I’ve been trying to use NX devkit as PCIe endpoint mode,I follow the AGX procedure to modify,details as follows:
- In the extracted Jetson Linux release directory, edit p3668.conf.common Set bit 12 of the ODMDATA value, i.e. change it from
0xB8190000to0xB8191000; - Run this command to reflash the device: sudo ./flash.sh jetson-xavier-nx-devkit mmcblk0p1
But when I finished updating, there was an error in startup, as follows:
TICE: BL31: v2.5(release):ef8af0b99
NOTICE: BL31: Built : 20:57:59, May 16 2022
I/TC:
pmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
TC: Nk_early initialized
-seil_early initialized
se initialized
hwwdt initialized
e94_ec_get_ec_list: found 45 ecs
ernal DT initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
uc initialized
n_populate_monitors: found 73 monitors
on initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
TC: OP-TEE version: 6f444acf (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue May 17 04:00:18 UTC 2022 s initialized
initialized
pend initialized
64_late initialized
mrq_init initialized
strap initialized
initialized
TC: c initialized
emc_mrq initialized
imary CPU initializing
k_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs_clk_platform_post initialized
cvc_late initialized
regulator_post initialized
rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] TC: Primary CPU switching to normal world boot
etson UEFI firmware (version r34.1-975eef6 built on 2022-05-16T20:58:45-07:00)
ROR: MPIDR 0x80000000: exception reason=0 syndrome=0xbe000000
ERROR: **************************************
ERROR: RAS Error in L2, ERRSELR_EL1=0x200:
ERROR: Status = 0xfc006612
ERROR: IERR = SCF to L2 Slave Error Read: 0x66
ERROR: SERR = Error response from slave: 0x12
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: Uncorrectable (this is fatal)
ERROR: MISC0 = 0x80000000400000
ERROR: MISC1 = 0x20240000000
ERROR: ADDR = 0x8000000003eb00c0
Is there a step I’m missing and what do I need to do?
