I am using Video Codec SDK to develop application to decode video from RTSP stream.
My application is similar to AppDec in your examples, exception that the input stream is from RTSP.
FFmpegDemuxer has been established successful and received video data, but when I transfer video data to NvDecode I do not get any decoded frame return. Is there any mistake in my steps?
At the moment I can’t resolved my problem. I have run AppDec with input from file, but the output file have no decoded frame. Is there any conflict between library of cuda and video SDK?
I can not resolve my problem with AppDec when the input source is rtsp.
And I have another question about NvEncode.
In my application, I have to switch video output file to new one, when the size of output file has reached the specific value (ex 3M).
And I don’t want to release cuda resources, only reset to Encoder to beginning state. How can I do it?
My RTSP Stream is right. I have used FFmpegDemuxer + libavcodec (with hardware accl) to decode my RTSP stream and the result is OK
I have used AppDec as you recommend and the result as below:
./AppDec -i rtsp://root:xxxx@xxxx/axis-media/media.amp -o out.yuv -resize 1920x1080
GPU in use: GeForce GTX 1050 Ti
Decode with demuxing.
[INFO ][13:55:36] Media format: RTSP input (rtsp)
[rtsp @ 0x1bfb880] UDP timeout, retrying with TCP
[INFO ][13:55:48] Demux video result: 429891
[INFO ][13:55:48] Demux video result: 67373
[INFO ][13:55:48] Demux video result: 77933
[INFO ][13:55:48] Demux video result: 61037
[INFO ][13:55:48] Demux video result: 71685
[INFO ][13:55:48] Demux video result: 68049
[INFO ][13:55:48] Demux video result: 57717
[INFO ][13:55:48] Demux video result: 67309
[INFO ][13:55:48] Demux video result: 72753
[INFO ][13:55:48] Demux video result: 62245
[INFO ][13:55:48] Demux video result: 73657
[INFO ][13:55:48] Demux video result: 72329
[INFO ][13:55:48] Demux video result: 59233
[INFO ][13:55:48] Demux video result: 67717
[INFO ][13:55:48] Demux video result: 69017
[INFO ][13:55:48] Demux video result: 59353
[INFO ][13:55:48] Demux video result: 71077
[INFO ][13:55:48] Demux video result: 70881
[INFO ][13:55:48] Demux video result: 58961
[INFO ][13:55:48] Demux video result: 67973
[INFO ][13:55:48] Demux video result: 65617
[INFO ][13:55:48] Demux video result: 57313
[INFO ][13:55:48] Demux video result: 68893
[INFO ][13:55:48] Demux video result: 71277
[INFO ][13:55:48] Demux video result: 60869
[INFO ][13:55:48] Demux video result: 71417
[INFO ][13:55:48] Demux video result: 68641
[INFO ][13:55:48] Demux video result: 56569
[INFO ][13:55:48] Demux video result: 67489
[INFO ][13:55:48] Demux video result: 70653
[INFO ][13:55:48] Demux video result: 60437
[INFO ][13:55:48] Demux video result: 72121
[INFO ][13:55:49] Demux video result: 419093
[INFO ][13:55:49] Demux video result: 52985
[INFO ][13:55:49] Demux video result: 66197
[INFO ][13:55:49] Demux video result: 72481
[INFO ][13:55:49] Demux video result: 63533
[INFO ][13:55:49] Demux video result: 78789
[INFO ][13:55:49] Demux video result: 77877
[INFO ][13:55:49] Demux video result: 63281
[INFO ][13:55:49] Demux video result: 73557
[INFO ][13:55:49] Demux video result: 72709
[INFO ][13:55:49] Demux video result: 61913
[INFO ][13:55:49] Demux video result: 80273
[INFO ][13:55:50] Demux video result: 80465
[INFO ][13:55:50] Demux video result: 66181
[INFO ][13:55:50] Demux video result: 75841
[INFO ][13:55:50] Demux video result: 72269
[INFO ][13:55:50] Demux video result: 60101
[INFO ][13:55:50] Demux video result: 71361
[INFO ][13:55:50] Demux video result: 74477
[INFO ][13:55:50] Demux video result: 62785
[INFO ][13:55:50] Demux video result: 72869
[INFO ][13:55:50] Demux video result: 68977
[INFO ][13:55:50] Demux video result: 57801
[INFO ][13:55:50] Demux video result: 68033
[INFO ][13:55:50] Demux video result: 69965
[INFO ][13:55:50] Demux video result: 59509
[INFO ][13:55:50] Demux video result: 72505
[INFO ][13:55:50] Demux video result: 73193
[INFO ][13:55:50] Demux video result: 61145
[INFO ][13:55:51] Demux video result: 69645
[INFO ][13:55:51] Demux video result: 71153
[INFO ][13:55:51] Demux video result: 62173
[INFO ][13:55:51] Demux video result: 421997
[INFO ][13:55:51] Demux video result: 72761
[INFO ][13:55:51] Demux video result: 61637
[INFO ][13:55:51] Demux video result: 76817
[INFO ][13:55:51] Demux video result: 75789
[INFO ][13:55:51] Demux video result: 63777
[INFO ][13:55:51] Demux video result: 79389
It’s demuxed OK, but nFrameReturned when call function dec.Decode(pVideo, nVideoBytes, &ppFrame, &nFrameReturned) is 0. So none video frame is writen to file
This sounds like exactly the problem I had and the same as described here Video Codec SDK: Decoding problem I have commented there with my solution - basically the FFmpegDemuxer wasn’t designed to support RTSP streams - I’ve given details of the changes I made.
