I have a camera with an IMX565 sensor, and I’m trying to capture an image on the TX2_NX. Here’s the command I’m using:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 silent=false ! 'video/x-raw(memory:NVMM), width=4128, height=3008, format=(string)NV12, framerate=(fraction)5/1' ! nvvidconv ! 'video/x-raw,width=640, height=480' ! nvvidconv ! clockoverlay shaded-background=true font-desc='Sans 38' ! ximagesink -e
Here’s the error I’m getting:
Streamer-WARNING **: 11:30:37.135: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so': librestbed.so.4: cannot open shared object file: No such file or directory
X11 connection rejected because of wrong authentication.
nvbuf_utils: Could not get EGL display connection
WARNING: erroneous pipeline: no element "nvarguscamerasrc"
How can I solve this?
Have below command before gst-launch-1.0
export DISPLAY=:0
Still no go:
export DISPLAY=:0
hs@4-6-rev2-NX_TX2_BATI:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=1 sensor-mode=1 silent=false ! 'video/x-raw(memory:NVMM), width=4128, height=3008, format=(string)NV12, framerate=(fraction)5/1' ! nvvidconv ! 'video/x-raw,width=640, height=480' ! nvvidconv ! clockoverlay shaded-background=true font-desc='Sans 38' ! ximagesink -e
No EGL Display
nvbufsurftransform: Could not get EGL display connection
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:448): GStreamer-WARNING **: 12:52:33.865: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_evisplugin.so': libekinNvUtils.so: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:452): GStreamer-WARNING **: 12:52:34.166: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
No EGL Display
(gst-plugin-scanner:453): GStreamer-WARNING **: 12:52:34.192: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:492): GStreamer-WARNING **: 12:52:38.158: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
No EGL Display
(gst-plugin-scanner:493): GStreamer-WARNING **: 12:52:38.228: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
No EGL Display
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstXImageSink:ximagesink0: Could not initialise X output
Additional debug info:
ximagesink.c(860): gst_x_image_sink_xcontext_get (): /GstPipeline:pipeline0/GstXImageSink:ximagesink0:
Could not open display
Setting pipeline to NULL ...
Freeing pipeline ...
Do you have DISPLAY connected?
Try below.
xinit&
export DISPLAY=:0
gst-launch-1.0 ....
Yes I have display connected,
xinit&
[1] 30998
root@hsrev2-NX_TX2_BATI:/home/ekin/tx2_nx_imx568_imx565# export DISPLAY=:0
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 5.4.0-139-generic aarch64 Ubuntu
Current Operating System: Linux hsrev2-NX_TX2_BATI 4.9.253 #3 SMP PREEMPT Fri May 3 19:52:04 +05 2024 aarch64
Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0x96085000 lut_mem=0x2008@0x96081000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4
Build Date: 29 March 2023 03:17:58PM
xorg-server 2:1.19.6-1ubuntu4.15 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Mar 2 11:08:31 2023
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
root@hsrev2-NX_TX2_BATI:/home/ekin/tx2_nx_imx568_imx565# export DISPLAY=:0gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=0 silent=false ! 'video/x-raw(memory:NVMM), width=4128, height=3008, format=(string)NV12, framerate=(fraction)5/1' ! nvvidconv ! 'video/x-raw,width=640, height=480' ! nvvidconv ! clockoverlay shaded-background=true font-desc='Sans 38' ! ximagesink -e
bash: export: `sensor-id=0': not a valid identifier
bash: export: `sensor-mode=0': not a valid identifier
bash: export: `!': not a valid identifier
bash: export: `video/x-raw(memory:NVMM), width=4128, height=3008, format=(string)NV12, framerate=(fraction)5/1': not a valid identifier
bash: export: `video/x-raw,width=640, height=480': not a valid identifier
bash: export: `shaded-background=true': not a valid identifier
bash: export: `font-desc=Sans 38': not a valid identifier
bash: export: `-e': not a valid identifier
Seperate “export DISPLAY=:0” and gst-launch-1.0 to two command.
Yes, I write the commands separately but it still doesn’t work. I still can’t get an image.
What’s the log??
