I get an error when I use DeepStream-l4t
Hi guys:
I use the command “docker pull nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples” to run the Deepstream-sample container on nano, but the directory’/usr/src/tensorrt’ in the container is empty and I cannot Run the sample provided in Deepstream normally.
Any ideas?Thanks.
Hi, This looks like a deepstream issue. We recommend you to raise it to the respective forum.
