I am looking for a 7 meter dac or aoc cable for the MNPA19-XTR 10GB MELLANOX ConnectX®-2 card
I am looking for a 7 meter dac or aoc cable for the MNPA19-XTR 10GB MELLANOX ConnectX®-2 card. Is there a model that you can recommend me and that works for sure? I will make the connection between 2 MNPA19-XTR. I will not put a switch in between.
Hello Techdocstr,
Thank you for posting your inquiry on the Developers Forum.
As the ConnectX-2 is EOL/EOS for a long time already, compatible cables will be limited in availability.
The only 10Gb/S SFP+ 7m Eth. cable which we had available is the MC3309124-007 (https://network.nvidia.com/pdf/prod_cables/PB_MC33091xx-xxx_MCP210x-XxxxB_10GbE_SFP+_DAC.pdf)
Recommend to do a search on eBay or FS.com for a compatible cable.
Thank you and regards,
~NVIDIA Networking Technical Support
