How can to use i2c1(189, 191ping)? I can’t measure i2c1_scl and i2c1_sda signal when i exec i2cdetect -y 1.
kernel.log (58.8 KB)
Try i2cdetect -y 8
dumu@localhost:~$ sudo ./i2cdetect -y 8
Warning: Can’t use SMBus Quick Write command, will skip some addresses
0 1 2 3 4 5 6 7 8 9 a b c d e f
00:
10:
20:
30: – -- – -- – -- – --
40:
50: – -- – -- – -- – -- – -- – -- – -- – --
60:
You are right, exec i2cdetect -y 8. It can measure i2c1_scl and i2c1_sda signal. Can you send the other i2c correspondence? Thanks.
Another i2c0_xx is map to i2c bus 1
