000.nvdla0: initialized
[ 5.548294] nvdla 158c0000.nvdla1: Adding to iommu group 49
[ 5.553345] nvdla 158c0000.nvdla1: initialized
[ 5.555292] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 5.557116] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 5.563512] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 5.569773] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 5.576368] serial-tegra 3100000.serial: Adding to iommu group 2
[ 5.582699] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 5.591933] serial-tegra 3130000.serial: Adding to iommu group 2
[ 5.597423] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 5.606548] serial-tegra 3140000.serial: Adding to iommu group 2
[ 5.612214] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 5.639225] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 5.639482] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.639655] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.644035] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 5.652684] tegra-xusb 3610000.xhci: irq 229, io mem 0x03610000
[ 5.658903] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.666899] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.674071] usb usb1: Product: xHCI Host Controller
[ 5.679056] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 5.685357] usb usb1: SerialNumber: 3610000.xhci
[ 5.690717] hub 1-0:1.0: USB hub found
[ 5.693874] hub 1-0:1.0: 4 ports detected
[ 5.698128] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.703309] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.710925] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.718347] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.726493] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.733744] usb usb2: Product: xHCI Host Controller
[ 5.738734] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 5.744949] usb usb2: SerialNumber: 3610000.xhci
[ 5.750134] hub 2-0:1.0: USB hub found
[ 5.753364] hub 2-0:1.0: 4 ports detected
[ 5.780615] i2c i2c-2: Added multiplexed i2c bus 9
[ 5.781419] i2c i2c-2: Added multiplexed i2c bus 10
[ 5.781543] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 5.781978] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 5.794668] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2012000 KHz, changing to: 1984000 KHz
[ 5.797613] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1986000 KHz, changing to: 1984000 KHz
[ 5.804585] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 5.810393] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 5.816703] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 5.822657] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 5.830962] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 5.839533] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 5.954554] tegra194-pcie 14100000.pcie: Link up
[ 5.956906] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.957107] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.957260] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 5.957518] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 5.957793] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 5.958046] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 5.958353] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 5.958551] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 5.962767] pci 0001:01:00.0: [8086:2526] type 00 class 0x028000
[ 5.963112] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 5.964359] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[ 5.968450] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 5.968636] pci 0001:01:00.0: BAR 0: assigned [mem 0x20a8000000-0x20a8003fff 64bit]
[ 5.968914] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.969044] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 5.972529] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 5.981065] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 5.989925] pcieport 0001:00:00.0: Adding to iommu group 7
[ 5.995314] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 6.001354] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 6.007415] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.014053] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 6.019773] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 6.028257] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 6.036917] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 6.113458] usb 1-2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice=90.23
[ 6.113687] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.113885] usb 1-2: Product: USB2.0 Hub
[ 6.114031] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 6.115975] hub 1-2:1.0: USB hub found
[ 6.116704] hub 1-2:1.0: 4 ports detected
[ 6.150397] tegra194-pcie 14160000.pcie: Link up
[ 6.151542] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.151732] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.151883] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 6.152151] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 6.152442] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 6.152673] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 6.152967] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 6.156951] pci 0004:01:00.0: [2646:5017] type 00 class 0x010802
[ 6.157277] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 6.162505] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 6.162690] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 6.162969] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 6.168343] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 6.175613] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 6.184145] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 6.192811] pcieport 0004:00:00.0: Adding to iommu group 8
[ 6.198281] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 6.204155] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 6.209940] nvme 0004:01:00.0: Adding to iommu group 8
[ 6.215329] nvme nvme0: pci function 0004:01:00.0
[ 6.219847] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 6.220261] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.233308] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 6.238537] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 6.247009] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 6.247657] nvme nvme0: allocated 64 MiB host memory buffer.
[ 6.255490] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 6.270603] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[ 6.294367] nvme nvme0: 8/0/0 default/read/poll queues
[ 6.303238] usb 2-1: New USB device found, idVendor=2109, idProduct=0817, bcdDevice=90.23
[ 6.303386] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 6.303463] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.304839] usb 2-1: Product: USB3.0 Hub
[ 6.310093] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 6.319279] hub 2-1:1.0: USB hub found
[ 6.319946] hub 2-1:1.0: 4 ports detected
[ 6.426552] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 6.578309] usb 1-3: New USB device found, idVendor=8087, idProduct=0025, bcdDevice= 0.02
[ 6.578557] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 6.862555] usb 1-2.1: new full-speed USB device number 4 using tegra-xusb
[ 7.023362] usb 1-2.1: New USB device found, idVendor=4037, idProduct=2804, bcdDevice= 1.10
[ 7.023605] usb 1-2.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 7.023806] usb 1-2.1: Product: 2.4G Composite Devic
[ 7.030423] input: 2.4G Composite Devic as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:4037:2804.0001/input/input0
[ 7.090460] hid-generic 0003:4037:2804.0001: input,hidraw0: USB HID v1.10 Keyboard [2.4G Composite Devic] on usb-3610000.xhci-2.1/input0
[ 7.094838] usb 2-1.3: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[ 7.095237] input: 2.4G Composite Devic Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:4037:2804.0002/input/input1
[ 7.095647] input: 2.4G Composite Devic Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:4037:2804.0002/input/input2
[ 7.119083] usb 2-1.3: New USB device found, idVendor=2109, idProduct=0817, bcdDevice= 2.14
[ 7.119311] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.119498] usb 2-1.3: Product: USB3.0 Hub
[ 7.119630] usb 2-1.3: Manufacturer: VIA Labs, Inc.
[ 7.124389] hub 2-1.3:1.0: USB hub found
[ 7.125197] hub 2-1.3:1.0: 4 ports detected
[ 7.154442] input: 2.4G Composite Devic System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:4037:2804.0002/input/input3
[ 7.154837] hid-generic 0003:4037:2804.0002: input,hidraw1: USB HID v1.10 Mouse [2.4G Composite Devic] on usb-3610000.xhci-2.1/input1
[ 7.210968] usb 2-1.4: new SuperSpeed Gen 1 USB device number 4 using tegra-xusb
[ 7.237572] usb 2-1.4: New USB device found, idVendor=8086, idProduct=0b07, bcdDevice=50.e0
[ 7.237813] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.238017] usb 2-1.4: Product: Intel(R) RealSense(TM) Depth Camera 435
[ 7.238206] usb 2-1.4: Manufacturer: Intel(R) RealSense(TM) Depth Camera 435
[ 7.238410] usb 2-1.4: SerialNumber: 822213023066
[ 7.362397] usb 1-2.2: new high-speed USB device number 5 using tegra-xusb
[ 7.364027] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 7.364263] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 7.364447] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 7.364593] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 7.364848] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 7.365128] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 7.365381] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 7.365687] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 7.373120] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 7.373263] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.373737] pcieport 0007:00:00.0: Adding to iommu group 9
[ 7.374074] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 7.374745] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 7.375100] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 7.375331] pci 0007:00:00.0: Removing from iommu group 9
[ 7.377735] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 7.385033] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 7.390232] vdd-3v3-sd: supplied by vdd-3v3
[ 7.396077] tegra194-isp5 14800000.isp: initialized
[ 7.402091] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 7.405285] (NULL device *): fops function table already registered
[ 7.412251] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 7.418169] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 7.424234] irq: IRQ302: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.514175] usb 1-2.2: config 1 interface 0 altsetting 0 bulk endpoint 0x81 has invalid maxpacket 64
[ 7.514427] usb 1-2.2: config 1 interface 0 altsetting 0 bulk endpoint 0x1 has invalid maxpacket 64
[ 7.518245] usb 1-2.2: New USB device found, idVendor=03e7, idProduct=2150, bcdDevice= 0.01
[ 7.518474] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.518672] usb 1-2.2: Product: Movidius MA2X5X
[ 7.518799] usb 1-2.2: Manufacturer: Movidius Ltd.
[ 7.518931] usb 1-2.2: SerialNumber: 03e72150
[ 7.540120] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 7.540315] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 7.540536] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 7.540753] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 7.646409] tegra194-pcie 140a0000.pcie: Link up
[ 7.648990] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 7.649194] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 7.649344] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 7.649625] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 7.649902] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 7.650146] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 7.650453] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 7.650611] usb 1-2.3: new high-speed USB device number 6 using tegra-xusb
[ 7.654596] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 7.654889] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 7.655215] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 7.655499] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 7.656692] pci 0008:01:00.0: supports D1 D2
[ 7.656800] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 7.661083] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 7.661997] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 7.668391] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 7.676356] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 7.684228] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 7.690552] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 7.695776] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 7.702165] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 7.709525] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 7.718065] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 7.726723] pcieport 0008:00:00.0: Adding to iommu group 10
[ 7.732390] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 7.738251] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 7.744788] irq: IRQ304: trimming hierarchy from :pmc@c360000
[ 7.749393] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.756807] input: gpio-keys as /devices/platform/gpio-keys/input/input4
[ 7.764100] tegra-se-nvhost 15810000.se: Adding to iommu group 50
[ 7.770068] tegra-se-nvhost 15810000.se: initialized
[ 7.783499] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 7.783756] tegra-se-nvhost 15820000.se: Adding to iommu group 51
[ 7.78722��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��7] tegra-se-nvhost 15820000.se: initialized
[ 7.794280] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.797984] tegra-se-nvhost 15840000.se: Adding to iommu group 52
[ 7.804461] tegra-se-nvhost 15840000.se: initialized
[ 7.810474] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 7.815876] tegra_actmon d230000.actmon: in actmon_register()...
[ 7.821515] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 7.827077] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 7.828047] usb 1-2.3: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 2.14
[ 7.834894] hvc_sysfs: hypervisor is not present
[ 7.842950] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.842951] usb 1-2.3: Product: USB2.0 Hub
[ 7.842952] usb 1-2.3: Manufacturer: VIA Labs, Inc.
[ 7.843693] hub 1-2.3:1.0: USB hub found
[ 7.876544] hub 1-2.3:1.0: 4 ports detected
[ 7.884257] ALSA device list:
[ 7.884336] No soundcards found.
[ 7.887431] Freeing unused kernel memory: 3968K
[ 7.898422] Run /init as init process
[ 7.911157] Root device found: initrd
[ 7.911628] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Device /dev/mmcblk?p1 does not exist
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Looking for OTA work directory on the device(s): /dev/nvme0n1p1
[ 7.950706] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
OTA work directory /mnt/ota_work is not found on /dev/nvme0n1p1
Finding OTA work dir on internal storage device
mount: /mnt: special device /dev/mmcblk0p1 does not exist.
Failed to mount /dev/mmcblk0p1 to /mnt
OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0# [ 8.622525] usb 1-2.3.1: new full-speed USB device number 7 using tegra-xusb
[ 8.783418] usb 1-2.3.1: New USB device found, idVendor=1209, idProduct=5741, bcdDevice= 2.00
[ 8.783666] usb 1-2.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.783897] usb 1-2.3.1: Product: mini-pix
[ 8.784021] usb 1-2.3.1: Manufacturer: ArduPilot
[ 8.784159] usb 1-2.3.1: SerialNumber: 3C0055000E51363135393734
[ 8.918522] usb 1-2.3.4: new full-speed USB device number 8 using tegra-xusb
[ 9.079190] usb 1-2.3.4: New USB device found, idVendor=1546, idProduct=01a8, bcdDevice= 3.01
[ 9.079448] usb 1-2.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.079670] usb 1-2.3.4: Product: u-blox GNSS receiver
[ 9.079820] usb 1-2.3.4: Manufacturer: u-blox AG - www.u-blox.com
I still want a supervisor enter in contact with me. Thank you.
you can still try to fix the issue if you wish, but having no idea I would say is happening exactly what I said in my question, why I did that question, and the result looks directly related with the answer given. It doesn’t look a corrupted kernel, isn’t? but that mmccblk… thing looks quite similar to what I said in my few first posts.
So yeah, please I would like to a supervisor check this as can cost me a lot of money, that for sure I will claim if it it is not fixed without lost of data in any way and was derived by a bad advice. There is not such corruption but there is mmccblk missing.
