How to use ipython with IsaacSim pip installation?
I installed Isaac Sim using the pip installation method. It seems that jupyter_notebook.sh mentioned in the Jupyter Notebook snippet in the official document is not present.
I try to first start a standard IPython kernel and then load the Omni app launcher. However, after running AppLauncher(), the IPython console stops working. Setting the ISAAC_JUPYTER_KERNEL environment variable and applying nest_asyncio as mentioned in the Docs does not help.
Any idea how to get Jupyter/IPython working with my installation? Thanks!
Hi @mcfloundinho
Basically, the only you need to use IPyton/Jupyter with “Isaac Sim - Python packages” is to install and launch Jupyter
  1. Install Isaac Sim and Jupyter, then launch jupyter
    # create a new virtual environment
     python3.10 -m venv env_isaacsim
     source env_isaacsim/bin/activate
     pip install --upgrade pip
     # install Isaac Sim
     pip install isaacsim --extra-index-url https://pypi.nvidia.com
     # install Jupyter
     pip install jupyterlab
     # launch Jupyter
     jupyter lab
  2. Open a new “Python 3 (ipykernel)” notebook and play with it
