I cannot sudo rm default.target
Please confirm the contents.
Thank you.
which parameter you entered for <root> :
$ sudo ./apply_binaries.sh -r <root >
The file you’re looking for might be here:
Linux_for_Tegra/rootfs/etc/systemd/system/default.target
try from root user
Does the file exist? If it does, then it will probably be a symbolic link. If not, then you cannot rm something which isn’t there.
I have to check, but I guess I created a backup.img on the source device (jetson nano) without setting oem-config and mounted it with it.
When I try to follow the manual in a state of lack of understanding, I think it gives wrong results. I should check it again.
thank you.
