I tried to calibrate a USB camera of my laptop with following this page.
I think I did the steps 1-8, however I encounter an warning and I could not proceed.
And I could not press Calibrate button.
An warning is this.
admin@7-ssd:/workspaces/isaac_ros-dev$ ros2 run camera_calibration cameracalibrator --size 6x8 --square 0.20 image:=/my_camera/image_raw camera:=/my_camera
[WARN] [1706578266.099333686] [rcl]: Found remap rule ‘image:=/my_camera/image_raw’. This syntax is deprecated. Use ‘–ros-args --remap image:=/my_camera/image_raw’ instead.
[WARN] [1706578266.099346440] [rcl]: Found remap rule ‘camera:=/my_camera’. This syntax is deprecated. Use ‘–ros-args --remap camera:=/my_camera’ instead.
[WARN] [1706578266.099625202] [rcl]: Found remap rule ‘image:=/my_camera/image_raw’. This syntax is deprecated. Use ‘–ros-args --remap image:=/my_camera/image_raw’ instead.
[WARN] [1706578266.099657082] [rcl]: Found remap rule ‘camera:=/my_camera’. This syntax is deprecated. Use ‘–ros-args --remap camera:=/my_camera’ instead.
Waiting for service camera/set_camera_info …
OK
Waiting for service left_camera/set_camera_info …
OK
Waiting for service right_camera/set_camera_info …
OK(display:20436): dbind-WARNING **: 10:31:21.188: Couldn’t connect to accessibility bus: Failed to connect to socket /run/user/1000/at-spi/bus_1: No such file or directory
But I think there is the file or directory in my Ubuntu22.04.
uma7@7-ssd:~/workspaces/isaac_ros-dev/src/isaac_ros_common$ ls -l /run/user/1000/at-spi/bus_1
srwxrwxrwx 1 uma7 uma7 0 Jan 30 10:14 /run/user/1000/at-spi/bus_1
Through the NVIDIA Docker, I can not connect to the file or directory.
uma7@7-ssd:~/workspaces/isaac_ros-dev/src/isaac_ros_common$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common &&
./scripts/run_dev.sh
admin@7-ssd:/workspaces/isaac_ros-dev$ ls /run/user/1000/at-spi/bus_1
ls: cannot access ‘/run/user/1000/at-spi/bus_1’: No such file or directory
What should I do for this?
Thank you.
