Gst launch failing with ov5693 on jetson TX2 EVK
I am running gst launch to capture video on jetson tx2 EVK.
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1’ ! nvvidconv flip-method=2 ! fakesink silent=false -v
error i am getting:
nvbuf_utils: Could not get EGL display connection
nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR
nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: stream-start (10254), GstEventStreamSta0
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, f1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(strin1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV121
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: caps (12814), GstEventCaps, caps=(GstCa0
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)N1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV11
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(stri1
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras avaie
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: eos (28174), ) 0x558b2bb6d0
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.057999296
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvT)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, funct)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper()
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line )
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
Any help will be appreciated.
hello anupam.kumar,
may I know which JetPack release you’re working with.
could you please also confirm ov5693 sensor driver was probe, and device nodes were generated successfully.
thanks
I am using ov2735 sensor instead of ov5693 on tx2 EVk.
yes video node i am getting and also i am able to capture frames using v4l2-utils and yavta utils but gst-launch command is failing on tx2 evk.
can you help on this.
I am using latest SDK 32.4.3 on Tx2.
hello anupam.kumar,
please correct the discussion thread title to avoid confusion,
there’s error while you initial camera stream, please also gather kernel messages, i.e. $ dmesg for more details.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available
can you just confirm the gst-launch command i am using is fine or not i am missing something in command?
there’s documentation you may refer to, Approaches for Validating and Testing the V4L2 Driver.
i am following this guide. but still i am getting below error on tx2 EVK
how to resolve this.
hello anupam.kumar,
had you tried below configure EGL display?
i.e. export DISPLAY=:0
after exporting export DISPLAY=:0 this, i am getting following error.
command run :
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1’ ! nvoverlaysink -e
Execution ended after 0:00:00.026203814
Freeing pipeline …
root@linux:/home/ubuntu#
hello anupam.kumar,
you still got an error message that reports no cameras available, please examine your sensor driver and also device tree.
suggest you may validate sensor stream with v4l2 standard controls to check the camera functionality.
thanks
i checked with v4l2 commands,all are working fine.
so when i programmed the image of ov5693 using jetpack with latest release on Tx2 EVK,i am able to capture the video but when i am taking sdk 32.4.3 and compiling and programming to board to check ov5693,it is not working.
h264enc ! qtmux ! filesink location=test.mp4 -eramerate=30/1, format=NV12’ ! omxh
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
Execution ended after 0:00:00.033483952
Freeing pipeline …
root@linux:/home/ubuntu# ls -l
total 20
drwxr-xr-x 2 ubuntu ubuntu 4096 Oct 18 06:49 Desktop
-rw-r–r-- 1 ubuntu ubuntu 8980 Apr 16 2018 examples.desktop
-rw-r–r-- 1 root root 616 Oct 21 08:14 test.mp4
so ov5693 working fine with default jetpack image but same is failing when i compiled my own image and running on tx2 EVK,what could be the issue
any help will be appreciated.
hello anupam.kumar,
may I know what’s the modification you’d done for your customize image?
thanks
