TL;DR: Unable to boot Xavier NX in PCIe endpoint mode with Jetpack 5.0.2 in UEFI mode, getting errors. Reverting ODMDATA value to the original allows UEFI to start and work as expected.
Hello Support Team,
Please help me to find a way to use Xavier NX modules configured in PCIe End Point mode with Jetpack 5.0.2 and UEFI.
I changed the ODMDATA value from 0xB8190000 to 0xB8191000 in the file p3668.conf.common, and applied the command sudo ./flash.sh jetson-xavier-nx-devkit-qspi mmcblk0p1
After that the system won’t boot and report the following errors:
??ERROR: MPIDR 0x80000000: exception reason=0 syndrome=0xbe000000
ERROR: **************************************
ERROR: RAS Error in L2, ERRSELR_EL1=0x200:
ERROR: Status = 0xfc006612
ERROR: IERR = SCF to L2 Slave Error Read: 0x66
ERROR: SERR = Error response from slave: 0x12
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: Uncorrectable (this is fatal)
ERROR: MISC0 = 0x80000000400000
ERROR: MISC1 = 0x20240000001
ERROR: ADDR = 0x8000000003eb00c0
ERROR: RAS Error in SCF_IOB, ERRSELR_EL1=0x401:
ERROR: Status = 0xf4009604
ERROR: IERR = CBB Interface Error: 0x96
ERROR: SERR = Assertion failure: 0x4
ERROR: MISC0 = 0x40
ERROR: MISC1 = 0x664a444461
ERROR: RAS error handled!
ERROR: sdei_dispatch_event returned -1
When I revert ODMDATA to the original value, the UEFI would start and work as expected.
Is there anything in the UEFI / BSP configuration that needs to be changed to make EP mode work?
Thanks,
