I’m trying to set the Xavier EP mode but couldn’t make it.
What am I supposed to do further? Please give me any advises.
Model: Xavier AGX
Fusing process:
Download L4T Driver Package(L4T R32.5.1)
Applying roots.
$ tar xf ${L4T_RELEASE_PACKAGE}
$ cd Linux_for_Tegra/rootfs/
$ sudo tar xpf …/…/${SAMPLE_FS_PACKAGE}
$ cd …
$ sudo ./apply_binaries.sh -
Edit p2972-0000.conf.common
ODMDATA=0x9190000; —> ODMDATA=0x9191000; -
get into recovery mode
sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1
result:
dmesg
grep pcie1-desktop:/sys/kernel/config/pci_ep/functions/pci_epf_nv_test$ dmesg | grep pcie
[ 0.832954] iommu: Adding device 141a0000.pcie_ep to group 0
[ 0.833619] iommu: Adding device 14180000.pcie to group 1
[ 0.834330] iommu: Adding device 14100000.pcie to group 2
[ 0.835038] iommu: Adding device 14140000.pcie to group 3
[ 0.895102] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 0.895141] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 4.211368] tegra-pcie-dw 141a0000.pcie_ep: Setting init speed to max speed
[ 4.212603] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 4.213687] OF: PCI: host bridge /pcie@14180000 ranges:
[ 4.725768] tegra-pcie-dw 14180000.pcie: link is down
[ 4.725967] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 4.726939] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 4.726945] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 4.727059] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 4.727205] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
[ 4.727245] aer 0000:00:00.0:pcie002: unloading service driver aer
[ 4.728793] tegra-pcie-dw 14180000.pcie: PCIe link is not up…!
[ 4.729734] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 4.730443] OF: PCI: host bridge /pcie@14100000 ranges:
[ 4.840892] tegra-pcie-dw 14100000.pcie: link is up
[ 4.841160] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 4.855258] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 4.855268] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 4.855397] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 4.857306] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 4.858060] OF: PCI: host bridge /pcie@14140000 ranges:
[ 5.373883] tegra-pcie-dw 14140000.pcie: link is down
[ 5.374058] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 5.374961] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.374968] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.375088] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 5.375231] pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
[ 5.375306] aer 0003:00:00.0:pcie002: unloading service driver aer
[ 5.377078] tegra-pcie-dw 14140000.pcie: PCIe link is not up…! -
sudo lspci -v
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1) (prog-if 00 [N)
Flags: bus master, fast devsel, latency 0, IRQ 36
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 00000000-00000fff
Memory behind bridge: 40000000-400fffff
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Port (Slot-), MSI 00
Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] #19
Capabilities: [158] #26
Capabilities: [17c] #27
Capabilities: [190] L1 PM Substates
Capabilities: [1a0] Vendor Specific Information: ID=0002 Rev=4 Len=100 >
Capabilities: [2a0] Vendor Specific Information: ID=0001 Rev=1 Len=038 >
Capabilities: [2d8] #25
Capabilities: [2e4] Precision Time Measurement
Capabilities: [2f0] Vendor Specific Information: ID=0004 Rev=1 Len=054 >
Kernel driver in use: pcieport -
ls -la /sys/firmware/devicetree/base/chosen/plugin-manager/odm-data
-r–r–r-- 1 root root 4 Jan 28 11:10 bootloader_unlocked
-r–r–r-- 1 root root 4 Jan 28 11:10 disable-pcie-c0-endpoint
-r–r–r-- 1 root root 4 Jan 28 11:10 disable-pcie-c4-endpoint
-r–r–r-- 1 root root 4 Jan 28 11:10 disable-pmic-wdt
-r–r–r-- 1 root root 4 Jan 28 11:10 disable-sata
-r–r–r-- 1 root root 4 Jan 28 11:10 enable-debug-console
-r–r–r-- 1 root root 4 Jan 28 11:10 enable-denver-wdt
-r–r–r-- 1 root root 4 Jan 28 11:10 enable-nvhs-uphy-pcie-c5
-r–r–r-- 1 root root 4 Jan 28 11:10 enable-pcie-c5-endpoint
-r–r–r-- 1 root root 4 Jan 28 11:10 enable-ufs-uphy-l10
-r–r–r-- 1 root root 9 Jan 28 11:10 name
-r–r–r-- 1 root root 4 Jan 28 11:10 no-battery
-r–r–r-- 1 root root 4 Jan 28 11:10 normal-build
-r–r–r-- 1 root root 4 Jan 28 11:10 pcie-xbar-4-1-0-1-2
