english is not my first language ,so i may get some wrong word or expression ,thankd for your time to read from me and try to help me
when i get this log, the process totaly stop :
21:56:32 ERROR : OpenCV on Target : OpenCV on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
logs are here,and that is all!
DETAILS TERMINAL
Component Name: All
Message Type: All
Filter text here…
22:06:22 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:22 INFO : TensorRT on Target : *begin sudo dpkg -i /opt/nvidia/deb_repos/python3-libnvinfer-dev_6.0.1-1+cuda10.0_arm64.deb, 5
22:06:22 INFO : TensorRT on Target : [target] [sudo] password for nvidia:
22:06:22 INFO : TensorRT on Target : Selecting previously unselected package python3-libnvinfer-dev.
22:06:23 INFO : TensorRT on Target : (Reading database … 128634 files and directories currently installed.)
22:06:23 INFO : TensorRT on Target : Preparing to unpack …/python3-libnvinfer-dev_6.0.1-1+cuda10.0_arm64.deb …
22:06:23 INFO : TensorRT on Target : Unpacking python3-libnvinfer-dev (6.0.1-1+cuda10.0) …
22:06:23 INFO : TensorRT on Target : Setting up python3-libnvinfer-dev (6.0.1-1+cuda10.0) …
22:06:28 INFO : TensorRT on Target : change working directory to /tmp
22:06:28 INFO : TensorRT on Target : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ python3-libnvinfer-dev”
22:06:28 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:29 INFO : TensorRT on Target : Target Deb package NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP python3-libnvinfer-dev_6.0.1-1+cuda10.0_arm64.deb installed successfully.
22:06:29 INFO : TensorRT on Target : [ Package Install Finished Successfully ]
22:06:29 INFO : TensorRT on Target : [ Package Install Started ]
22:06:29 INFO : TensorRT on Target : target deb installer start to install
22:06:29 INFO : TensorRT on Target : exec_command: dpkg -f /home/cds/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb Package | tr -d ‘\n’
22:06:29 INFO : TensorRT on Target : exec_command: dpkg -f /home/cds/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb Version | tr -d ‘\n’
22:06:29 INFO : TensorRT on Target : deb file /home/cds/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb, package name [graphsurgeon-tf], package version [6.0.1-1+cuda10.0]
22:06:29 INFO : TensorRT on Target : infer package info from file name graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb [ name: graphsurgeon-tf, version: 6.0.1-1+cuda10.0 ]
22:06:29 INFO : TensorRT on Target : exec_command [target]:
22:06:29 INFO : TensorRT on Target : **********************
22:06:29 INFO : TensorRT on Target : #!/bin/bash
22:06:29 INFO : TensorRT on Target : set -e
22:06:29 INFO : TensorRT on Target : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
22:06:29 INFO : TensorRT on Target : sudo mkdir -p /opt/nvidia/deb_repos
22:06:29 INFO : TensorRT on Target : sudo chmod 777 /opt/nvidia/deb_repos
22:06:29 INFO : TensorRT on Target : sudo rm -f /opt/nvidia/deb_repos/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb
22:06:29 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:30 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:30 INFO : TensorRT on Target : [target] [sudo] password for nvidia:
22:06:30 WARNING : TensorRT on Target : Warning: Permanently added ‘192.168.55.1’ (ECDSA) to the list of known hosts.
22:06:31 INFO : TensorRT on Target :
22:06:31 INFO : TensorRT on Target : graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb 0% 0 0.0KB/s --:-- ETA graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb 100% 16KB 2.6MB/s 00:00
22:06:31 INFO : TensorRT on Target : exec_command [target]:
22:06:31 INFO : TensorRT on Target : **********************
22:06:31 INFO : TensorRT on Target : #!/bin/bash
22:06:31 INFO : TensorRT on Target : set -e
22:06:31 INFO : TensorRT on Target : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
22:06:31 INFO : TensorRT on Target : function safe_apt_install {
22:06:31 INFO : TensorRT on Target : echo “*begin $1, $2”
22:06:31 INFO : TensorRT on Target : tmp_log=/tmp/jetpack_dpkg_log.txt
22:06:31 INFO : TensorRT on Target : sudo rm -f $tmp_log
22:06:31 INFO : TensorRT on Target : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
22:06:31 INFO : TensorRT on Target : while [ ${CMD_STATUS} -ne 0 ]; do
22:06:31 INFO : TensorRT on Target : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
22:06:31 INFO : TensorRT on Target : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
22:06:31 INFO : TensorRT on Target : else
22:06:31 INFO : TensorRT on Target : echo “Unhandled error when running $1”; exit 1
22:06:31 INFO : TensorRT on Target : fi
22:06:31 INFO : TensorRT on Target : done
22:06:31 INFO : TensorRT on Target : }
22:06:31 INFO : TensorRT on Target : safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb” 5
22:06:31 INFO : TensorRT on Target : sleep 5
22:06:31 INFO : TensorRT on Target : sudo rm -f /opt/nvidia/deb_repos/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb
22:06:31 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:32 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:32 INFO : TensorRT on Target : *begin sudo dpkg -i /opt/nvidia/deb_repos/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb, 5
22:06:32 INFO : TensorRT on Target : [target] [sudo] password for nvidia:
22:06:32 INFO : TensorRT on Target : Selecting previously unselected package graphsurgeon-tf.
22:06:32 INFO : TensorRT on Target : (Reading database … 128637 files and directories currently installed.)
22:06:33 INFO : TensorRT on Target : Preparing to unpack …/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb …
22:06:33 INFO : TensorRT on Target : Unpacking graphsurgeon-tf (6.0.1-1+cuda10.0) …
22:06:33 INFO : TensorRT on Target : Setting up graphsurgeon-tf (6.0.1-1+cuda10.0) …
22:06:38 INFO : TensorRT on Target : change working directory to /tmp
22:06:38 INFO : TensorRT on Target : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ graphsurgeon-tf”
22:06:38 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:39 INFO : TensorRT on Target : Target Deb package NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb installed successfully.
22:06:39 INFO : TensorRT on Target : [ Package Install Finished Successfully ]
22:06:39 INFO : TensorRT on Target : [ Package Install Started ]
22:06:39 INFO : TensorRT on Target : target deb installer start to install
22:06:39 INFO : TensorRT on Target : exec_command: dpkg -f /home/cds/Downloads/nvidia/sdkm_downloads/uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb Package | tr -d ‘\n’
22:06:39 INFO : TensorRT on Target : exec_command: dpkg -f /home/cds/Downloads/nvidia/sdkm_downloads/uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb Version | tr -d ‘\n’
22:06:39 INFO : TensorRT on Target : deb file /home/cds/Downloads/nvidia/sdkm_downloads/uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb, package name [uff-converter-tf], package version [6.0.1-1+cuda10.0]
22:06:39 INFO : TensorRT on Target : infer package info from file name uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb [ name: uff-converter-tf, version: 6.0.1-1+cuda10.0 ]
22:06:39 INFO : TensorRT on Target : exec_command [target]:
22:06:39 INFO : TensorRT on Target : **********************
22:06:39 INFO : TensorRT on Target : #!/bin/bash
22:06:39 INFO : TensorRT on Target : set -e
22:06:39 INFO : TensorRT on Target : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
22:06:39 INFO : TensorRT on Target : sudo mkdir -p /opt/nvidia/deb_repos
22:06:39 INFO : TensorRT on Target : sudo chmod 777 /opt/nvidia/deb_repos
22:06:39 INFO : TensorRT on Target : sudo rm -f /opt/nvidia/deb_repos/uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb
22:06:39 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:40 INFO : TensorRT on Target :
22:06:40 INFO : TensorRT on Target : [target] [sudo] password for nvidia:
22:06:40 WARNING : TensorRT on Target : Warning: Permanently added ‘192.168.55.1’ (ECDSA) to the list of known hosts.
22:06:40 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:40 INFO : TensorRT on Target : uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb 0% 0 0.0KB/s --:-- ETA uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb 100% 37KB 6.2MB/s 00:00
22:06:40 INFO : TensorRT on Target : exec_command [target]:
22:06:40 INFO : TensorRT on Target : **********************
22:06:40 INFO : TensorRT on Target : #!/bin/bash
22:06:40 INFO : TensorRT on Target : set -e
22:06:40 INFO : TensorRT on Target : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
22:06:40 INFO : TensorRT on Target : function safe_apt_install {
22:06:40 INFO : TensorRT on Target : echo “*begin $1, $2”
22:06:40 INFO : TensorRT on Target : tmp_log=/tmp/jetpack_dpkg_log.txt
22:06:40 INFO : TensorRT on Target : sudo rm -f $tmp_log
22:06:40 INFO : TensorRT on Target : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
22:06:40 INFO : TensorRT on Target : while [ ${CMD_STATUS} -ne 0 ]; do
22:06:40 INFO : TensorRT on Target : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
22:06:40 INFO : TensorRT on Target : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
22:06:40 INFO : TensorRT on Target : else
22:06:40 INFO : TensorRT on Target : echo “Unhandled error when running $1”; exit 1
22:06:40 INFO : TensorRT on Target : fi
22:06:40 INFO : TensorRT on Target : done
22:06:40 INFO : TensorRT on Target : }
22:06:40 INFO : TensorRT on Target : safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb” 5
22:06:40 INFO : TensorRT on Target : sleep 5
22:06:40 INFO : TensorRT on Target : sudo rm -f /opt/nvidia/deb_repos/uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb
22:06:41 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:41 INFO : TensorRT on Target : *begin sudo dpkg -i /opt/nvidia/deb_repos/uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb, 5
22:06:41 INFO : TensorRT on Target : [target] [sudo] password for nvidia:
22:06:42 INFO : TensorRT on Target :
22:06:42 INFO : TensorRT on Target : Selecting previously unselected package uff-converter-tf.
22:06:42 INFO : TensorRT on Target : (Reading database … 128670 files and directories currently installed.)
22:06:42 INFO : TensorRT on Target : Preparing to unpack …/uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb …
22:06:42 INFO : TensorRT on Target : Unpacking uff-converter-tf (6.0.1-1+cuda10.0) …
22:06:42 INFO : TensorRT on Target : Setting up uff-converter-tf (6.0.1-1+cuda10.0) …
22:06:47 INFO : TensorRT on Target : change working directory to /tmp
22:06:47 INFO : TensorRT on Target : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ uff-converter-tf”
22:06:47 INFO : TensorRT on Target : [target] nvidia@192.168.55.1’s password:
22:06:48 INFO : TensorRT on Target : Target Deb package NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP uff-converter-tf_6.0.1-1+cuda10.0_arm64.deb installed successfully.
22:06:48 INFO : TensorRT on Target : [ Package Install Finished Successfully ]
22:06:48 INFO : TensorRT on Target : [ 8.94 MB used. Disk Avail: 40.88 GB ]
22:06:48 INFO : TensorRT on Target : [ NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP Install took 4m18s ]
22:06:48 INFO : TensorRT on Target : command finished successfully
22:06:48 INFO : TensorRT on Target : install ‘TensorRT on Target’ success
22:06:48 INFO : OpenCV on Target : Start to install ‘OpenCV on Target’
22:06:49 DEBUG : OpenCV on Target : running command < cd ‘/home/cds/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP’ -v=‘4.1.1’ -l=‘/home/cds/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310’ -L=‘/home/cds/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘3343’ -t=‘P3310’ -e=‘/home/cds/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb’ >
22:06:49 INFO : OpenCV on Target : [ Disk Avail:40.88 GB ]
22:06:49 INFO : OpenCV on Target : Using GenericInstaller to Install NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP
22:06:49 INFO : OpenCV on Target : NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP include 5 package
22:06:49 INFO : OpenCV on Target : [ Package PreInstall Started ]
22:06:49 INFO : OpenCV on Target : current working directory is /home/cds/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310
22:06:49 INFO : OpenCV on Target : exec_command [target]:
22:06:49 INFO : OpenCV on Target : **********************
22:06:49 INFO : OpenCV on Target : #!/bin/bash
22:06:49 INFO : OpenCV on Target : set -e
22:06:49 INFO : OpenCV on Target : function safe_apt_install {
22:06:49 INFO : OpenCV on Target : echo “*begin $1, $2”
22:06:49 INFO : OpenCV on Target : tmp_log=/tmp/jetpack_dpkg_log.txt
22:06:49 INFO : OpenCV on Target : sudo rm -f $tmp_log
22:06:49 INFO : OpenCV on Target : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
22:06:49 INFO : OpenCV on Target : while [ ${CMD_STATUS} -ne 0 ]; do
22:06:49 INFO : OpenCV on Target : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
22:06:49 INFO : OpenCV on Target : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
22:06:49 INFO : OpenCV on Target : else
22:06:49 INFO : OpenCV on Target : echo “Unhandled error when running $1”; exit 1
22:06:49 INFO : OpenCV on Target : fi
22:06:49 INFO : OpenCV on Target : done
22:06:49 INFO : OpenCV on Target : }
22:06:49 INFO : OpenCV on Target : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
22:06:49 INFO : OpenCV on Target : safe_apt_install “sudo apt-get update” 5
22:06:49 INFO : OpenCV on Target : safe_apt_install “sudo apt-get install -y libtbb2 libtbb-dev” 5
22:06:49 INFO : OpenCV on Target : safe_apt_install “sudo apt-get install -y python-dev python-numpy python-py python-pytest” 5
22:06:49 INFO : OpenCV on Target : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh”
22:06:49 INFO : OpenCV on Target : [target] nvidia@192.168.55.1’s password:
22:06:50 INFO : OpenCV on Target :
22:06:50 INFO : OpenCV on Target : [target] nvidia@192.168.55.1’s password:
22:06:50 INFO : OpenCV on Target : *begin sudo apt-get update, 5
22:06:50 INFO : OpenCV on Target : [target] [sudo] password for nvidia:
22:06:50 INFO : OpenCV on Target : Get:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
22:06:51 INFO : OpenCV on Target : Ign:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
22:06:51 INFO : OpenCV on Target : Get:2 file:/var/cuda-repo-10-0-local-10.0.326 Release [574 B]
22:06:54 INFO : OpenCV on Target : Hit:4 Index of /ubuntu-ports bionic InRelease
22:06:58 INFO : OpenCV on Target : Hit:7 Index of /ubuntu-ports bionic-updates InRelease
22:06:58 INFO : OpenCV on Target : Hit:8 Index of /ubuntu-ports bionic-backports InRelease
22:06:59 INFO : OpenCV on Target : Hit:9 Index of /ubuntu-ports bionic-security InRelease
22:06:59 INFO : OpenCV on Target : Hit:5 https://repo.download.nvidia.cn/jetson/common r32 InRelease
22:06:59 INFO : OpenCV on Target : Hit:6 https://repo.download.nvidia.cn/jetson/t186 r32 InRelease
22:07:04 INFO : OpenCV on Target : Reading package lists…
22:07:05 INFO : OpenCV on Target : *begin sudo apt-get install -y libtbb2 libtbb-dev, 5
22:07:05 INFO : OpenCV on Target : Reading package lists…
22:07:05 INFO : OpenCV on Target : Building dependency tree…
22:07:05 INFO : OpenCV on Target : Reading state information…
22:07:06 INFO : OpenCV on Target : The following packages were automatically installed and are no longer required:
22:07:06 INFO : OpenCV on Target : apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
22:07:06 INFO : OpenCV on Target : dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
22:07:06 INFO : OpenCV on Target : kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common
22:07:06 INFO : OpenCV on Target : kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5
22:07:06 INFO : OpenCV on Target : libkdecorations2private5v5 libkf5activities5 libkf5attica5
22:07:06 INFO : OpenCV on Target : libkf5completion-data libkf5completion5 libkf5declarative-data
22:07:06 INFO : OpenCV on Target : libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5
22:07:06 INFO : OpenCV on Target : libkf5globalaccelprivate5 libkf5idletime5 libkf5jobwidgets-data
22:07:06 INFO : OpenCV on Target : libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5
22:07:06 INFO : OpenCV on Target : libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5
22:07:06 INFO : OpenCV on Target : libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5
22:07:06 INFO : OpenCV on Target : libkf5quickaddons5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data
22:07:06 INFO : OpenCV on Target : libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
22:07:06 INFO : OpenCV on Target : libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data
22:07:06 INFO : OpenCV on Target : libkf5xmlgui5 libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
22:07:06 INFO : OpenCV on Target : libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
22:07:06 INFO : OpenCV on Target : libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
22:07:06 INFO : OpenCV on Target : libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
22:07:06 INFO : OpenCV on Target : libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5
22:07:06 INFO : OpenCV on Target : libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5test5 libqt5webchannel5
22:07:06 INFO : OpenCV on Target : libqt5webkit5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober
22:07:06 INFO : OpenCV on Target : python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
22:07:06 INFO : OpenCV on Target : python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
22:07:06 INFO : OpenCV on Target : qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
22:07:06 INFO : OpenCV on Target : qml-module-qtquick2 rdate tasksel tasksel-data
22:07:06 INFO : OpenCV on Target : Use ‘sudo apt autoremove’ to remove them.
22:07:06 INFO : OpenCV on Target : Suggested packages:
22:07:06 INFO : OpenCV on Target : tbb-examples libtbb-doc
22:07:06 INFO : OpenCV on Target : The following NEW packages will be installed:
22:07:06 INFO : OpenCV on Target : libtbb-dev libtbb2
22:07:07 INFO : OpenCV on Target : 0 upgraded, 2 newly installed, 0 to remove and 230 not upgraded.
22:07:07 INFO : OpenCV on Target : 1 not fully installed or removed.
22:07:07 INFO : OpenCV on Target : Need to get 319 kB of archives.
22:07:07 INFO : OpenCV on Target : After this operation, 1,924 kB of additional disk space will be used.
22:07:07 INFO : OpenCV on Target : Get:1 Index of /ubuntu-ports bionic/universe arm64 libtbb2 arm64 2017~U7-8 [87.8 kB]
22:07:12 INFO : OpenCV on Target : Get:2 Index of /ubuntu-ports bionic/universe arm64 libtbb-dev arm64 2017~U7-8 [231 kB]
22:07:24 INFO : OpenCV on Target : debconf: delaying package configuration, since apt-utils is not installed
22:07:24 INFO : OpenCV on Target : Fetched 319 kB in 17s (18.5 kB/s)
22:07:24 INFO : OpenCV on Target : Selecting previously unselected package libtbb2:arm64.
22:07:24 INFO : OpenCV on Target : (Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 128777 files and directories currently installed.)
22:07:24 INFO : OpenCV on Target : Preparing to unpack …/libtbb2_2017~U7-8_arm64.deb …
22:07:24 INFO : OpenCV on Target : Unpacking libtbb2:arm64 (2017~U7-8) …
22:07:25 INFO : OpenCV on Target : Selecting previously unselected package libtbb-dev:arm64.
22:07:25 INFO : OpenCV on Target : Preparing to unpack …/libtbb-dev_2017~U7-8_arm64.deb …
22:07:25 INFO : OpenCV on Target : Unpacking libtbb-dev:arm64 (2017~U7-8) …
22:07:25 INFO : OpenCV on Target : Setting up libtbb2:arm64 (2017~U7-8) …
22:07:25 INFO : OpenCV on Target : Setting up nvidia-container-csv-cudnn (7.6.3.28-1+cuda10.0) …
22:07:25 INFO : OpenCV on Target : Setting up libtbb-dev:arm64 (2017~U7-8) …
22:07:25 INFO : OpenCV on Target : Processing triggers for libc-bin (2.27-3ubuntu1) …
22:07:28 INFO : OpenCV on Target : *begin sudo apt-get install -y python-dev python-numpy python-py python-pytest, 5
22:07:29 INFO : OpenCV on Target : Reading package lists…
22:07:29 INFO : OpenCV on Target : Building dependency tree…
22:07:29 INFO : OpenCV on Target : Reading state information…
22:07:30 INFO : OpenCV on Target : The following packages were automatically installed and are no longer required:
22:07:30 INFO : OpenCV on Target : apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
22:07:30 INFO : OpenCV on Target : dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
22:07:30 INFO : OpenCV on Target : kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common
22:07:30 INFO : OpenCV on Target : kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5
22:07:30 INFO : OpenCV on Target : libkdecorations2private5v5 libkf5activities5 libkf5attica5
22:07:30 INFO : OpenCV on Target : libkf5completion-data libkf5completion5 libkf5declarative-data
22:07:30 INFO : OpenCV on Target : libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5
22:07:30 INFO : OpenCV on Target : libkf5globalaccelprivate5 libkf5idletime5 libkf5jobwidgets-data
22:07:30 INFO : OpenCV on Target : libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5
22:07:30 INFO : OpenCV on Target : libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5
22:07:30 INFO : OpenCV on Target : libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5
22:07:30 INFO : OpenCV on Target : libkf5quickaddons5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data
22:07:30 INFO : OpenCV on Target : libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
22:07:30 INFO : OpenCV on Target : libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data
22:07:30 INFO : OpenCV on Target : libkf5xmlgui5 libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
22:07:30 INFO : OpenCV on Target : libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
22:07:30 INFO : OpenCV on Target : libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
22:07:30 INFO : OpenCV on Target : libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
22:07:30 INFO : OpenCV on Target : libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5
22:07:30 INFO : OpenCV on Target : libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5test5 libqt5webchannel5
22:07:30 INFO : OpenCV on Target : libqt5webkit5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober
22:07:30 INFO : OpenCV on Target : python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
22:07:30 INFO : OpenCV on Target : python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
22:07:30 INFO : OpenCV on Target : qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
22:07:30 INFO : OpenCV on Target : qml-module-qtquick2 rdate tasksel tasksel-data
22:07:30 INFO : OpenCV on Target : Use ‘sudo apt autoremove’ to remove them.
22:07:30 INFO : OpenCV on Target : The following additional packages will be installed:
22:07:30 INFO : OpenCV on Target : libblas3 libexpat1 libexpat1-dev libgfortran4 liblapack3 libpython-dev
22:07:30 INFO : OpenCV on Target : libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib
22:07:30 INFO : OpenCV on Target : python-attr python-funcsigs python-pkg-resources python-pluggy python-six
22:07:30 INFO : OpenCV on Target : python2.7 python2.7-dev python2.7-minimal
22:07:30 INFO : OpenCV on Target : Suggested packages:
22:07:30 INFO : OpenCV on Target : python-attr-doc python-funcsigs-doc gfortran python-nose python-numpy-dbg
22:07:30 INFO : OpenCV on Target : python-numpy-doc python-setuptools subversion python-pytest-xdist
22:07:30 INFO : OpenCV on Target : python-mock python2.7-doc binfmt-support
22:07:30 INFO : OpenCV on Target : The following NEW packages will be installed:
22:07:30 INFO : OpenCV on Target : libblas3 libexpat1-dev libgfortran4 liblapack3 libpython-dev
22:07:30 INFO : OpenCV on Target : libpython2.7-dev python-attr python-dev python-funcsigs python-numpy
22:07:30 INFO : OpenCV on Target : python-pkg-resources python-pluggy python-py python-pytest python-six
22:07:30 INFO : OpenCV on Target : python2.7-dev
22:07:30 INFO : OpenCV on Target : The following packages will be upgraded:
22:07:30 INFO : OpenCV on Target : libexpat1 libpython2.7 libpython2.7-minimal libpython2.7-stdlib python2.7
22:07:30 INFO : OpenCV on Target : python2.7-minimal
22:07:30 INFO : OpenCV on Target : 6 upgraded, 16 newly installed, 0 to remove and 224 not upgraded.
22:07:30 INFO : OpenCV on Target : Need to get 36.8 MB of archives.
22:07:30 INFO : OpenCV on Target : After this operation, 59.8 MB of additional disk space will be used.
22:07:30 INFO : OpenCV on Target : Get:1 Index of /ubuntu-ports bionic-updates/main arm64 python2.7 arm64 2.7.17-1~18.04 [248 kB]
22:07:50 INFO : OpenCV on Target : Get:2 Index of /ubuntu-ports bionic-updates/main arm64 libpython2.7 arm64 2.7.17-1~18.04 [905 kB]
22:08:25 INFO : OpenCV on Target : Get:3 Index of /ubuntu-ports bionic-updates/main arm64 libexpat1 arm64 2.2.5-3ubuntu0.2 [69.3 kB]
22:08:28 INFO : OpenCV on Target : Get:4 Index of /ubuntu-ports bionic-updates/main arm64 libpython2.7-stdlib arm64 2.7.17-1~18.04 [1,855 kB]
22:09:31 INFO : OpenCV on Target : Get:5 Index of /ubuntu-ports bionic-updates/main arm64 python2.7-minimal arm64 2.7.17-1~18.04 [1,141 kB]
22:10:19 INFO : OpenCV on Target : Get:6 Index of /ubuntu-ports bionic-updates/main arm64 libpython2.7-minimal arm64 2.7.17-1~18.04 [335 kB]
22:10:30 INFO : OpenCV on Target : Get:7 Index of /ubuntu-ports bionic/main arm64 libblas3 arm64 3.7.1-4ubuntu1 [83.1 kB]
22:10:33 INFO : OpenCV on Target : Get:8 Index of /ubuntu-ports bionic-updates/main arm64 libexpat1-dev arm64 2.2.5-3ubuntu0.2 [110 kB]
22:10:37 INFO : OpenCV on Target : Get:9 Index of /ubuntu-ports bionic-updates/main arm64 libgfortran4 arm64 7.4.0-1ubuntu1~18.04.1 [249 kB]
22:10:45 INFO : OpenCV on Target : Get:10 Index of /ubuntu-ports bionic/main arm64 liblapack3 arm64 3.7.1-4ubuntu1 [1,371 kB]
22:11:39 INFO : OpenCV on Target : Get:11 Index of /ubuntu-ports bionic-updates/main arm64 libpython2.7-dev arm64 2.7.17-1~18.04 [28.0 MB]
