I have tried to download the Image from:
https://developer.nvidia.com/jetpack-sdk-44-archive
but it does not work. I get a window with the error: 404 - Not Found
Any solution?
Any solution?
I can download it, I press the “Download the SD Card Image” under JETSON NANO DEVELOPER KIT and it starts downloading.
Could you try with another browser or clean cookies/cache to see if can start downloading?
You may also find the SD card image from Jetson Download Center | NVIDIA Developer
I have the same problem, can’t download from
e.g. Jetson Nano Developer Kit SD Card Image - JP 4.4.1
Error: 404 - Not Found
Thanks for reporting this issue, I have forwarded to relevant team to fix this problem, please stay tuned.
Download problem should be fixed, please get it a try. Thanks
Now I can download the image.
Thank you very much!
Regards.
