How to use Orin spi5?
Hi everyone,
we want use Orin spi5 the CVM Connector pins are F10,F9,G7,L15,but in Jetson_AGX_Orin_Series_Pinmux_Config_Template_1.5.xlsm file these pins are not allowed set as SPI function, and also dts file not configure spi@3250000. How to use spi5? Thanks
SPI5 is not supported on Orin, as you can refer to the DG in DLC: https://developer.nvidia.com/embedded/secure/jetson/agx_orin/jetson_agx_orin_design_guide_dg-10653-001_v0.2.pdf
